Stagecoach North East: Order Predictions - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Stagecoach North East (https://northeastbuses.co.uk/forumdisplay.php?fid=57) +--- Thread: Stagecoach North East: Order Predictions (/showthread.php?tid=1398) |
RE: Stagecoach North East: Order Predictions - toward6931 - 22 Aug 2022 (22 Aug 2022, 3:57 pm)stagecoachbusdepot wrote Of course, assuming the ones available aren't knackered. I would be amazed however if SNE went to the expense of converting some more life expired deckers to open top for the PVR of 1 on the 19 plus whatever random offering on the Es. The only reason we have the open toppers is because they became spare on the demise of CSS. They tried Seasider and abandoned it (who knows if that might have grown were it not for Covid) and now are basically just making use of the otherwise dead resource.no i wasn't suggesting to convert these vehicles yet, what I was suggesting was that if it is worth putting decker's on those services, bearing in mind how unpredictable the weather has been and the age of the open toppers, could it be worth if the Cumbria decker's aren't knackered acquiring them to use as spare vehicles so that if the open toppers do have a serious break down there is a vehicle of similar capacity to cover it. optimistically if there was ever a need for open toppers again bearing in mind the age and mechanical reliability of the current open tops at least if you had acquired the 3 Cumbria vehicles as "spares" you then have suitable vehicles already sourced for conversion if needed. alternatively send the 3 to Stockton depot as col 87 said where you could then increase capacity by maybe cascading or loaning 1 E200 and 2 ALX300 to hartlepool depot to alleviate their shortages. after how bad things were when the MMCs got sent to the commonwealth games at least having those 3 spare vehicles could alleviate some of the problems faced such as vehicles having to be pulled from paint shops half finished, a high volume service like 62/63 getting allocated an E200 and as happened twice a 71 service being cut down to 2 running vehicles because they didn't have a spare when one broke down. in the absence of new vehicles turning up simple things like this could make a real difference RE: Stagecoach North East: Order Predictions - F114TML - 22 Aug 2022 (22 Aug 2022, 7:18 pm)toward6931 wrote no i wasn't suggesting to convert these vehicles yet, what I was suggesting was that if it is worth putting decker's on those services, bearing in mind how unpredictable the weather has been and the age of the open toppers, could it be worth if the Cumbria decker's aren't knackered acquiring them to use as spare vehicles so that if the open toppers do have a serious break down there is a vehicle of similar capacity to cover it.I feel like I'm missing something - if one breaks down what's wrong with an E400? Why must it be another ALX? The Eco routes run along the coast - why wouldn't you run open toppers on it in summer, even if existing pax numbers didn't justify it? It's an easy (and probably cheap) way of going "ooh look at our routes" while maybe increasing passenger numbers a bit. RE: Stagecoach North East: Order Predictions - toward6931 - 22 Aug 2022 (22 Aug 2022, 7:24 pm)F114TML wrote I feel like I'm missing something - if one breaks down what's wrong with an E400? Why must it be another ALX? The Eco routes run along the coast - why wouldn't you run open toppers on it in summer, even if existing pax numbers didn't justify it? It's an easy (and probably cheap) way of going "ooh look at our routes" while maybe increasing passenger numbers a bit.no I'm not saying it has to be an ALX, what I mean is there is a growing shortage of vehicles. the fact that the MMCs get pulled away regularly for events like Cheltenham and the commonwealth games. there is an increasingly older fleet of single decker's to rely on and there is also a problematic fleet of E200s. you've got vehicles getting pulled out of paintshops incomplete because there isn't any spares. high volume routes like the 62/63 getting allocated an 39xxx E200 because there isn't a spare vehicle. after walkergates 19439 I believe it was caught fire nothing replaced it as far as I know, all I'm saying is until either new deliveries or a decent cascade of vehicles happens what is the harm in acquiring a stopgap, in this hypothetical case if they are in reasonable working order 3 tridents. on paper you could send one of them to Sunderland so that one E400 could go back to walkergate to cover 19439 and 2 to Stockton to allow 2 ALX300s to go to hartlepool to alleviate vehicle problems there. I would personally love to see 30 plus single and double deck MMCs turn up in the north east but its