Arriva North East: Service Suggestions - Printable Version +- North East Buses (https://northeastbuses.co.uk/forums) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forums/forumdisplay.php?fid=1) +--- Forum: Arriva North East (https://northeastbuses.co.uk/forums/forumdisplay.php?fid=56) +--- Thread: Arriva North East: Service Suggestions (/showthread.php?tid=503) |
RE: Arriva North East: Service Suggestions - V514DFT - 20 Sep 2022 (19 Sep 2022, 10:44 am)Storx See if I was going to do stuff I think I'd be more radical than that and do something like:Your 52 would also give Forest Hall back a bus to the Freeman Hospital RE: Arriva North East: Service Suggestions - Storx - 20 Sep 2022 (20 Sep 2022, 8:33 am)V514DFT Your 52 would also give Forest Hall back a bus to the Freeman Hospital Aye your right, missed that one ngl. RE: Arriva North East: Service Suggestions - V514DFT - 20 Sep 2022 I'd also swap the 53 and 54 53- Cramlington-Whitley Bay 54-Newcastle-North Shields Never understood why it was swapped in the first place after the 56/X6 was axed, ran perfectly fine when it was the 356 RE: Arriva North East: Service Suggestions - Storx - 20 Sep 2022 (20 Sep 2022, 7:36 pm)V514DFT I'd also swap the 53 and 54 Must admit I didn't really get that one, guessing the people in Backworth preferred a bus to Whitley over North Shields. All I can really think of tbh. I'm surprised the 52/53/54 are all still full size buses, the 52 (340/342) and 53 (343/344) ran with minibuses for years and they never really shouted out at bus routes that needed anything bigger tbh. Whenever I see them now they never seem to need anything bigger either tbh but there might be some areas I miss where they actually need them. RE: Arriva North East: Service Suggestions - V514DFT - 21 Sep 2022 The 52/53/54 are strange routes tbh, sometimes it gets rammed, then other times it carries fresh air RE: Arriva North East: Service Suggestions - GNE6312 - 28 Sep 2022 (20 Sep 2022, 7:36 pm)V514DFT I'd also swap the 53 and 5453 used to go to Whitley Bay years ago when it ran from Blyth to Whitley Bay via Cramlington and the current route from Cramlington to New York. Remember doing the whole run of it on a V reg dart, was about 2 hours end to end from Blyth to Whitley Bay. RE: Arriva North East: Service Suggestions - Storx - 28 Sep 2022 (28 Sep 2022, 1:46 pm)GNE6312 53 used to go to Whitley Bay years ago when it ran from Blyth to Whitley Bay via Cramlington and the current route from Cramlington to New York. Remember doing the whole run of it on a V reg dart, was about 2 hours end to end from Blyth to Whitley Bay. The 53 ran from Whitley to Cramlington for years with the Vario's then MPD's. It's just the old 343/344 which used to extend to Morpeth aswell instead of the 43. Not sure if you knew then for some reason they swapped what was the 356, now partially the 54 and 53 around around 2012 I believe it was. The 56/57/57A used to interwork hence the number change so it was easier to change the manual blinds at North Shields. RE: Newcastle Depot - Storx - 02 Oct 2022 (13 Aug 2022, 9:35 am)L469 YVK A hypothetical one here, would Arriva not have been better off doing a deal with GNE? I'm not going to hunt for your post which always mentioning it. But I actually agree than Arriva should probably try later buses on the X7 / X11 / X21 / 308 possibly using the 43 / 44 / 45 / 52 / 53 / 54 buses which terminate in Newcastle at a night to get them back to Blyth / Ashington even if it's just a Saturday. I'm not sure whether last night was a freak