Redcar depot - Printable Version
+--- Thread: Redcar depot (/showthread.php?tid=4318)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
RE: Redcar depot - peter - 11 Jan 2025
(11 Jan 2025, 10:20 pm)Ryland wrote 4722 now reported to be withdrawn .
When the next lot of Merseyside Pulsars due and how many are due.
When the envora come will that see off the final temsa
The Pulsars are seeing off the Temsa's, it's been stated elsewhere about 23 which should see them off - presuming the shortfall will be made up by either cutting the number of spares needed, other transfers, PVR decreases etc.
The Evora's are rumoured to be displacing Pulsars to Stockton to displace Streetlites to Merseyside, which in turn will displace Pulsars there - potentially the same ones coming to Redcar.
The impression I get is that Redcar have taken the 10 Evora's away from Merseyside's order, which is needed to clear all their older Pulsars due to the 15 year age limit, and as a result ANE are having to give them Streetlites instead. The Merseyside Pulsars I imagine would have otherwise been for the scrap man had it not been for the wise decision to send them up here to replace the Temsa's which are of a similar age but far more difficult to source parts for.
RE: Redcar depot - tyresmoke - 12 Jan 2025
I can’t see any more transferring until the Evora’s replace them. Luton are expecting theirs in May so it won’t be before then. Redcar’s ones are due around June so as they were originally bound for NW you would assume that Luton are first.
It could be a long few months of lost mileage for no bus…
RE: Redcar depot - Shrek - 12 Jan 2025
(12 Jan 2025, 8:52 am)tyresmoke wrote I can’t see any more transferring until the Evora’s replace them. Luton are expecting theirs in May so it won’t be before then. Redcar’s ones are due around June so as they were originally bound for NW you would assume that Luton are first.
Do we know when the electrics for the 43/44/45 are due at Blyth? I'm sure it was stated that would be by March? If that's the case, could some of the Blyth buses they're replacing be heading down for a short while?
RE: Redcar depot - Storx - 12 Jan 2025
(12 Jan 2025, 10:27 am)Shrek wrote Do we know when the electrics for the 43/44/45 are due at Blyth? I'm sure it was stated that would be by March? If that's the case, could some of the Blyth buses they're replacing be heading down for a short while?
Not much use Deckers down at Redcar as it'll be the 57/58 Plate Enviros that I'd imagine are going.
You might get 3 Pulsars out of it but not much use there and arguably they'd be better displacing the Solos out being Euro 6 etc.
RE: Redcar depot - Leon3367 - 15 Jan 2025
1399 Is under 4720 on the 63
RE: Redcar depot - Michael Euston - 18 Jan 2025
1398 and 3052 both on the X4 today.
RE: Redcar depot - Mike_98 - 18 Jan 2025
According to some, theres a possibility 4723 has now been withdrawn. Anyone know if this is true?
RE: Redcar depot - Ryland - 18 Jan 2025
(18 Jan 2025, 4:06 pm)Mike_98 wrote According to some, theres a possibility 4723 has now been withdrawn. Anyone know if this is true?
There quite a few temsa that aren't tracking today.
1399? Is this still at stockton  as sn spare is being used
RE: Redcar depot - Leon3367 - 18 Jan 2025
(18 Jan 2025, 4:09 pm)Ryland wrote There quite a few temsa that aren't tracking today.
It's only on loan but got pull off the 7 earlier in the afternoon so could be arriving back to its home depot
Michael Euston1398 and 3052 both on the X4 today.
 Correct to and I have a photo of the both since it was pretty good decent weather
RE: Redcar depot - Mark66t - 20 Jan 2025
Nice to see Redcar is finally getting journey mark pulsars  which makes a nicer selection of Liverys  more too come i been hearing
RE: Redcar depot - PH - BQA - 20 Jan 2025
(20 Jan 2025, 2:39 am)Spottybus17 wrote No one knows what else they’re getting just have to wait instead of getting off on your high horses
It’s been pretty widely reported that they’re due a hefty amount of Pulsars from elsewhere.
From memory you have a history of shooting people down who make accurate posts for no real reason, which isn’t particularly nice.
(20 Jan 2025, 11:05 am)Spottybus17 wrote Yes I know that Redcar are getting pulsars but clearly you didn’t read my comment correctly, no one knows what they’re getting stating the fact it could be journey mark, Arriva old or cotswold, I’m not even shooting anyone down at all I’m just stating the fact that no one knows what else Redcar are getting as it could be a mix up of pulsars
Could you point to where you specified that you were talking about the liveries? Your post makes no mention of them, and the one you had replied to simply stated that there were more to come (which is correct) - which followed on from a remark about liveries.
If all you’re saying is that nobody knows which exact Pulsars Redcar are getting, then there are far more polite ways to phrase it.
RE: Redcar depot - Leon3367 - 22 Jan 2025
PH - BQA
He's been banned no so less headache thank goodness and arguments
RE: Redcar depot - Storx - 22 Jan 2025
Does anyone know if 3038 (MX10BZY), assume the missing 1395, is heading to Redcar (assume so) or Ashington? Been mixed reports on it depending where you look. Supposedly it's broken at St. Helens atm hence why it's not turned up yet.
RE: Redcar depot - Kuyoyo - 22 Jan 2025
(22 Jan 2025, 2:08 pm)Storx wrote Does anyone know if 3038 (MX10BZY), assume the missing 1395, is heading to Redcar (assume so) or Ashington? Been mixed reports on it depending where you look. Supposedly it's broken at St. Helens atm hence why it's not turned up yet.
