Go North East: Major Service Changes July 2022 - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Go North East (https://northeastbuses.co.uk/forumdisplay.php?fid=54) +--- Thread: Go North East: Major Service Changes July 2022 (/showthread.php?tid=3937) |
RE: Go North East: Major Service Changes July 2022 - MurdnunoC - 03 Jun 2022 (03 Jun 2022, 5:43 am)Dan wrote Perhaps not, although in such a small team I’m sure he could have a big influence on other matters outside of the primary responsibilities of the role. Constantopoulos Consulting will undoubtedly be better than Shyster Solutions - the team who GNE currently outsource work to in the field of commercial decision making. RE: Go North East: Major Service Changes July 2022 - Andreos1 - 03 Jun 2022 (03 Jun 2022, 4:55 am)DeltaMan wrote The good news for you is that they are still advertising for a Commedcial Assistant. So there is a nice opportunity for you to share your knowledge.Did you go for it in the end? A little piddling local bus operator? Nah, I'll stick with ranting on here as far as they go and in the real world do my stuff with larger organisations. But I'm sure myself and the other sensible non-fan boy posters on here could join together on a consortium basis and for a fee, offer plenty of advice and thought provoking comments. Of course we would be laughed out of the office, because they know best! :huh: (03 Jun 2022, 5:43 am)Dan wrote Perhaps not, although in such a small team I’m sure he could have a big influence on other matters outside of the primary responsibilities of the role.Don't be daft. I'm not part of the clique. They only head hunt their mates. RE: Go North East: Major Service Changes July 2022 - busmanT - 03 Jun 2022 (03 Jun 2022, 12:23 am)Andreos1 wrote Surely a competent commercial team would look at alternatives to relying on subsidies and come up with something like yourself and many others have suggested?I suspect that the 4 in 1 solution I thought of still might not be commercial - low frequency linking everywhere to everywhere else, typical secured service. A big question I think is for Bank Holidays post any cuts, especially Good Friday when services are normally very busy. Even those services that aren't that busy on a Sunday are busy on a Bank Holdiay - or example, I spent 45 minutes in CLS just after 1200 today and the 34 was very busy in both directions, and the 25 had quite a few on when it arrived just before 1300. If the 34, for example, doesn't have a Sunday service post 24th July will GNE provide a service on Bank Holidays? there certainly seemed enough passengers travelling to cover the cost of operation. Even the 21 (on its current 12-minute frequency) was very busy, with long gaps in service - how will it cope when it's every 15 minutes on Sundays/Bank Holidays? A rethink of Bank Holdiay frequencies and running times required, I think. RE: Go North East: Major Service Changes July 2022 - busmanT - 03 Jun 2022 (03 Jun 2022, 3:33 pm)busmanT wrote I suspect that the 4 in 1 solution I thought of still might not be commercial - low frequency linking everywhere to everywhere else, typical secured service.A quick look on bustimes show a service 8 heading into Sunderland with 20 odd passengers on board - so unless it's going to be a "special" Sunday service on bank holidays quite a lot of passengers are going to be inconvenienced. RE: Go North East: Major Service Changes July 2022 - NEtransport - 03 Jun 2022 (03 Jun 2022, 3:45 pm)busmanT wrote A quick look on bustimes show a service 8 heading into Sunderland with 20 odd passengers on board - so unless it's going to be a "special" Sunday service on bank holidays quite a lot of passengers are going to be inconvenienced. It's probably more likely that the driver hasn't entered it into the ticket machine when a passenger has alighted - even more so when there is an 8 at the other end apparently with 2 seats free. So in reality it's probably 20 or so passengers who have used it across the whole route. RE: Go North East: Major Service Changes July 2022 - L469 YVK - 03 Jun 2022 I've worked it out and if the potential changes as outlined in the consultation go ahead, the following interworking patterns for the Evening & Sunday trips are definitely do-able (see attached screenshot of timings). Note that the timings are only estimates. 