North East Buses The Canteen Off-topic bus chat 'More than one change' challenge.
  • 1 Vote(s) - 5 Average
Pages (4) Previous 1 2 3 4
Storx
4,576
17 Aug 2020, 8:46 pm #61
(17 Aug 2020, 4:15 pm)BusLoverMum Either through Durham and consett when the 689(?) is running a full Saturday timetable or head via Sunderland, get the x24 which goes nowhere near Gateshead interchange, then Newcastle to Hexham to do it in 6 buses there and back.
Nope :p You have to go via Eldon Square both ways, and the bus has to serve it so you can't use the X24 as it's the opposite side of Newcaslte, it doesn't go into Park Lane neither so you can't connect the other side either without walking Tongue
Probably easier to say 6 buses, Hartlepool -> Eldon Square without touching Gateshead Interchange or buses serving it. The Hexham part is easy. You're right with going over Consett way though. There's only 1 possible way I believe though, might be wrong though.
Storx
18 Aug 2020, 2:10 pm #62
In 9 Buses: 57 (To Durham), 16 (To Stanley), X30 (To Newcastle), 10 (To Hexham), X84 (To Newcastle), 310 (to North Shields), 319 (to Jarrow), 9 (to Sunderland), 22 (to Hartlepool).
It would have been 8 a few years ago as well.
Also do Nat Ex Coaches Count?
Twitter: @ASX_Terranova
ASX_Terranova
Storx
4,576
18 Aug 2020, 3:15 pm #63
(18 Aug 2020, 2:10 pm)ASX_Terranova In 9 Buses: 57 (To Durham), 16 (To Stanley), X30 (To Newcastle), 10 (To Hexham), X84 (To Newcastle), 310 (to North Shields), 319 (to Jarrow), 9 (to Sunderland), 22 (to Hartlepool).
The 310 doesn't serve Eldon Square it's Haymarket Wink Close though - got the right idea, the 57/24, 23 (not 22), X84/X85/685 and X30 are part of it though to give a little hint Smile
No Nat Ex but can definitely see how you'd do it that way though.
Storx
18 Aug 2020, 5:27 pm #64
(18 Aug 2020, 3:15 pm)Storx The 310 doesn't serve Eldon Square it's Haymarket Wink Close though - got the right idea, the 57/24, 23 (not 22), X84/X85/685 and X30 are part of it though to give a little hint Smile
Is there a way it could be done using the tunnel?
Is the 78 one of the services, could go ncl to cls then cls to park lane or even 71 to new seaham.
Edited 18 Aug 2020, 5:35 pm by ASX_Terranova.
ASX_Terranova
Storx
4,576
18 Aug 2020, 5:44 pm #65
(18 Aug 2020, 5:27 pm)ASX_Terranova Is there a way it could be done using the tunnel?
Nah don't think so with the Tunnel as you can't get from Eldon Square to N. Shields easily since Eldon Square only really goes south. Can't get from NCL to CLS though without going through Gateshead Tongue. You're on the right track with the 78 though Tongue
I'll give you another big hint though, look at one of the services I didn't list before Wink
Storx
18 Aug 2020, 6:02 pm #66
(18 Aug 2020, 5:44 pm)Storx Nah don't think so with the Tunnel as you can't get from Eldon Square to N. Shields easily since Eldon Square only really goes south. Can't get from NCL to CLS though without going through Gateshead Tongue. You're on the right track with the 78 though Tongue
36/X12/X5/X45/10/685/X30/78/22 = 9 Changes
57/X5/X45/74/685/X30/8/22 = 8 Changes
22/939/91/685/74/10/X22/57 = 8 Changes (?)
If you include my proposed network : 57(ANE)/X20(GNE)/X8(TSX)/X85(GNE)/74(GNE)/X3(TSX)
ASX_Terranova
Storx
4,576
18 Aug 2020, 6:21 pm #67
(18 Aug 2020, 6:02 pm)ASX_Terranova 36/X12/X5/X45/10/685/X30/78/22 = 9 Changes
You got it, didn't expect anyone to get that. It's the 23 though, 22 is Sunderland to Durham.
Couldn't do the bottom one though as the 91 doesn't serve Eldon Square and the X22 isn't running atm but usually you could do the X22 route.
Storx
18 Aug 2020, 6:48 pm #68
(18 Aug 2020, 6:21 pm)Storx You got it, didn't expect anyone to get that. It's the 23 though, 22 is Sunderland to Durham.
Couldn't do the bottom one though as the 91 doesn't serve Eldon Square and the X22 isn't running atm but usually you could do the X22.
In the good old days you could have done X5/183/610/685/74/21X/57.
ASX_Terranova
col87
503
24 Aug 2020, 3:10 pm #69
No normal services only
I tell you the answer I had before I set the challenge. Arriva 24 Hartlepool to Durham. Go North East 21 Durham to Eldon Square
Go North East 10 Eldon Square to Hexham.
