Arriva North East: Service Suggestions - Printable Version
+--- Thread: Arriva North East: Service Suggestions (/showthread.php?tid=503)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
RE: Arriva North East: Service Suggestions - Storx - 24 Aug 2022
(24 Aug 2022, 9:05 pm)OrangeArrow49 wrote The 342? Where could Great Park fit into the route? Hopefully it will happen when the new roads eventually open.
Could run it something like this:
https://goo.gl/maps/qrrvmENCCxbiVdhU9
or like this if you wanted to keep Hazlerigg aswell:
https://www.google.com/maps/dir/55.0116956,-1.6678266/55.051741,-1.6257554/@55.0319764,-1.6697067,2867m/data=!3m1!1e3!4m19!4m18!1m15!3m4!1m2!1d-1.6660175!2d55.0193113!3s0x487e768d9f863883:0xf6f32967613855b7!3m4!1m2!1d-1.6562452!2d55.0278572!3s0x487e7699f0e12697:0x6af149a6182df0d3!3m4!1m2!1d-1.6514808!2d55.0414777!3s0x487e7421b7ef42ad:0xa1e99644690a247f!1m0!3e0
RE: Arriva North East: Service Suggestions - OrangeArrow49 - 24 Aug 2022
(24 Aug 2022, 9:24 pm)Storx wrote Could run it something like this:
Hmm, interesting. Perhaps the 342 would be a good route for Great Park. Time will tell. Great Park continues to be a work in progress, hopefully new links will be created.
Arriva North East: Service Suggestions - Dan - 25 Aug 2022
(24 Aug 2022, 8:53 pm)mb134 wrote Will an E200 with USB charging and WiFi tempt them?
Do you think a new E200 is likely to be used, or the 46 withdrawn? I’d go with the latter, if I was a betting man!
RE: Arriva North East: Service Suggestions - PH - BQA - 25 Aug 2022
(25 Aug 2022, 4:55 am)Dan wrote Do you think a new E200 is likely to be used, or the 46 withdrawn? I’d go with the latter, if I was a betting man!
Unless the 46 is withdrawn in the next couple of weeks, I'd absolutely say it's more likely that an E200 will appear on there.
(25 Aug 2022, 6:05 am)mb134 wrote Unless the 46 is withdrawn in the next couple of weeks, I'd absolutely say it's more likely that an E200 will appear on there.
Let’s hope the new E200s aren’t used on the 46 from September for the service to be withdrawn at the end of October when Jesmond closes…
We’ve seen the criticism that operators face on this forum for this kind of thing in the past!
(25 Aug 2022, 6:51 am)Dan wrote Let’s hope the new E200s aren’t used on the 46 from September for the service to be withdrawn at the end of October when Jesmond closes…
Not sure what your point is there?
The vehicles are evidently being bought ahead of the CAZ, to be used on any (current) Jesmond minibus work. You would say that with the amount purchased vs current PVR that cutting something has at least been looked at. Obviously Arriva's approach to vehicle allocation is vastly different from other operators, so I'd imagine it's highly likely that they'll be allocated given that they'll be the available minibus vehicles and that the 46 is a minibus route (and interworks with the 51, so the appearance of an E200 is virtually guaranteed).
I'd say there's a significant difference between that and vehicles being specifically route branded for a route then the route being withdrawn.
RE: Arriva North East: Service Suggestions - Storx - 25 Aug 2022
(25 Aug 2022, 10:22 am)mb134 wrote Not sure what your point is there?
Has it actually been confirmed that all 14 are still going to Jesmond now?
Haven't heard much about them for awhile and I had a family member the other week who randomly came out with, you'll probably already know but Ashington are getting new 5 new minibuses next month, assuming one of the driver's mentioned it. I know bus / driver gossip is the least reliable gossip going but it was just out the blue, especially considering the other 9 are very very likely going to end up there from October anyway especially with the bother Ashington are having with the 5 Solo's and the Dart pretty much daily now.
2816 breaking down today already just to pick one out.
RE: Arriva North East: Service Suggestions - peter - 25 Aug 2022
(25 Aug 2022, 10:56 am)Storx wrote Has it actually been confirmed that all 14 are still going to Jesmond now?