6/12/X30/X72 - Riverside * Interworked using 7x StreetLites. * Changeovers for pattern 1 done at MetroCentre and changeovers for pattern 2 done at Blaydon. * Common frequency maintained with X30/X72 between Sunniside and Newcastle. * Would reduce costs using a more appropriate vehicle type for capacity requirements as well eliminating the need for any remote reliefs at Stanley from Hownsgill. * If extra capacity is required (i.e matchdays), low height E400MMCs not used on the X9/X10 or 6336/37 can also be allocated to some boards. 16B/47/47A/X5/X45 - Hownsgill * Interworked using 9x StreetDeck or E400MMC (whichever type is not eliminated from Consett after changes.....most likely will be StreetDecks eliminated). * All changeovers done at Consett. * Compliant with driving hours. * Common frequency maintained with X45/47 between Rowlands Gill and Newcastle. * Would reduce costs using a more fuel efficient vehicle type. * Short X15 between Castleside and Consett only interworked with 78 on Sundays. * 47A runs between Shotley Bridge Hospital and Consett on Sundays formed of the X5 and then forms the 47 after returning to Consett. RE: Go North East: Major Service Changes July 2022 - busmanT - 03 Jun 2022 (03 Jun 2022, 3:53 pm)Thomas12 wrote It's probably more likely that the driver hasn't entered it into the ticket machine when a passenger has alighted - even more so when there is an 8 at the other end apparently with 2 seats free.I hadn't realised that the "When2Travel" and "How Many Seats are left on my bus" tools had disappeared, thought they would still be useful. https://www.gonortheast.co.uk/new-tools-help-bus-passengers-prove-hit-during-covid-19-crisis RE: Go North East: Major Service Changes July 2022 - NEtransport - 03 Jun 2022 (03 Jun 2022, 5:23 pm)busmanT wrote I hadn't realised that the "When2Travel" and "How Many Seats are left on my bus" tools had disappeared, thought they would still be useful. I think bustimes is useful but it is only reliable if the driver accurately records the number of passengers departing. I'd say most of the drivers do record it, but sometimes bustimes will say the bus is full when there is plenty of seats available. RE: Go North East: Major Service Changes July 2022 - Gonorth91 - 03 Jun 2022 They taking 35 of from boldon RE: Go North East: Major Service Changes July 2022 - busmanT - 04 Jun 2022 http://publictransportexperience.blogspot.com/2022/05/go-ahead-goes-backwards-1.html http://publictransportexperience.blogspot.com/2022/05/go-ahead-goes-backwards-2.html An outsiders view....... RE: Go North East: Major Service Changes July 2022 - Andreos1 - 04 Jun 2022 (04 Jun 2022, 8:59 pm)busmanT wrote http://publictransportexperience.blogspot.com/2022/05/go-ahead-goes-backwards-1.htmlBut tables, titivations and paint... Who would have thought it wouldn't work? Any other industry the people making those decisions and seeing them fail in such spectacular fashion, would be sacked. Someone needs to let RF and RS know! RE: Go North East: Major Service Changes July 2022 - Unber43 - 04 Jun 2022 (04 Jun 2022, 10:06 pm)Andreos1 wrote But tables, titivations and paint... Don't forget the blatant false advertising! I never want anyone to lose their jobs, however GNE Marketing/Promotion/Decison Makers, if things just aren't working it might be worth stop blaming the pandemic and look at themselves. RE: Go North East: Major Service Changes July 2022 - Economic505 - 04 Jun 2022 (04 Jun 2022, 10:06 pm)Andreos1 wrote But tables, titivations and paint...Go Ahead are a disgrace. Pretty buses, no F@&king routes. RE: Go North East: Major Service Changes July 2022 - Andreos1 - 04 Jun 2022 (04 Jun 2022, 10:12 pm)Unber43 