Go North East: Upcoming Service Changes - Printable Version
+--- Thread: Go North East: Upcoming Service Changes (/showthread.php?tid=1186)
RE: Go North East: Upcoming Service Changes - Andreos1 - 31 Dec 2015
(31 Dec 2015, 2:58 pm)Michael wrote I don't think the X1 will be changing at all.
The ques on a morning from the galleries to Newcastle are long, one thing they should do in increase the frequency on that part of the route but don't think they'll do that and just stick with a 10 min frequency through out the full route
Dropping the frequency between Hetton and the galleries to accommodate the increase between the Galleries and Newcastle, won't work either... the full route should stay every 10 minutes.
It isn't just in a morning that the queues at the Galleries are long.
Whilst the runs south from the galleries out of peaks can be quiet, they seem to be intermittent. Haven't worked out why some are busy and others less so.
Trips between Hetton and Houghton in particular, can be very busy. Regardless of time of day.
I wonder if it has anything to do with the X1 being the quickest (regular) service between the two.
With the 35's being reduced from 10, to 20mins, the X1 appears to have picked up a lot of custom between those points.
Ditto short, local runs between Houghton and Herrington Burn - which has the alternative of a longer 35/36 or infrequent 38.
2mins may not be a lot on paper, but to take out a bus from a service that has frequent delays, could mean hanging around a lot longer than the regular 20mins+ waits I have experienced all too often.
Better management of the service between the Galleries and Gateshead in particular, would be my preference.
RE: Go North East: Upcoming Service Changes - L469 YVK - 31 Dec 2015
If anything the X9/X10 will get new buses before the X1..... i think the B9's will be on the X1 for a couple of more years...
Bar the Pronto idea which has now been knocked on the head with the Streetdecks, the only other possible mainstream use that the B9s could see would be:
- Crusader (Only a very small number of journeys warrant deckers but would be handy for Metro replacements too).
- Stanley Network (Omnidekkas are fine and further changes may happen to the 6/X70/X71).
Could've mentioned the Coaster but will need to see how the 22 gets on. But for the meantime, I think the B9s are staying put for the next year but whether or not they get re-liveried, will tell whether or not theres going to be investment.
I think the TTX is a likely candidate but GNE might wait until the Scania E400MMC has been tried, thats if they do trial it.
RE: Go North East: Upcoming Service Changes - park5354 - 31 Dec 2015
www.nexus.org.uk/sites/default/files/documents/bus/A001-A002-A03-GNE-110116.pdf
Wonder if 563 will get Asda logos ????
RE: Go North East: Upcoming Service Changes - dannygee - 31 Dec 2015
(31 Dec 2015, 8:08 pm)park5354 wrote www.nexus.org.uk/sites/default/files/documents/bus/A001-A002-A03-GNE-110116.pdf
Which depot operating this?
RE: Go North East: Upcoming Service Changes - DanPicken - 31 Dec 2015
(31 Dec 2015, 8:29 pm)dannygee wrote Which depot operating this?
Percy Main.
RE: Go North East: Upcoming Service Changes - S813 FVK - 31 Dec 2015
(31 Dec 2015, 9:30 pm)DanPicken wrote Percy Main.
Do you know for certain this time?
RE: Go North East: Upcoming Service Changes - R852 PRG - 31 Dec 2015
(31 Dec 2015, 10:51 pm)S813 FVK wrote Do you know for certain this time?
I was also wondering that. Believe there is a rule that states all information, if not confirmed, is clearly posted as speculation.
RE: Go North East: Upcoming Service Changes - Adrian - 31 Dec 2015
(31 Dec 2015, 10:53 pm)R852 PRG wrote I was also wondering that. Believe there is a rule that states all information, if not confirmed, is clearly posted as speculation.
There's also one that states to use the report button. Smile
RE: Go North East: Upcoming Service Changes - NK53 TKT - 31 Dec 2015
Oooh, Phoenix must've lost the contract, a lot of the routes I THINK 563 is too big I think a slimline solo is needed especially for the A3.
RE: Go North East: Upcoming Service Changes - Rapidsnap - 01 Jan 2016
Actually Phoenix had their large Solo on it on New Years Eve, and MPDs can easily fit around the route. If a bin wagon can do it, so can a MPD.
