Before Christmas last I believe it was mentioned about Washington getting a new Leisure Centre which now in the process of being, the land has been cleared and the skate park moved, so all been well building work should start soon.
Also last year there was talk of a Morrisons being built up by B&Q in the Blackfell area of Washington along with a Tesco which would be situated across the road from McDonald's and Clay Garden Centre on the Peel Retail Park where Homebase etc currently are, no idea on how plans are going with that atm. Would have to do some research into it.
But now the Washington area is set even more development with the announcement last of a New 9 Screen Cinema and a Resturant next to Asda at Washington Galleries. it will be situated where current Cheviot House is which due to be knocked down in the next few weeks, As it has stood empty for a number of years now.
More Info on this link
http://www.sunderlandecho.com/news/busin...-1-5830363
Now my Question is with all this supposed Development in the Washington Area, could this then lead into plans for an improved Transport Facillity aswell, Thus making Washington a Major HUB for members of the Public to come to instead going further afield to the likes of Sunderland - Newcastle and the MetroCentre which are all Major Shopping/Transport HUB's in my opinion.
Now obviously as mentioned on other forums on this site it is unlikely Washington will ever receive a Metro System although it could be possible, but I do think an Improved Bus System would be great for Washington as a whole, resulting in giving links to Areas such as Middlesbrough and Hartlepool or North Shields and Tynemouth for example.
Washington Area Development
RE: Washington Area Development
I think Washington is more likely to be served by the railways than it is the Tyne and Wear Metro.
The line, as it stands, is just too peripheral to the people of Washington. If the Metro was to be extended into Washington, it needs to serve the villages but, more importantly, it needs to serve the Galleries: the commercial centre of the town. I'm not against any proposal to close the 'Wearside Loop' between South Hylton and Pelaw. Any improvement is better than none. But, in my opinion, Washington would be best served by a 'Parkway' station on the Leamside line offering new rail links to Darlo, Teesside and maybe even further south. A 'Parkway' station can be situated away from the commercial centre and, if new developments are happening at the Peel Retail Park, then it is perfectly located as a new transport hub. However, the Tyne and Wear Metro runs into the heart of Newcastle, Sunderland, Gateshead, South Shields, North Shields and so on.. Excluding it from the heart of Washington would be a big mistake.
Not sure which would come first, but one would most certainly be followed by the other. Both Nexus and Network Rail most likely want it (for different reasons), but they'll remain in a 'Mexican stand off' as neither wants to fund it..
Few bits of info. Morrisons at Armstrong Industrial Estate is still pending a formal decision. Full details here. The Tesco store at Peel Retail Park has now been 'downgraded' from an Extra store to a normal supermarket. Again, it's still pending decision. Full details here.
Forum Moderator | Find NEB on facebook
No doubt about it, it will need work to be able cope with incoming/outcoming traffic from the area, I would suspect there be traffic lights etc to be introduced.
As for buses I think they'll have the M2/M3 serve Bus Stops outside of the Tesco if it goes ahead although both stop at the bottom of the Motorway and at Barmston coming from Concord and Washington. Perhaps a quicker shuttle service could be introduced. It would be the same case with the Morrisons also.
As for the New Leisure Developments in Central Washington, I think there might be some road closures coming into Washington from Lambton/Oxclose and from Biddick/Glebe via the Leisure Centre. But we'll have to wait and see. TBF as I have lived in Washington all my life, which is almost 21 years, I think this sort of Development is long over due and is certainly welcomed by myself. I hope everything goes to plan.
(09 Jul 2013, 8:08 pm)Adam Malarkey Wrote: No doubt about it, it will need work to be able cope with incoming/outcoming traffic from the area, I would suspect there be traffic lights etc to be introduced.
I agree with what you say about the M2/M3. The easiest solution would be to turn left into Peel, then round the McDonalds roundabout and then back to normal route (as below). It would only add a minute or so on to the journey at most.
![[Image: XrPm8Mn.jpg]](http://i.imgur.com/XrPm8Mn.jpg)
Regarding road closures. I wouldn't expect too many of them. Road closures on developments mainly occur to route the services into the development - e.g. water, gas, and electric. That shouldn't be required for either the Leisure Centre or the new Leisure complex at the galleries. Fingers crossed!
I think close off those entrances at Washington Galleries when they implode Chariot House as it's next to the road in which Buses use coming in/out of the galleries, plus there would be some debris on the road and dust also, unless they due it during the night or on a Sunday when it's less busy.
They've already dug little square holes on the Car Park to put explosives into I think. No doubt there will be an infestation of rats in there also, as I seen a few go into nearby bushes a few weeks back.
Either way it'll brought to it knees in the next few weeks
In the post this morning I received a Morrisons Washington let's make it happen leaflet.
Basically they rallying for support behind the project from the local community to then persuade the local council to accept there bid, Morrisons have also asked in the leaflet to fill out a little questionnaire to give our views and also email the local council also on the following email address dc@sunderland.ac.uk.