wrote Don't forget the blatant false advertising! I never want anyone to lose their jobs, however GNE Marketing/Promotion/Decison Makers, if things just aren't working it might be worth stop blaming the pandemic and look at themselves.100%. This isn't calling for anyone losing their job. It's calling out the apparent lack of competence when we are told they know best. And to be honest, it's questionable whether they actually do. If they were competent, stopped the finger pointing, blaming and shrugging - I genuinely don't think we would have communities stressing like they are. Nor a network that's clearly not fit for purpose. (04 Jun 2022, 10:15 pm)Economic505 wrote Go Ahead are a disgrace. Pretty buses, no F@&king routes.Are they really that pretty? I just see fur coats and a total lack of knickers. RE: Go North East: Major Service Changes July 2022 - Ambassador - 04 Jun 2022 (04 Jun 2022, 8:59 pm)busmanT wrote http://publictransportexperience.blogspot.com/2022/05/go-ahead-goes-backwards-1.html Dear Lord, the anti Roger French exists. RE: Go North East: Major Service Changes July 2022 - Unber43 - 04 Jun 2022 (04 Jun 2022, 10:54 pm)Andreos1 wrote 100%.They think they know best, and what people want without actually asking them, who’d thought that would backfire, whats this like 4th attempt after the Pandemic to fix the network. And when it doesn't work, they'll just blame the pandemic, its like a endless loop. They waste so much money on pointless things, maybe get someone to deliver leaflets around doors promoting their services and not cutting the Frequency e.g 4, went from 10-12-15, that is losing two buses per hour, it may not seem much but in the grand scheme of things is waiting for a bus which has been cut a lot over just a two year period,really giving them confidence then slash sunday and morning services. That'll get people back! Won't it! Send leaflets and also advertise that they have tables, USB/Plug Sockets (ON SERVICES WHICH THEY WORK, not the 20/10/47 etc). RE: Go North East: Major Service Changes July 2022 - Andreos1 - 04 Jun 2022 (04 Jun 2022, 10:58 pm)Ambassador wrote Dear Lord, the anti Roger French exists.You reckon RF is wandering down the street singing this? https://youtu.be/eUJ_ifjKopM Go North East: Major Service Changes July 2022 - Dan - 05 Jun 2022 (04 Jun 2022, 10:06 pm)Andreos1 wrote Someone needs to let RF and RS know! I see it didn’t take someone very long! https://twitter.com/bullsht_bot/status/1533210842287702018?s=21&t=f1eWizL6dvPE1HRWoDIrnA Sent from my iPhone using Tapatalk Go North East: Major Service Changes July 2022 - Dan - 05 Jun 2022 (04 Jun 2022, 10:06 pm)Andreos1 wrote Someone needs to let RF and RS know! I see it didn’t take someone very long! https://twitter.com/bullsht_bot/status/1533210842287702018?s=21&t=f1eWizL6dvPE1HRWoDIrnA Sent from my iPhone using Tapatalk RE: Go North East: Major Service Changes July 2022 - Ambassador - 05 Jun 2022 (05 Jun 2022, 7:36 am)Dan wrote I see it didn’t take someone very long!I mean….I’d have taken a more constructive approach but hey ho… RE: Go North East: Major Service Changes July 2022 - L469 YVK - 05 Jun 2022 Maybe GNE's approach that they're taking now would've worked before covid? But at this time, perhaps a back to basics approach with a single corporate identity (with sub-branding for areas and generic XLines) will put GNE in the best possible position moving forward? RE: Go North East: Major Service Changes July 2022 - DeltaMan - 05 Jun 2022 (05 Jun 2022, 9:02 am)L469 YVK wrote Maybe GNE's approach that they're taking now would've worked before covid? But at this time, perhaps a back to basics approach with a single corporate identity (with sub-branding for areas and generic XLines) will put GNE in the best possible position moving forward? I am pretty sure there was a MG video stating passenger numbers were increasing before the pandemic. RE: Go North East: Major Service Changes July 2022 - Andreos1 - 05 Jun 2022 (05 Jun 2022, 7:36 am)Dan wrote I see it didn’t