North East Buses Local Bus Scene Other Operators Northumberland Independents PCL Travel
PCL Travel
PCL Travel
  • 1 Vote(s) - 4 Average
Pages (43): Previous 130 31 3243 Next
1395
15 Aug 2018, 10:26 pm
(15 Aug 2018, 10:18 pm)mb134 "Arriva prove themselves unreliable" - I wonder if you've given much thought to why the Alnwick services aren't always bang on time, or how often you use them and understand why? The A1 north of Morpeth is a single carriageway for much of the X15 route, and is frequently at a standstill. Morpeth traffic is also ridiculously unpredictable, and can be awful at various points of the day. Also "unreliable" - yes they're usually 5-10 minutes late, but in all the time I've used them, they've never failed to turn up.
The N1 - I don't understand how that route would be any more reliable than the X15. The issue with the X15 is, mainly, the A1 between Morpeth and Alnwick, and Morpeth itself. There also isn't an awful lot of demand for a really slow route to the Airport. Most people will get a taxi, or an express to Regent Centre and catch a Metro.
It's well worth a try at New Ideas, people said the X10 into Dalton Park would be a bad move, it turns out it's boosted passenger numbers...
And I think you will find most delays are caused by passengers at the bus stations mainly purchasing various tickets. I've been on the X15 quite a few times and even when it departs Newcastle late it makes up the time on route.
S830OFT
15 Aug 2018, 10:26 pm #601
4177
15 Aug 2018, 11:16 pm
(15 Aug 2018, 10:26 pm)S830OFT It's well worth a try at New Ideas, people said the X10 into Dalton Park would be a bad move, it turns out it's boosted passenger numbers...
However the X10 was building on an already solid route. Your proposal would be in competition with an established service, and ran by a company with a bad reputation.
The X15 generally does make up time out of Newcastle, as the time allocated for it to cover the A1 stretch to Morpeth is usually more than required. There is time allowed at each bus station for passengers to buy tickets, as is the same with any bus route. The X15 has 7 minutes at Haymarket, 5 at Morpeth and 6 at Alnwick (10 if it doesn't extend to Berwick). A big issue with the X15 is that the A1 has no overtaking lane from Morpeth until just after the Felton turn off, where it duals until after Alnwick. Traffic on this section of road is horrific at the best of times, often slowed to 5-10 mph for no reason. You also then need to contend with the traffic in Morpeth, Alnwick and Gosforth.
Arriva could, of course, whack a load of extra running time into each journey to combat this traffic. However, what happens when the traffic is less than expected, or is only bad in one place? They'd have a load of early running buses doing dangerously low speeds on the A1, carrying fresh air because the advertised journey time was excessive.
mb134
15 Aug 2018, 11:16 pm #602
10979
15 Aug 2018, 11:44 pm
Not quoting multiple posts, so this applies to all of the three above posts.
I agree with all this (above quoted post), X15 etc has more often than not been close to time most of the times I've used it but of course there is some instances where this isn't the case for whatever reasons. Will additionally add that his route suggestion to Newcastle is similar to the old 44 that carried very few passengers between Morpeth and Dinnington. Would also dread to think how much it would cost to run one of those Versa's to Newcastle and back and how would the 470/473 run if one of the buses for the service is heading to/from Newcastle?
With regards to promotion of their services, considering they set up a Facebook page and suddenly deleted it says it all... So good luck at any sense of promotion.
Just been on PCLs website and the M1 timetable which is a Nexus one has been cut and edited and now indicates that there is now only an M1 Monday to Fridays departing Morpeth for Thropton at 10am, all other journeys have seemingly being dropped all of a sudden including the diverted Wednesday service and Sunday service to the Metrocentre, however I see no changes registered on VOSA since November 2017 and the Sunday M1 registration is still 'registered' which sounds fishy but let us not forget the 79 to Kingston Park or wherever it went and seemingly morphed into a circular around the Morpeth area but timetables didn't reflect that change. All other timetable sources still indicate the timetable is as it was from November 2017.
Jimmi
15 Aug 2018, 11:44 pm #603
1395
16 Aug 2018, 11:34 am
(15 Aug 2018, 11:44 pm)Jimmi Not quoting multiple posts, so this applies to all of the three above posts.
Maybe if PCL did what Glen Valley did, which was run the 473 to Wooler but return to Alnwick as the 470. Also interwork with the 15 if they changed the timetable...
S830OFT
16 Aug 2018, 11:34 am #604
474
16 Aug 2018, 12:37 pm
I was under the impression that the Wednesday service to the Upper Wansbeck Valley was subsidised by Northumberland County Council. I'm therefore quite surprised it's been just dropped altogether.
