Newcastle Clean Air Zone: services which need to be upgraded - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Management & Infrastructure (https://northeastbuses.co.uk/forumdisplay.php?fid=3) +--- Thread: Newcastle Clean Air Zone: services which need to be upgraded (/showthread.php?tid=2407) |
RE: Newcastle Clean Air Zone: services which need to be upgraded - glen - 05 Oct 2021 How many of Stockton E300 are going to be swop? RE: Newcastle Clean Air Zone: services which need to be upgraded - ne14ne1 - 05 Oct 2021 Do any of the smaller operators running Presidents and Tridents run services through the CAZ area, Scholars services for example? I know they often cover Metro Replacements but we don’t know if this work will be exempt to begin with. RE: Ne14ne1 - Storx - 05 Oct 2021 (05 Oct 2021, 11:17 am)peter wrote I think part of the problem with Arriva's fleet is that they have too many Solo's for their present operation. And so you end up with the situation at Jesmond where there's a mixture of everything on all services because they need to try and allocate the Solo's to the boards with the fewest passengers. We've seen Blyth essentially remove it's midi-bus fleet by nabbing Pulsars which have been made spare elsewhere due to Covid reductions, but the likes of Durham and Newcastle have too many smaller vehicles which are then having to be used on services which need higher capacity. Yeah your right tbh. Mind for the 57/57A (Ashington) you'd probably be better off running them with some form of midi bus even known they're not really needed capacity wise. It would be easier to have one type of bus for the 35 / 57 / 57A / X14 rather than having different fleets running different routes. The 1 / 2 / 58 at Blyth could be same as no doubt over time they won't need 10.8m Pulsar's either unless you can somehow get Jesmond running the 58. The Durham services and the 52/53/54/55 could all be ran by them aswell something like a 9.7m/10.4m vehicle with 29/33 forward seats would be more than enough. Least it brings a bit of fleet continuity so things can be swapped around easier rather that what we have at Ashington currently with the Solo's running on the X21 etc while 7510 has worked itself on the 57 boards again and everything being allover the place at both Jesmond and Durham. RE: Newcastle Clean Air Zone: services which need to be upgraded - 54APhotography - 05 Oct 2021 (05 Oct 2021, 9:03 am)Dan wrote Why do they need to put ALX300s through MOT? Surely it’d just be a swap of existing fleet, without impacting on MOT requirements?I think the 03 plates were all assumed to be withdrawn, but without any hope of anything new for the North East, the only option was to sort them out and get them ready for the switch. RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 05 Oct 2021 (05 Oct 2021, 12:35 pm)ne14ne1 wrote Do any of the smaller operators running Presidents and Tridents run services through the CAZ area, Scholars services for example?Jh have a few but haven't seen a Metro replacement contract over in Newcastle in a few months L&G do but there only put onto Metro replacement if its an emergency RE: Newcastle Clean Air Zone: services which need to be upgraded - Dan - 05 Oct 2021 (05 Oct 2021, 12:35 pm)ne14ne1 wrote Do any of the smaller operators running Presidents and Tridents run services through the CAZ area, Scholars services for example? I'd imagine the CAZ will force Nexus' hand to change tender specification to be Euro 6 on school bus services, ensuring operators have CAZ-compliant buses for Metro Replacement, rail replacement, and other special events - this can be done at relatively low expense through exhaust upgrades as we've seen on operators' commercial services. I'd not expect Metro Replacement to be exempt from the CAZ. RE: Newcastle Clean Air Zone: services which need to be upgraded - 54APhotography - 05 Oct 2021 (05 Oct 2021, 12:35 pm)ne14ne1 wrote Do any of the smaller operators running Presidents and Tridents run services through the CAZ area, Scholars services for example?There's that Weardale job that runs via Sandyford into town for one. RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 05 Oct 2021 Is it possible that more than likely GNE, Arriva and Stagecoach would end up being awarded metro replacement in Newcastle area then Jh and others doing Metro replacement out of Newcastle RE: Newcastle Clean Air Zone: services which need to be upgraded - Dan - 05 Oct 2021 (05 Oct 2021, 1:53 pm)Train8261 wrote Is it possible that more than likely GNE, Arriva and Stagsden would end up being awarded metro replacement in Newcastle area then Jh and