1395 is MX10CZC and is at Darlington - that and 1396 are due to replace the remaining E300s there, although 1395 hasn't managed to make a brilliant start at Darlington, breaking down yesterday on the X67 in Stockton (meaning the last X67 from Middlesbrough didn't operate as a result) and then it didn't manage to do much this morning before breaking down as well.
EDIT: Having consulted a source of mine within Arriva - 3038 is not one of the Pulsars transferring to the North East region.
RE: Redcar depot - Aaron21 - 22 Jan 2025
Ashington have the 5 they were planning to get
(22 Jan 2025, 2:21 pm)Kuyoyo wrote 1395 is MX10CZC and is at Darlington - that and 1396 are due to replace the remaining E300s there, although 1395 hasn't managed to make a brilliant start at Darlington, breaking down yesterday on the X67 in Stockton (meaning the last X67 from Middlesbrough didn't operate as a result) and then it didn't manage to do much this morning before breaking down as well.
Thanks for that 1395 slipped in without me noticing and would make sense that they're prioritising the few non standard vehicles out the fleet asap.
Surprised 3038 isn't coming up here since the rest of the batch is here, guess there's some reason behind it though.
I herd Redcar are expecting another from a post on fb
RE: Redcar depot - Superman - 23 Jan 2025
3006, 3007, 3008, 3010, 3021, 3024, 3026, 3029, 3030 and 3031 are transferring from Birkenhead this weekend (26 Jan), to Stockton.
1564-1573 going the other way. They will be renumbered 6016-6025 in Merseyside.
RE: Redcar depot - Ryland - 23 Jan 2025
(23 Jan 2025, 8:40 pm)Superman wrote 3006, 3007, 3008, 3010, 3021, 3024, 3026, 3029, 3030 and 3031 are transferring from Birkenhead this weekend (26 Jan), to Stockton.
Ok so they're transferring to stockton. So what's going to Redcar then?
(23 Jan 2025, 9:02 pm)Ryland wrote Ok so they're transferring to stockton. So what's going to Redcar then?
Redcar are still due more, but they will come in batches.
RE: Redcar depot - Storx - 23 Jan 2025
Evora's. These were diverted from the Liverpool order to effectively displace the X4 Streetlite's down instead.
Seems they're just sending up the Pulsar's early so Merseyside can get their Streetlite's earlier.
Not ideal for Stockton mind who are getting a downgrade from it all, especially considering how elderly the fleet is there already. Debate on whether a 5 year old Pulsar is better than a Streetlite mind.
Originally it was mentioned that the 09 Plate Pulsar's were meant to be moving from Redcar instead but seems plans have changed.
RE: Redcar depot - Leon3367 - 23 Jan 2025
(23 Jan 2025, 10:26 pm)Storx wrote Evora's. These were diverted from the Liverpool order to effectively displace the X4 Streetlite's down instead.
 Seems it's changed  no moments from Redcar to Stockton   now
So the evoras are due to come this year. Likely hood of 10 temsa staying on at Redcar till they come potentially
(23 Jan 2025, 11:06 pm)Ryland wrote So the evoras are due to come this year. Likely hood of 10 temsa staying on at Redcar till they come potentially
I'd imagine they'll all be in service until then now. Don't think anything else is planned to leave Liverpool until their Evora's turn up now though - they're due some aswell. I could be wrong there though as plans seem to change quite a bit but that's what has been said quite recently.
RE: Redcar depot - Leon3367 - 24 Jan 2025
(23 Jan 2025, 11:56 pm)Storx wrote I'd imagine they'll all be in service until then now. Don't think anything else is planned to leave Liverpool until their Evora's turn up now though - they're due some aswell. I could be wrong there though as plans seem to change quite a bit but that's what has been said quite recently.
2 are expecting to arrive with in the next few weeks I been told
RE: Redcar depot - Kuyoyo - 24 Jan 2025
Stockton actually benefit from taking the Merseyside Pulsars compared to taking their original ones back from Redcar - the  Merseyside ones have been modified to Euro6 standard so increases the number of vehicles that can be used on the Newcastle X12 turns by 10 (while the StreetLites are CAZ compliant, they are now rarely used on there except for emergencies).
(24 Jan 2025, 6:05 am)Kuyoyo wrote Stockton actually benefit from taking the Merseyside Pulsars compared to taking their original ones back from Redcar - the  Merseyside ones have been modified to Euro6 standard so increases the number of vehicles that can be used on the Newcastle X12 turns by 10 (while the StreetLites are CAZ compliant, they are now rarely used on there except for emergencies).
 The 8 could be reduce as yesterday 3 were leaving Middlesbrough together  personally it's way to frequent and never full  wouldn't it make sense putting streetlites on the 8 1550 57
RE: Redcar depot - Storx - 24 Jan 2025
Yeah had a feeling that might have been the reason why. It'll be interesting to see what the plans are for Stockton as the fleet is getting on there as an understatement and it's not as if the routes are poor routes especially considering there's nothing ordered and nothing planned for the place either, as far as I'm aware.
RE: Redcar depot - tyresmoke - 24 Jan 2025
(24 Jan 2025, 9:18 am)Leon3367 wrote  The 8 could be reduce as yesterday 3 were leaving Middlesbrough together  personally it's way to frequent and never full  wouldn't it make sense putting streetlites on the 8 1550 57
Why would you reduce the service 8? It’s clearly busy enough to justify its frequency! Streetlites generally do get shoved on local routes not many go far out of town now! Of course with some departing this weekend then you’ll see less of them.