Charles
Charles41
16 Aug 2018, 12:37 pm #605
Charles
16 Aug 2018, 10:55 pm
(15 Aug 2018, 10:01 pm)S830OFT Suggestion:
Route N1 'The Northern Direct'
Alnwick - Willowburn - Shilbottle - A1 - Morpeth - Stannington - Dinnington - Newcastle Airport - Newcastle St. Thomas Street - Central Station.
This service will replace service S1/S2 in Stannington, it will reinstate the link to Newcastle, it will allow links to Train and Flight Connections by serving Newcastle Airport and Central Station. Also will allow more choice for passengers, in particular Alnwick to Morpeth as the current X15 is always delayed for various reasons.
No demand for running services to Newcastle Airport. Just look at the existing services which run there, nobody uses them as they'd rather get the Metro or drive as it's more convenient.
And there is really no point running in competition with Arriva, that service won't be self-sustainable, and will rely on Council subsidies from other services to prop it up.
omnicity4659
16 Aug 2018, 10:55 pm #606
14273
17 Aug 2018, 7:33 am
I've wonder if we just need a shift in mindset, both from a passenger perspective and an operational one.
Logistically it will be a pain from both sides.
Do services tie in with flight departures and arrivals? Are there options available should there be delays to flights?
If the answers are no to those questions, then it is little wonder bus services have never taken off (pardon the pun) - regardless of any other mitigating factors that there may be.
Andreos1
17 Aug 2018, 7:33 am #607
Tom
6138
17 Aug 2018, 6:08 pm
(15 Aug 2018, 9:01 pm)James101 PSVAR/DDA doesn’t apply to vehicles with less than 22 passenger capacity.
I’m torn on opinion on PCL. Clearly their vehicles and presentation standards are not ideal but neither is the owner on a yacht in the Maldives whilst the pensioners of Croquetdale suffer. PCL are a marginal operator working scraps of services not profitable enough for Arriva to bother. Certainly, the output of Spirit Buses was much better, but clearly unsustainable. The issue here, I feel, is government policy on supported services more generally.
What is unacceptable, however, is dropping journies randomly on such infrequent routes. Again, much of the blame lies with PCL here, but maybe if they, or others, were paid a fair amount for the carriage of passengers it would be a better story?
I think PCL get £51,000 a year for the 15/16 (I remembered that being quoted somewhere). So say they operate it 300 days a year at an estimate, that's like £170 a day. I don't know how that compares to other secured routes, but it doesn't seem much at all.
Tom
17 Aug 2018, 6:08 pm #608
998
17 Aug 2018, 6:31 pm
Does PCL still do the bus on a Sunday from Newcastle St Thomas Street to Whitehouse Farm at Morpeth?
if so, is it reliable as its only couple of journeys each way, and does anyone have an idea of fares. Thanks
LVK 404L
17 Aug 2018, 6:31 pm #609
10979
17 Aug 2018, 7:02 pm
(17 Aug 2018, 6:31 pm)ifm001 Does PCL still do the bus on a Sunday from Newcastle St Thomas Street to Whitehouse Farm at Morpeth?
According to the M1 timetable on PCLs website, no, the timetable on their site is now showing that there is only a departure from Morpeth at 10am up to Thropton on weekdays only. Other outlets are suggesting that the Sunday service plus some other departures still run but the reality seems to be that only the weekday morning run operates now.
I really wouldn't risk catching it, as you're likely to end up wasting your time.
Jimmi
17 Aug 2018, 7:02 pm #610
652
17 Aug 2018, 7:06 pm
(17 Aug 2018, 6:08 pm)Tom I think PCL get £51,000 a year for the 15/16 (I remembered that being quoted somewhere). So say they operate it 300 days a year at an estimate, that's like £170 a day. I don't know how that compares to other secured routes, but it doesn't seem much at all.
So say they receive £170 per day. If they used a small conventional bus and 15MPG from it, that would be around £50 in fuel alone. Plus say £90 on 10 hours labour for the driver? £30 to cover overheads of running a bus, I doubt that would even come close to covering a lease on something like the E200 Spirit were using. Is it any wonder the service is in the state it's in?
James101
17 Aug 2018, 7:06 pm #611
1395
17 Aug 2018, 7:14 pm
(17 Aug 2018, 7:02 pm)Jimmi According to the M1 timetable on PCLs website, no, the timetable on their site is now showing that there is only a departure from Morpeth at 10am up to Thropton on weekdays only. Other outlets are suggesting that the Sunday service plus some other departures still run but the reality seems to be that only the weekday morning run operates now.
It would be best ringing PCL up and asking...
S830OFT
17 Aug 2018, 7:14 pm #612
Tom
6138
17 Aug 2018, 7:32 pm
(17 Aug 2018, 7:06 pm)James101 So say they receive £170 per day. If they used a small conventional bus and 15MPG from it, that would be around £50 in fuel alone. Plus say £90 on 10 hours labour for the driver? £30 to cover overheads of running a bus, I doubt that would even come close to covering a lease on something like the E200 Spirit were using. Is it any wonder the service is in the state it's in?