I think given the number of buses : PVR ratio at Ashington the reliability of the solo's must leave a lot to be desired.
Ashington have 6 Solo's and an MPD for a PVR of 4 on the 57/57A
Whereas Jesmond have 13 Solo's for a PVR of 11
Ideally, like you say, if the 55 were withdrawn you'd have a PVR of 12 with two spares. That should allow 1800 and 2809/12/13/16/17/22 to be withdrawn with the rest perhaps heading to replace some of the older Solo's at Durham/Darlington, certainly the last two in the old old livery at Durham 2818/20 should be withdrawn.
RE: Arriva North East: Service Suggestions - V514DFT - 25 Aug 2022
I do teckon the 55 might bite the bullet
RE: Arriva North East: Service Suggestions - RobinHood - 25 Aug 2022
Five of the fourteen are going to Ashington, yes. This was confirmed internally.
The remaining 9 are for (on paper - the 55(3) and the 46/51(5) +1 spare).
The 555 and 553 don't need CAZ compliant vehicles. I understand 2601-2603 are being kept for these.
If the 55 or 46 does go, then that will probably convert the 553/555 to E200, as they won't want to split the vehicle batch any more than already planned.
RE: Arriva North East: Service Suggestions - MurdnunoC - 25 Aug 2022
(25 Aug 2022, 5:36 pm)V514DFT wrote I do teckon the 55 might bite the bullet
Prefer Street Fighter or Mortal Kombat to Tekken though it is a good game.
RE: Arriva North East: Service Suggestions - RMF1254 - 26 Aug 2022
Shame for the residents of Meadway, Forest Hall, Longbenton and the Matthew Bank area whose only direct bus to the City Centre is the 55. I don’t think can count the 63 as a direct bus from Forest Hall as it goes via Heaton and Byker.
RE: Arriva North East: Service Suggestions - Storx - 26 Aug 2022
(25 Aug 2022, 7:56 pm)RobinHood wrote Five of the fourteen are going to Ashington, yes. This was confirmed internally.
Thank you, wasn't made up bus rumours for once then. Believe it's the first the 57/57A/10/10A/11/12/810/811/442/19/318 or whatever other variation I've missed of them has had a brand new bus bought for them since deregulation.
(26 Aug 2022, 8:04 am)RMF1254 wrote Shame for the residents of Meadway, Forest Hall, Longbenton and the Matthew Bank area whose only direct bus to the City Centre is the 55. I don’t think can count the 63 as a direct bus from Forest Hall as it goes via Heaton and Byker.
Longbenton has the 52, Matthew Bank has the X7/X8. For the other half of the route, they could easily divert the 52 to go to Killingworth via the 55/53 route. It would arguably offer a better service anyway as it would reconnect the links up to Cramlington which they lost with the 42 cuts. No-one else really loses out, Cramlington/Burradon uses the X7/X8 to Newcastle / Quorum anyway so adding time to the Southern end of the route wouldn't be the end of the world as long as they diverted the 54 to loop FLE.
RE: Arriva North East: Service Suggestions - V514DFT - 26 Aug 2022
(26 Aug 2022, 8:28 am)Storx wrote Thank you, wasn't made up bus rumours for once then. Believe it's the first the 57/57A/10/10A/11/12/810/811/442/19/318 or whatever other variation I've missed of them has had a brand new bus bought for them since deregulation.
Do you mean loop like what the 356/56 used to do
Unless its curtailed at FLE
(25 Aug 2022, 7:57 pm)MurdnunoC wrote Prefer Street Fighter or Mortal Kombat to Tekken though it is a good game.
Shhhh you,i was half asleep lol
(26 Aug 2022, 9:54 am)V514DFT wrote Do you mean loop like what the 356/56 used to do
I can't link it now as I'm on my phone but it was the 52 taking over the 55 from FLE to the end of Meadway then after there just running the 53 route to Killingworth then back as the 52 route from Killingworth to Cramlington.
