Go North East - State of the Fleet - Printable Version
+--- Thread: Go North East - State of the Fleet (/showthread.php?tid=4189)
RE: Go North East State Of The Fleet - stagecoachbusdepot - 26 Jan 2025
(26 Jan 2025, 1:52 pm)WestDurhamSwift wrote The B5LHs seem to have vanished entirely, replaced by second-hand 61-plate buses. If I recall correctly, the B5LHs were supposedly heading to EYMS, though they were originally meant to go to GNW to join the B&H ones now in service there.
As for 6334 and 6335, they were sent to GNW after undergoing internal refurbishments and a repaint. Interestingly, they’ve since been repainted into Bee Network livery and undergone yet another internal refurbishment.
You also have the 'other' Enviro 400MMCS which were ordered for Go North East but then diverted to Oxford.
Seems like a non-issue to me.  Swapping mid life vehicles for similar type around 1 year older isn't great but is also not a big deal to be flagging to the BBC as part of the reason for the current embarrassment that is GNE.  I highly doubt that getting rid of the hybrids and replacing them with the London deckers has anything to do with the current mess.  Particularly when the second hand tat seems better able to remain on the road than much of the newer indigenous stock.
RE: Go North East State Of The Fleet - Storx - 26 Jan 2025
(26 Jan 2025, 3:25 pm)stagecoachbusdepot wrote Seems like a non-issue to me.  Swapping mid life vehicles for similar type around 1 year older isn't great but is also not a big deal to be flagging to the BBC as part of the reason for the current embarrassment that is GNE.  I highly doubt that getting rid of the hybrids and replacing them with the London deckers has anything to do with the current mess.  Particularly when the second hand tat seems better able to remain on the road than much of the newer indigenous stock.
Personally I'd argue the E400's are a big reason why GNE are a mess that they are.
The fleet currently consists of
Coaches: Unsure atm
Deckers: E400 ADL/E400 Optare/E400MMC/B5TL/B7TL/B9TL/Streetdeck
Singles: E200MMC/Streetlite/Yutong Diesel/Yutong Electric/Versa/Citaro/Solo SR/Merc Cityline
It's an absolutely ridiculous number of vehicles and it feels like certain depots have the vast majority of them, Consett being one of them. Parts is a big issue for the engineering issues and unless you want a warehouse of parts then there's a lot of spare stock required there.
RE: Go North East - State of the Fleet - WestDurhamSwift - 27 Jan 2025
5492 died at Lanchester this morning, very early doors. Not long been recovered by Alpha
RE: Go North East - State of the Fleet - Ambassador - 27 Jan 2025
6220 doesn’t have working reversing warning and it’s reverse lights seem hit and miss
Workaround is the driver beeping his horn as it reverses…
It’s also raining inside
RE: Go North East - State of the Fleet - DeltaMan - 27 Jan 2025
(27 Jan 2025, 2:38 pm)WestDurhamSwift wrote 5492 died at Lanchester this morning, very early doors. Not long been recovered by Alpha
It must be costing GNE a fortune for recovery at the minute with initial callout fees and mileage rates!
RE: Go North East State Of The Fleet - L469 YVK - 27 Jan 2025
(26 Jan 2025, 3:55 pm)Storx wrote Personally I'd argue the E400's are a big reason why GNE are a mess that they are.
Coaches: Unsure atm
Quite interesting you mention the deckers too.
If GNE and GoEY could agree a swap (with some expenditure diverted to GNE to compensate for the older vehicles), would GNE not be better swapping their E400MMC (x20) for GoEY's low height EvoSeti's (X20)?
Still have the non-commonality to some extent, but keeps the front line diesel double deckers either Volvo (B5TL, B9TL) or WrightBus integral (StreetDeck).
As for the X10, that could benefit from the capital expenditure release and maybe receive some new Ultroliners. And if GAG feeling generous, some actual additional investment into GNE on top for the X21 to receive an upgrade and one single common fleet for the X10 & X21.
RE: Go North East State Of The Fleet - Storx - 27 Jan 2025
(27 Jan 2025, 6:22 pm)L469 YVK wrote Quite interesting you mention the deckers too.
Probably do the opposite personally, and send the B5's down to EYMS in return for the newest B9's. There's only a 2 year difference and they'd arguably be better that having 7 buses which pretty much live VOR which are on the road today just to prove me wrong.
If you wanted to go into that territory there's loads you could do tbh between GoAhead areas as it's a problem all over.
