794 - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Go North East (https://northeastbuses.co.uk/forumdisplay.php?fid=54) +--- Thread: 794 (/showthread.php?tid=4218) |
794 - OrangeArrow49 - 18 Jan 2023 From 30th January there is a route change on the 794 (DWP - Stanley), and it appears it's replacing part of the 792 (DWP - Blackhall Mill) Just the South Gosforth Roundabout/Cowgate section by the looks of it. Does anyone know if the 792 is getting revised/cancelled? Any help much appreciated. RE: 794 - R838PRG - 18 Jan 2023 Doesn’t look like 794 stops on that section? RE: 794 - OrangeArrow49 - 18 Jan 2023 (18 Jan 2023, 6:59 pm)R838PRG wrote Doesn’t look like 794 stops on that section? It's listed on the bus stops along the section on Google Maps, but could be wrong. Apparently it stops in South Gosforth, West Jesmond, Cowgate and Slatyford. Either way it's an interesting change and means it will avoid Newcastle and won't need to comply with the CAZ. RE: 794 - V514DFT - 18 Jan 2023 (18 Jan 2023, 7:18 pm)OrangeArrow49 wrote It's listed on the bus stops along the section on Google Maps, but could be wrong. Apparently it stops in South Gosforth, West Jesmond, Cowgate and Slatyford. Either way it's an interesting change and means it will avoid Newcastle and won't need to comply with the CAZ.Its probably for that reason, as the CAZ comes into effect from the 30th RE: 794 - OrangeArrow49 - 18 Jan 2023 (18 Jan 2023, 8:21 pm)V514DFT wrote Its probably for that reason, as the CAZ comes into effect from the 30th Possibly. Makes sense missing out Newcastle as it doesn't stop anyway. But I wonder if it will run non-stop between Lobley Hill and HMRC or not. RE: 794 - BusesInTheNorth - 06 Feb 2023 Those changes were to allow compatibility with Clean Air Zone. |