Tbh i cant see how that wouldnt work
Another on i was thinking is this
Re-number the 51A to 50 divert it to serve Cross Avenue,Springfield Gardens,Wiltshire Drive,giving those residents back a bus that was lost when the 42 was withdrawn and an improves link to Newcastle for them
Then the 51 do this Haymarket, Matthew Bank, D.S.S Longbenton,FLE, Whitley Road then re-joining its old route from the roundabout outside The Range
52 does your suggestion
Arriva North East: Service Suggestions - tyresmoke - 29 Aug 2022
Personally I think it’s more likely the 46 is withdrawn completely and the 55 reduced to half hourly would fit in the gap between the 51s. Remotely operating this from Blyth at Whitley Bay wouldn’t be beyond the imagination once Jesmond/Walkergate does close.
RE: Arriva North East: Service Suggestions - RMF1254 - 30 Aug 2022
(26 Aug 2022, 5:28 pm)V514DFT wrote Tbh i cant see how that wouldnt work
I’m not surprised buses were removed from Springfield Gardens because of the number of parked cars, even the minibuses had a problem. Looking at the stops, only the one at Springfield Gardens / Cross Ave junction was really affected by the 42 withdrawal and even that stop is very close to Wiltshire Drive.The other 2 stops are almost on Wiltshire Drive or Station Road.
Removing the 51 from the Coast Rd and Station Road would seem to remove most of its passengers. Recently both the 51 / 51a seem busier as they are picking up more passengers from the new housing on Station Rd. I was on a 51a last week which was full with standing passengers at the bottom of Wiltshire Drive.
RE: Arriva North East: Service Suggestions - L469 YVK - 19 Sep 2022
- X7 - Same route but every 20 minutes.
- X8 - Withdrawn and replaced by 43/43A.
- X9 - Same route as now from Blyth to Shankhouse then via X10 route to Newcastle. Every 30 minutes.
- X10 - Same route as now from Blyth to Newcastle. Every 30 minutes.
- X11 - Same route as now from Blyth to Newcastle. Every 30 minutes.
- 43 - Same route as now from Morpeth to Cramlington. Then via High Pit, Annitsford and Fern Drive before resuming normal route. Every 30 minutes Newcastle to Cramlington, continuing to Morpeth every 60 minutes. Could additionally serve NSECH depending on timings.
- 43A - Same route as 'old' X9/X13 including Amersham Road. Will operate all stops between Fisher Lane and Newcastle via Seaton Burn and Wide Open. Every 30 minutes Newcastle to Cramlington, continuing to Blyth every 60 minutes.
- 44/45 - Re-instated to every 30 mins each (every 15 combined).
PVRs (before COVID) = 39x:
- X7/X8/X9 - 14x
- X10/X11 - 13x
- 43 - 7x
- 44/45 - 5x
Current PVR (not including temp reductions to 43/44/45*) = 34x:
- X7/X8/X9 - 14x
- X10/X11 - 8x
- 43 - 7x
- 44/45 - 5x
* Note this PVR is reduced by a further 3x if temp reductions to 43/44/45 are taken into account
Suggested PVR = 36x
- X7 - 7x
- X9/X10/X11 - 13x
- 43/43A - 9x
- 44/45 - 7x
Benefits of above changes:
- Even faster journey times from North of Blyth and Bebside to Newcastle.
- 10 minute combined frequency restored > Blyth - Parkside - Cramlington - Newcastle.
- New direct links to NSECH and to nearby new build developments in East Cramlington.
- Easier vehicle allocations and purchasing decisions, with all Blyth to Newcastle 'X' routes streamlined.
* PVR of all Blyth to Newcastle 'X' routes would be 20x, therefore covering a similar size order for what was previously ordered for Ashington.
* 2023 - 20x StreetDeck - X7 & X9/X10/X11
- More reliable service for High Pit, Annitsford and a new direct link to Newcastle restored along Fern Drive.
- Improved frequency for the Seaton Valley.
Drawbacks of above changes:
- Loss of more direct service for Northern Terrace (but still have services 52/53).
- Slightly reduced frequency through Burradon, Camperdown, Cygnet Park and Quorum (but still every 20 minutes).
- Slightly slower service from Eastfields and Beacon Hill to Newcastle.
- Reduced frequency via South Newsham (South Beach) and Eastfields - has been previously reduced during COVID so potentially not well used?
RE: Arriva North East: Service Suggestions - Storx - 19 Sep 2022
(19 Sep 2022, 8:39 am)L469 YVK wrote - X7 - Same route but every 20 minutes.