RE: Go North East: Upcoming Service Changes - R852 PRG - 01 Jan 2016
(01 Jan 2016, 1:37 am)GMitchelhill wrote Actually Phoenix had their large Solo on it on New Years Eve, and MPDs can easily fit around the route. If a bin wagon can do it, so can a MPD.
Thought they were the same thing. Wink
RE: Go North East: Upcoming Service Changes - DanPicken - 01 Jan 2016
Its the most logical depot to run it.
RE: Go North East: Upcoming Service Changes - Dan - 01 Jan 2016
(01 Jan 2016, 8:06 am)DanPicken wrote Its the most logical depot to run it.
Surely it's more logical to operate the service out of Riverside Depot?
The loss of the Queen Elizabeth Hospital contract would have resulted in the loss of two or three lines of work at Riverside Depot. It would therefore make more sense for the service to operate out of Riverside Depot, as this service would require at least one driver.
It's one thing comparing the mileage between a depot and the starting/ending point of the service, but there's also a lot more to consider.
Take this as speculation or confirmation - whatever you like...
To add to Dans comment, there is other things to take into consideration. For example for Phoenix, their Solo was occupied at either end of the service by operating on a school service. So the vehicle that is used may end up being used on some other misc workings.
I know fine well that Stanley depot actually operates a school service in North Shields!
Also the distance to Byker Asda from either Riverside or Percy Main depots are roughly the same at around 5 miles, it's effectively right bang smack in the middle of them.
RE: Go North East: Upcoming Service Changes - Michael - 02 Jan 2016
Gne have only done a page for the changes to the X84/X85...
Do you not think they've left it late for the other services changing? Although its only timings but still.
(31 Dec 2015, 6:58 pm)DaveyBowyer wrote Bar the Pronto idea which has now been knocked on the head with the Streetdecks, the only other possible mainstream use that the B9s could see would be:
The Crusader on some runs are busy as out however i'm sure it was said a while that GNE want to avoid having 2 different types of buses a route.
Like you said, having deckers on the route could help with metro replacement but come on Davey, we know that'll be every week so the full allocation can be deckers!  Wink
The TTX buses will probables be replaced soon so it doesnt end up like what happened to B7's.. loads of breakdowns etc.
I do hope we the Scania E400MMC in the NE.
Dont get me wrong Davey, i'm not disagreeing with you at all, i think you're right but just added stuff on. Smile
RE: Go North East: Upcoming Service Changes - G-CPTN - 02 Jan 2016
(31 Dec 2015, 3:42 pm)G-CPTN wrote Today there were, on average 2 to 3 passengers alighting and 2 to 3 catching each bus as it arrived.
I was there from 11:30 to 12:20, as my expected 687 connection to Corbridge failed to show @11:40 (nor @12:07), but this turned out to be because GNE were running a Saturday service!
I ended up catching the Acomb bus on its return (had I known that the 687 wasn't coming I would have taken the outgoing 682 and had a ride around Acomb).
Today (Saturday) I caught the 10:55 687 to ALDI (despite knowing that there would be no return to Corbridge @ 11:40) - there were about ten passengers aboard, most of whom continued to the centre of Hexham (or the railway station).
For the return trip, the 11:42 688 from ALDI was used by 4 passengers (including myself) to reach the bus station.
RE: Go North East: Upcoming Service Changes - L469 YVK - 02 Jan 2016
(02 Jan 2016, 1:04 am)Michael wrote The Crusader on some runs are busy as out however i'm sure it was said a while that GNE want to avoid having 2 different types of buses a route.
Hehe, aye I think they'll be staying put now. I still don't know whether or not the Streetdeck will be purchased for the X10. The Streetdeck could go either two of these ways being:
- Proves to be a reliable (albeit a bit slow) workhorse on the X21 and more are subsequently ordered.
- Proves to be the worst deckers purchased since the Lolynes.
To be fair, 9119 although having a few teething issues with regards to the high performance setup needed for the TTX, hasn't actually performed too badly but the 2-3 year mark will tell whether or not they've proved themselves or turned out to be as bad as if not, worse than the Lolynes.
