RE: Go North East: Service Suggestions v2 - User2613 - 08 Nov 2021 If the 25 were to ever be branded it should be called the Rambler because if you ride it end to end it doesn't half go on and on. RE: Go North East: Service Suggestions v2 - Keeiajs - 08 Nov 2021 Connect the 6 & 25 to create the 6/7 Newcastle - Metrocentre - Stanley - Lanchester (same route) - A691 - Langley Park - CLS - Gateshead - Eldon Square (same route) every 30 mins loop. Newcastle - Gateshead - Stanley - Lanchester - A691 - Langley park - CLS - Gateshead - Eldon Square (every 30 mins) X42 Newcastle - Metrocentre - NCL - Kingston Park Bring back the X88 / X89 X88 Sunderland - A690 (stopping) - A19 - Concord (non stop) -Washington A2131 A194 - A184 - Heworth (non-stop) Gateshead Metrocentre Every 60 Mins. X89 Seaham (maybe parkside) - Dalton Park (X1/X10/X89 operate eveyr 20 mins between each other) - A19 - Sunderland - A690 - Concord - Washington - Heworth - Gateshead - Metrocentre (eveyr 60 mins) follows a every 30 mins from Sunderland & Gateshead & Heworth. Retime the X10, so it comes 20 mins after or 30 mins after the X1. Instead of 3 mins. Extend the X22 to Brandon 21 to Bowburn for the amazon factory Create a X23 Darlington - Durham - Arnsion Centre - Chester Le Street - Wreckton - Gateshead - Newcastle RE: Go North East: Service Suggestions v2 - ASX_Terranova - 09 Nov 2021 Divert either the 16/16A or X5/X15 to serve the Arnison Centre. You could use Potterhouse Lane and/or Trouts Lane RE: Go North East: Service Suggestions v2 - Andreos1 - 09 Nov 2021 (09 Nov 2021, 12:21 pm)ASX_Terranova wrote Divert either the 16/16A or X5/X15 to serve the Arnison Centre . You could use Potterhouse Lane and/or Trouts Lane Mentioned this many a time. No direct links to the largest retail park in the area, from the west or north west. Absolutely boat loads from the north or south - with a load of duplication on the way. RE: Go North East: Service Suggestions v2 - ASX_Terranova - 09 Nov 2021 (09 Nov 2021, 12:45 pm)Andreos1 wrote Mentioned this many a time. Not much from the south either, considering most of the arriva services terminate in Durham. Also on a different note did anyone ever use the Ferryhill X22. RE: Go North East: Service Suggestions v2 - Storx - 09 Nov 2021 (09 Nov 2021, 12:21 pm)ASX_Terranova wrote Divert either the 16/16A or X5/X15 to serve the Arnison Centre. You could use Potterhouse Lane and/or Trouts Lane People will disagree here but unless they make changes to the Arnison ie a bus gate, from where Greggs is onto the main road then I'd pull everything out of there. It's not worth delaying the rest of the service for the severe traffic problems, mainly caused by no-one controlling the McDonald's queue line from backing onto the main route. RE: Go North East: Service Suggestions v2 - DeltaMan - 09 Nov 2021 I like the idea of buses from North West Durham going to Arnison. I think they'd need to sack off the Shotley Bridge extension on the X5/X15 in order to extend buses up to Arnison Centre with the same PVR, unless they can magic a bus up from somwhere RE: Go North East: Service Suggestions v2 - Andreos1 - 09 Nov 2021 (09 Nov 2021, 4:52 pm)Storx wrote People will disagree here but unless they make changes to the Arnison ie a bus gate, from where Greggs is onto the main road then I'd pull everything out of there. It's not worth delaying the rest of the service for the severe traffic problems, mainly caused by no-one controlling the McDonald's queue line from backing onto the main route. I'm not sure they even need to go in to be honest. Stick a decent stop/crossing behind Subway to complement the one already by Lidl and it solves the issue of buses heading in and looping around. Long term, I'd ensure the bus gate was adapted so it wasn't just one-way and counter the problems caused by the queues of traffic. I'd hazard a guess quite a few of those cars are from areas such as Lanchester, Stanley etc. RE: Go North East: Service Suggestions v2 - peter - 09 Nov 2021 (09 Nov 2021, 6:09 pm)DeltaMan wrote I like the idea of buses from North West Durham going to Arnison. I think they'd need to sack off the Shotley Bridge extension on the X5/X15 in order to extend buses up to Arnison Centre with the same PVR, unless they can magic a bus up from somwhereWith the Streetdecks soon being replaced with B5's, if the X5/15 were extended then 6069/70 could be painted to join 6065-68 quite easily. RE: Go North East: Service Suggestions v2 - Storx - 09 Nov 2021 (09 Nov 2021, 8:44 pm)Andreos1 wrote I'm not sure they even need to go in to be honest. Stick a decent stop/crossing behind