Go North East: Upcoming Service Changes v2 - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Go North East (https://northeastbuses.co.uk/forumdisplay.php?fid=54) +--- Thread: Go North East: Upcoming Service Changes v2 (/showthread.php?tid=1832) |
RE: Go North East: Upcoming Service Changes v2 - callum2015 - 15 Jul 2017 (15 Jul 2017, 5:39 pm)park5354 wrote No where else to split X10 to put it on domestic hours. After a quick look at googlemaps,would another solution for X10 be join A19 as normal from Norton,exit at Peterlee then via Burnhope Way to Peterlee BS,Up Easington Way then re-join the A19 at Little Thorpe (so the same as the X9 route) ? would still make the X10 Slightly quicker than the X9 by avoiding Billingham but not sure if it would be quicker than diverting it via Dalton Park RE: Go North East: Upcoming Service Changes v2 - BusLoverMum - 15 Jul 2017 (15 Jul 2017, 11:49 am)citaro5284 wrote Aye you right there Michael, going southbound, you have to pass it to come off the A19 and then double back slightly don't you ? Yes, you do (just checked with Husband. Not that being a man makes him more knowledgeable, more that he simply knows his way around there by road pretty well!!) And the road into the retail park gets quite congested at times. The 22 is always late on Sundays when Dalton Park is busy. RE: Go North East: Upcoming Service Changes v2 - BusLoverMum - 15 Jul 2017 (15 Jul 2017, 5:11 pm)cbma06 wrote On a normal day by the time the X10 pulls off the A19 and gone into dalton park and back on the A19, the X10 would of already passed Peterlee, if there's an event on at dalton park then the X10 would probably of reached norton or Stockton by the time it rejoined A19, can see this as a bad idea, what's wrong with passengers alighting at A19 northbound and then jump on the X6 to dalton park at the same bus stop and doing southbound get off at moorcock and walk around the corner to jump on the X10 southboundThat would only work with 2 conditions: 1: The connection time between the X10 and X6 was short enough not to put people off, in both directions, and long enough not to be a right PITA if one of the buses is 10 minutes late. People don't want to be waiting around for an hour because they've missed their connection. 2: People particularly don't want to be waiting around in a location that has no shelter and nothing to do. (as an illustration I missed my connection at Durham bus station, by a minute, yesterday, leaving me with 29 minutes to kill. As it happened, I was carrying nothing, so the centre of Durham is easy enough to kill half an hour in, even after many of the shops have shut. If it had been raining, most of the bus station offers protection from that, so long as you avoid the holes in the rood and don't trip over the buckets! I would be less than comfortable if I had been stranded at the Moorcock at 5:30pm, though) (15 Jul 2017, 6:33 pm)callum2015 wrote After a quick look at googlemaps,would another solution for X10 be join A19 as normal from Norton,exit at Peterlee then via Burnhope Way to Peterlee BS,Up Easington Way then re-join the A19 at Little Thorpe (so the same as the X9 route) ? would still make the X10 Slightly quicker than the X9 by avoiding Billingham but not sure if it would be quicker than diverting it via Dalton ParkBillingham's bus services have been decimated enough already. You need to remember that a bus route is more than its end points. There are two completely different Durham-Sunderland services, for example, but they have little more than a mile of their routes in common. The ANE 22 passes my front door. The GNE 20/20A passes no closer than 4 miles away and is no good to me unless I catch a 22 to meet it. (and yes, I'm aware that pedants will remind me that the 20 goes through Sunderland to South Shields, these days, but you can make the same comparison of the 20/20A and the 50 if the start and end points matter that much. They don't even have any of their respective routes through Durham in common!) RE: Go North East: Upcoming Service Changes v2 - L469 YVK - 15 Jul 2017 Bear in mind that although the X10 will serve Dalton Park, the long layover at Eldon Square (like the X21 at Bishop Auckland and the 10 at Hexham) would compensate for this as well as the PVR increase. Are the new B5TLs equipped with Tachographs? Also, will the X9/X10 be driven by all drivers or just a dedicated rotas as now? Go North East: Upcoming Service Changes v2 - 2bagstew - 15 Jul 2017 (15 Jul 2017, 10:05 pm)L469 YVK wrote Bear in mind that although the X10 will serve Dalton Park, the long layover at