On another note, GNE would either have to upgrade the Crusader as a whole or stick with the Mercs and I think that they'll stick with the Mercs. I don't see the Coaster getting an upgrade at the moment and the same goes for the Stanley Network.
I think GNE have taken the decision to repaint them for now and wait until the next financial year (June) to see whether or not they're going to get newer stock before reapplying the Red Arrows livery but I personally don't think the Red Arrows will get anything now until at least 2018 for certain unless GNE need to shift more non DDA compliant deckers through OmniDekkas which I believe at the moment consists of 11x Lolynes and 8x Palatine IIs (7x of which can be replaced by the B7s from Crook which I'm led to believe are DDA compliant when the Streetdecks arrive).
Just going to sit back and see what happens now, no point in predicting. Only predicted with the Pronto what I thought was going to be a possibility but obviously cheaper to purchase 7x new deckers than what it would've been to purchase 16x new deckers despite the more widespead benefits.
Citaro / Dan 1 - Davey 0
RE: Go North East: Upcoming Service Changes - Panasonic44 - 02 Jan 2016
Crusader needs to be sorted out e.g increase to every 15/20 mins instead upto 12 mins this would allow more time to recover at both ends but if GNE did add another route maybe xpress running along side 27 or to be more like QuaryLink and with proper dayticket more than 1 service to/from Shields to Newcastle.
Anyway I think Omnidekkas or buy omnicity dd would be prefect for 27 or upgrade.
RE: Go North East: Upcoming Service Changes - Adrian - 02 Jan 2016
(02 Jan 2016, 9:16 pm)Panasonic44 wrote Crusader needs to be sorted out e.g increase to every 15/20 mins instead upto 12 mins this would allow more time to recover at both ends but if GNE did add another route maybe xpress running along side 27 or to be more like QuaryLink and with proper dayticket more than 1 service to/from Shields to Newcastle.
I'd say if anything, they'd need to throw extra resource at the current 12 minute frequency, rather than cut it further. Baring in mind that it was originally cut from 10 to 12 minutes to improve reliability. It's still a busy route, especially given DB's inability to run a Metro system.
RE: Go North East: Upcoming Service Changes - Dan - 02 Jan 2016
(02 Jan 2016, 10:19 pm)Adrian wrote I'd say if anything, they'd need to throw extra resource at the current 12 minute frequency, rather than cut it further. Baring in mind that it was originally cut from 10 to 12 minutes to improve reliability. It's still a busy route, especially given DB's inability to run a Metro system.
Like the 56, I think that decrease in frequency really helped the reliability of the daytime 27 service.
At peak times, it still goes to pot though (just like pretty much every other bus service in the region!)
RE: Go North East: Upcoming Service Changes - BJ10VUS - 03 Jan 2016
(02 Jan 2016, 4:32 pm)G-CPTN wrote Today (Saturday) I caught the 10:55 687 to ALDI (despite knowing that there would be no return to Corbridge @ 11:40) - there were about ten passengers aboard, most of whom continued to the centre of Hexham (or the railway station).
Certainly sounds like the Aldi link is being well used, and thank you for the very useful updates. Although, it seems like the 687 could do with some improvements in order to help the people tthat use it?
RE: Go North East: Upcoming Service Changes - G-CPTN - 03 Jan 2016
(03 Jan 2016, 11:53 am)BJ10VUS wrote Certainly sounds like the Aldi link is being well used, and thank you for the very useful updates. Although, it seems like the 687 could do with some improvements in order to help the people that use it?
The 687 was downgraded from an hourly service throughout the day to two from Hexham to Corbridge and three from Corbridge to Hexham, most of which do not 'join up' (only the 10:55 weekday service returns).
Agreed that usage was sparse and, therefore, not commercially viable.
The Saturday (only) 15:10 does have a return with the 16:35 from Hexham, which, strangely, then runs back to Hexham NIS, having arrived in Corbridge @ 16:52 instead of waiting and collecting those shop-workers who finish at 5pm, however these people do have a TEN @17:08 or 17:15 (weekdays).
