RE: Go North East: Service Suggestions v2 - Malarkey - 11 Oct 2021 V1/V2 - Stanley - East Stanley - Sheridan Drive - Stanley Hall Estate - South Moor - Quaking Houses - Lanchester - Burnhope - Delves Lane - Consett - Number One Roundabout - Shotley Bridge Hospital - The Dene - High Westwood - Ebchester - Hamsterley - Hamsterley Hill - Burnopfield - Crookgate Bank - Tanfield - Tanfield Lea - Stanley Merging of Services 30/31/V1/V2 & V3 creating a circular service between Consett and Stanley operating Every 30 Minutes Monday to Sunday. Quaking Houses to Stanley via South Moor RE: Go North East: Service Suggestions v2 - Keeiajs - 11 Oct 2021 Upgrade X6/62 to versa's RE: Go North East: Service Suggestions v2 - ASX_Terranova - 11 Oct 2021 You could remove the 37 (Nexus) entirely by extending the 82 to Concord, 82, 84 or 85 to Coach Road & 33 to Washington Galleries. Go North East: Service Suggestions v2 - cbma06 - 12 Oct 2021 (11 Oct 2021, 10:38 pm)ASX_Terranova wrote You could remove the 37 (Nexus) entirely by extending the 82 to Concord, 82, 84 or 85 to Coach Road & 33 to Washington Galleries. Isn’t the 37 a secured service?, there’s nothing much you can do with a secured service ran by the local authority, as there’s a reason why the service runs as is, it doesn’t run to profit to line the pockets of bus companies , there run the service as it’s needed in the community Sent from my iPhone using Tapatalk RE: Go North East: Service Suggestions v2 - Andreos1 - 12 Oct 2021 (12 Oct 2021, 7:00 am)cbma06 wrote Isn’t the 37 a secured service?, there’s nothing much you can do with a secured service ran by the local authority, as there’s a reason why the service runs as is, it doesn’t run to profit to line the pockets of bus companies , there run the service as it’s needed in the community The 37 came about after GNE decided to do away with their commercial offerings. It left a few areas without a service and Nexus had to step up and fill the gap. RE: Go North East: Service Suggestions v2 - ASX_Terranova - 12 Oct 2021 (12 Oct 2021, 8:04 am)Andreos1 wrote The 37 came about after GNE decided to do away with their commercial offerings. It left a few areas without a service and Nexus had to step up and fill the gap.Am i right i thinking that even back in the 169 days it was a secured service. RE: Go North East: Service Suggestions v2 - User2613 - 12 Oct 2021 Could a 4a type route work? I was thinking normal route heworth to the galleries then out of Washington running via lambton, harraton (sycamore avenue) and rickelton to Chester then the 71 route to Houghton. Journey time would be 70 minutes each way so a PVR of 5 with a 30 minute frequency. The 8 could then be rerouted to be sped up between the galleries and Chester and potentially mean the timing of the 78 and 8 could be made more even rather than running from common areas a few minutes apart like now. The 71 could also be withdrawn. RE: Go North East: Service Suggestions v2 - Train8261 - 12 Oct 2021 (12 Oct 2021, 5:15 pm)User2613 wrote Could a 4a type route work? I was thinking normal route heworth to the galleries then out of Washington running via lambton, harraton (sycamore avenue) and rickelton to Chester then the 71 route to Houghton. Journey time would be 70 minutes each way so a PVR of 5 with a 30 minute frequency.Nah can't withdraw the 71. September service changes already proved that RE: Go North East: Service Suggestions v2 - User2613 - 12 Oct 2021 (12 Oct 2021, 6:11 pm)Train8261 wrote Nah can't withdraw the 71. September service changes already proved thatThat's because of the Chester to Houghton section. Which this would replace. Past versions of the 71 and 36 when that