Arriva State of The Fleet - Printable Version
+--- Thread: Arriva State of The Fleet (/showthread.php?tid=4386)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
RE: Arriva State of The Fleet - Storx - 23 Jan 2026
(23 Jan 2026, 1:46 pm)Kuyoyo wrote The whole point of the new E400MMCs going to Whitby is to displace the now-aged B9TLs away from the highly demanding work they've been used on since new on the X93/X94 corridor (don't forget the X94 boards spend most of their day running between Whitby and Scarborough - the part with probably the most demanding of the hills along the corridor) plus given they are only 5 years younger than 7609/10, they'll soon be too old for the P&R contract in any case, hence the reason for 7594/5 being earmarked for that if Arriva retain it. I understand from a source within Arriva, the B9s may already have a new home lined up under the original plans.
I also have been told why the new E400MMCs for Ashington are intended to replace 7541-52 - those have smaller fuel tanks than the newer examples, which means they have issues when being used on certain Morpeth Express boards as a result (not due to the fuel tank but Stockton once had something similar happening when 1512 was based at the depot as the Sapphire spare - it almost always ended up on the same board, which happened to be the first bus out of the depot and the last bus into the depot, and was known to be running on fumes when it got back in).
Aye I get that, but surely they'd be good enough for 2/6 boards on the X93/X94 if you switched them around daily. Arguably no worse than the ex B7TL's from London which coped well enough for a couple year anyway?
But I get why aswell, obviously the ideal solution is to deal with the chronic shortage of reasonable deckers across the North East, but can't really expect them to renew the whole fleet overnight. Hopefully 2027 will see a bigger push to sort out Blyth and Ashington who are both desperate for more really.
Unsure what you could do with 7401-6 and 7522-7533 as they really badly need to be retired to pottering around estates on a city route but there's not really anything in the North East.
RE: Arriva State of The Fleet - PH - BQA - 23 Jan 2026
(23 Jan 2026, 1:46 pm)Kuyoyo wrote I also have been told why the new E400MMCs for Ashington are intended to replace 7541-52 - those have smaller fuel tanks than the newer examples, which means they have issues when being used on certain Morpeth Express boards as a result (not due to the fuel tank but Stockton once had something similar happening when 1512 was based at the depot as the Sapphire spare - it almost always ended up on the same board, which happened to be the first bus out of the depot and the last bus into the depot, and was known to be running on fumes when it got back in).
Genuinely mental reasoning. They’re capable of doing most X18 boards, it was only ever the couple of double Berwick X15 boards that they (occasionally) got swapped off.
Even outside of those, there are 6 X20 boards and 20 X21/35 and X22 boards they could be used on. A batch of 12 buses, 26 boards which they are completely suitable for.
Crucially, they’re all more than capable of actually doing the express work - the 8 Streetlites, 09/10/61-plate Pulsars, and the 14/64/15-plate E400s are not.
Moving an entire batch of buses away because of (at most) a couple of boards which they ‘may’ struggle with is completely illogical - especially when there are far, far larger issues.
(23 Jan 2026, 9:08 pm)PH - BQA wrote Crucially, they’re all more than capable of actually doing the express work - 09/10/61-plate Pulsars.
Must say I do think they should've been kept but more for these. It's absolutely bonkers that there's currently 31 Pulsars in Northumbria for a realistic PVR of 11 (5x 57/57A, 5x X9, 1x 553)
Like imo in an ideal world it should be something like
1602 - 1606 | 57/57A (the shorter vehicles are also inappropiate at Darlington and would benefit some of the tight streets especially Tillmouth Avenue)
1574 - 1577 | 1
1578 - 1581 | 2
1607 / 1582 / 1583 | Ashington Spares
1499 | 553
1500 - 1505 | X9 / Spare
Every other single Pulsar out and no singles anywhere near the expresses, yet it appears there's been an order put in to displace 25 deckers...
