Arriva North East: Service Suggestions
(14 Mar 2022, 9:42 am)GNE6312 Arriva should extend the 44/45 to Newcastle Airport on all journeys
Because a lot of people don't want to pay for a day rover to get a bus and metro when an Arriva day ticket would be cheaper. There are also plenty of times where the Metro's are off at short notice (that's happened the last two times I've got a flight from the airport), so it would give additional choice on those occasions.
I actually know this idea has been put forward to Arriva as an idea to cover part of the route cut by GNE and the 42a. I don't know whether they have made a response to the idea though.
(14 Mar 2022, 4:28 pm)Shrek Because a lot of people don't want to pay for a day rover to get a bus and metro when an Arriva day ticket would be cheaper. There are also plenty of times where the Metro's are off at short notice (that's happened the last two times I've got a flight from the airport), so it would give additional choice on those occasions.Nothing been changed on nexus or Arriva website
Promotional idea for 308 & 54 with timetable changes (improved connections in W.Bay and shift time coverage) and other uses. Would tie in with the appropriate zones covering Blyth & T&W.
"Work at Cobalt and live in Blyth? Then one ticket is all you will ever need"
"Catch our Service 308 & 54* to work and on your day off, get around with us onboard our fast X10/X11 service to Newcastle as well as many other local services too"
* Requires a change of bus in Whitley Bay
Simple one but change the 57/57A to do a loop around Whitley Bay like https://www.google.com/maps/dir/55.04175...77!1m0!3e0
It's actually quicker and opens new links to the Seafront, the walk is a bit of a chore for people needing to do it rather than wasting time circling around the back of the Fire Station etc.
People from Park View could just get on towards Whitley Bay and go around the loop.
Google isn't good at sharing modified routes, your link just shows as a straight line over the Monkseaton Metro bridge.
(05 Jul 2022, 9:01 am)omnicity4659 Google isn't good at sharing modified routes, your link just shows as a straight line over the Monkseaton Metro bridge.
Bring the old 9 back, running hourly every day: Central Station - Blakelaw - Kenton Bar, possibly extended to Cramlington and extended once each day to run between Haymarket and Belsay. Someone recently said they miss the old 9.
(10 Jul 2022, 12:27 am)OrangeArrow49 Bring the old 9 back, running hourly every day: Central Station - Blakelaw - Kenton Bar, possibly extended to Cramlington and extended once each day to run between Haymarket and Belsay. Someone recently said they miss the old 9.
(14 Jul 2022, 5:11 pm)Coastliner700 I used to use the 9/9A and then later 9X but sadly Arriva ran it into the ground constantly cancelling journeys to the point where it was no longer reliable and the inevitable happened. Not sure how it would manage in today’s world but it was a fantastic bus service whilst it ran but most of its route is served by other buses so cant imagine its going to happen. Sadly to say I can now see Stagecoach 31 the Montagu Estate leg going exactly the same way. Constantly cancelling journeys even late at night they’ve reduced the frequency and the passenger numbers seem at an all time low. With 10/11 almost following same route perhaps this long serving bus could be the next casualty.
(14 Jul 2022, 6:49 pm)OrangeArrow49 From your username, I would assume you like Arriva.
(14 Jul 2022, 9:12 pm)omnicity4659 https://en.wikipedia.org/wiki/Coastliner_700
If somebody was planning to do a rival Newcastle - Blyth express, what would be the best routing in order to make it a reasonable success?
My orignial routing was:
Haymarket, Gosforth High Street, Regent Centre, A1, Old Great North Road, Bladgon Lane, Northumberlandia Car Park, East Hartford, Furnace Bank, B1331, Moorland Avenue, East Sleekburn, A189, Bebeside, Cowpen Lane, Waterloo Road & Blyth Bus Station which would take about 54 minutes depending on traffic.
(19 Jul 2022, 2:31 pm)ASX_Terranova If somebody was planning to do a rival Newcastle - Blyth express, what would be the best routing in order to make it a reasonable success?
(19 Jul 2022, 3:16 pm)omnicity4659 Nothing there to serve apart from Northumberlandia, which isn't popular nor interesting - it's just an apology from Banks Group for digging massive holes.
Not suitable for buses.
Weak bridge prevents access to East Sleekburn.
X30 being operated all day would be sufficient, perhaps a bidirectional circular service so Bebside gets an express straight down the Spine Road too without travel via Blyth/Newsham.
The best route would be straight up the Spine Road to Blyth, then serving Cambois (observing East Sleekburn road end on the way) if you really needed to serve it.
(19 Jul 2022, 3:24 pm)ASX_Terranova Theres a village at east hartford, surely a direct newcastle would be good for them.
(19 Jul 2022, 3:29 pm)omnicity4659 But it doesn't justify the cost of running a bus service through there the way you propose it, I'm sure the Arriva 43 went into the village at one point too?You have the 58, which could be changed to go into newcastle.
The Arriva 43 is actually the closest route to serve it, it passes by on the main road.