Eldon Square (like the X21 at Bishop Auckland and the 10 at Hexham) would compensate for this as well as the PVR increase. I can't see the B5TL been fitted with Tachos as the service been been split X9 (X10) Newcastle - Peterlee Bus Station X9 (X10) Dalton Park - Middlesbrough Sent from my iPhone using Tapatalk RE: Go North East: Upcoming Service Changes v2 - Jamie M - 16 Jul 2017 (15 Jul 2017, 11:12 pm)2bagstew wrote I can't see the B5TL been fitted with Tachos as the service been been split We'll be seeing South Tyne versas on those stints before too long, then! Sent from my SM-G920F using Tapatalk Go North East: Upcoming Service Changes v2 - James101 - 16 Jul 2017 The X10 currently has very many passengers happy not serving Dalton Park. Increasing journey times will just push more passengers toward the train when Northern Connect starts. I'd think to keep within the legislation every X10 will have to go through Dalton Park, including the early morning southbound journeys. Sounds pretty pointless, and potentially irritating, considering the shops and restaurants don't open until 10am. I'd hazard a guess there will be more passenger inconvenienced by the route change than additional passengers attracted by it, despite the operational advantages GNE achieve. Sent from my iPhone using Tapatalk RE: Go North East: Upcoming Service Changes v2 - L469 YVK - 16 Jul 2017 (16 Jul 2017, 12:13 am)Jamie M wrote We'll be seeing South Tyne versas on those stints before too long, then! Not exactly, I think the pecking order depending on availabilty would go like this on the assumption that 3x ex-TTX are allocated to the TVT with 3x spares (1x at Hexham + 2x at Riverside) with 6084 also spare: 1.) 6084 2.) 1x of the 2x corporate ex TTX B9s (2x at Riverside with the other at Hexham) 3.) TVT branded B9TL On another note, will the ex TTX B9s be fitted with pushchair bays to make sure that prams can get on without having to potentially wait for the next bus if a Wheelchair or another pushchair is already on? RE: Go North East: Upcoming Service Changes v2 - callum2015 - 16 Jul 2017 (15 Jul 2017, 9:34 pm)BusLoverMum wrote Billingham's bus services have been decimated enough already. You need to remember that a bus route is more than its end points. There are two completely different Durham-Sunderland services, for example, but they have little more than a mile of their routes in common. The ANE 22 passes my front door. The GNE 20/20A passes no closer than 4 miles away and is no good to me unless I catch a 22 to meet it. (and yes, I'm aware that pedants will remind me that the 20 goes through Sunderland to South Shields, these days, but you can make the same comparison of the 20/20A and the 50 if the start and end points matter that much. They don't even have any of their respective routes through Durham in common!) BIB - Sorry if i didnt make it clear,but i ment Billingham would still have the X9 As like present,so they would not see a service reduction & Evenings/Sundays would still have the X10 also like present,i just ment that instead of diverting X10 Via Dalton Park,divert it Via Peterlee (maybe this would be better for the Service suggestion thread) RE: Go North East: Upcoming Service Changes v2 - citaro5284 - 16 Jul 2017 (15 Jul 2017, 10:05 pm)L469 YVK wrote Bear in mind that although the X10 will serve Dalton Park, the long layover at Eldon Square (like the X21 at Bishop Auckland and the 10 at Hexham) would compensate for this as well as the PVR increase. Dedicated rota as now - Could not fancy learning all of Gateshead drivers the route, just for 7 buses on it. Go North East: Upcoming Service Changes v2 - cbma06 - 16 Jul 2017 I wonder if GNE done a passenger consultation onboard the X10, or maybe there should and see what the response is. Sent from my iPhone using Tapatalk RE: Go North East: Upcoming Service Changes v2 - nk55 - 16 Jul 2017 (16 Jul 2017, 7:25 am)cbma06 wrote I wonder if GNE done a passenger consultation onboard the X10, or maybe there should and see what the response is. Sadly very much doubt it, as said previously I think a lot of passengers will be pushed onto the trains. RE: Go North East: Upcoming Service Changes v2 - Dan - 16 Jul 2017 (16 Jul 2017, 9:35 am)nk55 wrote Sadly very much doubt it, as said previously I think a lot of passengers will be pushed onto the trains. The flip side of the coin is that the X9/X10 services don't have enough layover time at either end to recover after incurring delays, and if a bus arrives in 10 minutes late, it's guaranteed to depart late by the time everyone alights and then boards