(23 Jan 2026, 9:32 pm)Storx wrote Must say I do think they should've been kept but more for these. It's absolutely bonkers that there's currently 31 Pulsars in Northumbria for a realistic PVR of 11 (5x 57/57A, 5x X9, 1x 553)
Absolutely agree. It’s a clear indication to me that, for all the noise, the new management are just as incompetent at those that went before.
The amount of standing load Pulsars and Streetlites I’ve observed leaving Newcastle recently is too many to list.
Getting rid of significantly younger and more capable buses ahead of things which barely make it through a day of service is beyond idiotic.
The current media attention on their operation in SE Northumberland is starting to expose them for the morons they are. I’ve been pointing it out for ages on here - the engineering issues, the horrific decision making, the lack of accountability.
(23 Jan 2026, 10:26 pm)PH - BQA wrote Absolutely agree. It’s a clear indication to me that, for all the noise, the new management are just as incompetent at those that went before.
Yeah I don't want to be overcritical of the management but can't disagree. It's not like it's something totally impossible needing investment as what's coming in could do it easily ie.
12x New E400MMC's (Ashington), 12x Pulsar Out
13x New E400MMC's (Blyth), 7601-7615 Withdrawn
6x 16 Plate E400MMC Durham to Darlington, 6x Streetlite to Ashington, 6 Pulsar Out
1512/1513 and 1579/80 straight swap, 2 Pulsar Out
14x New Electrics, 12 Oldest E400 Withdrawn, 2 Pulsar Out
61 Plate Pulsars to Darlington to displace oldest Pulsars with a future bid in to upgrade the likes of the 1, 5, 7, X66 and X67 which deserve new buses.
Would make a massive massive difference that imo and you've got the DB300's out as planned. It's not like they can exactly come out with x needs buses more because Ashington is absolutely chronic because of the fleet in recent months.
RE: Arriva State of The Fleet - Shrek - 24 Jan 2026
Interesting when you point these things out. Maybe shows there is more logic in their plans than we all know, and there are some necessities in the moves they're making which we aren't privy to the information on.
RE: Arriva State of The Fleet - Storx - 24 Jan 2026
(24 Jan 2026, 10:18 am)Shrek wrote Interesting when you point these things out. Maybe shows there is more logic in their plans than we all know, and there are some necessities in the moves they're making which we aren't privy to the information on.
It's only an issue if the buses are actually meant to be on those routes though? The buses were purchased for the X21/X22 and there's been nothing else sent to Ashington, bar a whole load of Pulsar's which are not appropiate, to replace them off there.
Surely the discussion should be, we don't have enough deckers for the X14/X15/X18 and are having to take allocations off the X21/X22 which in turn means we are having overcrowding issues with saloons on peak runs? Therefore it's unreliable saloons leaving, especially the 4 which were traded for the E400MMC's which were sent to Whitby which arguably led to the shortages in the first place...
RE: Arriva State of The Fleet - L469 YVK - 24 Jan 2026
Will also be interesting over the years to see whether or not ADL will modify the E400MMC to include the new 7 speed Voith gearbox like the Wright Ultroliner.
Seen a video of one of GNE's examples, and looks very comfortable on the Washington Highway with plenty of steam left!
RE: Arriva State of The Fleet - PH - BQA - 26 Jan 2026
(24 Jan 2026, 11:53 am)Storx wrote It's only an issue if the buses are actually meant to be on those routes though? The buses were purchased for the X21/X22 and there's been nothing else sent to Ashington, bar a whole load of Pulsar's which are not appropiate, to replace them off there.
Exactly. Purchased for the X21/22, and with new deckers arriving they definitely shouldn't be straying from there? From memory the Pulsars also can't do the mileage of a couple of the boards, yet they're happy to keep those (make that make sense). It's such a non-issue, that it screams someone has made a bad decision and they're desperate to try and cover their back. To show how irrelevant it is, check 7547 on 21 January, 7549 on 17 January, 7543 on 6 January - all three comfortably finished X18 midnights. I can't find any example over the past few weeks where a 17-plate has been swapped off an X18 midnight in the evening either - indicating both that they are trusted to finish them, and that the 72-plates are generally allocated anyway...
