Max Brand - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Arriva North East (https://northeastbuses.co.uk/forumdisplay.php?fid=56) +--- Thread: Max Brand (/showthread.php?tid=3290) |
RE: Max Brand - Train8261 - 28 Sep 2021 They need to sort allocations out like 306 is a mix of Deckers, Solos, StreetLite and VDL Pulsar 52/53/54 is a mix of StreetLite & Solos with the odd Pulsar and decker chucked in 43/44/45 is the same as the 306 taking away the Solos X7/X8/X9/X10/X11 is mainly DB300 Wright Gemini with the odd few Pulsar chucked in X14/X15/X18 is mainly all deckers but a mix of E400 and MMC X21/X22 is Mainly always MMC but with the odd Solo thrown is as well I'd say the only routes that have full allocations all the time is the 685 & 51/51A I mean the 306 is branding on two different buses RE: Max Brand - Storx - 28 Sep 2021 (28 Sep 2021, 10:21 pm)Train8261 wrote They need to sort allocations out like The reason there's no allocations per say is because buses get swapped around at Blyth and Jesmond to keep buses on time. It's better than the alternative of curtailing buses short to keep things on the same route. I know which option I'd rather have and nearly every normal customer would agree. Arriva also have mixed allocations for some routes as there's some boards busier than others. What's the point in having deckers on something when all it needs a full single. This forums the dull the last few weeks. Just constant moaning about allocations when it's the least of problems atm with a massive driver shortage and because of Covid, parts shortages aswell. RE: Max Brand - PH - BQA - 28 Sep 2021 (28 Sep 2021, 10:21 pm)Train8261 wrote X14/X15/X18 is mainly all deckers but a mix of E400 and MMC So, the correct allocation? MMCs are rarely allocated, if they are it's generally as a last resort or later on in the day. (28 Sep 2021, 10:21 pm)Train8261 wrote X21/X22 is Mainly always MMC but with the odd Solo thrown is as well I mean, it's more common to be a B7TL standing in, but ultimately if the only bus left is a Solo then folk will prefer that to walking. Don't see this same energy from you towards other companies like... RE: Max Brand - citaro5284 - 29 Sep 2021 (28 Sep 2021, 10:44 pm)Storx wrote The reason there's no allocations per say is because buses get swapped around at Blyth and Jesmond to keep buses on time. It's better than the alternative of curtailing buses short to keep things on the same route. I know which option I'd rather have and nearly every normal customer would agree. It will be interesting how this would work if the rumoured new depot at East Hartford gets built and Blyth closes, as they will not have the buses at Blyth to play around with. RE: Max Brand - omnicity4659 - 29 Sep 2021 (29 Sep 2021, 4:15 am)citaro5284 wrote It will be interesting how this would work if the rumoured new depot at East Hartford gets built and Blyth closes, as they will not have the buses at Blyth to play around with. If the Ashington move is anything to go by (they moved into a vacant shop next to the bus station), then they'll still have facilities at or near Blyth bus station for supervisors and driver breaks so there'll probably still be someone on the ground to swap buses around. RE: Max Brand - Storx - 29 Sep 2021 (29 Sep 2021, 4:15 am)citaro5284 wrote It will be interesting how this would work if the rumoured new depot at East Hartford gets built and Blyth closes, as they will not have the buses at Blyth to play around with. Yeah that's true but I suppose it depends where breaks are done like someone said. I believe it happens at Durham aswell but I'm not 100% sure on that as I'm not from down there and the depot there is a similar distance away. Wasn't it supposed to be a super depot to replace Jesmond aswell though. So I suppose it could all be done at Haymarket with everything at play bar the Ashington buses. RE: Max Brand - Jimmi - 29 Sep 2021 (28 Sep 2021, 8:58 pm)Keeiajs wrote Lets face it Arriva has given up. There is still MAX branding off 4 years ago. Vinyl Wraps to cover stuff up. I wouldn't say given up, they've played very safe the last 2 years especially since covid as let's face it, buying new buses in the hope of seeing some returns is a very risky strategy. Given the fact that vinyls are being addressed now leads to suggest some effort is being at least thought of, granted its not the best look but looks to be the start of a big project to address fleet presentation and considering the numbers of buses that have to be done is gonna take time (or at least I hope this is the case), feels like Arriva now want to get rid of these old route brandings and liveries, think some of the buses I saw in Yorkshire had also lost route specific branding although less of a push with new logo. Last new buses for North East were 67 plate Lites at Darlington at the start of 2018, wish I could forget them like all the Tyneside enthusiasts seem to do! RE: Max Brand - GNE6312 - 01 Oct 2021 MAX Geminis 7603 & 7624 now debranded aswell as frequenta pulsars 1429 & 1432 RE: Max Brand - Driver9*** - 01 Oct 2021 Main reason a lot of Blyth Geminis are being done is because they were still showing X10/11 "Up to every 10 minutes" which is not the case now and never will be again, 15 mins is more than adequate as long as DD are used. RE: Max Brand - L469 YVK - 02 Oct 2021 (01 Oct 2021, 5:50 pm)Driver9*** wrote Main reason a lot of Blyth Geminis are being done is because they were still showing X10/11 "Up to every 10 minutes" which is not the case now and never will be again, 15 mins is more than adequate as long as DD are used.Would they not be better (with the southern sections from Cramlington to Newcastle replaced by something else) scrapping the X8 & X9 in current form and just having the following: - X9 every 30 mins= Current X8 route from Blyth to Cramlington then X10/X11 route to Newcastle - X10 = Same route and frequency as now - X11 = Same route and frequency as now RE: Max Brand - Cock Robin - 04 Oct 2021 They're going to need a hell of a lot of new buses in 5 or so years time when the Pulsars and Temsas need replacing, not to mention deckers and Solos. They haven't had continous investment like GNE and Stagecoach. RE: Max Brand - Ryland - 04 Oct 2021 However from 2008 to 2012 we had alot of investment so a whole new fleet will be needed across the board of arriva north east RE: Max Brand - Train8261 - 04 Oct 2021 Arriva should take ideas from other Arriva companies up and down the country. Optare Versa, StreetDeck, E200MMC, Volvo B9TL Wright Eclipse Gemini 2, Mercedes-Benz Citaro RE: Max Brand - Storx - 04 Oct 2021 (04 Oct 2021, 7:56 pm)Cock Robin wrote They're going to need a hell of a lot of new buses in 5 or so years time when the Pulsars and Temsas need replacing, not to mention deckers and Solos. They haven't had continous investment like GNE and Stagecoach. Must have missed the continuous fleet renewal at Stagecoach mind. They're in a worse place atm imo with buses which need withdrawing now nevermind in 5 years and there's nothing planned. Not to mention the majority of the fleet haven't been refurbished since new and are extremely outdated, regardless to what people thought of the Arriva refurbs. They've also got an awful lot of 08/58/09/60/11/61 buses which will need renewing at the same and since some of them are cheap MAN rubbish they'll need replacing aswell. Arriva has always ran it like that though, with a similar scenario between 2001 - 2007 where nothing was really ordered except it was much much worse than it is now with the leaking Scania's at Blyth which we're shot, Olympians still in the smartie interior and stuff like this https://farm9.static.flickr.com/8142/7637379970_d717e9fefc.jpg running on frontline services. People would have a field day on here if it was back then. Not to mention ex Darts from anywhere they could find them, Metroriders everywhere which were completely shot and Prestige's which the less said is better. RE: Max Brand - PH - BQA - 04 Oct 2021 (04 Oct 2021, 8:18 pm)Train8261 wrote Arriva should take ideas from other Arriva companies up and down the country. Volvo Olympian, Dennis Dominator, Scania L113, Enviro 300. I can list random buses too. RE: Max Brand - L469 YVK - 04 Oct 2021 (04 Oct 2021, 8:25 pm)Storx wrote Must have missed the continuous fleet renewal at Stagecoach mind. They're in a worse place atm imo with buses which need withdrawing now nevermind in 5 years and there's nothing planned. Not to mention the majority of the fleet haven't been refurbished since new and are extremely outdated, regardless to what people thought of the Arriva refurbs.I think the big thing back then was the likes of N3** OTY and P4** CCU and M3** FTY were built to last. If Arriva had a fleet of B9TLs and E400s (latter not used on any Alnwick X routes or X93), they'd be fine. GNE have a large fleet of B9TLs and unless the EV bid is approved for the Cobalts & Angel (meaning perhaps StreetDecks cascaded onto the 27 or 56 with some B9TLs cascading elsewhere within GNE or GAG), they'll likely be run in frontline service for 12-15 years. ANE ordering new vehicles for the X15/X18, X21/X22 and X93 would be a good starting point. Plenty of decent cascades available from these down. In turn, the cascades would upgrade the X14 (newer E400), X20 (B9TL), 43/44/45 (newer E400) and 308 (E400MMC voith). RE: Max Brand - Storx - 04 Oct 2021 (04 Oct 2021, 10:08 pm)L469 YVK wrote I think the big thing back then was the likes of N3** OTY and P4** CCU and M3** FTY were built to last. Not sure on the OTY batch at Blyth like they we're bloody awful. You couldn't sit on the seats near the windows splits when it was raining from water pouring in and they used to absolutely stink of damp. Horrid buses by the end and some of them were with withdrawn early at 13 year old, shocking build quality. The Gemini's and Pulsar's are much better built machines imo and will last awhile yet. The Commanders lasted 18 year without any real bother and could've easily lived on in service. Can't argue against the Olympians though but they we're seriously outdated by the end especially