again, meaning that a lot of journeys take more time than scheduled to, already. This change would presumably only add around 5 minutes onto the timetable in either direction (i.e. roughly the same amount of time as what a lot of customers are being inconvenienced by already, due to lack of appropriate layover time), so in reality, this change would just provide a more realistic and achievable timetable, whilst also opening up new, direct links for passengers, which would hopefully grow the services in order to pay for the extra bus being added to the PVR. RE: Go North East: Upcoming Service Changes v2 - Ambassador - 16 Jul 2017 (16 Jul 2017, 9:35 am)nk55 wrote Sadly very much doubt it, as said previously I think a lot of passengers will be pushed onto the trains. Northern Connect is still 2 years away though, to be fair it won't just be the X10 impacted, the new Middlesbrough-Durham-Newcastle service will drive more people onto trains to Durham as the 158s will likely be hitting 90mph on the ECML, that's a threat to any express bus service (aside the twirlys who'll go with the freebie option) to Durham. Interesting times ahead, either way. RE: Go North East: Upcoming Service Changes v2 - tyresmoke - 16 Jul 2017 (16 Jul 2017, 10:00 am)Dan wrote The flip side of the coin is that the X9/X10 services don't have enough layover time at either end to recover after incurring delays, and if a bus arrives in 10 minutes late, it's guaranteed to depart late by the time everyone alights and then boards again, meaning that a lot of journeys take more time than scheduled to, already. I think going into Dalton Park is an interesting move for GNE and the extra bus added to the PVR will, as Dan says, allow for a good amount of layover time at each end of the route. This will be the bigger bonus for the X9/X10 in terms of reducing delays as buses that come in late will depart on time 90% of the time. Expecting Dalton Park to pay for the extra bus added to the PVR may be expecting a bit much though. I wonder whether going half hourly via the Sunday route would have attracted a higher amount of growth? Admittedly this would have increased the journey time further, however I think this would be more than offset by the half hourly frequency attracting people. RE: Go North East: Upcoming Service Changes v2 - Michael - 17 Jul 2017 PB0002400/629 Cancelled (Short notice) GO NORTHERN LTD Route: Chester-Le-Street, Ropery Lane/Durham County Cricket Ground to Newcastle, Eldon Square Bus Station Service number: 21 Service type: Normal Stopping Effective date: 25 Jul 2017 PB0003954/825 Registered (Short notice) GO NORTH EAST LIMITED Route: Chester-Le-Street, Ropery Lane/Durham Cricket Ground to Newcaste, Eldon Square Bus Station Service number: 21 Service type: Normal Stopping Effective date: 25 Jul 2017 RE: Go North East: Upcoming Service Changes v2 - BusLoverMum - 17 Jul 2017 (16 Jul 2017, 10:00 am)Dan wrote The flip side of the coin is that the X9/X10 services don't have enough layover time at either end to recover after incurring delays, and if a bus arrives in 10 minutes late, it's guaranteed to depart late by the time everyone alights and then boards again, meaning that a lot of journeys take more time than scheduled to, already.I agree with this. Apart from the Heworth-Newcastle stint, the X9 an X10 are entirely different route, which means that each one is effectively only hourly for the vast majority of its customers. A missing X9 or X10 is more than a daily occurrence, currently, which amounts to a 2 hour gap in service (because Newcastle - Heworth is more than adequately duplicated by the 27, even if you need to use different stops in Newcastle city centre) Even if you live in Peterlee and work in Newcastle, if your X9 is a no show (ignoring the X10 because it barely skirts by), either because of a faulty vehicle (hopefully will be fixed, by September) or bad traffic (less controllable) then if you have the necessary GNE pass, you're shafted. it's either idle to Sunderland on the 56, be lucky enough to get on an X36 or make your way to Sunderland via Washington (assuming the pass you have covers the relevant zones). Stil takes well over an hour. By the time you've crawled into Peterlee on the X5/6/7, your journey time has more than doubled from the reasonable just under an hour you were banking on. OK if you have no commitments and a strong baldder, but not good if you need to pick up kids from childcare or get to another job or caring role. The only way to speed it up is to pay for a Metro or Stagecoach ticket. 