The microfleet of Mercs here being swapped for the microfleet of Streetlites down in the Oxford area to pick one.
RE: Go North East - State of the Fleet - PH - BQA - 28 Jan 2025
Looks like both electric Yutongs in use on the H today have been pulled off before they made it to lunchtime. 6357 is one of the replacements, which was taken off an X21 earlier, looks to have broken at the Freeman prior to the 1220.
RE: Go North East - State of the Fleet - Unber43 - 28 Jan 2025
oh honestly....
RE: Go North East - State of the Fleet - NL62WVW - 28 Jan 2025
(28 Jan 2025, 12:34 pm)PH - BQA wrote Looks like both electric Yutongs in use on the H today have been pulled off before they made it to lunchtime. 6357 is one of the replacements, which was taken off an X21 earlier, looks to have broken at the Freeman prior to the 1220.
8805 was involved in a RTA with a pedestrian, unsure why the other one came off.
(28 Jan 2025, 8:30 pm)NL62WVW wrote 8805 was involved in a RTA with a pedestrian, unsure why the other one came off.
Believe 8804 was on Monday too at the top of Matthew Bank.
Obviously hope those involved in both incidents are okay.
RE: Go North East - State of the Fleet - deanmachine - 29 Jan 2025
I mean if you're going to be hit by a bus, you'd want it to be a bus full of medical staff.
RE: Go North East - State of the Fleet - Ambassador - 30 Jan 2025
Adding to Washington woes
6214 has been abandoned at the cannon for 2 hours mid 22 run
RE: Go North East - State of the Fleet - WestDurhamSwift - 30 Jan 2025
6340 was broken down near South Causey with an engineer in attendance earlier on.
Showing as being back in service tonight
RE: Go North East - State of the Fleet - Storx - 30 Jan 2025
(30 Jan 2025, 5:17 pm)Ambassador wrote Adding to Washington woes
Looking at tracking, that looks like it already had an issue earlier on aswell. It might manage a full run by the end of the day as it seems to have a service of
Run 1: To Newcastle, issues 30 minutes late - Got there
Run 2: To CLS, Cancelled, ran empty to CLS
Run 3: To Newcastle, broke down at Birtley
Run 4: To CLS, Cancelled
Run 5: To Newcastle, Ran short from Birtley
Run 6: Now
Be interesting to see what VOSA would say if they made a random spot check on it as I'd be surprised if it passed as there's clearly something wrong.
RE: Go North East - State of the Fleet - Tiger5105 - 30 Jan 2025
Another E200 joins the sick list tonight. 5494 towed in by Alpha. Thats 5492, 5494 and 5495 off the road now.
6179 heading through Lanchester waking the entire village up, fairly sure its at Consett now and I can still hear it ....
RE: Go North East - State of the Fleet - BusLoverMum - 31 Jan 2025
Storx
Run 6: Now
(fubarred the formatting)
2 hour gaps in the 22 thus afternoon. Looks like 5399 gave up in Wrekenton, this time. (spotted it when waiting for a no show X21 at Eldon square - turns out that was 6357 that looks to have conked out in Low Fell)
RE: Go North East - State of the Fleet - L469 YVK - 31 Jan 2025
(31 Jan 2025, 3:02 pm)BusLoverMum wrote (spotted it when waiting for a no show X21 at Eldon square - turns out that was 6357 that looks to have conked out in Low Fell)
Nice to know a few people were probably enjoying a ride on effectively a ghost bus through Whickham & Dunston (double the seats pre Nov 2019) whilst there was probably a queue at Eldon Square waiting for a 4 pot heap of s***e expected to run GNE's 2nd longest route!
Boils my **** knowing that GNE could easily solve the issues on the X10 & X21 yet have just took the lazy option not only for vehicle allocations, but interworking patterns & efficiencies!
(31 Jan 2025, 5:13 pm)L469 YVK wrote Nice to know a few people were probably enjoying a ride on effectively a ghost bus through Whickham & Dunston (double the seats pre Nov 2019) whilst there was probably a queue at Eldon Square waiting for a 4 pot heap of s***e expected to run GNE's 2nd longest route!
There was a very grumbly queue at Eldon Square! The next X21 turned up late, at the same time as the X12. I gave Arriva my £2.50 and lots of others had the same idea.
(31 Jan 2025, 5:41 pm)BusLoverMum wrote There was a very grumbly queue at Eldon Square! The next X21 turned up late, at the same time as the X12. I gave Arriva my £2.50 and lots of others had the same idea.