night but it's busiest I've seen all them at 11pm even before Covid. The X7 believe had 35+, there was still 24 on board at Seaton Delaval and quite a few had already left. The X11 and X21 seemed even busier. The X11 nearly filled a double decker (and I'm not talking 1 person per seat). Mind it was noticeable how dead the Jesmond routes were on the other hand the 52 was single numbers and the 43 didn't seem much better (why on earth does the 52 and X7 leave a same time is a mystery considering the duplication of the routes and their both hourly but that's another thing). Wonder if we might see long term the likes of the last 52 scrapped and running on the X7 instead with the inbound X7 terminating at Seghill to save buses, the inbound buses are always dead to get them back to the depot. RE: Newcastle Depot - omnicity4659 - 02 Oct 2022 (02 Oct 2022, 6:20 am)Storx But I actually agree than Arriva should probably try later buses on the X7 / X11 / X21 / 308 possibly using the 43 / 44 / 45 / 52 / 53 / 54 buses which terminate in Newcastle at a night to get them back to Blyth / Ashington even if it's just a Saturday. Not at all a freak night, for a good few hours after the last bus departures there's an endless stream of hackney carriages heading north out of Newcastle. Nights in Newcastle do fluctuate, sometimes the peak of it ends earlier which will fill up the last buses, but most of the time the peak ends later meaning that taxis handle it. Some later bus departures might cut down on the amount of taxi drivers driving like dickheads up the Spine Road... RE: Newcastle Depot - Storx - 02 Oct 2022 (02 Oct 2022, 7:09 am)omnicity4659 Not at all a freak night, for a good few hours after the last bus departures there's an endless stream of hackney carriages heading north out of Newcastle. Ah I didn't mean Newcastle there, I just meant the buses. Newcastle was quite quiet last night tbf but I've never seen Haymarket so busy. It's usually only 10 - 15 people on them whenever I've used it in the past. Agreed with the taxis though around 3am but tbh I could imagine a lot of them will refuse to use the bus anyway for whatever reason. RE: Arriva North East: Service Suggestions - Unber43 - 02 Oct 2022 Newcastle did seem extremely busy yesterday compared to a Normal saturday, I thought there was a match on (there wasn't). All Arriva/GNE buses I saw were all quite busy. RE: Newcastle Depot - L469 YVK - 02 Oct 2022 (02 Oct 2022, 6:20 am)Storx I'm not going to hunt for your post which always mentioning it.In a lot of instances, moving the last departutres to between 11:20 and 11:30 would work well. If Arriva did however re-introduce a 30 minute Monday to Saturday evening service on the 306 & 308 (every 15 mins combined), I'd say the best laat departures would be: 306 - 22:42 - Sundays 308 - 22:42 - Monday to Saturday 306 - 22:57 - Monday to Saturday 308 - 23:12 - Daily 306 - 23:32 - Daily 308 - 23:52 - *Friday & Saturday only* Note the last 308 on a Fri & Sat would work off the 44 (23:15 ex Dinnington) RE: Newcastle Depot - Storx - 02 Oct 2022 (02 Oct 2022, 4:25 pm)L469 YVK In a lot of instances, moving the last departutres to between 11:20 and 11:30 would work well. Aye disagree too much really bar the 44 is going to Ashington I believe rather than Blyth or it was in the early rumours so ideally that would have to go onto an X21/X22 instead which probably wouldn't be too bad to have a later service either. Mind I'd be tempted to say flip the 306/308 around so you have the 23:32, 308 and then have the later 306 on