:LIVE bus tracker - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Go North East (https://northeastbuses.co.uk/forumdisplay.php?fid=54) +--- Thread: :LIVE bus tracker (/showthread.php?tid=4400) |
:LIVE bus tracker - Columbo70 - 20 Sep 2023 I track my bus on the app which shows in real time where the bus is. Is this reliable because sometimes I cannot locate my bus and so just presume the service is not running. I ask because 3 times in last 2weeks my intended bus has not been showing on the app and I havent gone to the bus stop but waited for the next one . RE: :LIVE bus tracker - Adrian - 20 Sep 2023 It's pretty reliable if the times are showing in green with the animated signal icon below them. If they're showing as standard black text without this, then that's the time per the registered timetable and the bus isn't tracking. It could be an issue with the ticket machine not sending location update, or more likely nowadays, the trip has been cancelled due to them not having enough driving resource to cover their work. RE: :LIVE bus tracker - Columbo70 - 20 Sep 2023 (20 Sep 2023, 8:59 am)Adrian wrote It's pretty reliable if the times are showing in green with the animated signal icon below them. Thanks Adrian much appreciated thank you.....the conditions you are quoting here seem to be different to the app I am using......I am using the app where it shows the animated bus travelling on the route....your remarks seem to point to a different app.....can you send me it or show me where i can locate it......im using thisĀ https://www.gonortheast.co.uk/services/GNE/65 RE: :LIVE bus tracker - Adrian - 20 Sep 2023 (20 Sep 2023, 9:26 am)Columbo70 wrote Thanks Adrian much appreciated thank you.....the conditions you are quoting here seem to be different to the app I am using......I am using the app where it shows the animated bus travelling on the route....your remarks seem to point to a different app.....can you send me it or show me where i can locate it......im using thisĀ https://www.gonortheast.co.uk/services/GNE/65 Go North East app on Android (or iOS) RE: :LIVE bus tracker - BusLoverMum - 20 Sep 2023 If you pan to your stop when opening the app, you can get a list of services scheduled to run from that stop, as well as track the services. This is where you find the green or grey text that Adrian mentioned. RE: :LIVE bus tracker - deanmachine - 21 Sep 2023 (20 Sep 2023, 8:46 am)Columbo70 wrote I track my bus on the app which shows in real time where the bus is. Is this reliable because sometimes I cannot locate my bus and so just presume the service is not running. I ask because 3 times in last 2weeks my intended bus has not been showing on the app and I havent gone to the bus stop but waited for the next one . Sometimes the GPS can fail on the ticket machines and a bus will not be tracking on apps, whilst this is rare, it can sometimes mean a bus is running perfectly on time even if it's not on the tracker. |
