Route numbers - Printable Version
+--- Thread: Route numbers (/showthread.php?tid=4029)
Route numbers - Washingtonian - 03 Jul 2022
There's been a lot of discussion on here about route numbers and how they are in a right mess, and I fully agree! You have the 1 serving North Tyneside mainly but then have the 2 serving Sunderland, the 4 mainly around Washington and Houghton, and then the 5 around South Shields. It's just all over the place. How about something this: -
North Tyneside - 1-50
Gateshead area - 50-100
Consett area - 101-150
County Durham area - 151-200
Washington Area - 201-250
Sunderland area - 251-300
South Shields - 301-350 etc
This is just an example. Ok there may not be 50 bus routes in one area but this would make room for any potential new routes for each area in the future. Routes to major attractions such as the MetroCentre should start with the letter of the main attraction it serves, so the X66 would become the M1 for example. All Xlines would be renumbered but retain the X at the start. Just a thought.
RE: Route numbers - Economic505 - 03 Jul 2022
(03 Jul 2022, 11:41 am)Washingtonian wrote There's been a lot of discussion on here about route numbers and how they are in a right mess, and I fully agree! You have the 1 serving North Tyneside mainly but then have the 2 serving Sunderland, the 4 mainly around Washington and Houghton, and then the 5 around South Shields. It's just all over the place. How about something this: -
Happy to revert back to the TWPTE standard. Sunderland was 100 -199 for example.
RE: Route numbers - Storx - 03 Jul 2022
Personally I'd look at areas separately and each operator have their patterns and if there's duplicates then who cares along as they're not serving the same areas.
Arriva Northumbria already have a pattern pretty much
1 - 2 - Blyth Local Services
X5 - X11 - Blyth / Cramlington Expresses
X14 - X18 - Morpeth Expresses
X20 - X22 - Ashington Expresses
30's - Ashington Local Services
40's - Great North Road Services
50's - North Tyneside Local Services
60+ - Unused bar 306/308.
imo. it doesn't really matter if there's a 57 in North Shields and a 57 in Heworth as they never overlap and are so far apart, it's better than having numbers like 354 etc. It only comes a problem when you have a GNE 1 and Stagecoach 1 serving the same stops in Newcastle.
The biggest problems is corridors like through Grangetown in Sunderland where you have a 2/2A/39/39A/60/61 doing pretty much the same route but with no connection at all. It's the easiest marketing ever to say there's 15 buses an hour along there but they don't if they're serious about the BSIP add the 22/23 aswell and it's 19 buses an hour.
RE: Route numbers - ian foster - 03 Jul 2022
I agree completely . Before de regulation in 1986 it was 1 - 99 Newcastle and Gateshead, 100 - 199 Sunderland and Washington 200 - 299 Sunderland to East Durham, 300 - 399 North Tyneside, 400 - 499 South East Northumberland including services to Newcasltle, 500 - 599 South Tyneside, 600 - 699 West Gateshead & into Northumberland, 700 - 799 County Durham 800 - 899 independent operators, 900 - 999 Schools and works services, X services fast or limited stop. There was a few services that didn,t follow this mainly the longer distance services up the Northumberland coast which were 500's but not many.
RE: Route numbers - GNE6312 - 03 Jul 2022
Coast road (bar the 51 & Cobalt expresses) is 306/308-311 believe there was a 307 a while ago to benton asda to fill that gap but it's been that way for as long as I can remember
RE: Route numbers - Aaron21 - 03 Jul 2022
(03 Jul 2022, 4:47 pm)GNE6312 wrote Coast road (bar the 51 & Cobalt expresses) is 306/308-311 believe there was a 307 a while ago to benton asda to fill that gap but it's been that way for as long as I can remember
Yea 307 ran by Go North East
Newcastle to Benton Asda
RE: Route numbers - LVK 404L - 03 Jul 2022
(03 Jul 2022, 4:56 pm)Aaron21 wrote Yea 307 ran by Go North East
And Arriva, it kept swapping
RE: Route numbers - wibblejunior - 03 Jul 2022
(03 Jul 2022, 12:31 pm)Storx wrote Personally I'd look at areas separately and each operator have their patterns and if there's duplicates then who cares along as they're not serving the same areas.
Seems to be mostly the same within Durham and Darlington.
1-19 - Darlington/Bishop Auckland area local services
2x - East Durham local services
3x - unused
4x - West Durham local services
5x - services via Bowburn/Coxhoe
6x - Durham City local services
7x - ???
8x - Bishop Auckland local services
9x - Barnard Castle local services
The X12, X26/X27 and X66/X67 seem to be the main exceptions here.
RE: Route numbers - Unber43 - 03 Jul 2022
Tbh won't just changing the route numbers and adding more digits just confuse people.
RE: Route numbers - peter - 04 Jul 2022
(03 Jul 2022, 11:42 pm)wibblejunior wrote Seems to be mostly the same within Durham and Darlington.
3x - unused
7x - ???
7x are traditionally Barnard Castle local services, town services 70/71/72/74, wednesday only 73 and X75/X76 (formerly 75/76). 95 and 96 are only so numbered as they were previously operated by Arriva as a continuation of the 75/76 from Barnard Castle.
RE: Route numbers - Storx - 04 Jul 2022
3x - unused
7x - ???
Aye believe there's patterns down in Stockton aswell if I'm right between both Arriva and Stagecoach
3 - 5 - East Cleveland Services
8 - 20 - Middlesbrough / Thornaby Local Services
20's - Nunthorpe Services
30's - Billingham Services
40's - Unused
50's - Stockton Local Services
60's - Redcar Services
70's - Unused
80's - Guisborough Local Services
90's - Whitby Services
The 7, 39 and 61 are a bit of an outlier and the X66/X67 again but suppose they follow the road so makes sense. X12 is arguably a Middlesbrough service so kind of fits there.
RE: Route numbers - omnicity4659 - 05 Jul 2022
(04 Jul 2022, 7:52 pm)Storx wrote Aye believe there's patterns down in Stockton aswell if I'm right between both Arriva and Stagecoach
40's - Unused
70's - Unused
X12 is just the result of combining the X1 and X2 together. Probably fits within the X10 series of numbering for Newcastle-Teesside services.
RE: Route numbers - EastGatesheadRider - 10 Sep 2026
First comment in 4 years.
1-99  Main routes that serve metropolitan areas
100-199  Routes that serve estates and small areas
200-299  Not many bus routes , but some longer routes that goes through Industrial areas and business parks.
300-399  North Shields and some Blyth Services
400-499  Alnwick services
500-599  Routes in areas with less coverage and work express services (eg:555)
600-699  Mainly school routes
700-799  Stanley services and short metropolitan services
800-899  Mainly school routes
900-999  Work routes and shopping services (eg:939 is both)
X:Express services
TB:Taxibus
A/B:Alternatives of other routes (eg:62->62B  301->301A)
RE: Route numbers - V514DFT - 10 Sep 2026
(10 Sep 2026, 5:34 pm)EastGatesheadRider wrote First comment in 4 years.
X:Express services
TB:Taxibus
Most of what you've wrote is not correct
RE: Route numbers - Economic505 - 10 Sep 2026
X:Express services
TB:Taxibus
I think you need to to consult the bible…find a copy of an old PTE timetable booklet that is pre the Thatcher hatchet job eg 1986.
(10 Sep 2026, 5:59 pm)V514DFT wrote Most of what you've wrote is not correct
