Arriva North East: Latest News & Discussion - November 2017 - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Arriva North East (https://northeastbuses.co.uk/forumdisplay.php?fid=56) +--- Thread: Arriva North East: Latest News & Discussion - November 2017 (/showthread.php?tid=2041) |
Arriva North East: Latest News & Discussion - November 2017 - RBZ 5459 - 03 Nov 2017 Arriva North East: Latest News & Discussion - November 2017 RE: Arriva North East: Latest News & Discussion - November 2017 - Kuyoyo - 05 Nov 2017 One to start some rumours me thinks ![]() 1311 has been on-loan to Stockton depot today for evaluation on the 17/17a route - as well as the 9 route (new interworking over the Christmas period) RE: Arriva North East: Latest News & Discussion - November 2017 - tyresmoke - 05 Nov 2017 Providing it passed the route trials then there's no rumours to be started RE: Arriva North East: Latest News & Discussion - November 2017 - Tom - 10 Nov 2017 Bloody hell what has happened to the pulsars... on 1481 and it’s possibly one of the most underpowered buses I’ve been on. Are all of them like this now? RE: Arriva North East: Latest News & Discussion - November 2017 - BusLoverMum - 10 Nov 2017 (10 Nov 2017, 4:05 pm)Tom wrote Bloody hell what has happened to the pulsars... on 1481 and it’s possibly one of the most underpowered buses I’ve been on. Are all of them like this now? Quite a few of them were speed limited, last year. On a sapphire 6 E400 this morning, that had to slow down significantly from 60 (I could see the speedo) when it caught up with a sapphire 7 pulsar. RE: Arriva North East: Latest News & Discussion - November 2017 - Multi21 - 12 Nov 2017 (10 Nov 2017, 5:56 pm)BusLoverMum wrote Quite a few of them were speed limited, last year. This is due to a computer program called "Econospeed". You may have heard some drivers complaining about it. What it does is, it limits acceleration when pulling away, limits the amount of kickdown a driver can use and the top speed is also limited. The main problem is when it reaches the top speed (which on most is 53mph) if you push beyond the limited it will let you for about 3 seconds then drops the speed back to 45mph. Mercedes/Daimler designed this program so as you can imagine it works as designed on Mercedes products most solos are fitted with it. On VDL products it just doesn't work which is why passengers feel the difference between one that's fitted with it and one that's not. Any more questions PM me. RE: Arriva North East: Latest News & Discussion - November 2017 - BusLoverMum - 12 Nov 2017 (12 Nov 2017, 12:02 pm)Multi21 wrote This is due to a computer program called "Econospeed". You may have heard some drivers complaining about it. Some of those Pulsars didn't half go, pre-econospeed. When it was first fitted, you could tell the difference between a Darlo and Durham pulsar, pretty quickly - though at least a couple of belmont's were already knackered and sluggish, anyhow. RE: Arriva North East: Latest News & Discussion - November 2017 - South Tyne Lad - 13 Nov 2017 (12 Nov 2017, 10:44 pm)BusLoverMum wrote Some of those Pulsars didn't half go, pre-econospeed. When it was first fitted, you could tell the difference between a Darlo and Durham pulsar, pretty quickly - though at least a couple of belmont's were already knackered and sluggish, anyhow. A lot of them still do, I honestly don't see why there bothering with it anymore, As its just creating problems for the rest of the bus, Eventually increasing Maintenance cost's... Which add that to the abysmal amount of cost cutting in this part of the Durham County business, Would just put them in a bigger predicament there already in! When they first introduced the Econospeed chip, It caused uproar from Driver's and unions due to its way too restrictive ( Dangerous in fact ) setup, Most divisions abandoned the idea after that.. However 2 and a half years later North East are one of I believe Two still having it, Albeit with about 3 software amendments since, Its a pointless system now, And causing more problems than others, The reason its stayed as long as it has is only because it looks good on paper from the men in suits! A lot recently which have come under problems have it taken out without being refitted, There's a canny few of them about. Another thing it could be that the engines ECU has placed itself into Derate ( Limp Mode ) due to running out of AdBlue or a different problem which I cant remember, Though is mostly problematic with Cummins engines,The bus gives itself a 53 hour time delay from the emission's light coming on the dashboard to placing itself in Derate, Though in a lot of cases the AdBlue is never topped up in time. RE: Arriva North East: Latest News & Discussion - November 2017 - morritt89 - 17 Nov 2017 (12 Nov 2017, 12:02 pm)Multi21 wrote This is due to a computer program called "Econospeed". You may have heard some drivers complaining about it. RE: Arriva North East: Latest News & Discussion - November 2017 - V514DFT - 17 Nov 2017 Why was 4512 kept instead of anything else from that batch (4501-4515) bar the ones that became driver training vehicles,was stuck behind it today and the decibels coming from it were ridiculous RE: Arriva North East: Latest News & Discussion - November 2017 - PH - BQA - 17 Nov 2017 (17 Nov 2017, 7:25 pm)V514DFT wrote Why was 4512 kept instead of anything else from that batch (4501-4515) bar the ones that became driver training vehicles,was stuck behind it today and the decibels coming from it were ridiculous Arriva likely didn't choose that to stay longer over any of the rest of them, just a unique sequence of events that led to that being the case. Others, I believe, had ceased engines, some may have had other issues that became uneconomical to repair, 4503 was obviously written off. Same question could be asked about 7439. Would have depended on whether it was needed when it was due to be withdrawn, if they needed to keep it on they would have. RE: Arriva North East: Latest News & Discussion - November 2017 - omnicity4659 - 17 Nov 2017 2837 now carries Arriva's new logo. A few bits missing from the livery like...whoops. RE: Arriva North East: Latest News & Discussion - November 2017 - Adrian - 22 Nov 2017 We're looking to change the way this forum is setup! Have your say in the following thread: http://northeastbuses.co.uk/forum/showthread.php?tid=2047 Arriva North East: Latest News & Discussion - November 2017 - Jimmi - 23 Nov 2017 The next stop announcements on the Sapphire 7 buses at Darlington are currently not playing any announcements, just showing a static Sapphire slide. Unsure as to why this is the case. Sent from my F5321 using Tapatalk RE: Arriva North East: Latest News & Discussion - November 2017 - Teessider2014 - 24 Nov 2017 1923 has returned to Stockton depot in the new livery. RE: Arriva North East: Latest News & Discussion - November 2017 - Cock Robin - 25 Nov 2017 (24 Nov 2017, 4:10 pm)Smarty93 wrote 1923 has returned to Stockton depot in the new livery. Fleetnames on? Arriva North East: Latest News & Discussion - November 2017 - Stu1639 - 25 Nov 2017 (23 Nov 2017, 6:24 am)Jimmi wrote The next stop announcements on the Sapphire 7 buses at Darlington are currently not playing any announcements, just showing a static Sapphire slide. Unsure as to why this is the case. They’ve updated the screens on all sapphire vehicles in Darlington for the evening when they go through feethams, nothings actually changed on the display screen though, but it’s knocked all the announcements off Sent from my iPhone using Tapatalk RE: Arriva North East: Latest News & Discussion - November 2017 - JoshP - 25 Nov 2017 Why does service 3 have NSA's and a monitor? I've used service 3 a lot recently and none of them work... seems pointless. Arriva North East: Latest News & Discussion - November 2017 - Stu1639 - 27 Nov 2017 (25 Nov 2017, 10:34 pm)JoshP wrote Why does service 3 have NSA's and a monitor? I've used service 3 a lot recently and none of them work... seems pointless. Supposedly all Frequenta vehicles are getting NSA’s in the future, wether it happens or not is a different story, Redcars 4701 has the top Sent from my iPhone using Tapatalk RE: Arriva North East: Latest News & Discussion - November 2017 - omnicity4659 - 30 Nov 2017 2828 has entered service at Whitby, complete with new livery and logos. Arriva North East: Latest News & Discussion - November 2017 - Stu1639 - 30 Nov 2017 ![]() Does anyone know why there’s a X12 in Darlington/ Newton Aycliffe Sent from my iPhone using Tapatalk RE: Arriva North East: Latest News & Discussion - November 2017 - BusLoverMum - 30 Nov 2017 (30 Nov 2017, 1:40 pm)Stuartphin1639 wrote Blown in on a snow drift? (yes, I've reverted to old school 1990s smileys for this site!)