existed all had the Chester to Houghton section as that's the section which is subsidised. RE: Go North East: Service Suggestions v2 - Andreos1 - 12 Oct 2021 (12 Oct 2021, 2:30 pm)ASX_Terranova wrote Am i right i thinking that even back in the 169 days it was a secured service. The 169 wasn't the same as the 37 though. Two totally different routes. The 37 came about after GNE removed the service to Biddick Woods and axed one variation of a Newcastle express, which extended to Seaham. They did send the X1 (would have been the X5 at the time) in to Biddick Woods at one point. I say they sent it in - it was meant to serve Biddick Woods, but more often than not, they didn't bother. RE: Go North East: Service Suggestions v2 - Keeiajs - 12 Oct 2021 (12 Oct 2021, 6:11 pm)Train8261 wrote Nah can't withdraw the 71. September service changes already proved thatThat was because the main part of the service is subsidised so if they did replace that section they could withdraw that route. RE: Go North East: Service Suggestions v2 - Storx - 12 Oct 2021 (12 Oct 2021, 6:20 pm)User2613 wrote That's because of the Chester to Houghton section. Which this would replace. Past versions of the 71 and 36 when that existed all had the Chester to Houghton section as that's the section which is subsidised. I don't know the history of Houghton to Seaham but I'd be surprised if that bit nowadays at least isn't important if not more so that the Chester to Houghton end which is mostly Nexus territory. It's the only bus in Dene Estate and Seaton and would leave communities without a bus service at all, the other end is all served by buses even known it means changing buses. RE: Go North East: Service Suggestions v2 - Andreos1 - 12 Oct 2021 (12 Oct 2021, 5:15 pm)User2613 wrote Could a 4a type route work? I was thinking normal route heworth to the galleries then out of Washington running via lambton, harraton (sycamore avenue) and rickelton to Chester then the 71 route to Houghton. Journey time would be 70 minutes each way so a PVR of 5 with a 30 minute frequency. I think it was a variation of the 179, but pretty sure the Washington - Houghton via Chester has been tried already. At least 2 or 3 times. Chester - Seaham was the 735 donkeys years ago and that didn't last, even when the pits were open. Thats not to say it can't/won't work nowadays. My own thoughts revolve about the need to improve the headway on the Washington - Chester and Chester - Woodstone Village services before tinkering with any routes. That should be the priority imo. RE: Go North East: Service Suggestions v2 - Keeiajs - 12 Oct 2021 (12 Oct 2021, 6:35 pm)Storx wrote I don't know the history of Houghton to Seaham but I'd be surprised if that bit nowadays at least isn't important if not more so that the Chester to Houghton end which is mostly Nexus territory. It's the only bus in Dene Estate and Seaton and would leave communities without a bus service at all, the other end is all served by buses even known it means changing buses.You could do like a 60A, which would be seperate to the current Version - Parkside, Princess Road, Seaham, Seaton - Houghton - Sunderland College - Sunderland. (12 Oct 2021, 5:15 pm)User2613 wrote Could a 4a type route work? I was thinking normal route heworth to the galleries then out of Washington running via lambton, harraton (sycamore avenue) and rickelton to Chester then the 71 route to Houghton. Journey time would be 70 minutes each way so a PVR of 5 with a 30 minute frequency.8/78 should be kept 15 mins apart from each other most time, not as bad timing as X6/62. RE: Go North East: Service Suggestions v2 - V514DFT - 12 Oct 2021 Tbh ive thought this for a while,but