not looking hopeful so realistically this could be a situation that does occur (maybe newer vehicles) RE: Stagecoach North East: Order Predictions - stagecoachbusdepot - 22 Aug 2022 (22 Aug 2022, 8:24 pm)toward6931 wrote no I'm not saying it has to be an ALX, what I mean is there is a growing shortage of vehicles. the fact that the MMCs get pulled away regularly for events like Cheltenham and the commonwealth games. there is an increasingly older fleet of single decker's to rely on and there is also a problematic fleet of E200s. Special events aside, I'm not convinced there is a vehicle shortage. Sunderland are still sat on a load of spares since the PVR reduction there. Things are always going to be tight when large numbers are off for a few days/weeks on events work but they aren't going to fund an increased spares % just for that. The issues with the MAN 14.240s is seemingly being addressed by acquiring Darts, which is likely to be the route they continue down as it will be far more economical running an 06 plate dart than an 06 plate decker. When we talk about vehicles getting pulled out of the paintshop half done, let's remember that was one vehicle, which had incompletely applied promotional livery - not a regular occurrence and arguably with better planning they shouldn't have been trying to do it when a load of the fleet were off to Brum... RE: Stagecoach North East: Order Predictions - 54APhotography - 23 Aug 2022 (22 Aug 2022, 8:24 pm)toward6931 wrote no I'm not saying it has to be an ALX, what I mean is there is a growing shortage of vehicles. the fact that the MMCs get pulled away regularly for events like Cheltenham and the commonwealth games. there is an increasingly older fleet of single decker's to rely on and there is also a problematic fleet of E200s.In essence 19179 replaced 19439 RE: Stagecoach North East: Order Predictions - col87 - 24 Aug 2022 (22 Aug 2022, 10:05 pm)stagecoachbusdepot wrote Special events aside, I'm not convinced there is a vehicle shortage. Sunderland are still sat on a load of spares since the PVR reduction there. Things are always going to be tight when large numbers are off for a few days/weeks on events work but they aren't going to fund an increased spares % just for that. The issues with the MAN 14.240s is seemingly being addressed by acquiring Darts, which is likely to be the route they continue down as it will be far more economical running an 06 plate dart than an 06 plate decker. When we talk about vehicles getting pulled out of the paintshop half done, let's remember that was one vehicle, which had incompletely applied promotional livery - not a regular occurrence and arguably with better planning they shouldn't have been trying to do it when a load of the fleet were off to Brum...Would disagree Hartlepool has had a shortage for years now not helped by having an unreliable fleet with buses frequently having to be borrowed from Stockton or Sunderland with 3 Hartlepool having 3 buses permanently off the road since December and at least one has now been scrapped. While the Darts have helped slightly they is a shortage of buses at Hartlepool with not many spares. The fact Stockton themselves have now had to borrow buses from Newcastle would suggest that they is a shortage. 39666 has not been in use for over a week so don’t know if it been withdrawn but alongside 34605 that’s now another 2 buses off the road so something is going to need to happen especially with rumours that 2 - 3 others at Hartlepool could be getting withdrawn as well. RE: Stagecoach North East: Order Predictions - stagecoachbusdepot - 24 Aug 2022 (24 Aug 2022, 12:21 am)col87 wrote Would disagree Hartlepool has had a shortage for years now not helped by having an unreliable fleet with buses frequently having to be borrowed from Stockton or Sunderland with 3 Hartlepool having 3 buses permanently off the road since December and at least one has now been scrapped. While the Darts have helped slightly they is a shortage of buses at Hartlepool with not many spares. The fact Stockton themselves have now had to borrow buses from Newcastle would suggest that they is a shortage. Across SNE there is no vehicle shortage. The Newcastle buses at Stockton are largely covering for the E200MMCs which were at the Games. This isn't a chronic shortage, the Commonwealth Games is a once in however many years special event. They are not going to hold an inflated fleet in all divisions that send buses to the likes of this, just in case another special event comes along...particularly when they seem to have managed perfectly well with temp national cascades to cover. 