5 extra minutes to reach Dalton park, as annoying as it is is a small consideration, really. RE: Go North East: Upcoming Service Changes v2 - Ambassador - 17 Jul 2017 (17 Jul 2017, 7:11 pm)Michael wrote PB0002400/629 Cancelled (Short notice) T20 Blast buses http://newsroom.gonortheast.co.uk/news/extra-buses-for-durham-county-cricket-club-events-243999 RE: Go North East: Upcoming Service Changes v2 - James101 - 18 Jul 2017 (17 Jul 2017, 10:31 pm)BusLoverMum wrote I agree with this. They could just add another bus into the PVR without diverting via Dalton Park, and they could continue the service 'whole' rather than splitting it. Costly, but not impossible. There seems to be an assumption passengers have to sacrifice something (in this case journey times) in exchange for a reliable service. There's no dressing the change up other than efficiencies for GNE. That in itself is fine, Go-Ahead operate for profit - but it's always irritating when they advertise things like frequency reductions and additional running time as for the customer's benefit. RE: Go North East: Upcoming Service Changes v2 - tyresmoke - 18 Jul 2017 (18 Jul 2017, 9:05 am)James101 wrote They could just add another bus into the PVR without diverting via Dalton Park, and they could continue the service 'whole' rather than splitting it. Costly, but not impossible. There seems to be an assumption passengers have to sacrifice something (in this case journey times) in exchange for a reliable service. Splitting the route will mean the drivers (& buses) will no longer be on EU tachograph regulations. Therefore it'll give them flexibility in what vehicles can be used on the route (everything, basically). No longer will they have to scrap around for tacho fitted buses to replace breakdowns or help with delays etc. No waiting for one to come back in off a 97 or whatever to pinch, they'll be able to send any bus out. This will help massively with flexibility and should help solve some delays at very little cost to the passengers. RE: Go North East: Upcoming Service Changes v2 - markydh - 18 Jul 2017 PB0003954/809 Registered GO NORTH EAST LIMITED Route: Chester-Le-Street, Waldridge Park to Chester-Le-Street, Waldridge Park Service number: 34,34A (834) Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/808 Registered GO NORTH EAST LIMITED Route: Gateshead Interchange to Metro Retail Park via Team Street, Metrocentre Interchange Service number: X66 Service type: Limited Stop Effective date: 03 Sep 2017 PB0003954/806 Registered GO NORTH EAST LIMITED Route: Front Street, Low Moorsley to Heworth Interchange via Hetton Le Hole, Houghton Le Spring, Silksworth, Sunderland, Hylton, Boldon Service number: 35 (35A) Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/803 Registered GO NORTH EAST LIMITED Route: Sunderland Docks, Barrack Street to Silksworth, Church View Service number: 33 (33A) Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/797 Registered GO NORTH EAST LIMITED Route: Easington Lane, High Street to Newcastle, Eldon Square Bus Station Service number: X1 (X1A) Service type: Limited Stop, Normal Stopping Effective date: 03 Sep 2017 PB0003954/779 Registered GO NORTH EAST LIMITED Route: Park Lane Interchange, Sunderland to New Bridge St, Newcastle via Monkwearmouth, Hylton Castle, Wrekenton Service number: 56 (56A, N56) Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/776 Registered GO NORTH EAST LIMITED Route: Park Lane Interchange, Sunderland to Station Est, Murton via Grangetown, Ryhope, New Seaham Service number: 61 Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/775 Registered GO NORTH EAST LIMITED Route: Consett Bus Station to Park Lane Interchange, Sunderland via Leadgate, South Stanley, Grange Villa, Shiney Row Service number: 78 (78A, X78) Service type: Limited Stop, Normal Stopping Effective date: 03 Sep 2017 PB0003954/772 Registered GO NORTH EAST LIMITED Route: Concord to Brady Square/Waterview Park, Mandarin Way Service number: 85 (86) Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/766 Registered GO NORTH EAST LIMITED Route: Sunderland, Park Lane Interchange to Hartlepool, Marina Way Service number: X5 (X5A) Service type: Limited Stop, Normal Stopping Effective date: 03 Sep 2017 PB0003954/763 Registered GO NORTH EAST LIMITED Route: Durham Bus Station to Metrocentre Interchange Service number: X22 (937) Service type: Limited Stop, Normal Stopping Effective date: 03 Sep 2017 PB0003954/703 Registered GO NORTH EAST LIMITED Route: Wallsend, Redesdale Park/Wiltshire Drive to Billy Mill, St Thomas More Catholic School Service number: 678 Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/690 