i think what helps a service to grow,is frequency,and the attractiveness of vehicles that service uses,if neither appeal,then that said service's days are numbered from day 1 RE: Go North East: Service Suggestions v2 - ASX_Terranova - 13 Oct 2021 Increase 8 to Every 20 Mins, With 2 8's and an 8A 8 Route to remain the same except for serving Enterprise Park Western End. 8A Re-route: Park Lane, Royal Hospital, Pallion, Spire Bridge, Casteltown, Teal Farm, Waterview Park, Barmston Slip-Road, Washington Galleries, Biddick, Harraton, Rickleton, Picktree, Chester-Le-Street, Pelton, Newfield, Grange Villa, Craghead, South Moor, Stanley. Departs Stanley: 19 (8), 39, (8A), 59 (8) Departs Sunderland: 52 (8), 12 (8A), 32(8) Would provide additonal buses between CLS, Pelton, Newfield, Grange Villa & Stanley. Would give GNE Links between Park Lane, Royal Hospital, St Lukes Cross, Pallion & Castletown. If still not enough, make the 78 every 20 Mins and add a 78A as well. RE: Go North East: Service Suggestions v2 - Storx - 13 Oct 2021 (13 Oct 2021, 2:46 pm)ASX_Terranova wrote Increase 8 to Every 20 Mins, With 2 8's and an 8A Personally on the Western side if you wanted to increase buses to Stanley I'd change the 28/28A/28B all running through to this route - https://www.google.com/maps/dir/54.868208,-1.6989631/Ouston/@54.8681785,-1.702673,14z/data=!4m54!4m53!1m45!3m4!1m2!1d-1.6841682!2d54.8687004!3s0x487e78ce5d2134bf:0xa7e5f9a9b3b401e6!3m4!1m2!1d-1.681579!2d54.8692628!3s0x487e78d1d6d8f2bf:0x777257e07cb84497!3m4!1m2!1d-1.6784818!2d54.8697822!3s0x487e78d101e11079:0x18c31efe295cf871!3m4!1m2!1d-1.6753774!2d54.8729229!3s0x487e78d9ff38061f:0x18d95b294a13df41!3m4!1m2!1d-1.6623113!2d54.8736791!3s0x487e792609f7b0c5:0x5756dacd9110dcb5!3m4!1m2!1d-1.6545401!2d54.8771002!3s0x487e793b4cc29e45:0x511dde5079b6fc27!3m4!1m2!1d-1.640346!2d54.8710492!3s0x487e79483a856ff1:0x2f3f5258f4ceba5c!3m4!1m2!1d-1.6353561!2d54.8726823!3s0x487e7948a3c64345:0x4cfa21f66b7a1b87!3m4!1m2!1d-1.6245162!2d54.8705222!3s0x487e7950549b6ea5:0xea82d5394aa0168b!1m5!1m1!1s0x487e7bdd1a08158f:0xa34de1daebc7bd17!2m2!1d-1.5977091!2d54.883391!3e0 It gives a few new links such as Birtley / Ouston to Stanley, evening East Stanley to Newcastle, Stanley to Gateshead (even known slow), No Place to Newcastle, QE to Stanley. It also partially replaces the 31 and gives new links to places where people actually want to be as long as you can work with DCC and get stops on Humber Hill or do Hail and Ride. Not sure what demand there would be but it seems more logical than it's Perkinsville ending and Pelton Fell has the 78/78A so the horseshoe route doesn't make much sense nowadays since everywhere else has the 8 to CLS which is quicker. RE: Go North East: Service Suggestions v2 - ASX_Terranova - 13 Oct 2021 (13 Oct 2021, 3:25 pm)Storx wrote Personally on the Western side if you wanted to increase buses to Stanley I'd change the 28/28A/28B all running through to this route - https://www.google.com/maps/dir/54.868208,-1.6989631/Ouston/@54.8681785,-1.702673,14z/data=!4m54!4m53!1m45!3m4!1m2!1d-1.6841682!2d54.8687004!3s0x487e78ce5d2134bf:0xa7e5f9a9b3b401e6!3m4!1m2!1d-1.681579!2d54.8692628!3s0x487e78d1d6d8f2bf:0x777257e07cb84497!3m4!1m2!1d-1.6784818!2d54.8697822!3s0x487e78d101e11079:0x18c31efe295cf871!3m4!1m2!1d-1.6753774!2d54.8729229!3s0x487e78d9ff38061f:0x18d95b294a13df41!3m4!1m2!1d-1.6623113!2d54.8736791!3s0x487e792609f7b0c5:0x5756dacd9110dcb5!3m4!1m2!1d-1.6545401!2d54.8771002!3s0x487e793b4cc29e45:0x511dde5079b6fc27!3m4!1m2!1d-1.640346!2d54.8710492!3s0x487e79483a856ff1:0x2f3f5258f4ceba5c!3m4!1m2!1d-1.6353561!2d54.8726823!3s0x487e7948a3c64345:0x4cfa21f66b7a1b87!3m4!1m2!1d-1.6245162!2d54.8705222!3s0x487e7950549b6ea5:0xea82d5394aa0168b!1m5!1m1!1s0x487e7bdd1a08158f:0xa34de1daebc7bd17!2m2!1d-1.5977091!2d54.883391!3e0Are