XML Feed - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Other Forums (https://northeastbuses.co.uk/forumdisplay.php?fid=7) +--- Forum: Site Updates & Announcements (https://northeastbuses.co.uk/forumdisplay.php?fid=8) +--- Thread: XML Feed (/showthread.php?tid=683) |
XML Feed - DavidP - 07 Oct 2013 Hi I've having problems accessing the NEB News XML feed from your 'News' page. Do you know if that's a general issue or could it just be at my end? Thanks David RE: XML Feed - Adrian - 07 Oct 2013 Hi David. Also having the same problem. We'll get this looked into. RE: XML Feed - DavidP - 08 Oct 2013 Thank you and happy to report that this morning I can get access to this feed. Cheers David RE: XML Feed - Dan - 08 Oct 2013 It was my fault! Sorry :p RE: XML Feed - DavidP - 23 Oct 2013 I see the XML feed is down again. It is most definitely NOT Dan's fault, it's the stupid XML not recognising the "£" sign as the UK currency symbol. Best Wishes David RE: XML Feed - DavidP - 23 Oct 2013 (23 Oct 2013, 7:52 am)DavidP wrote I see the XML feed is down again. And now working again. Thank you!! |