on the X21/X22, that said I wouldn't purchase new buses for it though and would focus personally on the likes of the X66/X67, X26/X27 which are crying for investment and the X15/X18 due to the problem's with reliability. It's the Solo's which need replacing imo as they're life expired pretty much now (usually 12 year for a minibus) and they're falling apart some of them, 2809 in particular for being extremely unreliable (potentially the worst bus in the North East). RE: Max Brand - peter - 04 Oct 2021 (04 Oct 2021, 10:25 pm)Storx wrote Not sure on the OTY batch at Blyth like they we're bloody awful. You couldn't sit on the seats near the windows splits when it was raining from water pouring in and they used to absolutely stink of damp. Horrid buses by the end and some of them were with withdrawn early at 13 year old, shocking build quality. The Gemini's and Pulsar's are much better built machines imo and will last awhile yet. The Commanders lasted 18 year without any real bother and could've easily lived on in service. The fact that the last of the MPD's have only just been withdrawn at 16 years old suggests the Solo's will be around until about 2024. RE: Max Brand - Jimmi - 05 Oct 2021 (04 Oct 2021, 10:25 pm)Storx wrote Can't argue against the Olympians though but they we're seriously outdated by the end especially on the X21/X22, that said I wouldn't purchase new buses for it though and would focus personally on the likes of the X66/X67, X26/X27 which are crying for investment and the X15/X18 due to the problem's with reliability. Think the Omnis based at Darlington could be gone by end of this year/start of next once the 3 ex Tiger OmniLinks land (one snapped with it's new paint job today so shouldn't be long) and think most of the remainder will go once the refurbishment of the gas buses at Darlington is complete. Solos is an interesting one because of CAZ, can't seem them paying to convert what will be 14 year old life expired Solos for it, not convinced even transferring Darlington's 11 year old Solos would be worth it either and likely will depend whatever else happens to services, think frequency cuts with larger buses like what's happened with the 1 & 2 already is possible again. A decker order, ideally for X15/X18 would probs be enough to sort out the worst of our problems, just really the 20 year year B7TLs that are an issue and even then depends how you look at it as to whether it's a major issue or not, maybe another Northumberland route if they're willing to splash the cash but I doubt it. I can't much major investment really occurring until about 2024 when the oldest Pulsars and VDL Geminis hit 15 years of age. RE: Max Brand - Storx - 05 Oct 2021 (05 Oct 2021, 10:41 pm)Jimmi wrote Think the Omnis based at Darlington could be gone by end of this year/start of next once the 3 ex Tiger OmniLinks land (one snapped with it's new paint job today so shouldn't be long) and think most of the remainder will go once the refurbishment of the gas buses at Darlington is complete. Yeah your probably right. Was just reading the Arriva London forums there and supposedly they're expecting some buses to be coming up here (rumours atm) with T288 - T300 without a route soon which are all 61 plate Euro 6 Enviro 400's plus some Gemini's on the 349 which have been recently replaced by Borisbuses. They could certainly be the answer which would see of the rest of the current ex London stock with a potential upgrade to the 306 so the Pulsars from there and the X16 can do the 52, 53, 55 etc. Would just leave the 51 and 46 to be Solo operated within the LEZ. There's also some electric buses heading soon down there which is going to leave more buses up for release aswell. No doubt it's where they're going to come from eventually. RE: Max Brand - peter - 06 Oct 2021 (05 Oct 2021, 10:41 pm)Jimmi wrote Think the Omnis based at Darlington could be gone by end of this year/start of next once the 3 ex Tiger OmniLinks land (one snapped with it's new paint job today so shouldn't be long) and think most of the remainder will go once the refurbishment of the gas buses at Darlington is complete. Assuming the 2/2A PVR is going to remain at 5 as it is now, then that leaves 5 free to be allocated to the X66/X67 and 3 to be allocated to the X21. There's enough Streetlites to cover the 1/5/5a/X1 as well as the 8/8a, so that leaves enough Pulsars for the X26/X27 if that's going to remain at 4. And then I reckon the Omnilinks will end up on the X75/X76. The PVR decreases on the likes of the 46 and 55 seems to have pushed Solo's onto other services allowing Pulsars to replace the Cross Pennine Omnicites and then perhaps the two X16 Pulsars will migrate over to Ashington to replace 4653/4664. So a full Omnicity withdrawal is definitely on the cards I reckon. RE: Max Brand - Train8261 - 20 Oct 2021 1411 and 1408 have both lost there Max branding and now have just the Arriva Logo RE: Max Brand - Ryland - 20 Oct 2021 [quote pid="265936" dateline="1634739556"]
[/quote] Along with 1591 Presuming 1590/2/3/4 have followed |