I don't blame you.
GNE's problem is easily solvable. All of 6308-14 & 6356-63 to Consett + 6x E400MMC with timetable below. More than enough to cover PVR & spares. Then 14x E400MMC + 6377 covering the X10 & X21 with 3x spares.
- X32 omits Lobley Hill Est and 2bph
- X70 serves Lobley Hill Est
- X31 dropped
- X30/X71 half hourly through Whickham & Dunston
Only issue GNE would have is ths X20 but could get some Cobalt B9TL's if 307/309 get the Angel StreetDecks (which is likely).
Problem solved!
I'd forgotten that we picked up the passengers off, presumably, 6358 on our way in, this morning. That one gave up in Chester-le-Street. (and, yes, some had stubbornly waited half an hour for the next X21 rather than catch one of the several 21s in the meantime). Though it looks like one of the 21s started from later in the route, too.
And that's with an R in the month so no excuse!
RE: Go North East - State of the Fleet - garym67 - 31 Jan 2025
(31 Jan 2025, 6:22 pm)L469 YVK wrote I don't blame you.
- X31 dropped
Problem solved!
Enough now, how many times are you going to post this crap, surely you get the message by now no one agrees with you?
Believe me as someone who uses these services you hate so much I can tell you these buses are nowhere near the answer to your prayers.
Just as examples last week I was an an E400 on the X30 that was struggling so much I thought it was't going to get up Dunston bank, could have walked it quicker. The week before everytime the stop/start kicked in the bus gradually got less and less keen on restarting, to the point when it got to Sunniside we were on the verge of having to get off before the driver finally got it restarted. These are not isolated incidents, and the fact that a large number of services this week have be run by coast and county streetlites suggest a number of them have given up.
If they're going to change anything lets go back to X30 twice an hour and X31 twice an hour as before, personally I prefer it going via Whickham/Dunston as it gets into the right side of town, unlike the trip over the Tyne Bridge but if you give me the X30 back twice an hour you can do whatever you like with the X31/32.
(31 Jan 2025, 8:30 pm)garym67 wrote Enough now, how many times are you going to post this crap, surely you get the message by now no one agrees with you?
Well why have Arriva Northumbria used the E400 Classic (ZF) and E400MMC (Voith) as the bus of choice on the X14/X15/X18/X20 and X21/X22/35? And the X93/X94?
Not forgetting Stagecoach and the 685?
Could be a maintenance issue with GNE (well more than likely)? Any recall of Arriva 7501-06 which were ruined by Blyth / Redcar shilst 7507-13 ran well out of Ashington?
RE: Go North East - State of the Fleet - Ambassador - 31 Jan 2025
There was a non CAZ Citaro on the 29
Rather than do the right thing and pay the relatively small fee…Go Nowhere ran it short to Gateshead
Absolutely shameless
RE: Go North East - State of the Fleet - TransitObserver - 31 Jan 2025
(31 Jan 2025, 10:22 pm)Ambassador wrote There was a non CAZ Citaro on the 29
They’re done that a few times now. Shouldn’t be terminating a bus early just because of a clean air zone fine. I thought stagecoach were bad but go north east seem to be getting worse every day.
RE: Go North East - State of the Fleet - omnicity4659 - 01 Feb 2025
https://www.gov.uk/guidance/report-a-bus-or-coach-service-or-driver#report-buses-arriving-late-early-not-stopping-or-not-turning-up
Please email the DVSA's intelligence unit regarding a deliberate failure to operate a registered service in full, a formal (and still anonymous) paper trail works better than forum posts!
RE: Go North East - State of the Fleet - DeltaMan - 01 Feb 2025
Bustimes (usual caveats) shows it happening all day yesterday. Vehicle 5368.
That's bang to rights. I'd genuinely inform the traffic commissioner.
The CAZ is not a vehicle ban. There is no good reason why it shouldn't run to Newcastle.
RE: Go North East - State of the Fleet - GuyParkRoyal - 01 Feb 2025
(09 Jan 2025, 8:57 am)ASX_Terranova wrote Is today the worst reliability weve seen out of washy depot?
This is typical of the poor service being provided by Washington. On Wednesday morning all 3 vehicles missing from the 34 resulting in no service on that route.
While Go North East have awarded Washington as their depot of the year 2024. Sorry but that award is insulting to all of Washington customers.
RE: Go North East - State of the Fleet - citaro5284 - 01 Feb 2025
I blame Sunderland Council for using the wrong type of grit and salt in Washington......
