Bank Holiday Services - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Management & Infrastructure (https://northeastbuses.co.uk/forumdisplay.php?fid=3) +--- Thread: Bank Holiday Services (/showthread.php?tid=1444) |
RE: Bank Holiday Services - Ambassador - 05 Apr 2017 Just hopped in the 22.42 21 ex Newcastle. Standing room only to the Angel. The previous two services were full. People still left at Gateshead Sure Sunday service on Good Friday will be fine...no demand is there RE: Bank Holiday Services - GX03 - 06 Apr 2017 (05 Apr 2017, 10:36 pm)Ambassador wrote Just hopped in the 22.42 21 ex Newcastle. Something to do with the match maybe? RE: Bank Holiday Services - Ambassador - 06 Apr 2017 (06 Apr 2017, 12:07 am)GX03 wrote Something to do with the match maybe? Well that's my point. Likely to be even higher demand on a Good Friday RE: Bank Holiday Services - GX03 - 06 Apr 2017 (06 Apr 2017, 6:08 am)Ambassador wrote Well that's my point. Likely to be even higher demand on a Good Friday Are Newcastle at home on Friday?, not a fan so don't know. RE: Bank Holiday Services - Ambassador - 06 Apr 2017 (06 Apr 2017, 7:08 am)GX03 wrote Are Newcastle at home on Friday?, not a fan so don't know. They are. It's a sellout top. Last night was about 4k down on capacity RE: Bank Holiday Services - L469 YVK - 06 Apr 2017 Right then, lets have a prediction on the so called delays then! GNE: 1/1A= 30 minutes 21= 40 minutes X1= 30 minutes 10/10A/10B = 15 minutes (up to 30 minutes on the 10) 45/46/47 = 30 minutes 12/12A = 10 minutes 309/310 = 30-45 minutes (or more with demand for Spainish City as well as traffic in Seaton Sluice for chippies, could rise if a number of 306/308s are no shows which will be likely if Tynemouth is busy as well as traffic the 308 will have to face) 56 = 15 minutes 57 = 15 minutes 58 = 10 minutes 27 = 15 minutes ANE: 306/308 = 30 minutes (Jesmond / Blyth can regulate if needed) X10/X11 = 15-20 minutes X18 = 15-30 minutes X21/35 = 30 minutes X22 = 15 minutes X7/X8 = 15 minutes 43/46/52/53 = 15-30 minutes 44/45= 15 minutes RE: Bank Holiday Services - citaro5284 - 06 Apr 2017 (06 Apr 2017, 7:28 pm)L469 YVK wrote Right then, lets have a prediction on the so called delays then! I hope you are not encouraging people to go to Harbour View, the queues on Good Friday are bad enough to start with
RE: Bank Holiday Services - PH - BQA - 06 Apr 2017 (06 Apr 2017, 7:28 pm)L469 YVK wrote Right then, lets have a prediction on the so called delays then! From what I remember, Ashington are usually pretty good at regulating the X21/22 and 35 on a Sunday or Bank Holiday when things start to run late. If one gets anywhere near +30 then they'll send something to cover the 35 run. RE: Bank Holiday Services - L469 YVK - 13 Apr 2017 Thought with tomorrow fast approaching I'll put a rather appropriate theme tune on here for you all: https://youtu.be/M8wl4acSmfs RE: Bank Holiday Services - Ambassador - 14 Apr 2017 GNE have confirmed football specials will run as normal tonight. Fairly badly advertised until today and still not that clear on the website RE: Bank Holiday Services - Mark1 - 14 Apr 2017 (14 Apr 2017, 2:11 pm)Ambassador wrote GNE have confirmed football specials will run as normal tonight. Its been on the Nexus website since Tuesday and on the GNE website news section since March RE: Bank Holiday Services - Adrian - 14 Apr 2017 (14 Apr 2017, 2:11 pm)Ambassador wrote GNE have confirmed football specials will run as normal tonight. You must wonder why Altoonative travel aren't publishing better details? RE: Bank Holiday Services - Ambassador - 14 Apr 2017 (14 Apr 2017, 8:41 pm)Mark1 wrote Its been on the Nexus website since Tuesday and on the GNE website news section since March When i asked GNE when timetables were published they advised,that the wouldn't be running, Judging by anecdote, I wasn't the only one told this RE: Bank Holiday Services - L469 YVK - 14 Apr 2017 Well, I seen a Jesmond 308 running 30 late as a VDL Pulsar then getting put onto the 43/46/52/53. I also seen an X22 running 15-20 minutes late. My 309 was 15 down as a result of the 308 above. RE: Bank Holiday Services - Ambassador - 29 May 2017 21 failing miserably today. Running in 3s Newcastle bound and packed Though on a plus they are all hybrids Edit 6066 running with Gateshead destination RE: Bank Holiday Services - Dan - 29 May 2017 (29 May 2017, 10:26 am)Ambassador wrote 21 failing miserably today. Running in 3s Newcastle bound and packed The steamed-up windows from the miserable weather must have obscured your vision of the two diesel pretend-rids out on the 21/X21 today (3962/65)! Jimmi needs to introduce you to the "What's annoying you today?" thread!