others doing Metro replacement out of Newcastle No. Arriva can't bid for Metro Replacement, the only operators that can are Go North East, Stagecoach and JH Coaches. Stagecoach have never bid for a Metro Replacement contract yet (presumably isn't worth the hassle to them), so it's only really out of Go North East and JH Coaches. As I said before, I'd imagine Nexus will specify that the Miscellaneous Works contracts from September 2022 must be Euro 6. All the buses operating these services currently (Volvo B7TL, Scania OmniDekka, Dennis Trident) can be upgraded to Euro 6. RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 05 Oct 2021 (05 Oct 2021, 2:02 pm)Dan wrote No. Arriva can't bid for Metro Replacement, the only operators that can are Go North East, Stagecoach and JH Coaches.I'm guessing Stagecoach won't is because I remember back In early 2020. Stagecoach got awarded a Metro replacement contract between Regent Centre and Heworth. Stagecoach put what of 6 buses while Stanley Travel and GNE had to give the rest out. Yet we're on hire to Stagecoach RE: Newcastle Clean Air Zone: services which need to be upgraded - Andreos1 - 05 Oct 2021 (05 Oct 2021, 1:53 pm)Train8261 wrote Is it possible that more than likely GNE, Arriva and Stagsden would end up being awarded metro replacement in Newcastle area then Jh and others doing Metro replacement out of Newcastle Getting in before anyone else does! Are they a new company, similar to Ssriva, Lothian of Derwentside etc? RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 05 Oct 2021 (05 Oct 2021, 2:46 pm)Andreos1 wrote Getting in before anyone else does!Bloody autocorrect. It said stagecoach when typed stagecoach
RE: Newcastle Clean Air Zone: services which need to be upgraded - peter - 06 Oct 2021 (05 Oct 2021, 1:12 pm)Storx wrote Yeah your right tbh. Mind for the 57/57A (Ashington) you'd probably be better off running them with some form of midi bus even known they're not really needed capacity wise. It would be easier to have one type of bus for the 35 / 57 / 57A / X14 rather than having different fleets running different routes. The 1 / 2 / 58 at Blyth could be same as no doubt over time they won't need 10.8m Pulsar's either unless you can somehow get Jesmond running the 58. Yeah I agree, Arriva's system of regulation and lack of fixed allocation makes them the ideal candidates for fleet standardisation and yet they don't seem to really employ it. I do hope they might take the opportunity during the next fleet renewal. -Ashington and Blyth are fairly simple really, I think replacing the remaining single-decks with double-decks on the 'former' MAX services would help, with just the 1/2, 57/57A, and 58 as non-double deck. No route specific branding (except Sapphire X21/X22) and all the same vehicles would make regulation and allocation a much more effective process. -Jesmond is slightly more complex but I think more standardised single and double deck fleets e.g. Streetlites and E400's for generic allocation across the 43/44/45, 52/53/54, 306 and 685 would help, with Solo's used on everything else. -Darlington do okay with Solo's on the town services and then larger vehicles on the long distance services - obviously the Omnicities are crying out to be replaced. -Redcar I think could do with some more Streetlites so they can make the full allocation on the X3/X3A/X4 and remove their now dwindling fleet of Pulsars - definitely think a swap with those currently at Belmont would make sense, and then Temsa's cover everything else. -Stockton does best with a fleet almost entirely made up of Pulsars - I reckon the Centros could be used elsewhere - Ashington or Blyth maybe. -Durham I think is in the worst position with a very mismatched fleet. A standardised set of single and double decks for use on the 6/7/22/23/24/43/X46/48/64/X12 and then a minibus fleet for the 49/49A/56/57/57A/61/62 would be ideal but I don't know how achievable. RE: Newcastle Clean Air Zone: services which need to be upgraded - idiot - 06 Oct 2021 Why can't Arriva bid for metro replacement? Have I missed something?! Newcastle Clean Air Zone: services which need to be upgraded - Dan - 06 Oct 2021 (06 Oct 2021, 7:28 am)idiot wrote Why can't Arriva bid for metro replacement? Have I missed something?! Operators need to ‘sign up’ at the start of the term for planned Metro Replacement - only Go North East, Stagecoach and JH Coaches signed up. Sent from my iPhone using Tapatalk RE: Newcastle Clean Air Zone: services which need to be upgraded - MurdnunoC - 06 Oct 2021 (05 Oct 2021, 2:46 pm)Andreos1 wrote Getting in before anyone else does! Funny you