take someone very long!Just had a look at some of the replies and it looks like someone already did it earlier in the week https://twitter.com/paulmch/status/1532042703734726657?t=hZkIABDhqtEObqdzZUXGGg&s=19 RE: Go North East: Major Service Changes July 2022 - DH9 - 06 Jun 2022 Reading the above and looking at the cancellations still happening, it reads as though they can't recruit the drivers and are blaming everyone but themselves. RE: Go North East: Major Service Changes July 2022 - KingSlayerRBLX - 06 Jun 2022 I hope with the changes coming that some services can be saved such as the X46, good routes that dont deserve to go yet! RE: Go North East: Major Service Changes July 2022 - Unber43 - 06 Jun 2022 (06 Jun 2022, 7:17 pm)KingSlayerRBLX wrote I hope with the changes coming that some services can be saved such as the X46, good routes that dont deserve to go yet!Just think, GNE brought in 7(i think) brand new Streetdecks for the X45/46 at every 15 mins, two years later, the frequency has halved and loads of runs don't make money. If they get rid of the X46, keep the X45 at every 20 mins When do you think we'll find about about the final changes, and do you think any of GNE's decisions will have been reversed without Gov. Funding? RE: Go North East: Major Service Changes July 2022 - Jack Gill - 06 Jun 2022 (06 Jun 2022, 7:23 pm)Unber43 wrote GNE brought in 7(i think) brand new Streetdecks for the X45/46 at every 15 mins, two years later, the frequency has halved and loads of runs don't make money. RE: Go North East: Major Service Changes July 2022 - L469 YVK - 06 Jun 2022 (06 Jun 2022, 7:23 pm)Unber43 wrote Just think, Original plans and frequencies for Consett (pre-covid) were X30: - 4x E400MMC (1x on the original X1 order before StreetDeck swap) - Every 30 mins to Stanley, every 60 mins to Consett X31/X45/X46: - X31 every 30 mins - X45/X46 every 10-20 mins (every 10 combined with X47 on common sections) - 13x StreetDeck X47/X70/X71: - X47 every 30 mins (every 10 combined with X45/X46 on common sections) - X70/X71 every 60 mins each (every 30 combined on common sections) - 9x StreetDeck X5/X15: - X5/X15 every 60 mins each (every 30 combined on common sections) - 4x StreetDeck RE: Go North East: Major Service Changes July 2022 - Andreos1 - 06 Jun 2022 (06 Jun 2022, 7:17 pm)KingSlayerRBLX wrote I hope with the changes coming that some services can be saved such as the X46, good routes that dont deserve to go yet!You mean titivations and paint jobs don't work? Stone the crows! What about upgrading nearly new tables? Can't remember if the vehicles allocated to these routes got table upgrades or not. RE: Go North East: Major Service Changes July 2022 - Michael - 10 Jun 2022 Changes on VOSA for the 24 July 2022: Variation: PB0003954/732 Variation GO NORTH EAST LIMITED 2 (2, 2A) Silksworth Washington PB0003954/557 Variation GO NORTH EAST LIMITED 69 (69) Winlaton Wardley PB0003954/733 Variation GO NORTH EAST LIMITED 4 (4) Houghton-le-Spring Heworth Metro PB0003954/735 Variation GO NORTH EAST LIMITED 8 (8, 8A) Sunderland Stanley PB0003954/771 Variation GO NORTH EAST LIMITED 91 (91) West Chirton Team Valley South PB0003954/365 Variation GO NORTH EAST LIMITED X15 (X15, X5) Durham Castleside PB0003954/805 Variation GO NORTH EAST LIMITED 39 (39, 39A, 39B) Pennywell Doxford International PB0003954/824 Variation GO NORTH EAST LIMITED X10 (X10) Peterlee Middlesbrough PB0003954/1102 Variation GO NORTH EAST LIMITED X30 (X30, X31) Stanley Newcastle PB0003954/1209 Variation GO NORTH EAST LIMITED 47 (47) Shotley Bridge Hospital Newcastle PB0003954/367 Variation GO NORTH EAST LIMITED X45 (X45) Hownsgill Industrial Estate Newcastle PB0003954/763 Variation GO NORTH EAST LIMITED 937 (937) Chester-le-Street Team Valley PB0003954/806 Variation GO NORTH EAST LIMITED 35 (35, 35A) Boldon Low Moorsley PB0003954/809 Variation GO NORTH EAST LIMITED 34 (34) Waldridge Park Ouston PB0003954/823 Variation GO NORTH EAST LIMITED X10 (X10) Newcastle Peterlee PB0003954/86 Variation GO