Subway to complement the one already by Lidl and it solves the issue of buses heading in and looping around. I'd probably true mind, pensioners won't be happy they can't dump their trolleys and get on the bus outside Sainsbury's anymore. Regardless to buses the whole Arnison needs redone it's a mess transport wise. The simple solution would be to force traffic to go in the Sainsbury's car park and make it one way coming out via McDonalds, there should be enough space to make it 3/4 lanes along there and make the bus road one way towards the roundabout, then one way towards the exit. It's literally just painting lines pretty much. RE: Go North East: Service Suggestions v2 - Dan - 11 Nov 2021 (09 Nov 2021, 8:44 pm)Andreos1 wrote I'm not sure they even need to go in to be honest. Stick a decent stop/crossing behind Subway to complement the one already by Lidl and it solves the issue of buses heading in and looping around. Bus priority would be vastly improved at the Arnison Centre if the bus gate was reversed. There's little congestion getting into the Arnison Centre, it's always coming out that's an issue. Go in the same way as the cars, and out the same way that the buses currently go in, and there'd be little congestion/delays to services. RE: Go North East: Service Suggestions v2 - Keeiajs - 11 Nov 2021 Extend the 71 to Sunderland, to give them a rough every 30 mins between seaham and Sunderland or re-time X6/62/71 at a 20 min frequency Replace the X6/38A, with the 9 as that does have a long enough layover to cover it Go North East: Service Suggestions v2 - cbma06 - 12 Nov 2021 (11 Nov 2021, 5:15 pm)Keeiajs wrote Extend the 71 to Sunderland, to give them a rough every 30 mins between seaham and Sunderland or re-time X6/62/71 at a 20 min frequency Looks like the X6/55 are being set up for withdrawl , since the x1 extension to Peterlee and the 62 roughly timed with one of the 55’s and the 62 timed about the same time as the x6. With the 71 between Chester and Houghton , I would renumber it with the Chester locals. With the 71 between Seaham and Houghton , I would extend the nexus 37 from Doxford park to Seaham via Burdon road and Burdon Lane, if the Houghton to Seaham link has to be maintained then run one of those 65’s as a 66 and run it the same way as the 71 to Houghton then rainton bridge then up Hetton downs into Hetton interchange then joining up with the normal 65 to Durham, but the 66 would have to be operated by a solo’s due to the estates in Seaham where it’s secured. Sent from my iPhone using Tapatalk RE: Go North East: Service Suggestions v2 - Storx - 12 Nov 2021 (12 Nov 2021, 12:35 pm)cbma06 wrote Looks like the X6/55 are being set up for withdrawl , since the x1 extension to Peterlee and the 62 roughly timed with one of the 55’s and the 62 timed about the same time as the x6. The 71 will be getting subsidised mainly for the Seaham to Houghton side. It's the only bus route through Seaton and the local estates in Seaham. Durham Council won't be interesting in funding a bus only between Chester Le Street and Houghton which can easily be done with a change onto the 4 at numerous places or extensions to Nexus services that benefit only Sunderland. The rest of the route isn't their business and does nothing to benefit them. Go North East: Service Suggestions v2 - cbma06 - 12 Nov 2021 (12 Nov 2021, 12:48 pm)Storx wrote The 71 will be getting subsidised mainly for the Seaham to Houghton side. It's the only bus route through Seaton and the local estates in Seaham. Durham Council won't be interesting in funding a bus only between Chester Le Street and Houghton which can easily be done with a change onto the 4 at numerous places or extensions to Nexus services that benefit only Sunderland. Yea, I know that the section between Houghton and Seaham is secured, it was when northern dropped the 735 between Houghton and Seaham, I didn’t say for DCC to fund the Chester to Houghton section but could be numbered in the 700 sequence going off the Chester local services, if one of the 65 half hourly service could be diverted as a 66 which would provide new links and the service might potentially get income, so the big cats can purchase another box of Cuban cigars while playing monopoly with bus services Sent from my iPhone using Tapatalk RE: Go North East: Service Suggestions v2 - ASX_Terranova - 12 Nov 2021 Think I might have suggested this before but what about spilting then extending the 53 & 54 to any of: Low Fell, Harlow Green, Birtley, Wrekenton, Kibblesworth, Washington etc..... RE: Go North East: Service Suggestions v2 - Drifter60 - 12 Nov 