From big'un's list:
7809 on X10 vs Max X10/X11 on the 308
1504 on X8
4518 on North Tyneside 43
Max X10/X11 on the X9
(27 Feb 2016, 5:46 pm)Kuyoyo 1914 on 7/7a
EDIT: 7455 on X12
EDIT: 7455 on X12
(28 Feb 2016, 12:41 pm)mb134 1580 on the 418
(28 Feb 2016, 12:50 pm)mb134 An Omnicity I believe
It should be a StreetLite, due to the OmniCitys not being trusted.
(28 Feb 2016, 1:12 pm)GX03 SVC It should be a StreetLite, due to the OmniCitys not being trusted.
1465 was (don't know if it still is) on X66 via Hartburn and 26A's
(28 Feb 2016, 4:39 pm)mb134 Seems a pretty poor reason, the StreetLite's aren't designed for that route. I've used the X18 every other Sunday for the past year and a half, I've never seen a failed Omnicity on the 418, also the 418 is generally on time when its been allocated an Omnicity, however majority of the time I see a StreetLite its running late...
(28 Feb 2016, 5:34 pm)GX03 SVC StreetLites are more reliable, if a OmniCity breaks down between Alnwick and Berwick, it causes more hassle to get there, with getting to a breakdown taking over an hour in a bus.
And the OmniCitys aren't reliable either... one was taken off the X14 recently with the suspension sky high, it's not worth the risk sending them further north than Alnwick on a Sunday, where resources are at a minimum.