NORTH EAST LIMITED 93,94 (93, 94) Gateshead Gateshead PB0003954/285 Variation GO NORTH EAST LIMITED 53,54 (53, 54) Newcastle Newcastle PB0003954/769 Variation GO NORTH EAST LIMITED 50 (50) Durham South Shields PB0003954/1137 Variation GO NORTH EAST LIMITED 57 (57) Wardley Newcastle PB0003954/1211 Variation GO NORTH EAST LIMITED 78 (78) Sunderland Consett PB0003954/720 Variation GO NORTH EAST LIMITED V1 (V1, V2) Consett Consett PB0003954/559 Variation GO NORTH EAST LIMITED 10 (10, 10A, 10B) Blackhall Mill Newcastle PB0003954/686 Variation GO NORTH EAST LIMITED 58 (58, X58) Follingsby Amazon Newcastle PB0003954/777 Variation GO NORTH EAST LIMITED 60 (60) Sunderland Parkside PB0003954/779 Variation GO NORTH EAST LIMITED 56 (56) Sunderland Newcastle PB0003954/296 Variation GO NORTH EAST LIMITED 49,49A (49, 49A) Gateshead Winlaton PB0003954/351 Variation GO NORTH EAST LIMITED 27 (27) South Shields Newcastle PB0003954/364 Variation GO NORTH EAST LIMITED X71 (X71, X72) Stanley Newcastle PB0003954/822 Variation GO NORTH EAST LIMITED N21 (21, N21) Newcastle Durham University College PB0003954/795 Variation GO NORTH EAST LIMITED 65 (65) Seaham Durham PB0003954/801 Variation GO NORTH EAST LIMITED 20 (20) Durham Sunderland PB0003954/1079 Variation GO NORTH EAST LIMITED X6 (X6) Peterlee Sunderland PB0003954/1093 Variation GO NORTH EAST LIMITED 5 (5, 5A) Jarrow South Shields PB0003954/1165 Variation GO NORTH EAST LIMITED 61 (61, 861) Peterlee Sunderland PB0003954/1179 Variation GO NORTH EAST LIMITED 21 (21) Brandon Newcastle PB0003954/1203 Variation GO NORTH EAST LIMITED 9 (9) Jarrow Sunderland PB0003954/1204 Variation GO NORTH EAST LIMITED 16 (16, 16A, 16B) Hownsgill Industrial Estate Durham PB0003954/1214 Variation GO NORTH EAST LIMITED 96 (96) Metrocentre Gateshead PB0003954/1216 Variation GO NORTH EAST LIMITED 97 (97) Metrocentre ASDA Newcastle PB0003954/1222 Variation GO NORTH EAST LIMITED 51, 52 (51, 52) Gateshead Newcastle PB0003954/1251 Variation GO NORTH EAST LIMITED 6 (6) Lanchester Newcastle PB0003954/1208 Variation GO NORTH EAST LIMITED 38 (38) Sunderland Docks Cancellation PB0003954/651 Cancellation GO NORTH EAST LIMITED 808 (808D) Castleside Consett Academy PB0003954/762 Cancellation GO NORTH EAST LIMITED 25 (25) Langley Park Newcastle PB0003954/1212 Cancellation GO NORTH EAST LIMITED 82 (82) Birtley Barmston Court PB0003954/1218 Cancellation GO NORTH EAST LIMITED V3 (V3) The Dene Consett PB0003954/1230 Cancellation GO NORTH EAST LIMITED 28S (28S) Pelton Schools Lord Lawson of Beamish Academy PB0003954/1231 Cancellation GO NORTH EAST LIMITED 28 (28, 28A, 28B) Newcastle Chester-le-Street PB0003954/659 Cancellation GO NORTH EAST LIMITED 448 (448) Bedlington Station Guide Post PB0003954/772 Cancellation GO NORTH EAST LIMITED 85 (85, 85A) Washington Galleries Concord PB0003954/1101 Cancellation GO NORTH EAST LIMITED 31 (31) Stanley Stanley PB0003954/1139 Cancellation GO NORTH EAST LIMITED 836 (836D) Crookgate Tanfield School PB0003954/1207 Cancellation GO NORTH EAST LIMITED 30 (30) Quaking Houses Stanley PB0003954/1210 Cancellation GO NORTH EAST LIMITED 55 (55) Peterlee Sunderland PB0003954/1213 Cancellation GO NORTH EAST LIMITED 84 (84, 84A) Rickleton Concord PB0003954/1220 Cancellation GO NORTH EAST LIMITED X62 (X62) Peterlee Durham PB0003954/1227 Cancellation GO NORTH EAST LIMITED 734 (734) Chester-le-Street Chester-le-Street PB0003954/520 Cancellation GO NORTH EAST LIMITED 29 (29) Kibblesworth Gateshead PB0003954/658 Cancellation GO NORTH EAST LIMITED 434 (434) Bedlington Station Linton PB0003954/1141 Cancellation GO NORTH EAST LIMITED X21 (X21) Durham Newcastle PB0003954/1142 Cancellation GO NORTH EAST LIMITED X21 (X21) West Auckland Durham PB0003954/1215 Cancellation GO NORTH EAST LIMITED 62 (62, 62A) Peterlee Sunderland New PB0003954/1273 New GO NORTH EAST LIMITED 24 (24) Sunderland South Shields PB0003954/1271 New GO NORTH EAST LIMITED 84 (84, 85) Coach Road Estate Concord PB0003954/1272 New GO NORTH EAST LIMITED X21 (X21) West Auckland Newcastle |