The situation at Ashington is increasingly bad. There were multiple hour long gaps in the X21, X22, and 35 today as two consecutive boards were dropped on each service - AGAIN. Clear that the supervisors aren't getting monitored as they should be by management, if I was that incompetent at my job I'd expect to be on a PIP or out of the door. They're back to using clapped out Pulsars on express work again, which is having the expected (to anyone with half a brain cell) consequences. 1512 failed on an X20 this morning, 1404 was hauled off an X18 on Saturday and failed twice today on the 35, 1462 made it to Longframlington and back today before failing (after earlier failing on an X21). They're completely inappropriate for the work they're being used on, and nothing is being done to remedy the situation.
I can almost see the press release now. They'll reduce frequencies citing lower passenger numbers, entirely because they aren't running half of the services, and the death spiral will continue - rather than seeing if passenger numbers return to where they were when they actually had functional vehicles. They seem to have no appreciation that franchising could, and should, wipe every single one of them out of a job - along with GNE it would be a disgrace if they held onto the current monopoly that they have if they don't quickly make improvements.
People were very vocal on here in recent months when engineering staff were replaced, it is interesting how silent they now are given the situation is getting significantly worse on a daily basis. New engineering manager clearly doesn't know what he is doing, local management clearly have no contingency plan, and once again the 'armchair experts' on here were correct in their criticism.
It would be interesting if it was having literally any impact on operations. By the time they'd be anywhere close to being out of fuel, which from memory was close to the end of a double Berwick X15 board, it was always far enough into the evening that buses were readily available at Morpeth or Alnwick to swap onto them. I'd also point out here that the Volvo Olympians that worked the Alnwick routes for years had the same 'issue' - maybe operational staff were less lazy back then...
Realistically they should be allocated to the X21/22 anyway, as pointed out by Storx, so it's a complete non-issue.
Truthfully I don't think they've got a clue what they're doing, as if this was such a huge problem why has it not been addressed at any point since they were new 9 years ago? They're past the halfway point in their life now, they should be settling onto less demanding work (like the X21/22...) anyway with new stock being delivered.
RE: Arriva State of The Fleet - Storx - 26 Jan 2026
(26 Jan 2026, 10:56 pm)PH - BQA wrote Exactly. Purchased for the X21/22, and with new deckers arriving they definitely shouldn't be straying from there? From memory the Pulsars also can't do the mileage of a couple of the boards, yet they're happy to keep those (make that make sense). It's such a non-issue, that it screams someone has made a bad decision and they're desperate to try and cover their back. To show how irrelevant it is, check 7547 on 21 January, 7549 on 17 January, 7543 on 6 January - all three comfortably finished X18 midnights. I can't find any example over the past few weeks where a 17-plate has been swapped off an X18 midnight in the evening either - indicating both that they are trusted to finish them, and that the 72-plates are generally allocated anyway...
Aye it's a complete mess isn't it?
Seems like Blyth is now heading down a similar path with breakdowns and cancellations so whatever they're doing isn't working. Believe Blyth has the scope for 9 vehicles VOR before things hit the fan and according to Bus Times, usual caveats, they were 10 down for most of the day and there's noticeable gaps on the 306/308.
Must admit I can see the X21/X22 frequency reduction coming mind and that's the true reasons for the rumoured 35/X21 split, very defeatest, but with Bedlington Station opening soon I can see the X21 taking a right clattering because anyone sane needing to go to town around there ain't going to be using the bus which 'might' turn up. It's arguably the most central station on the line in terms of housing aswell.
It'd be an idiotic decision mind, because the train will have it's own issues, but it's realistically the only route which can be cut.
RE: Arriva State of The Fleet - Storx - 27 Jan 2026
Just to add, there's 100% issues at Blyth now as there's multiple cancellations showing in the app.
Appears to be at least 2 boards on the X7/X8/X10/X11 missing today, a board on the X9, and at least one board on the 306/308 aswell checking the app.