Yeah exactly, I guess not much else can really be expected that the standard of service that it is.
Tom
17 Aug 2018, 7:32 pm #613
5327
17 Aug 2018, 7:46 pm
£50 in fuel? Maybe if you're using a minibus on it but that MPD they've got on it now will be using more in the region of £80-90 a day. Added to the wages of say £90 a day that eats up all of your subsidy and that's before adding other costs on top. It needs a lot of revenue to make it worthwhile and I dare say in the winter season it's a complete waste of time.
tyresmoke
17 Aug 2018, 7:46 pm #614
1395
17 Aug 2018, 7:55 pm
(17 Aug 2018, 7:32 pm)Tom Yeah exactly, I guess not much else can really be expected that the standard of service that it is.
If I was a regular passenger on service 15 I would expect the allocated vehicle to be Easy Accessible, the LDV Convoy and Sunshine bus are not accessible...
I was reading on here that somebody with a pram couldn't board the bus because it was a minibus... To be honest when they posted the council's response it was way past what I thought they would have said to the situation.
Definitely something going on with Northumberland County Council, they are not alike Nexus. Nexus give contracts first and foremost based on quality, I think NCC give contracts based on the lowest bid.
Also don't want to raise more concerns, however it is worth pointing out that when the Otterburn Parish Council reported PCL to the Traffic Commissioner PCL pulled out from operating the 808. And in a newspaper article they pointed out that there was holes in the door allowing draft in, to which they claim PCL patched up with a towel... Not sure how true those allegations were but it sounds extremely serious.
One thing all companies should remember, big or small is that the customer is King. Making their experience as pleasurable as possible will go a long way...
S830OFT
17 Aug 2018, 7:55 pm #615
10979
17 Aug 2018, 8:31 pm
They were supposedly on a subsidy of £75 a day for service 808 which consisted of one journey a day in each direction from Otterburn to Newcastle typically using a van interworking with some of their other supported runs on some days such as the 882 between Colwell and Hexham on Saturdays, this seemingly wasn't enough for them to continue operating the service, so they dropped the contract and it got put out for tender again with Phoenix now running it. If they are on about £170 a day for the 15/16, I fear there is little in the way of profit being made on the service.
Don't know where the bus is parked at the start/end of the day but the bus should actively be out on the road in motion for a minimum of 6 and a half hours a day, add nearly 2 hours on Tues, Thurs & Saturdays when the 16 runs. Think their drivers are on about £8 an hour, don't know how the rate of pay applies to the few breaks the service has over the course of the day.
I'd say that the service can typically carry somewhere in the region of 16 passengers on some journeys, some journeys may carry more and some will carry less.
Jimmi
17 Aug 2018, 8:31 pm #616
1395
17 Aug 2018, 11:08 pm
(17 Aug 2018, 8:31 pm)Jimmi They were supposedly on a subsidy of £75 a day for service 808 which consisted of one journey a day in each direction from Otterburn to Newcastle typically using a van interworking with some of their other supported runs on some days such as the 882 between Colwell and Hexham on Saturdays, this seemingly wasn't enough for them to continue operating the service, so they dropped the contract and it got put out for tender again with Phoenix now running it. If they are on about £170 a day for the 15/16, I fear there is little in the way of profit being made on the service.
Think the bus for the 15 now parks in Wooler Depot with the 2 versas...
S830OFT
17 Aug 2018, 11:08 pm #617
474
18 Aug 2018, 8:14 am
(17 Aug 2018, 11:08 pm)S830OFT Think the bus for the 15 now parks in Wooler Depot with the 2 versas...
They park on the Lionheart Industrial Estate near to the entrance to the Aln Valley Railway.
Charles
Charles41
18 Aug 2018, 8:14 am #618
Charles
18 Aug 2018, 8:25 pm
(18 Aug 2018, 8:14 am)Charles41 They park on the Lionheart Industrial Estate near to the entrance to the Aln Valley Railway.
Charles
Sometimes, a driver who lives just outside Alnwick will often have whatever vehicle he’s using outside his house in an adjacent lay-by too.
Check out my Flickr - www.flickr.com/cobalt512
Cobalt271
18 Aug 2018, 8:25 pm #619
Charles
474
19 Aug 2018, 2:00 pm
(18 Aug 2018, 8:25 pm)Cobalt271 Sometimes, a driver who lives just outside Alnwick will often have whatever vehicle he’s using outside his house in an adjacent lay-by too.
Parked at Lionheart today were:
KX06LYJ Solo
KX06LYS Dart
GN06UEK Iveco
I haven't seen the two Volkswagen LT minibuses in a while. Does anyone know if they are still in the fleet?
Charles
Charles41
19 Aug 2018, 2:00 pm #620
KX06LYJ Solo
KX06LYS Dart
GN06UEK Iveco
Charles