2021 (12 Nov 2021, 1:23 pm)cbma06 wrote Yea, I know that the section between Houghton and Seaham is secured, it was when northern dropped the 735 between Houghton and Seaham, I didn’t say for DCC to fund the Chester to Houghton section but could be numbered in the 700 sequence going off the Chester local services, if one of the 65 half hourly service could be diverted as a 66 which would provide new links and the service might potentially get income, so the big cats can purchase another box of Cuban cigars while playing monopoly with bus services But that takes away from the 65, the 65 isn’t just about Durham to Seaham journeys, it’s about Seaham to Dalton Park, Seaham to Murton, Murton to Hetton, Hetton to Seaham, Dalton Park to Hetton etc. The recent increase to this service shouldn’t be lost just to cover a gap somewhere else. The 71 I find a bit infuriating, I don’t think it’s been given a chance to work. The benefits of direct links across Houghton, linking Seaham to Chester - there’s good leisure opportunities, retail offerings, parks and recreation along the route. A good mix of employment/commuters, community needs and a bit of the leisure and tourism market that should on a paper make a bus route work. I can’t believe it couldn’t turn a profit. RE: Go North East: Service Suggestions v2 - Keeiajs - 12 Nov 2021 (12 Nov 2021, 2:19 pm)Drifter60 wrote But that takes away from the 65, the 65 isn’t just about Durham to Seaham journeys, it’s about Seaham to Dalton Park, Seaham to Murton, Murton to Hetton, Hetton to Seaham, Dalton Park to Hetton etc. The recent increase to this service shouldn’t be lost just to cover a gap somewhere else.Should be extened to Sunderland, then Byron Place, Dawdon, Dalton park, Grham Way, Seaton, Houghton, CLS RE: Go North East: Service Suggestions v2 - Andreos1 - 12 Nov 2021 (12 Nov 2021, 2:19 pm)Drifter60 wrote But that takes away from the 65, the 65 isn’t just about Durham to Seaham journeys, it’s about Seaham to Dalton Park, Seaham to Murton, Murton to Hetton, Hetton to Seaham, Dalton Park to Hetton etc. The recent increase to this service shouldn’t be lost just to cover a gap somewhere else. They've had 15 years of giving it a chance in the main (since they replaced the 21a, 177, 178 with it) and they will have had donkeys years worth of data to know what numbers are like between Seaham and Houghton. The quick fix is the timetable. There's also all those things you mention that be used as part of the marketing and promotion of the route. Go North East: Service Suggestions v2 - cbma06 - 12 Nov 2021 (12 Nov 2021, 2:19 pm)Drifter60 wrote But that takes away from the 65, the 65 isn’t just about Durham to Seaham journeys, it’s about Seaham to Dalton Park, Seaham to Murton, Murton to Hetton, Hetton to Seaham, Dalton Park to Hetton etc. The recent increase to this service shouldn’t be lost just to cover a gap somewhere else. Isn’t there a service 62 now between Seaham-Dalton Park-Murton etc… and there’s the X6 between Seaham and Dalton Park Sent from my iPhone using Tapatalk (12 Nov 2021, 2:35 pm)Andreos1 wrote They've had 15 years of giving it a chance in the main (since they replaced the 21a, 177, 178 with it) and they will have had donkeys years worth of data to know what numbers are like between Seaham and Houghton. Since in Houghton and everywhere else practically all competitions have ceased since In dependants have either been purchased, folded or driven off the road, depots closed (Philadelphia depot) since the depot closed nothing much of the services exist now than when the depot was open, areas been carved up, practically Houghton is just a couple of streamlined bus services , buses used to be for community but now it’s only there for profit with big margins, the councils get less and less of a budget for secured services each year and some services have to be cut right back or cancelled due to no money Sent from my iPhone using Tapatalk RE: Go North East: Service Suggestions v2 - Storx - 12 Nov 2021 (12 Nov 2021, 1:23 pm)cbma06 wrote Yea, I know that the section between Houghton and Seaham is secured, it was when northern dropped the 735 between Houghton and Seaham, I didn’t say for DCC to fund the Chester to Houghton section but could be numbered in the 700 sequence going off the Chester local services, if one of the 65 half hourly service could be diverted as a 66 which would provide new links and the service might potentially get income, so the big cats can purchase another box of Cuban cigars while playing monopoly with bus services Aye that's fair then. Tbh I'd just extend the 79 or whatever it