Arriva North East: Latest News & Discussion - February 2018
1604 is out on driver familiarisation today
(30 Jan 2018, 6:26 pm)Kuyoyo The two in Faverdale yard are now branded. They are 1604/5 but as yet, only 1604 has its plates uncovered - it’s NK67EDL.
(01 Feb 2018, 2:39 pm)JoshP What's going to happen with the 12 and the 19?
(01 Feb 2018, 12:43 pm)Stuartphin1639 1604 is out on driver familiarisation todayArriva North East: 1604 / NK67EDL by Matthew Jimmison, on Flickr
1506 now has new next stop announcements for 1/5/5A for the upgraded sapphire service
(01 Feb 2018, 2:57 pm)omnicity4659 Split off onto separate RTCs if I recall correctly?
(01 Feb 2018, 3:21 pm)Kuyoyo Remaining interworking with the 1/5/5a as now
They bought the wrong length of StreetLite... best rumour I've heard this year
(01 Feb 2018, 4:39 pm)Jimmi The rumour at one point was the 12/19 was to come off 5 boards and interwork with each other using Solo's with three StreetLite's being instead deployed onto the 8/8A (obviously not happening now).
(01 Feb 2018, 5:29 pm)peter I'm quite surprised that this hasn't happened. I was fully expecting Arriva to reduce the 19 to hourly and stick it onto the short 12s as the 12a so that they could discontinue the interworking with the 1/5/5a but keep the PVR the same. That way Darlington would have required 3 less Pulsars and could have gained 3 Optare Solo's from elsewhere in return.
(For those interested if the 1/5/5a interworked the PVR would be 10 while the 12 and the 19's departing at :46 from Darlington would interwork with a PVR of 3 with the other 19 being 1 bus standalone with a 15 minute layover.)
(01 Feb 2018, 6:13 pm)RobinHood That option you outline would require one more bus to do than it does now, which is probably why they haven't done it.
Apparently only 9 of the 13 buses will be branded for Service 1 and 5, so read into that what you will.
The next change date for Darlington is May, so we could see changes then.
New Wrightbus: Arriva North East Wright Streetlite Max Micro Hybrid (NK67EDO/6305, (NK67EDP/1606), (NK67EDL/1604) by Exploring North East Buses, on Flickr
Arriva North East Darlington Depot Sapphire 1/5/5A Branded Streetlite 1604 (NK67 EDL) seen here in-between driver familiarisation Duties by stuart phin, on Flickr
(01 Feb 2018, 9:27 pm)Malarkey When are the new Streetlites expected to enter service?
(01 Feb 2018, 6:17 pm)peter Agreed. Hence why I mentioned that I believe if this were to take place the 19 would be reduced to hourly to remove the standalone board and keep the PVR the same. You never know what May might bring!The reason that arriva took the 19 from scarlet band was to replace the 1/2 hourly staff shuttle to save money so hourly would cause problems
Just overtook former Arriva North East Optare Tempo 1309 on the back of a Thorntons low loader on the A1(M) near Wetherby. Thorntons looks to have done a canny job refurbishing it.
(02 Feb 2018, 12:53 pm)James101 These latest Streetlites really suit the new livery - just wish they'd ditch the clumsy web address!