39666 has been withdrawn but 36092/93 have been transferred in... The other MANs which have been withdrawn have been replaced by Darts. The issue with Hartlepool is it's a tiny fleet/PVR therefore even with a standard spares percentage in terms of number of buses it is very low. What probably needs to happen is for Hartlepool depot to close and whatever local services remain beyond the 36 to run from Stockton, to get economies of scale on fleet spares etc. RE: Stagecoach North East: Order Predictions - col87 - 24 Aug 2022 (24 Aug 2022, 1:20 am)stagecoachbusdepot wrote Across SNE there is no vehicle shortage. The Newcastle buses at Stockton are largely covering for the E200MMCs which were at the Games. This isn't a chronic shortage, the Commonwealth Games is a once in however many years special event. They are not going to hold an inflated fleet in all divisions that send buses to the likes of this, just in case another special event comes along...particularly when they seem to have managed perfectly well with temp national cascades to cover.Closing Hartlepool depot will probably happen but it’s a ridiculous idea. If a 7 breaks down at the Headland that’s going to be at least 30 - 35 minutes for a replacement to get though from Stockton. RE: Stagecoach North East: Order Predictions - tcts24 - 24 Aug 2022 Following the expiry of 39666's MOT, it has indeed been withdrawn. 39661 will follow in a few weeks and a third MAN is due for the chop soon. Not sure what's up with 34605, but its finally been moved back into the yard but face in, in the dead area. 36091-3 are replacing the MAN's. Apparently the reason Hartlepool depot is still open is because Stockton doesn't have the capacity for the fleet. RE: Stagecoach North East: Order Predictions - Kuyoyo - 24 Aug 2022 The issue now is, there's a vast number of MAN E200s still on fleet - including 39666, there's 40 in total. Once 39661 and the third example is withdrawn, that comes down to 37 - 8 at Hartlepool (presently 11), 11 at South Shields and the remaining 18 at Sunderland (although 39673 hasn't been in use since the end of July). As it appears the more troublesome examples are being withdrawn upon the expiry of their current MOT, replacements are going to be needed. With most other fleets now binning their reserve Darts, the subject of replacements becomes an interesting point of discussion....... RE: Stagecoach North East: Order Predictions - wibblejunior - 24 Aug 2022 I think Stagecoach London are starting to cascade the LX59 batch of E200s to other fleets, perhaps some of those may end up transferring over here? RE: Stagecoach North East: Order Predictions - toward6931 - 24 Aug 2022 (24 Aug 2022, 12:45 pm)wibblejunior wrote I think Stagecoach London are starting to cascade the LX59 batch of E200s to other fleets, perhaps some of those may end up transferring over here?are they a shorter length than the E200s up here? i remember some of the 56 examples i think were really short, i think one is at bedford now. and i take it they will have the second door removed and seating placed there? yes as i thought 36302 is an example of what i mean https://www.flickr.com/photos/aswans1234567/52155423014/ RE: Stagecoach North East: Order Predictions - stagecoachbusdepot - 24 Aug 2022 (24 Aug 2022, 12:45 pm)wibblejunior wrote I think Stagecoach London are starting to cascade the LX59 batch of E200s to other fleets, perhaps some of those may end up transferring over here? 13 year old midibuses that have been trashed in London? Hope not! RE: Stagecoach North East: Order Predictions - wibblejunior - 24 Aug 2022 (24 Aug 2022, 1:26 pm)toward6931 wrote are they a shorter length than the E200s up here? i remember some of the 56 examples i think were really short, i think one is at bedford now. and i take it they will have the second door removed and seating placed there?These are longer wheelbase ones. https://flic.kr/p/2npYWXr RE: Stagecoach North East: Order Predictions - col87 - 24 Aug 2022 Hartlepool especially needs investment. It’s fine bringing 4 darts up from Yorkshire but if one has been immediately scrapped another one has not been used due to problems and only 2 have actually been used in regular service while 4 buses have been withdrawn then it really don’t help much. The fact is since Stagecoach took over Hartlepool Transport it’s gone from a fully functional depot doing everything to the bare bones with services completely cut down. Hartlepool needs a depot or else it’s just going to lead to more service cuts in which case they might just be better off selling to Go North east or Arriva. They is a very simple solution though. Move all remaining Darts to Hartlepool with some E200 going elsewhere as replacements. Some of the Alx300 move to Hartlepool from Newcastle/ Stockton to see off most of the remaining Manviros. Service 1 and 36 to be joint operated between