They've also reduced the store size slightly as asked by the council. Also Morrisons have displayed 5 reasons why the scheme should go ahead.
1.) 250 local job opportunities
2.) An appropriately Sized Supermarket in the right location to provide an improved choice and competition on for the weekly shop in Washington
3.) A long awaited development of an under utilised site
4.) A Catalyst for further investment in this part of Washington
5.) Multi-million development bringing a 30,775 sq ft derelict site back to life.
I personally will be filling out my feedback card and sending an email as I totally agree with is has been said in the leaflet, and tbf I don't fancy trolling my backside over to Doxford Park when I fancy some of the freshly baked sausage rolls, when I could easily either Walk/Bike or get the Bus there as it's about 10 minutes up the road from where I live.
(11 Jul 2013, 3:40 pm)Adam Malarkey Wrote: In the post this morning I received a Morrisons Washington let's make it happen leaflet.
Is this in Washington Galleries they are planning? - There's already a Sainsbury's and ASDA :L
I do agree though, Morrisons is a great supermarket, as well as Tesco! - Hate the two in the Galleries!
Yeah there will be two much choice, I mainly go to Asda as its the cheapest, sometimes go to Sainsbury's or i'll bike over to Doxford Park as it only takes about 40 Minutes, depending on Weather Conditions which is a rarity.
But I welcome the competition, plus you have Tesco aswell on Peel Retail Park to built if they get planning permission. The Morrisons will be based on the Industrial Estate at Blackfell
I find it odd that the Competition Commission ruled that ASDA could not have Birtley Netto and were forced to sell it to the Co-Op due to the locale of the Galleries Asda but it's ok for Morrisons to have a 30,000sq foot supermarket in Birtley (construction starting August) and plan for another 30,000sq foot in Washington
(11 Jul 2013, 7:31 pm)gtomlinson Wrote: I find it odd that the Competition Commission ruled that ASDA could not have Birtley Netto and were forced to sell it to the Co-Op due to the locale of the Galleries Asda but it's ok for Morrisons to have a 30,000sq foot supermarket in Birtley (construction starting August) and plan for another 30,000sq foot in Washington
Not to mention the one they already have in Chester Le Street.
(11 Jul 2013, 8:24 pm)Andreos1 Wrote: And the rumoured one at the North End of Team Valley opposite Maingate.
The email I was referring to was the one AdamMalarkey mentioned. The @sunderland.ac one.
Apologies that was a typo, was meant to put GOV
I have posted this in the service suggestions also
Washington Galleries - Sainsbury's Car Park - Biddick(W5) - Glebe(W6) - Washington Village(W6) - Brady Square(W5) - Barmston Court (W6)- Barmston(Horsley Road) - Waterview Park - Nissan - Peel Retail Park - Sulgrave - Concord - B&Q - Blackfell - Oxclose - Washington Galleries
W5 Clockwise - W6 Anti-Clockwise Loop, as part of the revamp the Service would receive Optare Solo SR's and the service be run in a similar fashion to that of the Q1/Q2 and the 700.
I noticed when passing Cheviot House today that pretty much al the Windows had been fully removed, also where the Steps are there was Digger starting working on the grass side, must be going to level it all out. Also the new pathway/move of the skate park has been competed.
Looks like once Cheviot House is brought to it's knees work on both projects stated will commence.
(10 Aug 2013, 7:55 pm)Adam Malarkey Wrote: Cheviot House - Demolition in Progress
For some reason I thought Cheviot House was that tall blackish/brown building which you immediately notice when looking towards Washington from Stanley/Dipton. I'm glad that Cheviot House turned out to be something different.
(11 Aug 2013, 3:01 pm)AdamY Wrote:(10 Aug 2013, 7:55 pm)Adam Malarkey Wrote: Cheviot House - Demolition in Progress
That'll be Durham House. Still occupied by the DWP.
(11 Aug 2013, 3:08 pm)aureolin Wrote:(11 Aug 2013, 3:01 pm)AdamY Wrote:(10 Aug 2013, 7:55 pm)Adam Malarkey Wrote: Cheviot House - Demolition in Progress
Think that'll be getting knocked down as well at some point I think as some floors are deemed unsafe for usage, mainly the ones nearer the top apparently.
Washington Area Development - Leisure etc...
Washington Town centre Leisure Phase.
Below the proposed new layout of the new Cinema next to the Galleries:
http://www.sunderland.gov.uk/Planning/StreamDocPage/obj.pdf?DocNo=771778&PageNo=1&content=obj.pdf
Washington school to be rebuilt after being listed among UK’s most run-down
http://www.washingtonstar.co.uk/news/loc...-1-6193148
and I can't find anything for Washington Cinema either
(13 Nov 2013, 10:53 pm)Adam Malarkey Wrote: Washington school to be rebuilt after being listed among UK’s most run-down
It was on the front page of that edition along with the Dad of one of the girls who drowned in the summer at Fatfield
![[Image: FbCHJjd.jpg]](http://i.imgur.com/FbCHJjd.jpg)