is for the sake of it as it'll never be popular imo but the places need serving. Easier. For the other half of the route, I'd say extend the 25 towards Houghton via the current route every hour giving links to places beyond Chester Le Street where they might actually want to go and extend the 21 shorts to do the current 25 so the likes of Waldridge, Sacriston and Langley Park don't have to go on a mystery tour of Gateshead and Birtley to Newcastle. Can't see people complaining about either tbh and the estates in Birtley are more likely to want to go to Houghton than a few random Durham ex pit villages. RE: Go North East: Service Suggestions v2 - ASX_Terranova - 13 Nov 2021 (12 Nov 2021, 3:09 pm)Storx wrote Aye that's fair then. Tbh I'd just extend the 79 or whatever it is for the sake of it as it'll never be popular imo but the places need serving. Easier.I'm I correct in saying that the Seaham-Houghton section became a GNE route when GNE took over Jayline Travel RE: Go North East: Service Suggestions v2 - V514DFT - 13 Nov 2021 Merge the 11 and 41/41A,between Churchill Street and Church Bank will still be covered by the 1 Renumber the 19 to 40, route and timetable unchanged RE: Go North East: Service Suggestions v2 - Storx - 13 Nov 2021 (13 Nov 2021, 4:15 pm)ASX_Terranova wrote I'm I correct in saying that the Seaham-Houghton section became a GNE route when GNE took over Jayline Travel Not sure if I had to be honest. (13 Nov 2021, 5:12 pm)V514DFT wrote Merge the 11 and 41/41A,between Churchill Street and Church Bank will still be covered by the 1 Disagree with renumbering the 19. The 40 means nothing whereas it's quite common knowledge the 19 is the Northumberland Park to Cobalt Bus. It just needs to stay out of the Little Coaster brand altogether it's outright irrelevant, similar to the 204. RE: Go North East: Service Suggestions v2 - ASX_Terranova - 14 Nov 2021 In regards to Seaham-Houghton, can anyone remember how busy the 148 actually was at the time? Go North East: Service Suggestions v2 - cbma06 - 14 Nov 2021 (14 Nov 2021, 10:49 am)ASX_Terranova wrote In regards to Seaham-Houghton, can anyone remember how busy the 148 actually was at the time? If I remember rightly JC Bells of Seaham did the contract firstly, used to be a fair load, but car ownership gone up, used to see the bus at Houghton old bus station in the set down area with the other only bus service 234 TMS that used to terminate at the bus station Sent from my iPhone using Tapatalk RE: Go North East: Service Suggestions v2 - Drifter60 - 15 Nov 2021 (13 Nov 2021, 11:46 pm)Storx wrote Not sure if I had to be honest. Why shouldn’t the 19 be branded as Little Coasters? Just curious of the reasons. To me it makes as much sense as the X6/62 to Sunderland being branded as Peterlee Purples. RE: Go North East: Service Suggestions v2 - Keeiajs - 15 Nov 2021 (15 Nov 2021, 5:18 pm)Drifter60 wrote Why shouldn’t the 19 be branded as Little Coasters? Just curious of the reasons. To me it makes as much sense as the X6/62 to Sunderland being branded as Peterlee Purples.I thought it was removed due to capacity reasons. RE: Go North East: Service Suggestions v2 - Dan - 15 Nov 2021 (15 Nov 2021, 5:18 pm)Drifter60 wrote Why shouldn’t the 19 be branded as Little Coasters? Just curious of the reasons. To me it makes as much sense as the X6/62 to Sunderland being branded as Peterlee Purples. Initially it was because it was upgraded to larger capacity vehicles for social distancing, but the 19 has been taken out of the Little Coasters brand because there aren't enough buses branded any more (the OmniCitys displaced some of the branded Solo to Go North West) now the service has gone back to minibuses (fleet livery Solo). Of all the services, the 19 is arguably the one with the least relevance to the brand. With the impending withdrawal of 698 - 701, there won't even be enough branded Solos to cover all the 11, 41 and 42/42A, so another one of these will end up predominantly being allocated fleet livery Solo over branded examples. RE: Go North East: Service Suggestions v2 - Keeiajs - 15 Nov 2021 (15 Nov 2021, 5:23 pm)Dan wrote Initially it was because it was upgraded to larger capacity vehicles for social distancing, but the 19 has been taken out of the Little Coasters brand because there aren't enough buses branded any more (the OmniCitys displaced some of the branded Solo to Go North West) now the service has gone back to minibuses (fleet livery Solo). Of all the services, the 19 is arguably the one with the least relevance to the brand. Can't you brand the ex-venture which are meant to go over? |
