Redcar streetlites transferring to Stockton - Printable Version
+--- Thread: Redcar streetlites transferring to Stockton (/showthread.php?tid=4447)
Pages: 1 2 3
Redcar streetlites transferring to Stockton - megansmith - 13 Dec 2023
been mention on fb that 1560 73 are transferring to Stockton
Redcar streetlites transferring to Stockton - tyresmoke - 13 Dec 2023
Yes it seems 14 Streetlites are going to Stockton in return for 14 Pulsars of which 1421 is the first to transfer… 1570 has gone the other way
RE: Redcar streetlites transferring to Stockton - Ryland - 13 Dec 2023
What is the purpose of the transfer
RE: Redcar streetlites transferring to Stockton - megansmith - 13 Dec 2023
bad performance on Redcar x4 x93 routes where Stockton there be less maniacal problems'
(13 Dec 2023, 6:02 pm)Ryland wrote What is the purpose of the transfer
Supposedly they have a former Wrightbus engineer at Stockton who has worked wonders on their examples, improving mechanical performance and they want to do the same to the ‘Redcar’ examples.
My cynical mind would question if 1550-9 have already been through the modification program surely you’d swap those with 10 from Redcar to keep fleet ages & costs the same? Or is there something else at play here where 14 mid life vehicles are replaced with 14 life expired Pulsars?…
RE: Redcar streetlites transferring to Stockton - RobinHood - 14 Dec 2023
The transfer of the Streetlites is permanent. It is because they are having more frequent major unit failures operating the X4/X93.
Absolutely nothing to do with any additional work they are having undertaken.
Yes, Redcar gain older Pulsars from the swap, which will be better suited to the terrain of the X4/X93 and such, but conversely, it also makes Redcar that bit more attractive for a new vehicle business case too. There is mid-term logic behind it.
RE: Redcar streetlites transferring to Stockton - Andreos1 - 14 Dec 2023
(14 Dec 2023, 9:20 am)RobinHood wrote The transfer of the Streetlites is permanent. It is because they are having more frequent major unit failures operating the X4/X93.
Wonder if they remove the X3/X3A/X4/4 coving at this stage?
Old routes, numbers that don't exist anymore - but still advertised.
RE: Redcar streetlites transferring to Stockton - megansmith - 14 Dec 2023
(14 Dec 2023, 1:55 pm)Andreos1 wrote Wonder if they remove the X3/X3A/X4/4 coving at this stage?
no  branding on them now
(14 Dec 2023, 5:01 pm)megansmith wrote no  branding on them now
Not even the internal branding? It's been a few weeks since I was on one of the Streetlites, but I know the coving was there post-paint job.
(14 Dec 2023, 5:08 pm)Andreos1 wrote Not even the internal branding? It's been a few weeks since I was on one of the Streetlites, but I know the coving was there post-paint job.
the ones i been on have been complete de branded
RE: Redcar streetlites transferring to Stockton - Storx - 14 Dec 2023
Could be worse, could be advertising the X1 to Tow Low, in Ashington...
Redcar streetlites transferring to Stockton - tyresmoke - 15 Dec 2023
(14 Dec 2023, 7:05 pm)Storx wrote Could be worse, could be advertising the X1 to Tow Low, in Ashington...
Or the X12 in Huddersfield!
RE: Redcar streetlites transferring to Stockton - Storx - 15 Dec 2023
(15 Dec 2023, 6:40 pm)tyresmoke wrote Or the X12 in Huddersfield!
It's probably one the few places where Middlesbrough is an improvement Wink
Surprised they never debranded them, mind I believe one of the Pulsar's at Ashington still has Stockport branding on it aswell.
RE: Redcar streetlites transferring to Stockton - Ryland - 16 Dec 2023
Do we have any idea what other pulsar are coming to Redcar
RE: Redcar streetlites transferring to Stockton - megansmith - 16 Dec 2023
(16 Dec 2023, 8:33 am)Ryland wrote Do we have any idea what other pulsar are coming to Redcar
all together there be 14 coming from Stockton as a permeant transfer
(16 Dec 2023, 5:04 pm)Spottybus wrote We all know that 14 Pulsars are going to Redcar, you don’t have to keep on repeating it over & over again
how rude  are u  am not repeating myself I'm simply answering a question from someone
Redcar streetlites transferring to Stockton - tyresmoke - 16 Dec 2023
I would be willing to bet it’ll be the 14 09/59 plates that Stockton have to give away…
RE: Redcar streetlites transferring to Stockton - peter - 16 Dec 2023
(16 Dec 2023, 10:29 pm)megansmith wrote how rude  are u  am not repeating myself I'm simply answering a question from someone
The person asked which pulsars tho, and in fairness you did just repeat that there are 14 and didn't answer his question as to which ones they were - as for rudeness, some of your posts have been quite rude, just the other day you were quite rude when I posted that there were changes to the 1, 2/2A and 28/28A in January.