RE: Bank Holiday Services - Charles41 - 29 May 2017 (29 May 2017, 10:32 am)Dan wrote The steamed-up windows from the miserable weather must have obscured your vision of the two diesel pretend-rids out on the 21/X21 today (3962/65)! Jimmi needs to introduce you to the "What's annoying you today?" thread! I had to wait on over twenty minutes for a twenty one today. I decided to take the bus to newcastle rather than drive. Should have just took the car. Charles RE: Bank Holiday Services - Dan - 29 May 2017 (29 May 2017, 10:52 am)Charles41 wrote I had to wait on over twenty minutes for a twenty one today. I decided to take the bus to newcastle rather than drive. Should have just took the car. I always use real time information to my advantage when going out for buses now, especially when the weather isn't too good. Sometimes Go North East's app isn't the best for this, but the information tends to feed through to Google Maps without issue the majority of the time. The reliability of both seems to have improved significantly at each depot where the new ticket machines have been rolled out to, as well. This wouldn't help Ambassador with a bus being full, though! RE: Bank Holiday Services - idiot - 29 May 2017 I can't drive today due to alcohol intake last night. Can't be bothered to get the bus either RE: Bank Holiday Services - Ambassador - 29 May 2017 (29 May 2017, 10:32 am)Dan wrote The steamed-up windows from the miserable weather must have obscured your vision of the two diesel pretend-rids out on the 21/X21 today (3962/65)! Jimmi needs to introduce you to the "What's annoying you today?" thread! Haha, I'll stick with branded angels! Genuinely surprised by loadings today considering weather. Maybe time to reconsider Sunday pvr. On a plus I used the 28 and got the C&C Streetlite and it handles the route really well. Would be a great fit. Though the emergency exit door rattling was a little irritating. RE: Bank Holiday Services - Mark1 - 29 May 2017 Is the 50 allocated double deckers on a bank holiday, I think I am right in thinking it has previously when it was Chester-le-Street operated. I apprecite todays weather isn't going to encourage peole to go to South Shields. RE: Bank Holiday Services - Adrian - 29 May 2017 (29 May 2017, 1:07 pm)Mark1 wrote Is the 50 allocated double deckers on a bank holiday, I think I am right in thinking it has previously when it was Chester-le-Street operated. I apprecite todays weather isn't going to encourage peole to go to South Shields. In the past, the depots appear to have made a call based on the weather. There shouldn't be anything stopping Washington doing similar, as they have more than enough deckers standing around during a Sunday service. Unless the 5 route prevents this? Low bridges etc. RE: Bank Holiday Services - Ds1197 - 29 May 2017 (29 May 2017, 1:25 pm)Adrian wrote In the past, the depots appear to have made a call based on the weather. There shouldn't be anything stopping Washington doing similar, as they have more than enough deckers standing around during a Sunday service. Unless the 5 route prevents this? Low bridges etc. I think 5 and 50 are standalone on Sundays and the isn't any low bridges on the 5 the usually at least 1 double deckers allcatoted daily on the 5/50 RE: Bank Holiday Services - BusLoverMum - 29 May 2017 (29 May 2017, 12:22 pm)Ambassador wrote Haha, I'll stick with branded angels! I'm not surprised - we left the Metrocentre at 1-ish and the car parks were completely full with people stalking spaces like they do in the run up to Christmas. not exactly beach or barbecue weather, so what else is there oto do but the Northeast national pastime of shopping?! RE: Bank Holiday Services - South Tyne Lad - 29 May 2017 (29 May 2017, 1:38 pm)Ds1197 wrote I think 5 and 50 are standalone on Sundays and the isn't any low bridges on the 5 the usually at least 1 double deckers allcatoted daily on the 5/50 Nout stopping Decker's being sent out on 5's, No low bridges on route. And aye the 5 and 50/50A are standalone on Sundays. RE: Bank Holiday Services - L469 YVK - 09 Mar 2018 Looks like GNE will be running the X1 on a 20 minute frequency during the day on Good Friday. Great move and hope more service follow with 'special' bank holiday timetables. RE: Go North East: Major Service Changes July 2022 - F114TML - 02 Jun 2022 Well Stagecoach must be doing something right. I just had a ride around Sunderland and plenty of buses were quite busy (yes it's a bank holiday, but still), only saw one bus that was empty, and that was because it was closely following another on the same route. Delays - Unber43 - 02 Jun 2022 GNE have been hammered with delays today, there is definitely more late running services than on time services today RE: Bank Holiday Services - Jack Gill - 02 Jun 2022 From my experience today most GNE services seemed to be quite busy as well. RE: Delays - busmanT - 02 Jun 2022 (02 Jun 2022, 2:58 pm)Unber43 wrote GNE have been hammered with delays today, there is definitely more late running services than on time services todayGNE seem to be driving passengers away from their buses today, with the level of late running/lost mileage. They always seem to have similar issues on Bank Holidays. Surely an apology to customers for the poor service should be posted on their website. Taken out of context, but just a couple of weeks ago they said: "Work continues to rebuild passenger numbers across our network......." ".......it is only right that services are adapted to efficiently meet new patterns of demand". "We have analysed our services in great detail........." |
