Fleet Numbers - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Local Bus Scene (https://northeastbuses.co.uk/forumdisplay.php?fid=1) +--- Forum: Go North East (https://northeastbuses.co.uk/forumdisplay.php?fid=54) +--- Thread: Fleet Numbers (/showthread.php?tid=4552) |
Fleet Numbers - Retro Nero - 05 Jul 2024 Apparently Go ahead are going to introduce a 5 digit fleet number system throughout the group. Watch this space!!! RE: Fleet Numbers - citaro5284 - 05 Jul 2024 It is mentioned on the Chilterns Bus Page under fleet news and developments https://www.oxford-chiltern-bus-page.co.uk/Weekly%20Briefing%20nr%20307%20040724.html RE: Fleet Numbers - BusLoverMum - 05 Jul 2024 Oh crikey! It will take even longer for Youngest to recite the fleet numbers of entire depots than it does already! RE: Fleet Numbers - Unber43 - 06 Jul 2024 Whats the point of a 5 digit number, 4 works perfectly fine RE: Fleet Numbers - Ambassador - 06 Jul 2024 (06 Jul 2024, 10:01 pm)Unber43 wrote Whats the point of a 5 digit number, 4 works perfectly fine Would assume they’ve bought some off the shelf software that requires 5 digits. Most businesses would buy the software to suit them but I would guess the new owners might have existing arrangements RE: Fleet Numbers - Unber43 - 06 Jul 2024 just add 1 or two zeros on to the beginning RE: Fleet Numbers - Ianthegoon - 07 Jul 2024 It may be they're introducing a national numbering scheme which would require the extra digit to cover whatever classification they're introducing across the board. RE: Fleet Numbers - ian foster - 07 Jul 2024 (07 Jul 2024, 8:30 am)Ianthegoon wrote It may be they're introducing a national numbering scheme which would require the extra digit to cover whatever classification they're introducing across the board. If it is A national numbering let's hope they do a decent job of it like Stagecoach did and not a botched job like first did or give up on it like Arriva did. RE: Fleet Numbers - PH - BQA - 07 Jul 2024 (06 Jul 2024, 10:45 pm)Unber43 wrote just add 1 or two zeros on to the beginning Could you please explain how that would work in a national fleet numbering scheme? What would you do with 728, number it as 00728? Okay, but then what about the 728 in Oxford? RE: Fleet Numbers - V514DFT - 07 Jul 2024 Only time will tell RE: Fleet Numbers - Storx - 07 Jul 2024 I never understand why they don't adopt the London numbering system instead it's much better than 5 numbers which then run out so you have blocks all over the place ie. the Enviro 400's with Stagecoach. Much cleaner to have a 3 code class using letters then just number them numerically after that. So you might have WSD 1 for a Streetdeck, much cleaner than 34001 or whatever and they never run out. It's a problem within GoNorthEast, never mind the whole company and is a problem with Stagecoach aswell with the E400's as mentioned above. Fleet Numbers - streetdeckfan - 07 Jul 2024 If only vehicles were assigned their own unique identifier... Sent from my SM-F721B using Tapatalk RE: Fleet Numbers - Rapidsnap - 07 Jul 2024 Rumour has it Go North East vehicles will have a 5 (or 50 for minis) added in front of their exsisting number. So for example...... 730 - 50730. 3941 - 53941. 5525 - 55525. 6050 - 56050. 7142 - 57142. 8342 - 58342. Apparently the vehicles would still change number if they would move to another fleet. So it remains to be seen if the vehicles are going to have these numbers applied or it's just going to be on paper / behind the scenes use only. |