a Saturday maybe extended to Whitley Bay / Blyth to try and pick up a few punters from Tynemouth heading home. It would give an option home beyond midnight, the last Metro being 23:55 and 1 23:19 I do believe there's a 52 and 54 which come in as late though. RE: Arriva North East: Service Suggestions - Storx - 26 Nov 2022 When the new railway comes to Ashington, changes to the X21/X22 to serve more areas as a 20 minute service will be overkill via Bedlington station. X21 - X22 route to Bedlington, X21 route to Jubilee Ind. Estate, Newbiggin Road, College Road, Hawthorn Road, Ashington Bus Station, Current Route to Newbiggin (Every 30 Minutes) X22 - Current route to Ashington then Woodhorn Road, Woodhorn Lane, Hunstanton, Garcia Drive, Pine Valley Way - Terminate (Every 30 Minutes) X23 - X21 Route to Bedlington, X22 route to Guide Post, Stakeford Lane, Ramsheid Road, Blackthorn Way, Wansbeck Road, Green Lane, N Seaton Road, Ashington (Every 30 Minutes) New X21 - https://www.google.com/maps/dir/55.1850093,-1.5123926/Newcastle+upon+Tyne/@55.1775822,-1.5528086,3813m/data=!3m1!1e3!4m49!4m48!1m40!3m4!1m2!1d-1.5246!2d55.1762546!3s0x487e0d80b9fa5171:0xa88f7b22b8e50867!3m4!1m2!1d-1.5484672!2d55.1846468!3s0x487e0d97b07ed2c1:0xa6eb962452f51a32!3m4!1m2!1d-1.568067!2d55.1839163!3s0x487e0db1cebfeeab:0xa15338d64e79259!3m4!1m2!1d-1.561674!2d55.1805173!3s0x487e0da50db44679:0x2f7dfe240d0398da!3m4!1m2!1d-1.5762333!2d55.1566008!3s0x487e0ce275ea375b:0x9d3769fae7e4ea90!3m4!1m2!1d-1.5683873!2d55.1401496!3s0x487e0d26758b4123:0x78cdb311d9e90efd!3m4!1m2!1d-1.6002884!2d55.1291189!3s0x487e0ccaf2ce7f33:0x10d646aa7e82710d!3m4!1m2!1d-1.6230163!2d55.0295626!3s0x487e7152d15c99bb:0x89a7db516d9cc963!1m5!1m1!1s0x487d857e0c6f64cd:0xbe252b072a76191!2m2!1d-1.61778!2d54.978252!3e0 New X22 - https://www.google.com/maps/dir/55.1809122,-1.5423075/54.9774693,-1.614576/@55.1767056,-1.5785789,3705m/data=!3m1!1e3!4m44!4m43!1m40!3m4!1m2!1d-1.5663619!2d55.1836486!3s0x487e0db03dde696d:0x7d7854846b4531ce!3m4!1m2!1d-1.5865736!2d55.1837233!3s0x487e0c4e3f762cd9:0x46031ae3c02f9b7!3m4!1m2!1d-1.5780318!2d55.1815021!3s0x487e0c52b6a9bf95:0x961fd89e53b420bc!3m4!1m2!1d-1.5713618!2d55.1716442!3s0x487e0daa09604cf9:0x2b00d2996e8f9d42!3m4!1m2!1d-1.5915661!2d55.1659443!3s0x487e0cf74d70e8e7:0x58228968e9733d7e!3m4!1m2!1d-1.5981721!2d55.1389332!3s0x487e0cc6482cb981:0x7852222c833802c!3m4!1m2!1d-1.5920388!2d55.1309947!3s0x487e0ccdb4c8533b:0x3a35539ae1b15460!3m4!1m2!1d-1.6230163!2d55.0295626!3s0x487e7152d15c99bb:0x89a7db516d9cc963!1m0!3e0 New X23 - https://www.google.com/maps/dir/55.1841471,-1.5693279/54.9774693,-1.614576/@55.1159414,-1.6208428,10196m/data=!3m1!1e3!4m49!4m48!1m45!3m4!1m2!1d-1.5684036!2d55.181702!3s0x487e0dae3b42b0dd:0xd9ed2f9d022a4ac6!3m4!1m2!1d-1.581384!2d55.1772058!3s0x487e0c537d6d2f53:0x424137dd324b924!3m4!1m2!1d-1.5713618!2d55.1716442!3s0x487e0daa09604cf9:0x2b00d2996e8f9d42!3m4!1m2!1d-1.5841808!2d55.1632203!3s0x487e0cfb81ed5879:0x5e846f166952670!3m4!1m2!1d-1.5981721!2d55.1389332!3s0x487e0cc6482cb981:0x7852222c833802c!3m4!1m2!1d-1.5920388!2d55.1309947!3s0x487e0ccdb4c8533b:0x3a35539ae1b15460!3m4!1m2!1d-1.6300904!2d55.1322773!3s0x487e0ca9ff1d5315:0x2f3a7ff49d16f1c4!3m4!1m2!1d-1.625798!2d55.1171414!3s0x487e7357a36325c1:0xa26e7731e9adcdeb!3m4!1m2!1d-1.6230163!2d55.0295626!3s0x487e7152d15c99bb:0x89a7db516d9cc963!1m0!3e0 Reasons: Faster service to Newbiggin avoiding Nedderton, serve more areas of Ashington including new housing estates which are unserved and reduces the X21 which are going to be hampered by the train. Loses: Nedderton and Newbiggin