Reintroduction of Temporarily Reduced Services Back to Original Frequency
(05 Feb 2024, 1:32 pm)Unber43 Well if its due to a fault on the vehcile maybe they should fix the vehicle
(05 Feb 2024, 1:52 pm)Kuyoyo Which they do - but you clearly don't know anything about how things work in depots during the morning run-out. There's no way you can discover a defect on a vehicle and have the fitter fix it in the time allocated for a defect check before that working leaves the depot given the allocated time for a defect check is 10 minutes. If the allocated vehicle has a defect, the driver either has to start by defect checking another vehicle or take what is called a 'hot bus' - a spare vehicle already defect checked and ready to go. End of the day, at present, most of the general public would rather have a bus turn up vaguely on time than worry if it has the features.
Is the 10/A/B still on the cards to be reverted back? Just it seems the only brand to not have had its vinyls updated (I think), suggesting they still plan on reverting back to every 10 minutes?