Hartlepool and Stockton freeing up buses and drivers from Stockton depot. It means Hartlepool get some slightly better buses Stockton get some free drivers for other routes so win win. RE: Stagecoach North East: Order Predictions - toward6931 - 24 Aug 2022 (24 Aug 2022, 4:05 pm)col87 wrote Hartlepool especially needs investment. It’s fine bringing 4 darts up from Yorkshire but if one has been immediately scrapped another one has not been used due to problems and only 2 have actually been used in regular service while 4 buses have been withdrawn then it really don’t help much. The fact is since Stagecoach took over Hartlepool Transport it’s gone from a fully functional depot doing everything to the bare bones with services completely cut down. Hartlepool needs a depot or else it’s just going to lead to more service cuts in which case they might just be better off selling to Go North east or Arriva. They is a very simple solution though.yes would make sense that darts go to hartlepool, so that's the 2 (correct me if I'm wrong)at Sunderland swapped for 2 E200s, even if they are terrible Sunderland allegedly has a healthy spare vehicle ratio, however many at south shields swapped 1 for 1. ideally services 1 and 36 as you suggest get jointly operated like the 62/63 in Newcastle. maybe 2/3 ALX 300from Stockton go to hartlepool in return for E200. Hopefully either an investment of maybe 10-20 new short wheelbase MMCs per year for the next 3 years should be made which I would suggest for the CAZ coming split between Newcastle and Sunderland the first year, followed by Stockton and hartlepool the second year and then Newcastle and Sunderland the third year. thereby allowing the same amount of troublesome buses to be scrapped with hartlepool getting the 1st pick of any cascade until the problem has been sorted. or as sadly is probably the most likely outcome is that whatever cascades are made through the group hartlepool tries to grab and see what it can use. RE: Stagecoach North East: Order Predictions - Storx - 24 Aug 2022 (24 Aug 2022, 4:54 pm)toward6931 wrote yes would make sense that darts go to hartlepool, so that's the 2 (correct me if I'm wrong)at Sunderland swapped for 2 E200s, even if they are terrible Sunderland allegedly has a healthy spare vehicle ratio, however many at south shields swapped 1 for 1. I don't want to be a doom and gloomer here but remember Stagecoach South Shields / Sunderland and Stagecoach Teesside / Hartlepool haven't had any cuts in relationship to the end of the Covid bailouts yet. There will be cuts at both, the 18 and 30 were definitely on the chopping block at Sunderland / South Shields before the extension came in last minute. Hartlepool has always been a weak depot so wouldn't be surprised to see a few cuts there aswell. Isn't there a few hourly services which only operate 9am - 5pm, never the sort of services that will be money makers. Once they eventually come in, I wouldn't be surprised to see there's enough to get rid of the MAN's. RE: Stagecoach North East: Order Predictions - stagecoachbusdepot - 24 Aug 2022 (24 Aug 2022, 4:05 pm)col87 wrote Hartlepool especially needs investment. It’s fine bringing 4 darts up from Yorkshire but if one has been immediately scrapped another one has not been used due to problems and only 2 have actually been used in regular service while 4 buses have been withdrawn then it really don’t help much. The fact is since Stagecoach took over Hartlepool Transport it’s gone from a fully functional depot doing everything to the bare bones with services completely cut down. Hartlepool needs a depot or else it’s just going to lead to more service cuts in which case they might just be better off selling to Go North east or Arriva. They is a very simple solution though. 4 MANs withdrawn, 2 Darts plus 2 E200 (36092/93) arrived = no worse off??? What benefit is there to losing E200s which are some of Hartlepool's newest vehicles to other depots, to gain older Darts? (24 Aug 2022, 5:45 pm)Storx wrote I don't want to be a doom and gloomer here but remember Stagecoach South Shields / Sunderland and Stagecoach Teesside / Hartlepool haven't had any cuts in relationship to the end of the Covid bailouts yet. I've said previosuly but wouldn't necessarily expect mega cuts at Sunderland as they basically implemented the frequency reductions that were already planned - plus their main services generally appear to be doing pretty well in terms of loadings. The 18 presumably will be secured if/when they finally pull the plug, but it's only 2 vehicles anyway (of which one is needed for scholars at either end of the day) so not a great release of vehicles there. In Sunderland, the 8 would be the other potential for a frequency cut maybe? RE: Stagecoach North East: Order Predictions - Michael - 24 Aug 2022 (24 Aug 2022, 5:50 pm)stagecoachbusdepot wrote 4 MANs withdrawn, 2 Darts plus 2 E200 (36092/93) arrived = no worse off??? I'm really surprised its still going, service was wreaked when the council decided to close the Queen Alexandrea Bridge for work (which was needed) and terminate them at each end of the bridge - and when it opened the service never recovered, even after the route change to go Via Pennywell etc, it still runs empty. Wonder if they would merge the route with another route - maybe you could change the 20 back to its old route in Pennywell... the route is pretty much covered with other routes: E's - Seaburn 16 - Grindon 10/11 - Pallion 3/4/12/13/16 - Southwick 3/13 - Gilly Law Its got to be running a massive loss?, it carries fresh air during the day and on school days, its a double decker. RE: Stagecoach North East: Order Predictions - Storx - 24 Aug 2022 (24 Aug 2022, 5:50 pm)stagecoachbusdepot wrote I've said previosuly but wouldn't necessarily expect mega cuts at Sunderland as they basically implemented the frequency reductions that were already planned - plus their main services generally appear to be doing pretty well in terms of loadings. The 18 presumably will be secured if/when they finally pull the plug, but it's only 2 vehicles anyway (of which one is needed for scholars at either end of the day) so not a great release of vehicles there. In Sunderland, the 8 would be the other potential for a frequency cut maybe? Aye agreed, only little things I think might happen is the 3/4 being dropped from every 12 minutes to every 15 minutes or the 20 being dropped to every 12 minutes etc. Little changes that won't really impact people tbh but drop the PVR a bit. It's Hartlepool and South Shields I have a feeling might get clattered. Both are low cost units which means to me don't make any money and that was before Covid not to mention Stagecoach conveniently moving the E's which are decent routes to Sunderland randomly. Hartlepool I wouldn't be surprised to see desperate changes like which tax payers will no doubt have to fund alternatives: 1 - Dropped South of Seaton Carew 3/3A - Dropped altogether 6/7 - 6 withdrawn, 7 route extended to the South Fens via the 6 route and evening extension 36 - Extended to replace the top half of the 6 The place has been a basket case for years hence the lack of investment, low cost units etc. RE: Stagecoach North East: Order Predictions - Unber43 - 24 Aug 2022 (24 Aug 2022, 6:07 pm)Michael wrote I'm really surprised its still going, service was wreaked when the council decided to close the Queen Alexandrea Bridge for work (which was needed) and terminate them at each end of the bridge - and when it opened the service never recovered, even after the route change to go Via Pennywell etc, it still runs empty.I wonder if the 20 cancellation might increase passenger numbers on the 39A/39B if it does its coming at a bad time RE: Stagecoach North East: Order Predictions - Michael - 24 Aug 2022 (24 Aug 2022, 6:36 pm)Unber43 wrote I wonder if the 20 cancellation might increase passenger numbers on the 39A/39B if it does its coming at a bad time I doubt Stagecoach would cancel the 20, its one of their busiest routes in Sunderland... pretty sure at one point in the 1990's, it ran every 5 minutes. RE: Stagecoach North East: Order Predictions - toward6931 - 24 Aug 2022 Scotland getting 38 more electric buses, i wonder if there will be more cascades to SNE,7 standard length single decker's and included 5 midi buses are in the order so even in the extremely unlikely event of no routes getting cut, that could be a nice little haul of buses to "modernise" SNEs fleet, after the state of the 08 E300s though I wouldn't hold my breath https://www.bbc.co.uk/news/uk-scotland-tayside-central-62596174?fbclid=IwAR3X08WgjSYvUk2NsXZecJz_DEuaVP9Mh1zIlaC6KpAlXqDWUK5gQmkznTc RE: Stagecoach North East: Order Predictions - col87 - 24 Aug 2022 (24 Aug 2022, 6:09 pm)Storx wrote Aye agreed, only little things I think might happen is the 3/4 being dropped from every 12 minutes to every 15 minutes or the 20 being dropped to every 12 minutes etc. Little changes that won't really impact people tbh but drop the PVR a bit.Clearly you have no connection to Hartlepool then as you just making everything even worse. They nit going to make cuts to the 6/7 as they the two most profitable services in the town always usually quite busy even out of peak time. The 1 I don’t see getting cut either for the same reason. What might happen though is this. 1 Middlesbrough service dropped to hourly. Don’t forget if it gets cut completely that’s no service at all for Haverton Hill and Port Clarence so they will still be a service there. Then every 15 minutes to Seaton Carew. 