RE: Arriva State of The Fleet - PH - BQA - 27 Jan 2026
(27 Jan 2026, 2:53 pm)Storx wrote Just to add, there's 100% issues at Blyth now as there's multiple cancellations showing in the app.
Looks like they've finally been forced to give Ashington some help - in the form of 7522 (and only 7522).
It's mental. They've got 14 brand new BYDs sat there which can't be used yet because management didn't get the chargers installed in time. If they were in service now, which they should have been, then you could have sent 7501-7/9 and 7557-62 across to Ashington to trundle around on the 1/2/57 until their new stock arrives.
(27 Jan 2026, 5:45 pm)PH - BQA wrote Looks like they've finally been forced to give Ashington some help - in the form of 7522 (and only 7522).
Surprised they've made that move today considering Blyth can't run a full day's service either and dropping boards on the X7-X11 is a hell of a lot worse than the 35/X21/X22 as it's a hourly gap. The 43/44/45 being off the table since the 43 is partially subsidised.
Agreed though, personally I hope they keep them regardless when the electrics go into service and kick out the Pulsars instead. Bar the 6 on the X9 and 553, Pulsars at Blyth are a nuisance as an understatement because there's no-where for them to go and they are, I believe, part of the 43/44/45 allocation currently.
(27 Jan 2026, 6:50 pm)Storx wrote Surprised they've made that move today considering Blyth can't run a full day's service either and dropping boards on the X7-X11 is a hell of a lot worse than the 35/X21/X22 as it's a hourly gap. The 43/44/45 being off the table since the 43 is partially subsidised.
Ashington had 9, maybe 10, boards off at one stage so I don't think there was much choice to be honest.
I don't understand how Yorkshire have had 50+ new vehicles yet nothing has been sent up here as short term cover until the new NE vehicles arrive. Even if they're due to be scrapped, surely it makes sense to send them up here for a last hurrah before their final journey - they literally cannot be worse than no bus at all.
RE: Arriva State of The Fleet - L469 YVK - 27 Jan 2026
IMO, Arriva should have nothing older than the 14/64/15 plate E400 Classics kicking around Blyth or Ashington.
Everything older should be withdrawn.
I'd go as far to say that the newer E400 classics should just be on the 306 & 308. Bar the X9/553 and the 1/2, everything else at Blyth and Ashington should have newer deckers.
I know it's unlikely, but it would make sense for 7401-06 to see their days out on the 35 if it goes standalone with a padded 20 minute frequency.
(27 Jan 2026, 7:38 pm)L469 YVK wrote I know it's unlikely, but it would make sense for 7401-06 to see their days out on the 35 if it goes standalone with a padded 20 minute frequency.
I don't think that is unlikely at all.
(27 Jan 2026, 7:12 pm)PH - BQA wrote Ashington had 9, maybe 10, boards off at one stage so I don't think there was much choice to be honest.
Didn't realise it was that dire up at Ashington, obviously don't see much as it's just the 57/57A down here and it's always prioritised because of the subsidy. Agreed though mind, or even redirect some of the new order up here and then when the later order comes send them to Yorkshire instead (or send the 17 Plates if they're going early once they get a grip)
(27 Jan 2026, 7:38 pm)L469 YVK wrote IMO, Arriva should have nothing older than the 14/64/15 plate E400 Classics kicking around Blyth or Ashington.
Even known I get what you're saying just not sure it's really realistic right now to replace the whole fleet. Personally I'd have:
Ashington:
25x New E400MMC: X14/X15/X16/X18/X20/777
17 Plates + BOTW E400's: X21/X22
Worst E400's: 35
1574 - 1583 (Including 1579/80): 1/2
1602 - 1607: 57/57A
Blyth:
1499 - 1505: 553/X9
Electrics: 43/44/45
7616 - 7637: X7/X8/X10/X11
72 Plate E400MMC's: 306/308
4x E400: Spares
Out:
1512/1513: Durham (Swap for the 2 Streetlites)
57/58 E400's: Withdrawn
59 DB300's: Withdrawn
09/59/10 Pulsars: Withdrawn
61 Pulsars: Spread to whoever needs some / withdrawn
1602 - 1607 replaced at Darlington by the E400MMC's from Durham
Should be doable with what's due anyway, if the 17 Plates stayed, and would improve Northumbria massively and give some fleet tidying up between the depots with the next order in 2027 focusing on the X7/X8/X10/X11 whether that's electric or diesel then that's open.