Go North East X85 Hexham to Eldon Square
Go North East X1 Eldon Square to Washington
Go North East 2 Washington to Sunderland
Go North East 9 Sunderland to Dalton Park
Go North East X10 Dalton Park to Stockton
Stagecoach 36 Stockton to Hartlepool.
Edited 24 Aug 2020, 3:20 pm by col87.
col87
col87
503
24 Aug 2020, 3:32 pm #70
Another challenge then. Owton Manor to Saltburn then to Dalton Park back to Owton Manor. Middlesbrough and Hartlepool Town centres are only places allowed to be used twice with with one stop allowed in Redcar. The stagecoach 36 is not allowed to be used and it has to be done on 8 service buses with at a limit of 3 different companies. No service can be used twice.
col87
tcts24
24 Aug 2020, 5:44 pm #71
I'm guessing the 2 changes at Hartlepool and Middlesbrough centres are optional and the Redcar stop is compulsary? I was a little baffled by the Redcar stop as most buses that serve Saltburn go to Middlesbrough via Redcar anyways.
If I included your Redcar stop, I originaly had it down as 1 bus too many...
7 Stagecoach Owton Manor - Foggy Furze
1 Stagecoach Foggy Furze - Middlesbrough
X3A Arriva Middlesbrough - Redcar
3 Arriva Redcar - Saltburn
X4 Arriva Saltburn - Middlesbrough
X12 Arriva Middlesbrough - Durham
265 Go Ahead Durham - Dalton Park
23 Arriva Dalton Park - Hartlepool
3A Stagecoach Hartlepool - Owton Manor
For some bizarre reason I'd completely forgotten about the X10!
So change the X12 to X10 and remove the 265 completely and that brings me down to 8 buses.
The one thing that bothers me, is I'm passing back through Redcar on the X4. The only way I can think of to avoid that is to catch the X4 in the opposite direction to Whitby and the X93 back to Middlesbrough. But that takes me one bus over again.
tcts24
col87
503
24 Aug 2020, 6:12 pm #72
(24 Aug 2020, 5:44 pm)tcts24 I'm guessing the 2 changes at Hartlepool and Middlesbrough centres are optional and the Redcar stop is compulsary? I was a little baffled by the Redcar stop as most buses that serve Saltburn go to Middlesbrough via Redcar anyways.
Hartlepool and Middlesbrough allowed twice as in most cases it's unavoidable although you found the way round it.  You need to go though Redcar to get to and from Saltburn so thought would make it so needed to stop there on one of the journeys.  Good attempt though
col87
Storx
4,576
24 Aug 2020, 9:53 pm #73
(24 Aug 2020, 6:12 pm)col87 Hartlepool and Middlesbrough allowed twice as in most cases it's unavoidable although you found the way round it.  You need to go though Redcar to get to and from Saltburn so thought would make it so needed to stop there on one of the journeys.  Good attempt though
Could do
7 -> Hartlepool
1 -> Middlesbrough
X3 -> Saltburn
X4 -> Whitby
X93 -> Middlesbrough
X10 -> Dalton Park
23 -> Hartlepool
3 -> Owsen Manor
Don't have to go through Redcar twice Tongue
Storx
Could do
7 -> Hartlepool
1 -> Middlesbrough
X3 -> Saltburn
X4 -> Whitby
X10 -> Dalton Park
23 -> Hartlepool
3 -> Owsen Manor
tcts24
25 Aug 2020, 7:58 am #74
(24 Aug 2020, 9:53 pm)Storx Could do
7 -> Hartlepool
1 -> Middlesbrough
X3 -> Saltburn
X4 -> Whitby
X10 -> Dalton Park
23 -> Hartlepool
3 -> Owsen Manor
I would have probably went with that. But I'd got the impression a bus change in Redcar was compulsary. In which case, this would take it over the limit by 1 bus. Hence I opted to go back via Redcar but without changing on the return trip.
tcts24
7 -> Hartlepool
1 -> Middlesbrough
X3 -> Saltburn
X4 -> Whitby
X10 -> Dalton Park
23 -> Hartlepool
3 -> Owsen Manor
25 Aug 2020, 8:15 am #75
(25 Aug 2020, 7:58 am)tcts24 I would have probably went with that. But I'd got the impression a bus change in Redcar was compulsary. In which case, this would take it over the limit by 1 bus. Hence I opted to go back via Redcar but without changing on the return trip.
Could you go via york on this challange.
ASX_Terranova
col87
503
25 Aug 2020, 9:30 am #76
(25 Aug 2020, 8:15 am)ASX_Terranova Could you go via york on this challange.
As long as it's no more than 8 buses and only buses and you stop at Redcar and at least once in Hartlepool and Middlesbrough then go whatever you want.  If you reckon you could do it via York then go ahead.
Yes a change in Redcar has to happen but either from or to Middlesbrough. But you can though Redcar on the other journey.
Edited 25 Aug 2020, 9:32 am by col87.
col87