slightly decreased service, Milburn Road loses bus but Hawthorn Road is 100m to the East. RE: Arriva North East: Service Suggestions - L469 YVK - 26 Nov 2022 (26 Nov 2022, 8:58 am)Storx When the new railway comes to Ashington, changes to the X21/X22 to serve more areas as a 20 minute service will be overkill via Bedlington station.Only issue I could foresee is a 10-6-14 service from the Red Lion unless the X23 followed a similar stopping pattern to the 'old' X22 and X33 immediately turning onto Glebe Road from Ridge Terrace. RE: Arriva North East: Service Suggestions - Storx - 26 Nov 2022 (26 Nov 2022, 6:17 pm)L469 YVK Only issue I could foresee is a 10-6-14 service from the Red Lion unless the X23 followed a similar stopping pattern to the 'old' X22 and X33 immediately turning onto Glebe Road from Ridge Terrace. To be fair it's already like that anyway with it being 14 - 6 instead atm. Arguably it's a slight improvement in a way but I'm not sure if I'd just pull the X23 out of it altogether maybe with singles. So the X21/X22 run every 15 minutes between Bedlington and the X23 just runs inbetween, maybe 5 minutes infront of the X21 out of Newcastle so it groups back together at Bedlington so it's every 15 minutes from there to Ashington instead with the X22. Similar to how the X9/X10/X11 work from Blyth. Anyone with sense from Bedlington itself would take the X22 anyway rather than the detour round Nedderton if they could especially if it was 4 buses an hour. Undecided on the X23, now thinking this https://www.google.com/maps/dir/55.1809312,-1.542528/54.9774693,-1.614576/@55.169541,-1.6321284,14400m/data=!3m1!1e3!4m54!4m53!1m50!3m4!1m2!1d-1.5680227!2d55.1838068!3s0x487e0db1cebfeeab:0xa15338d64e79259!3m4!1m2!1d-1.569555!2d55.1841055!3s0x487e0db1eb5aafa1:0xcdefd51f377cdc01!3m4!1m2!1d-1.5684036!2d55.181702!3s0x487e0dae3b42b0dd:0xd9ed2f9d022a4ac6!3m4!1m2!1d-1.581171!2d55.1722197!3s0x487e0c559aeeefa7:0xfcee06118543d739!3m4!1m2!1d-1.5923129!2d55.1831356!3s0x487e0c4559d593cf:0x5d76cb6da5151d93!3m4!1m2!1d-1.6005717!2d55.1606752!3s0x487e0cf2634b9587:0x574b15e7a1ed79ff!3m4!1m2!1d-1.5920388!2d55.1309947!3s0x487e0ccdb4c8533b:0x3a35539ae1b15460!3m4!1m2!1d-1.6300904!2d55.1322773!3s0x487e0ca9ff1d5315:0x2f3a7ff49d16f1c4!3m4!1m2!1d-1.625798!2d55.1171414!3s0x487e7357a36325c1:0xa26e7731e9adcdeb!3m4!1m2!1d-1.6230163!2d55.0295626!3s0x487e7152d15c99bb:0x89a7db516d9cc963!1m0!3e0 would be better with the X22 terminating short instead. Would give access to the hospital across Ashington and give the top end a link to Newcastle and not kill the 57/57A by duplicating it through Stakeford. RE: Arriva North East: Service Suggestions - L469 YVK - 26 Nov 2022 (26 Nov 2022, 8:57 pm)Storx To be fair it's already like that anyway with it being 14 - 6 instead atm. Arguably it's a slight improvement in a way but I'm not sure if I'd just pull the X23 out of it altogether maybe with singles.Totally agree about the X21 and missing Nedderton. Although I've had the same debate on here in the past and the one thing (rightly) about the X21 / X22 was that they were a mess before being simplified in 2012 and have remained very stable since. Ironically overseen by GNE's now current MD. Big danger with the X23 is that route could turn into a 'secondary' route if not successful and overshadowed by the X21/X22 taking most of the loads. As for the X9, if in future the 43 was split into a 43/43A with the 43 via High Pit, Annitsford and Fern Drive to replace the X8 and a 43A all stops but via Beacon Hill with an hourly extension via the X8 route to