you saying bring back the 709/728 RE: Go North East: Service Suggestions v2 - ASX_Terranova - 15 Oct 2021 New Services for South Shields [b]503 & 504[/b] Same as SNE SS 3 & 4 [b][u]507 & 508[/u][/b] Same as SNE SS 7 & 8 510 & 511 South Shields, Bents Park, Horsley Hill, Marsden, McAnay Avenue, Hospital, Biddick Hall, Simonside, Stanhope Road, Chichester, Laygate, Trinity & South Shields 510 Clockwise (Every 30 MIns) 511 Anti-Clockwise (Every 30 Mins) 512 Same as SNE SS 12 515 & 516 South Shields, The Lawe, Lakes Avenue, Horsley Hill, Centenary Avenue, Harton Nook, Harton Moor, Tyne Dock, Templetown, South Shields 515 Clockwise (Hourly) 516 Anti-Clockwise (Hourly) 518, 526 & 528 518: South Shields, Chichester, Stanhope Road, Simonside, Brockley Whins, Edinbrugh Road, Low Simonside (Every 15 MIns) 526: South Shields, Chichester, Hospital, Simonside, Brockley Whins, Edinbrugh Road, Hill Park, Jarrow, Hebburn, Hartleyburn Estate, Monkton Lane, Luke's Lane (Every 30 MIns) 528: South Shields, Chichester, Hospital, Simonside, Brockley Whins, Edinbrugh Road, York Avenue, Jarrow, Hebburn, Hartleyburn Estate, Monkton Lane, Luke's Lane (Every 30 MIns) Combined up to Every 7-8 Mins Between Shields, Chichester, Simonside, Brockley Whins & Edinbrugh Road. 530 Same as SNE SS 30 533 Stopping Version of SNE SS X20 with Longer Simonside Diversion and Increased 20 MIns Frequency 543 & 544 543: South Shields, Westoe, Tyne Dock, Jarrow, Hedgeley Road, Hebburn, Monkton Lane, Heworth (Every 30 MIns 544: South Shields, Westoe, King George Road, Hospital, Tyne Dock, Jarrow, Hedgeley Road, Hebburn, Monkton Lane, Washington Galleries (Every 30 MIns) Combined up to Every 15 Mins Between South Shields, Tyne Dock, Jarrow, Hedgeley Road, Hebburn & Monkton Lane 550, 551, 552 & 553 550: Same as 50 but diverted to serve Westoe & Whiteleas Shops 551: Existing 5 552: South Shields, Laygate, Chichester, Stanhope Road, Whiteleas Shops, Boldon ASDA, Cotswolds Estate (Every 30 MIns) 553: South Shields, Laygate, Chichester, Hospital, Whiteleas Shops, Boldon ASDA, Boldon Cineworld (Every 30 MIns) Combined up to Every 7-8 Mins Between Shields, Chichester, Whiteleas & Boldon ASDA RE: Go North East: Service Suggestions v2 - V514DFT - 15 Oct 2021 (15 Oct 2021, 5:53 pm)ASX_Terranova wrote New Services for South ShieldsSee i like this suggestion based on your numbering,because South Tyneside used to be 5**, you could also re-number the 26/27 to 526/527,the 9 to 559 North Tyneside could do this Q3-300 1-301 11-312 19-313 41/41A-314/315 42/42A-316/317 RE: Go North East: Service Suggestions v2 - peter - 20 Oct 2021 I know it's very fresh but I reckon there would be some benefit to combining new service 42 with the 204/204A. The previous Scarlet Band S1 service offered a direct connection from Mount Oswald to Dragonville Tesco. As the new student accommodation is self-catered, I imagine there would still be a student demand for that link and for residents of the housing estate tbh. In addition lots of students live in Gilesgate and previously used the S1 to commute to Uni. Have one bus on the new 42 continue to the rail station and the other would continue through to Gilesgate and beyond. I know the 42 is DCC supported but I can't see why they would appose to this if the 42 service was still maintained apart from only one service per hour to the station. RE: Go North East: Service Suggestions v2 - Keeiajs - 20 Oct 2021 (20 Oct 2021, 12:45 am)peter wrote I know it's very fresh but I reckon there would be some benefit to combining new service 42 with the 204/204A. The