- X7/X8/X9 - 14x
- X10/X11 - 13x
- 43 - 7x
- 44/45 - 5x
- X7/X8/X9 - 14x
- X10/X11 - 8x
- 43 - 7x
- 44/45 - 5x
Suggested PVR = 36x
- X7 - 7x
- X9/X10/X11 - 13x
- 43/43A - 9x
- 44/45 - 7x
See if I was going to do stuff I think I'd be more radical than that and do something like:
X7 - No Changes
X8 - Do the old 363 route via Fern Drive, extended to Morpeth hourly to replace the 43 extension instead of heading to Blyth.
X9 - No Changes  (when new housing built run through new estates - see below)
X10/X11 - No Changes
42 - Newcastle to Seaton Burn (turn around at roundabout) only, Every 30 Minutes (when new housing is built at Cramlington and roads opened extended to Cramlington - see below)
43 - Dropped to every 30 minutes, partially replaced by X8 via Dudley and extended to Blyth on X8 route instead of Morpeth (when new housing is built at Cramlington and roads opened run via new estates)
44 - Every 30 Minutes
45 - Every 30 Minutes
46 - No Changes
52 - Same route Newcastle to Four Lane Ends, 55 route to Palmersville, 53 route to Killingworth, same route to Cramlington
53 - No Changes
54 - Additionally serve Four Lane Ends
55 - Withdrawn, Meadway section replaced by 52, South Gosforth to Newcastle covered by X7/X8.
1 - Curtailed at Wansbeck Hospital (PVR 3)
2 - No Changes
56 - Cramlington to Cresswell, hourly (PVR 2)
57 - Whitley Bay to Cramlington via Seghill, Annitsford, direct to Manor Walks, hourly (when new housing built run through new estates - see below)
57A - No Change (PVR 3 Combined)
Everything else remain the same.
Benefits:
New Morpeth and Bedlington to Quorum service (X8)
South Beach gets service back to Regent Centre (43)
Seghill gets 30 minute service back to Whitley Bay / Cramlington
Removed duplicate service 55 and serve more areas with 52 restoring Forest Hall to Cramlington links lost with GNE, the time difference isn't much.
Guide Post and Stakeford get direct Wansbeck Hospital service.
Everything else is pretty much the same.
New routes in future:
43/57 - Lime Route
42 - Orange Route
X9 - Pink Route
RE: Arriva North East: Service Suggestions - V514DFT - 20 Sep 2022
(19 Sep 2022, 10:44 am)Storx wrote See if I was going to do stuff I think I'd be more radical than that and do something like:
X7 - No Changes
46 - No Changes
53 - No Changes
2 - No Changes
Benefits:
43/57 - Lime Route
42 - Orange Route
X9 - Pink Route
Your 52 would also give Forest Hall back a bus to the Freeman Hospital
RE: Arriva North East: Service Suggestions - Storx - 20 Sep 2022
(20 Sep 2022, 8:33 am)V514DFT wrote Your 52 would also give Forest Hall back a bus to the Freeman Hospital
Aye your right, missed that one ngl.
I'd also swap the 53 and 54
53- Cramlington-Whitley Bay
54-Newcastle-North Shields
Never understood why it was swapped in the first place after the 56/X6 was axed, ran perfectly fine when it was the 356
(20 Sep 2022, 7:36 pm)V514DFT wrote I'd  also swap the 53 and 54
Must admit I didn't really get that one, guessing the people in Backworth preferred a bus to Whitley over North Shields. All I can really think of tbh.
I'm surprised the 52/53/54 are all still full size buses, the 52 (340/342) and 53 (343/344) ran with minibuses for years and they never really shouted out at bus routes that needed anything bigger tbh. Whenever I see them now they never seem to need anything bigger either tbh but there might be some areas I miss where they actually need them.
RE: Arriva North East: Service Suggestions - V514DFT - 21 Sep 2022
The 52/53/54 are strange routes tbh, sometimes it gets rammed, then other times it carries fresh air
RE: Arriva North East: Service Suggestions - GNE6312 - 28 Sep 2022
53 used to go to Whitley Bay years ago when it ran from Blyth to Whitley Bay via Cramlington and the current route from Cramlington to New York. Remember doing the whole run of it on a V reg dart, was about 2 hours end to end from Blyth to Whitley Bay.