(03 Jan 2016, 1:24 pm)G-CPTN wrote The 687 was downgraded from an hourly service throughout the day to two from Hexham to Corbridge and three from Corbridge to Hexham, most of which do not 'join up' (only the 10:55 weekday service returns).
Did it used to go around to Beaumount Park and Highford Park after the 684 was changed to the X84/X85, or is that a different service?
Maybe it's worth cancelling the 687 altogether and extending a 680 or 682 down to Corbridge via Beaufront instead? It's clear that people like yourself rely on the service for shopping, and with such a sparce service and odd timings, it's no surprise it isn't being used as much as it should. Clearly saying "put a bus here and do this and that" isn't always that easy, but it could work.
(03 Jan 2016, 3:25 pm)BJ10VUS wrote Did it used to go around to Beaumount Park and Highford Park after the 684 was changed to the X84/X85, or is that a different service?
The 687 used  to do Beaumont Park between journeys to Corbridge.
When Howard Snaith's routes to Colwell were taken over by GNE the Beaumont Park route was rejigged as the 682 to serve Acomb instead of Corbridge (on an hourly basis) as well as occasional journeys to Barrasford, Gunnerton and Colwell.
I don't think the Barrasford/Colwell service lasted long.
The 687 operates off some 686 and 689 journeys.
The weekday 11:35 from Hexham (11:53 from Corbridge) is a Venture Solo (which used to then go from Hexham to Barrasford/Colwell), whilst the Saturday 15:10 from Corbridge arrives from Prudhoe/Ovingham/Albemarle (686).
I think the 10:55 and the 12:55 from Corbridge come from Ovington (686 from Prudhoe 10:03 and 12:03).
(03 Jan 2016, 3:56 pm)G-CPTN wrote The 687 used  to do Beaumont Park between journeys to Corbridge.
Yeah, the 682 beyond Acomb towards Colwell only lasted a few months at most. The Northumberland area seems a little bit of a mess at the moment, with the current transport situation. Possibly extending the 683 or 688 buses could work instead, or a new service operating beyond Corbridge to somewhere like Matfen or Stamfordham could be an option?
(03 Jan 2016, 7:43 pm)BJ10VUS wrote Yeah, the 682 beyond Acomb towards Colwell only lasted a few months at most. The Northumberland area seems a little bit of a mess at the moment, with the current transport situation. Possibly extending the 683 or 688 buses could work instead, or a new service operating beyond Corbridge to somewhere like Matfen or Stamfordham could be an option?
There is already the 74 which serves Matfen, Stamfordham and Eldon Square four times daily.
Timings are such that it is possible to be in Newcastle from 08:19 to 17:35, or Hexham from 10:00 to 16:05.
RE: Go North East: Upcoming Service Changes - Jordan95 - 05 Jan 2016
Which depot and bus will be used on the new asda shuttles GNE are taking over
RE: Go North East: Upcoming Service Changes - Adrian - 05 Jan 2016
(05 Jan 2016, 4:14 pm)Jordan95 wrote Which depot and bus will be used on the new asda shuttles GNE are taking over
Riverside, and primarily 563 I believe.
RE: Go North East: Upcoming Service Changes - Dan - 07 Jan 2016
(05 Jan 2016, 7:57 pm)Adrian wrote Riverside, and primarily 563 I believe.
The allocation may be fluid - at least for the first week of operation.
UPDATED: Closure of Chowdene Bridge from 26 October 2015
http://www.simplygo.com/news/closure-of-chowdene-bridge-from-26-october-2015
Pedestrian access over the railway line will be maintained, with the exception of a 10 day period between Saturday 9th until Monday 18th January 2016. For this 10 day period, a CB1 free shuttle bus will run from the St Andrews Drive stop at Chowdene to Sainsburys. Buses will run every 15 minutes, throughout the day and night during the footbridge closure. Buses will leave Chowdene at 01, 16, 31 & 46 mins past each hour, with buses leaving Sainsburys at 09, 24, 39 & 54 mins past each hour
I understand 563 is to be used on the CB1 free shuttle bus, but I'm not sure which service (CB1 or A1/A2/A3) will get priority during the overlapping period of both services operating.