RE: Redcar streetlites transferring to Stockton - Storx - 16 Dec 2023
I might be overcomplicating things but it would make a hell of a lot more sense to send 9 (all 64 plates) to Darlington then do:
1584-1589: Darlington to Ashington
1537/1540-1542: Ashington to Darlington
1430: Darlington to Stockton
1512/1513: Ashington to Durham
09 Plate Pulsar's: Darlington to Redcar
1412/1413: Durham to Redcar
It would mean improvements for both Ashington and Darlington, and in turn send the oldest Pulsar's to Redcar where they can make a business case to get them out the fleet.
Would remove some ridiculous micro fleets which are around and batches split all over the place. If there's finally an resolution to the problems at Darlington then send 2 15 Plate Streetlite's more to Durham and send 1579/1580 to Ashington and finally get shot of the Solo's which are a waste of space the past few weeks, similar with 1543 eventually joining the rest at Darlington sometime aswell.
(16 Dec 2023, 11:19 pm)Spottybus wrote 1404/5/10 isn’t based at Darlington they are based at Stockton, I think it be better to send someone 10 plate pulsars to Redcar that way they will last longer & then Streetlites for 8s which would be good
Just seen this after, just edited it while you sent it (just noticed before you sent), so you're not quoting nothing.
The 8 probably deserves something better, I'd keep the Pulsar's on personally and do a case for replacing them. They're the sort of routes that would be ideal for any future ZEBRA bids imo.
The microfleet of Pulsar's at Ashington just really don't make sense when there's a microfleet of Euro 6 Streetlite's at Darlington aswell.
RE: Redcar streetlites transferring to Stockton - Kuyoyo - 17 Dec 2023
1404/5/15/9 are unlikely to be leaving Stockton - given they are all Euro6 therefore required for the X12 (1419 is of course branded for the X12). Of course, this swap does increase the amount of Stockton's fleet that are CAZ-complaint, as 1560-73 will also be able to be used on the full X12s.
RE: Redcar streetlites transferring to Stockton - Ryland - 17 Dec 2023
(17 Dec 2023, 8:54 am)Kuyoyo wrote 1404/5/15/9 are unlikely to be leaving Stockton - given they are all Euro6 therefore required for the X12 (1419 is of course branded for the X12). Of course, this swap does increase the amount of Stockton's fleet that are CAZ-complaint, as 1560-73 will also be able to be used on the full X12s.
So do you know which other pulsar are coming to Redcar. And when?
It would make sense to have 1420-30. And maybe 3 more
(17 Dec 2023, 12:48 pm)Ryland wrote So do you know which other pulsar are coming to Redcar. And when?
No, I don't know which ones are moving across - just that 1404/5/15/19 will definitely be staying at Stockton.
(16 Dec 2023, 11:25 pm)Storx wrote The microfleet of Pulsar's at Ashington just really don't make sense when there's a microfleet of Euro 6 Streetlite's at Darlington aswell.
Ashington's Pulsar fleet will be increasing by 1 in January anyway with the 777 starting. Also, Darlington's 'mircofleet' of Streetlites would be no good for Ashington given they are the shorter model and therefore defeat the whole purpose of Ashington's Pulsar allocation being for the 1/2 following the frequency reduction.
RE: Redcar streetlites transferring to Stockton - Storx - 17 Dec 2023
(17 Dec 2023, 1:20 pm)Kuyoyo wrote No, I don't know which ones are moving across - just that 1404/5/15/19 will definitely be staying at Stockton.
Aren't the ex 306 ones full length? They were the ones I was talking about about rather than the shorter 67 plates. Would get the batch all back together.
They're the allocation for the 1 and 2 currently anyway?
Redcar streetlites transferring to Stockton - tyresmoke - 18 Dec 2023
1427 & 1449 operating for Redcar today on 64/X3 and 63 respectively
RE: Redcar streetlites transferring to Stockton - megansmith - 18 Dec 2023
what two lites have transfer to Stockton
RE: Redcar streetlites transferring to Stockton - Ryland - 18 Dec 2023
(18 Dec 2023, 2:11 pm)tyresmoke wrote 1427 & 1449 operating for Redcar today on 64/X3 and 63 respectively
Do we know what they were tracking as.
One I believe was the spare and another tracking along with 1421 aswell as it tracking as itself
(18 Dec 2023, 7:29 pm)Ryland wrote Do we know what they were tracking as.
1427 was running around as a second 1421. 1449 was masquerading as scrapped ‘2824’
RE: Redcar streetlites transferring to Stockton - Mark66t - 19 Dec 2023
1449 is on the x4 today tracking as 2824
RE: Redcar streetlites transferring to Stockton - Rockstar666 - 19 Dec 2023
1426 is now at redcar saw it on X3 today
