Go North East 6337 - Jubilee Repaint - Printable Version
+--- Thread: Go North East 6337 - Jubilee Repaint (/showthread.php?tid=3830)
Pages: 1 2
Go North East 6337 - Jubilee Repaint - Train8261 - 02 Mar 2022
A photo on Facebook has appeared today showing possible 6336/6337 at Saltmedows in a new livery unbranded
RE: New branding? - ne14ne1 - 02 Mar 2022
How come they don’t need the ‘Spare Xlines’ vehicles anymore?
RE: New branding? - BusLoverMum - 02 Mar 2022
New pride bus?
RE: New branding? - Rapidsnap - 02 Mar 2022
Purple Rear could suggest something to do with the X10.
RE: New branding? - Train8261 - 02 Mar 2022
(02 Mar 2022, 2:18 pm)Rapidsnap wrote Purple Rear could suggest something to do with the X10.
Losing X Lines X10 already
RE: New branding? - N1cholas - 02 Mar 2022
Prince bishops cant be getting deckers.....just imagine it
RE: New branding? - DavidSBrough - 02 Mar 2022
Is it not something to do with the Queen’s Platinum Jubilee?
(02 Mar 2022, 3:18 pm)DavidSBrough wrote Is it not something to do with the Queen’s Platinum Jubilee?
Possible. Stagecoach did an E400MMC in jubilee
RE: New branding? - KingSlayerRBLX - 02 Mar 2022
I was thinking with the front. so possibly
(02 Mar 2022, 2:26 pm)Train8261 wrote Losing X Lines X10 already
It wasn't an X-Line X10 branded one, it was one of the X-Line pool vehicles.
RE: New branding? - EL1TE - 02 Mar 2022
Would guess that's 6337, hasn't been out since the 18th.
That would work with the colours.
(02 Mar 2022, 4:29 pm)EL1TE wrote Would guess that's 6337, hasn't been out since the 18th.
Yep its 6337 sadly. should of been 6336 as it would be more reasonable as it has no tables whereas 6337 does. 6336 should of been the one to lose the X-Lines branding cause of the less features
RE: New branding? - Omega54 - 03 Mar 2022
(02 Mar 2022, 5:15 pm)KingSlayerRBLX wrote Yep its 6337 sadly. should of been 6336 as it would be more reasonable as it has no tables whereas 6337 does. 6336 should of been the one to lose the X-Lines branding cause of the less features
But if it is going into Xlines why is it silver?
Because the rest of them are gold.
RE: New branding? - Rapidsnap - 03 Mar 2022
It was X-Lines, it's going into Silver.
RE: New branding? - Omega54 - 04 Mar 2022
(03 Mar 2022, 11:14 pm)Rapidsnap wrote It was X-Lines, it's going into Silver.
Could it be for the X85, might be a stretch, but they are putting a larger bus on it.
RE: New branding? - Rapidsnap - 04 Mar 2022
The X85 uses Solo SRs, do a bit of research man. All the info can be found on bus times.
They will be putting Optare Versas on the route instead of the Solo SR.
I agree with some of the posts that it's probably going into a special livery to celebrate the Queen Platnium jubilee. Not a novelty that we have really had in the North East aside from a gold colour Metro.
(04 Mar 2022, 12:49 am)Rapidsnap wrote The X85 uses Solo SRs, do a bit of research man. All the info can be found on bus times.
X85 has been a double decker a couple of times since the 684's introduction
RE: New branding? - streetdeckfan - 04 Mar 2022
(04 Mar 2022, 2:33 am)omnicity4659 wrote And not one we need either. Especially when money would be better spent on having routes to run said bus on...
Same thing could be said about the Pride buses, they're also a complete waste of money and only done to get another article in the Chronicle
Sent from my AC2003 using Tapatalk
Could it be for the Durham Culture Bid? Similar thing they did with the Sunderland one.
RE: New branding? - James101 - 04 Mar 2022
(04 Mar 2022, 8:30 am)streetdeckfan wrote Same thing could be said about the Pride buses, they're also a complete waste of money and only done to get another article in the Chronicle
Christ on a unicycle, we’re not going there again are we?
RE: New branding? - Unber43 - 21 Mar 2022
Anyone know what is happening to 6337
RE: New branding? - streetdeckfan - 21 Mar 2022
(21 Mar 2022, 9:56 pm)Unber43 wrote Anyone know what is happening to 6337
It's getting repainted  Cool
RE: New branding? - Train8261 - 24 Mar 2022
Introduce the Platinum Jubilee Special Livery for 6337
https://twitter.com/gonortheast/status/1506925538295832582?t=kVjMZ3CFjl9VPc8vC_ynZQ&s=19
RE: New branding? - stagecoachbusdepot - 24 Mar 2022
(24 Mar 2022, 9:38 am)Train8261 wrote Introduce the Platinum Jubilee Special Livery for 6337
Looks outstanding
RE: New branding? - Malarkey - 24 Mar 2022
(24 Mar 2022, 10:23 am)stagecoachbusdepot wrote Looks outstanding
The Road Stripes don't like they are in the correct position angle wise and if you look at the stripes above the upper deck window they are both white when one should be black otherwise i'd agree in saying it looks good.
RE: New branding? - Dan - 24 Mar 2022
(24 Mar 2022, 11:45 am)Malarkey wrote The Road Stripes don't like they are in the correct position angle wise and if you look at the stripes above the upper deck window they are both white when one should be black otherwise i'd agree in saying it looks good.
The silver vinyl is metallic and that's why it looks darker at the bottom and light at the top - it is the correct colour.
RE: New branding? - Adrian - 24 Mar 2022
(24 Mar 2022, 11:51 am)Dan wrote The silver vinyl is metallic and that's why it looks darker at the bottom and light at the top - it is the correct colour.
Never mind the metallic vinyls, I hope you've had a protractor out to measure the angle of those roadstripes! Big Grin
New branding? - streetdeckfan - 24 Mar 2022
I think it looks alright, other than the ugly purple patch on the front.
I thought they'd realised that looks awful
RE: New branding? - DavidSBrough - 24 Mar 2022
What a guess at the start of the month! Looks amazing