(27 Jan 2026, 8:17 pm)Storx wrote Even known I get what you're saying just not sure it's really realistic right now to replace the whole fleet. Personally I'd have:
Ashington:
Worst E400's: 35
1602 - 1607: 57/57A
Blyth:
1499 - 1505: 553/X9
Electrics: 43/44/45
4x E400: Spares
Out:
I think I'd be going with something like the below, purely because the Streetlites are completely incapable of doing any of the express work in this part of the region but can handle the town work further south. Fully aligned on what needs to be baked bean tins by the end of the year though.
Ashington:
X18 (16 boards): 16x new E400s
X20/30 (6 boards): 7563-7568
X21/22 (15 boards): 7541-7552, 7569-7571
35 (5 boards): 7401-7405
1/2 (8 boards): 1512-1519
57/A (5 boards): 1500-1504
434 (1 board): 3052
Spare (7): 1505, 3051, 7406, 7572-7575
Blyth:
X7/8/10/11 (18 boards): 7616/7/20-25/28-37
306/308 (14 boards): 9x new E400s, 7576/7, 7522/4/5
X9 (5 boards): 7529-33
553 (1 board): 1499
43/44/45 (14 boards): 14x BYD
Spare (6): 7526-8, 7553/4/6.
Out:
1574-83 (excl. 1579/80) to replace Pulsars in ADC - indirectly swapped for 1514-9.
57/58-plate E400s - Withdrawn
59-plate DB300s - Withdrawn
09/59/10-plate Pulsars - Withdrawn
Functional (I'd honestly limit this to 1479 and the Blyth ones - the Ashington interurban ones are dogs) 61-plate Pulsars to ADC to replace any outstanding 09/59/10-plates.
Then look to replace the 61-plate DB300s within the next couple of years, I'd think you could possibly replace the X7-11 allocation with electrics?
(27 Jan 2026, 9:01 pm)PH - BQA wrote I think I'd be going with something like the below, purely because the Streetlites are completely incapable of doing any of the express work in this part of the region but can handle the town work further south. Fully aligned on what needs to be baked bean tins by the end of the year though.
Ashington:
434 (1 board): 3052
Blyth:
553 (1 board): 1499
Out:
Aye not too dissimilar, just the Streetlite's for me I'm not sure I agree. Think they'd actually be useful for the 1/2/57/57A as they're pretty piss easy routes really. The short base ones are a complete headache aswell and would be suited for the 57/57A - I'd assume they'd be able to scrape around the 434 aswell if a decker can do it when the Solo SR's break (as usual). They can always do the 35 aswell when 7401-6 are off the road as there's not a cat hell in chance they'll be in service for more than a week.
Not many places down South where there's going to be town work free really; since the electrics and I'd assume some of the new singles at Stockton are going to take a fair chunk of it out and they'd be horrid on the likes of the 28/29 or X25/X26 or what not. The newer Pulsar's would be decent little workers for those for a few years though and replacements for the X12 aswell since there's nothing due for Durham bar the electrics - as far as I'm aware.
RE: Arriva State of The Fleet - davao123 - 27 Jan 2026
There are about 6 or 7 e200s in Yorkshire just sat there doing nothing, at Selby.  If they are that short it makes perfect sense to get some of these e200s in a stop gap measure,  as it's much better than keep missing boards and services being cancelled.
Personally Yorkshire shouldn't be getting Ashington's 17 plates,  Franchising in Liverpool would release a lot of 64 plate e400s later on in the year, and Yorkshire can get some of those instead, even if they are 12 years old, still bring the fleet age down replacing 58 plate e400s.