Blyth, the X9 could fall in with the X10/X11 following the same route via Southfield Green to give a 10 min combined frequency on common sections. RE: Arriva North East: Service Suggestions - mb134 - 26 Nov 2022 What seems to be missed quite consistently when discussing the X21/22 is the amount of local trips being made, particularly on the X21. Cutting the frequency between Ashington/Stakeford/Bedlington Station/Bedlington harms those making small hops, which is a decent chunk of revenue for Arriva given the fares. It's also the type of journey the introduction of trains isn't going to harm. Increasing the frequency along the X22 route in the suggestions above seems odd, it's generally the weaker of the two routes. The Bedlington to Guide Post section is already covered well by the current X22 and the 2. I'd get behind serving Blackthorn Way though, that area of Ashington needs a better service and it's easy enough to do. I imagine extending the X22 around the new estate at the hospital once the loop is complete would be the best way to do it, improving links for the elderly folks living around Ashington Drive and Fallowfield. RE: Arriva North East: Service Suggestions - Storx - 27 Nov 2022 (26 Nov 2022, 11:33 pm)mb134 What seems to be missed quite consistently when discussing the X21/22 is the amount of local trips being made, particularly on the X21. Aye no arguments, see I was thinking more trying to sort some of the stacking with the local runs where the 1 follows an X21 etc. So you'd merge the timetables of the 1/X21 (Every 15 Minutes), 2/X21 (Every 15 Minutes) for the local runs which if they can get them to work would be better, it's arguably better than the 20 / 20 / 10 / 10 on the 1/X21 atm. I was struggling with the X23 between Bedlington and Ashington if I had to be honest as it's not really needed anywhere but Ashington badly needs more buses. There's quite a few areas underserved. Alexandria Road is poor aswell with only the X20 which ends at 6pm, hence shunting the X21 across one road to kind of cover it (believe that used to be the X30 - might have the numbers mixed up though with the X31). One personal change I'd love to see is the 57/57A changed so it's half hourly through Seghill again, preferably to the old 10/11 timetable years ago where one went via High Pit and the other went via Fern Drive and direct to Cramlington but I'd probably swap that to using the route via the business park as now than Fern Drive. It's really stupid having 2 buses an hour plus the 58 via East Cramlington which is overkill imo but 1 bus from Seghill to Cramlington (the 19 comes at the same time and is a magical tour). RE: Arriva North East: Service Suggestions - L469 YVK - 27 Nov 2022 - X8 - withdrawn and replaced by X7 & 42. - X9 - Same route between Blyth & Shankhouse then same as X10 to Newcastle. Common 10 minute frequency with X10/X11 from Blyth and between Parkside and Newcastle. Will provide even faster journeys for North Blyth & Bebside. Every 20 minutes combined evenings & Sundays. Late Sunday evening X10 journeys withdrawn and X9 at these times additionally serves Newsham Shops. - 42 - 'Old' X9/X13 route from Blyth to Newcastle but all stops via Seaton Burn & Wideopen. Every 30 mins Newcastle to Cramlington continuing hourly to Blyth including Amersham Road re-instating link to Regent Centre. - 43 - Re-routed between Cramlington and Dudley via High Pit, Annitsford and Fern Drive. Every 30 minutes continuing to Morpeth every 60 minutes. - 44/45 - Re-instated to every 30 minutes each. |