3/3A. Works well enough as it is as usually gets enough passengers to continue. Maybe could reduce Bishop Cuthbert to hourly but it works as it is. 6/7 No changes. They tried going down to every 15 minutes during the emergency Timetables it ended up been a farce with a lot of complaints and people not having a service for nearly half an hour due to late running and breakdowns. I don’t see them trying again. 36. Your having a laugh. It did originally do the 6 route it was changed to the Marina for a reason due to it been easier. The same reason the Marina section was cut off was down to it been able to make up time if it running late by looping the Town Centre they no way it’s going to go back to doing the 6 route. If anything merging the 36 and 37 will be an improvement will save a bus or two and have the added bonus of a direct service between Hartlepool and North Tees Hospital. Other than a couple of changes in 2017 then a few minor tweaks in 2018 the Hartlepool network for the most part has been stable since 2010 what’s needed is a few extra services and better buses not closing the depot and having buses that are no good. Up until everything got decided at Sunderland Hartlepool actually worked fine it’s only since the creation of Stagecoach North East that Hartlepool started to get worse when it was just under Cleveland Transit it worked a lot better. It’s the management what’s actually ran the depot down to cut costs. RE: Stagecoach North East: Order Predictions - Storx - 24 Aug 2022 (24 Aug 2022, 7:29 pm)col87 wrote Clearly you have no connection to Hartlepool then as you just making everything even worse. They nit going to make cuts to the 6/7 as they the two most profitable services in the town always usually quite busy even out of peak time. The 1 I don’t see getting cut either for the same reason. What might happen though is this. The thing is though they could make changes which could streamline things but keep services mostly the same without duplicating services. Just to pick the 6/7/36/37/38 You could do 36: Clavering to Owton Manor, Every 20 Minutes or Middlesbrough, Every 20 Minutes - Combined Fens to Clavering, Every 10 Minutes 37: Every 20/40 Minutes 38: Every Hour 36/37/38: Every 10 Minutes 6: Withdrawn 7: Every 10 Minutes Hartlepool has it's two 10 minute services still without the duplicating 6/36. Bar a small estate in Norton and the awkward 20/40 at the end of the 37, there's still a 20 minute service on the 37/38 and the combined 10 minute service between Norton and Middlesbrough (vs 7.5 now). Those buses being pulled off the 36/38 will be used to improve what was the 6 with newer buses from Stockton with a suitable layover at Owton Manor so they're not delayed so Hartlepool wins aswell. RE: Stagecoach North East: Order Predictions - col87 - 24 Aug 2022 (24 Aug 2022, 8:14 pm)Storx wrote The thing is though they could make changes which could streamline things but keep services mostly the same without duplicating services.It don’t work though the 6 works and has worked for decades it would be very stupid to get rid. RE: Stagecoach North East: Order Predictions - glen - 25 Aug 2022 Way can't stagecoach north east pay standhard buses to replace all alx man buses if want get rid off them if can't new buses then. RE: Stagecoach North East: Order Predictions - toward6931 - 25 Aug 2022 (25 Aug 2022, 1:21 am)glen wrote Way can't stagecoach north east pay standhard buses to replace all alx man buses if want get rid off them if can't new buses then.ALXs aren't the problem glen, for their age they are quite good, its the E200s that are the problems RE: Stagecoach North East: Order Predictions - glen - 25 Aug 2022 Thanks for info mate I didn't that mate. I thought it was man alx buses. RE: Stagecoach North East: Order Predictions - tcts24 - 25 Aug 2022 Newer doesn't neccessarily mean better. Obviously it may vary depending on who you ask, but if i was to name the crappest few buses at Hartlepool starting with the worst- 36467, 36464, 36462. Of course I'm coming from a drivers view rather than engineering, but in my opinion some of the newest buses are the most problematic in service. In terms of cuts... I can't see any coming for the 1. Especially the long 1's as it would leave the Clarences without a bus, barring 1 journey a day on Stockton's 58A. The short 1's are actually set to improve with the reintroduction of an evening bus! Route 3 could theorectally be chopped north of ASDA where they aren't especially busy. 6 and 7 would be the most obvious target for a frequency reduction. Hartlepool is of course to gain an extra bus for it's forthcoming County Durham school contract meaning an extra spare on weekends at least! |