RE: Arriva State of The Fleet - Nerd4321 - 30 Jan 2026
1389 has been on the 553 since Monday. Checking the website for euro 6 check shows it is now not allowed in Newcastle without paying £50 fine. So Blyth got a Pulsar no longer allowed in town how fun
RE: Arriva State of The Fleet - Shrek - 31 Jan 2026
(30 Jan 2026, 4:50 pm)Nerd4321 wrote 1389 has been on the 553 since Monday. Checking the website for euro 6 check shows it is now not allowed in Newcastle without paying £50 fine. So Blyth got a Pulsar no longer allowed in town how fun
That's not an issue when they have a route they can put it on, and it will only be short term as we're probably a month away from the BYD getting into service.
RE: Arriva State of The Fleet - Nerd4321 - 31 Jan 2026
(31 Jan 2026, 10:02 am)Shrek wrote That's not an issue when they have a route they can put it on, and it will only be short term as we're probably a month away from the BYD getting into service.
I very highly doubt that. When I last went past Blyth depot a few weeks back. No works seems to have been started to install the chargers
RE: Arriva State of The Fleet - PH - BQA - 31 Jan 2026
1389 was on the 308 today.
(31 Jan 2026, 8:19 pm)PH - BQA wrote 1389 was on the 308 today.
Weirdly tracking as 7501
RE: Arriva State of The Fleet - Shrek - 01 Feb 2026
(31 Jan 2026, 1:18 pm)Nerd4321 wrote I very highly doubt that. When I last went past Blyth depot a few weeks back. No works seems to have been started to install the chargers
I don't think there was any expectation that it would have started yet, but that doesn't mean it won't be finished on time either.
RE: Arriva State of The Fleet - solsburian - 01 Feb 2026
(01 Feb 2026, 3:19 pm)Shrek wrote I don't think there was any expectation that it would have started yet, but that doesn't mean it won't be finished on time either.
It might also explain why the suspected public launch of the BYDs is in March.
RE: Arriva State of The Fleet - PH - BQA - 02 Feb 2026
Disgraceful performance from Ashington today. 0651/0711 X21 both missed this morning, as did the 0704/0729 X22s - essentially the 4 services which get people to work. Four in a row, to be clear.
Currently 3 out of 7 X22s in service, and 9 out of 13 X21/35s. There’s been a 1 and a 2 missing all day too. 10 services off the road yet again - nearly 20% of the PVR. Absolute shambles.
Drafting in vehicles from elsewhere is clearly a wild concept to those running the place.
RE: Arriva State of The Fleet - Shrek - 02 Feb 2026
(02 Feb 2026, 3:30 pm)PH - BQA wrote Disgraceful performance from Ashington today. 0651/0711 X21 both missed this morning, as did the 0704/0729 X22s - essentially the 4 services which get people to work. Four in a row, to be clear.
Is that going by bus times. Someone i work with was in on time and normally gets the 7.11 X21, and they weren't complaining so I'm guessing it turned up. Could some be tracking issues?
RE: Arriva State of The Fleet - Storx - 02 Feb 2026
(02 Feb 2026, 6:48 pm)Shrek wrote Is that going by bus times. Someone i work with was in on time and normally gets the 7.11 X21, and they weren't complaining so I'm guessing it turned up. Could some be tracking issues?
Can't confirm how many, but I had a little look at the app earlier today, around 11am, and there was definitely, at least
2x 306/308
3x X21/X22/35
1x 1
1x 2
1x 57/57A
1x 43/44/45
Cancelled boards today.
Might have improved, might have got worse and that was the ones actually reported in the Arriva app but it was bleak either way in Northumbria - again.
(The 7.11 started short at Ashington according to BusTimes btw, seems to be a lot of shorts today).
Btw does anyone know if the Ashington issues are all vehicle problems or whether there's driver related issues now aswell? Seen there's cancelled X22's tonight and there's absolutely zero rationale why there's cancellations at night due to vehicles.