mention this. On my walk to work this morning, I noticed a TfL bus operating the 794. With all these new operators, such as Lothian of Derwentside and Transdev of Sacriston, operating in the area, I guess Transport for Derwentside (TfD) has had to step in to sort everything out before it becomes a complete mess. RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 06 Oct 2021 (06 Oct 2021, 8:38 am)MurdnunoC wrote Funny you mention this.That might be one of Weardale Moter Service new bus RE: Newcastle Clean Air Zone: services which need to be upgraded - RMF1254 - 06 Oct 2021 (06 Oct 2021, 9:08 am)Train8261 wrote That might be one of Weardale Moter Service new busCorrect, I passed an ex London Scania Omnicity DD in Sandyford on Monday. It was all over red with a Weardale fleet name. I also saw it (or a similar one) on a scholars working in Wallsend yesterday. I think the two services could be operated by the same bus. RE: Newcastle Clean Air Zone: services which need to be upgraded - NewcastleOne - 06 Oct 2021 (06 Oct 2021, 9:29 am)RMF1254 wrote Correct, I passed an ex London Scania Omnicity DD in Sandyford on Monday. It was all over red with a Weardale fleet name. I also saw it (or a similar one) on a scholars working in Wallsend yesterday. I think the two services could be operated by the same bus.It would make sense considering the mileage. RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 06 Oct 2021 (06 Oct 2021, 9:29 am)RMF1254 wrote Correct, I passed an ex London Scania Omnicity DD in Sandyford on Monday. It was all over red with a Weardale fleet name. I also saw it (or a similar one) on a scholars working in Wallsend yesterday. I think the two services could be operated by the same bus.Yea does a 794 to the D,S,S then 681 Scholars then in the afternoon does 681 Scholars then 794 D,S,S RE: Newcastle Clean Air Zone: services which need to be upgraded - idiot - 06 Oct 2021 (06 Oct 2021, 7:29 am)Dan wrote Operators need to ‘sign up’ at the start of the term for planned Metro Replacement - only Go North East, Stagecoach and JH Coaches signed up. Thanks for the reply. How often do these come up? RE: Newcastle Clean Air Zone: services which need to be upgraded - V514DFT - 06 Oct 2021 (05 Oct 2021, 2:02 pm)Dan wrote No. Arriva can't bid for Metro Replacement, the only operators that can are Go North East, Stagecoach and JH Coaches.The last time i saw Stagecoach run the 900,was like 2003,theyve probably done again since then but i havent seen it RE: Newcastle Clean Air Zone: services which need to be upgraded - Andreos1 - 07 Oct 2021 (06 Oct 2021, 11:54 pm)V514DFT wrote The last time i saw Stagecoach run the 900,was like 2003,theyve probably done again since then but i havent seen it They had some work when the Shields extension was ongoing alongside some connected work. Can remember being lumbered on a replacement one night after going to Ocean Road and then the Customs House. I'd completely forgot the metros weren't running, but had planned the return leg around the 4 from Heworth. RE: Newcastle Clean Air Zone: services which need to be upgraded - stagecoachbusdepot - 07 Oct 2021 (06 Oct 2021, 11:54 pm)V514DFT wrote The last time i saw Stagecoach run the 900,was like 2003,theyve probably done again since then but i havent seen it They operated the 900 in Aug 2018 between Four Lane Ends and Monument to allow for modernisation work on the line. RE: Newcastle Clean Air Zone: services which need to be upgraded - Keeiajs - 27 Nov 2021 What's happening with the Toon Tour Euro 6? RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 27 Nov 2021 (27 Nov 2021, 7:07 pm)Keeiajs wrote What's happening with the Toon Tour Euro 6?Think there using the Ex London Open Toppers RE: Newcastle Clean Air Zone: services which need to be upgraded - Keeiajs - 27 Nov 2021 (27 Nov 2021, 7:36 pm)Train8261 wrote Think there using the Ex London Open ToppersSo what will the current 3 be used for? AD122's? X66's? 19's? 61's? Really if they based 2 at Hexham, One at Deptford or Riverside could get some nice services. RE: Newcastle Clean Air Zone: services which need to be upgraded - Train8261 - 27 Nov 2021 (27 Nov 2021, 7:41 pm)Keeiajs wrote So what will the current 3 be used for?Knowing GNE. Sold as they don't meet Euro 6 or scrapped RE: Newcastle Clean Air Zone: services which need to be upgraded - Keeiajs - 07 Dec 2021 Does anyone think there will be a Euro 7, RE: Newcastle Clean Air Zone: services which need to be upgraded - omnicity4659 - 08 Dec 2021 (07 Dec 2021, 11:29 pm)Keeiajs wrote Does anyone think there will be a Euro 7, Already is. Due to be announced soon, if not already. |