RE: Arriva North East: Service Suggestions - Storx - 28 Sep 2022
(28 Sep 2022, 1:46 pm)GNE6312 wrote 53 used to go to Whitley Bay years ago when it ran from Blyth to Whitley Bay via Cramlington and the current route from Cramlington to New York. Remember doing the whole run of it on a V reg dart, was about 2 hours end to end from Blyth to Whitley Bay.
The 53 ran from Whitley to Cramlington for years with the Vario's then MPD's. It's just the old 343/344 which used to extend to Morpeth aswell instead of the 43.
Not sure if you knew then for some reason they swapped what was the 356, now partially the 54 and 53 around around 2012 I believe it was.
The 56/57/57A used to interwork hence the number change so it was easier to change the manual blinds at North Shields.
RE: Newcastle Depot - Storx - 02 Oct 2022
(13 Aug 2022, 9:35 am)L469 YVK wrote A hypothetical one here, would Arriva not have been better off doing a deal with GNE?
GNE > Arriva
- 21 - Arriva takes this on and operates out of Belmont.
- GNE keep the X21 to keep CMA happy.
Arriva > GNE
- All Jesmond routes bar the 306 which is kept by Arriva and moved to Blyth. 685 moved to Hexham.
* All other services split between Percy Main & Riverside.
Benefits:
- Dead mileage reduced for both operators (although GNE would need to keep the X21 > could find space at Washington maybe moving the 8 to Consett and doing remote reliefs at Stanley).
- ANE get another 'gold mine' route in their portfolio alongside the 308 as well as some drivers from GNE's CLS operation if they agreed to TUPE and move to Belmont.
- GNE get an increased presence again in North Tyneside and can (hopefully under a new MD) stabilise their network.
- ANE can have a stronger focus concentrating on Blyth & Ashington.
I'm not going to hunt for your post which always mentioning it.
But I actually agree than Arriva should probably try later buses on the X7 / X11 / X21 / 308 possibly using the 43 / 44 / 45 / 52 / 53 / 54 buses which terminate in Newcastle at a night to get them back to Blyth / Ashington even if it's just a Saturday.
I'm not sure whether last night was a freak night but it's busiest I've seen all them at 11pm even before Covid. The X7 believe had 35+, there was still 24 on board at Seaton Delaval and quite a few had already left. The X11 and X21 seemed even busier. The X11 nearly filled a double decker (and I'm not talking 1 person per seat).
Mind it was noticeable how dead the Jesmond routes were on the other hand the 52 was single numbers and the 43 didn't seem much better (why on earth does the 52 and X7 leave a same time is a mystery considering the duplication of the routes and their both hourly but that's another thing).
Wonder if we might see long term the likes of the last 52 scrapped and running on the X7 instead with the inbound X7 terminating at Seghill to save buses, the inbound buses are always dead to get them back to the depot.
RE: Newcastle Depot - omnicity4659 - 02 Oct 2022
(02 Oct 2022, 6:20 am)Storx wrote But I actually agree than Arriva should probably try later buses on the X7 / X11 / X21 / 308 possibly using the 43 / 44 / 45 / 52 / 53 / 54 buses which terminate in Newcastle at a night to get them back to Blyth / Ashington even if it's just a Saturday.
Not at all a freak night, for a good few hours after the last bus departures there's an endless stream of hackney carriages heading north out of Newcastle.
Nights in Newcastle do fluctuate, sometimes the peak of it ends earlier which will fill up the last buses, but most of the time the peak ends later meaning that taxis handle it.
Some later bus departures might cut down on the amount of taxi drivers driving like dickheads up the Spine Road...
(02 Oct 2022, 7:09 am)omnicity4659 wrote Not at all a freak night, for a good few hours after the last bus departures there's an endless stream of hackney carriages heading north out of Newcastle.
Ah I didn't mean Newcastle there, I just meant the buses. Newcastle was quite quiet last night tbf but I've never seen Haymarket so busy. It's usually only 10 - 15 people on them whenever I've used it in the past.
Agreed with the taxis though around 3am but tbh I could imagine a lot of them will refuse to use the bus anyway for whatever reason.
