Blind displays - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Go North East (https://northeastbuses.co.uk/forumdisplay.php?fid=54) +--- Thread: Blind displays (/showthread.php?tid=2314) |
Blind displays - BeachBoy99 - 04 Oct 2019 Hi everyone. So for those who are aware, I'm working on bus drawings based on GNE liveries. Within these, I show the routes on all three blinds (front, rear and side). One problem I'm facing with a few is that the via points displayed on the front blind don't fit on the rear as the rear blinds are shorter. Example is below – the drawing I'm focusing on is Loop 93. Destination: Gateshead loop Via points: VIA Low Fell then Heworth Front display: Rear display: Obviously from the references here, the via points don't fit on the rear display. I was under the impression that the via points would be the same on both displays, but what would the solution be here? I had exactly the same problem yesterday trying to produce the display for service 35 to Low Moorsley, for which at one point the blind displays VIA Sunderland & Houghton and therefore also doesn't fit on the rear. Any solutions? Anyone have any good quality photos of these? Probably asking for too much here... Thanks RE: Blind displays - Andreos1 - 04 Oct 2019 (04 Oct 2019, 7:14 pm)BeachBoy99 wrote So I clicked the urls in your post and got the following images. Appreciate I'm not the most tech savvy when it comes to posting urls, but I'd go for a dowel joint and McLeans.
RE: Blind displays - BeachBoy99 - 04 Oct 2019 (04 Oct 2019, 9:15 pm)Andreos1 wrote Wtf? :') They shouldn't be links either. They should be attached photos? RE: Blind displays - Andreos1 - 04 Oct 2019 (04 Oct 2019, 10:24 pm)BeachBoy99 wrote Dunno if this is what others are seeing. RE: Blind displays - BeachBoy99 - 04 Oct 2019 (04 Oct 2019, 10:43 pm)Andreos1 wrote This is why I hate trying to attach photos into forums. Absolutely shit. (04 Oct 2019, 10:43 pm)Andreos1 wrote It's probably because you're on mobile also. I'm using desktop. RE: Blind displays - V514DFT - 04 Oct 2019 I see the image,not a link RE: Blind displays - garrymc05 - 05 Oct 2019 (04 Oct 2019, 11:17 pm)V514DFT wrote I see the image,not a link same RE: Blind displays - BeachBoy99 - 05 Oct 2019 So has anyone got any solutions to the problem rather than saying they can see the attached photos? -.- RE: Blind displays - deanmachine - 05 Oct 2019 I know the 35 just says “via Sunderland” on the rear rather than both via points. RE: Blind displays - BeachBoy99 - 05 Oct 2019 (05 Oct 2019, 4:38 pm)deanmachine wrote Ah right thanks! Thought it would have |