Registered GO NORTH EAST LIMITED Route: Great Park Village, Waggonway Drive to Wallsend Metro Service number: Q3 Service type: Hail & Ride, Normal Stopping Effective date: 03 Sep 2017 PB0003954/687 Registered GO NORTH EAST LIMITED Route: Gateshead Interchange to Lobley Hill, Cragside Gardend Service number: 95 Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/254 Registered GO NORTH EAST LIMITED Route: Hadrian Park to Burnside School, Wallsend via High Farm Service number: 665 Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/186 Registered GO NORTH EAST LIMITED Route: North Shields, Christ Church to Longbenton DSS, Tyneview Park via Hadrian Park Service number: 391 Service type: Normal Stopping Effective date: 03 Sep 2017 PB0003954/86 Registered GO NORTH EAST LIMITED Route: Gateshead Metro to Gateshead Metro via Team Valley, Heworth Service number: 93 (94) Service type: Normal Stopping Effective date: 03 Sep 2017 RE: Go North East: Upcoming Service Changes v2 - Michael - 18 Jul 2017 (18 Jul 2017, 4:36 pm)markydh wrote PB0003954/809 Registered Wonder if the X5A is the journeys on a night? RE: Go North East: Upcoming Service Changes v2 - James101 - 18 Jul 2017 (18 Jul 2017, 11:13 am)tyresmoke wrote Splitting the route will mean the drivers (& buses) will no longer be on EU tachograph regulations. Therefore it'll give them flexibility in what vehicles can be used on the route (everything, basically). No longer will they have to scrap around for tacho fitted buses to replace breakdowns or help with delays etc. No waiting for one to come back in off a 97 or whatever to pinch, they'll be able to send any bus out. This will help massively with flexibility and should help solve some delays at very little cost to the passengers. I understand why GNE are splitting the route. I'm saying we shouldn't discuss the splitting & re-route like it's the only solution the reliability problem. A customer-focused approach could be to leave the route as an express, add an extra bus into the PVR. I'd have thought the ratio of tacho'ed vehicles available as spares will go up when the B9s currently used are deployed onto other duties. If not, retro-fit tachos into as many vehicles as required to ensure a tacho'd spare is usually available on-call at Riverside (or better, stabled at Gateshead Metro during service hours) A cost-focused approach would be the upcoming changes; splitting the route, not ordering a dedicated spare & opting to buy a service bus over a coach. Clearly the cost-focused solution won-out in this case, or at least a compromise weighted towards cost-saving. That said, it's good there is a solution at all - the investment into the TTX is still sizeable, though it'd not a 'risky' investment as such. The TTX has a solid customer base and presumably a consistent revenue that justifies new buses every X number of years. RE: Go North East: Upcoming Service Changes v2 - Michael - 19 Jul 2017 I like how they've set up the new timetables for the Hexham area. Example: https://assets.goaheadbus.com/media/cms_page_media/3713/680_July2017_WEB.pdf RE: Go North East: Upcoming Service Changes v2 - RBZ 5459 - 19 Jul 2017 (19 Jul 2017, 1:40 pm)Michael wrote I like how they've set up the new timetables for the Hexham area. Assume they've been taken from the new 'Explore More' Hexham booklet Go North East have produced. More of a tourist guide rather than timetables for the everyday punter. RE: Go North East: Upcoming Service Changes v2 - Michael - 19 Jul 2017 (19 Jul 2017, 1:54 pm)RBZ 5459 wrote Assume they've been taken from the new 'Explore More' Hexham booklet Go North East have produced. More of a tourist guide rather than timetables for the everyday punter. Good idea, Go North Should make a booklet for the "Black Cat" services, same as the "Toonlink", then all the services would be under one booklet. RE: Go North East: Upcoming Service Changes v2 - Michael - 19 Jul 2017 With the buses changing in Sunderland, i hope we don't see any drastic cuts. Anyone know what the 8 change is?, as i get this to and from work. RE: Go North East: Upcoming Service Changes v2 - Ambassador - 22 Jul 2017 Farewell the 554. You shall...absolutely not be missed RE: Go North East: Upcoming Service Changes v2 - G-CPTN - 22 Jul 2017 I had meant to ride the final 687 journey, but I got involved looking for a lens for tomorrow's Airshow. RE: Go North East: Upcoming Service Changes v2 - Michael - 23 Jul 2017 (23 Jun 2017, 10:15 am)Michael wrote Just got an email from Go North East about the changes: A reminder these changes happen todayyyy. |