previous Scarlet Band S1 service offered a direct connection from Mount Oswald to Dragonville Tesco. As the new student accommodation is self-catered, I imagine there would still be a student demand for that link and for residents of the housing estate tbh. In addition lots of students live in Gilesgate and previously used the S1 to commute to Uni. Have one bus on the new 42 continue to the rail station and the other would continue through to Gilesgate and beyond. I know the 42 is DCC supported but I can't see why they would appose to this if the 42 service was still maintained apart from only one service per hour to the station.Do you have time table to these new changes? RE: Go North East: Service Suggestions v2 - ASX_Terranova - 21 Oct 2021 Could the 21 or 50 be diverted on the old X22 route (i.e. through Newton Hall & Carr House Drive), would the demand be there. RE: Go North East: Service Suggestions v2 - Jimmi - 21 Oct 2021 (21 Oct 2021, 1:29 pm)ASX_Terranova wrote Could the 21 or 50 be diverted on the old X22 route (i.e. through Newton Hall & Carr House Drive), would the demand be there.Not enough time currently to divert the 21/50 (or X20) via these areas, could maybe send the current X22 via there though as it currently has around 20 mins layover at the Metrocentre. No idea if demand would be there or not mind RE: Go North East: Service Suggestions v2 - Keeiajs - 21 Oct 2021 (21 Oct 2021, 3:48 pm)Jimmi wrote Not enough time currently to divert the 21/50 (or X20) via these areas, could maybe send the current X22 via there though as it currently has around 20 mins layover at the Metrocentre. No idea if demand would be there or not mindtbh I have been on the X22, and that 20 min layover is for delays on the A1. I think, or the X22 would be ridiculous late all the time. RE: Go North East: Service Suggestions v2 - Andreos1 - 21 Oct 2021 (21 Oct 2021, 1:29 pm)ASX_Terranova wrote Could the 21 or 50 be diverted on the old X22 route (i.e. through Newton Hall & Carr House Drive), would the demand be there. I've wondered if there's a deliberate operational decision to slow down the 21 between certain points (say Durham - Chester) , spreading the load and encouraging people to use the X21 between the same points. RE: Go North East: Service Suggestions v2 - V514DFT - 21 Oct 2021 I know Newcastle has more than enough services to/from Gateshead,but always thought they were missing a trick with the 93/94,i know back in the days of the 13/14 it used to go into Newcastle,dunno who ran it though RE: Go North East: Service Suggestions v2 - Wybus - 21 Oct 2021 The majority of the route has Newcastle services near by, Heworth side there is the 27, in the middle the 56, 57, 58, 21 etc, Team Valley South End there is the 28 and then Lobley Hill side the X70-X72 & 97 RE: Go North East: Service Suggestions v2 - Wybus - 21 Oct 2021 (21 Oct 2021, 4:13 pm)Keeiajs wrote tbh I have been on the X22, and that 20 min layover is for delays on the A1. I think, or the X22 would be ridiculous late all the time.It’s more the fact they can’t really take much layover at the Durham end at the moment without getting in the way, so it’s all taken at the MetroCentre end RE: Go North East: Service Suggestions v2 - ASX_Terranova - 22 Oct 2021 New Service 22: Newcastle, Bensham, Saltwell Park, Low Fell, Harlow Green, Washington Galleries, Lambton, Ayton, Chester-Le-Street, Plawsworth, Arnison Centre, Newton Hall, Carr House Drive, Framwellgate Moor, Durham, Shincliffe, Bowburn, Metal Bridge, Ferryhill. Every 15 Mins (Newcastle to Durham) Every 30 Mins (Newcastle to Ferryhill) Reasonings
if GNE wouldn't take this on, I could see someone else doing it instead. |
