Little Bits and Bobs: 19/12/14 Update - Printable Version +- North East Buses (https://northeastbuses.co.uk) +-- Forum: Other Forums (https://northeastbuses.co.uk/forumdisplay.php?fid=7) +--- Forum: Site Updates & Announcements (https://northeastbuses.co.uk/forumdisplay.php?fid=8) +--- Thread: Little Bits and Bobs: 19/12/14 Update (/showthread.php?tid=1199) |
Little Bits and Bobs: 19/12/14 Update - Dan - 20 Dec 2014 The presentation of the "Local Bus Scene" forums has really been irritating me as of late, and I've been conjuring up various ideas to make the forums more presentable. I've finally had a chance to get round to doing a few updates, and these are outlined below: Arriva, Go North East and Stagecoach North East forums
RE: Little Bits and Bobs: 19/12/14 Update - S813 FVK - 21 Dec 2014 Quite like the new announcement system. Quite easy to use and doesn't involve going on 2 different pages before you get to the page with the links on. This mini clean-up has certainly improved the way the forum looks. RE: Little Bits and Bobs: 19/12/14 Update - Dan - 31 Dec 2014 Following this update, Scott (tyresmoke) suggested that he wanted to 'clean up' the "Other Operators" section of the forum, too. Scott and I discussed our plans to improve this section this evening, and we'd like to put forward our suggestions to our members to gather opinions. Option 1 - Create alphabetical sub-forums within the "Other Operators" section When users click "Other Operators", the list of threads would not appear immediately. Instead, five sub-forums would appear: A - E, F - J, K - O, P - T, U - Z All of the current threads (excluding those with no further posts from the original post) would be placed into the relevant lettered category. Once a lettered sub-forum is clicked, all of the bus operators whose company name starts with one of those letters will be displayed. The upside to this is that this would allow standardisation between the forum and our fleet list homepage, which is sorted similarly. The downside is that there would still be approximately 30 threads for some of the more common letters, although the system allows for 30 threads to be shown per page (and this can be increased if necessary). Option 2 - Create sub-forums sorted by county within the "Other Operators" section As above, with the categories instead being: Northumberland, County Durham, Tyne and Wear, and Teesside Option 3 - Some operator threads merged, larger threads with the most discussion remain separated Everything is left as present, but threads similar to this one are created for all of the smaller threads with less discussion to be merged into. Larger threads, such as Procters Group, Gateshead Central Taxis, are not merged. Option 4 - Other Leave everything as present and don't bother at all - or an idea of your own (give feedback below if so). Any feedback appreciated! RE: Little Bits and Bobs: 19/12/14 Update - Tom - 31 Dec 2014 Option 2 sounds the best
RE: Little Bits and Bobs: 19/12/14 Update - Adrian - 31 Dec 2014 (31 Dec 2014, 7:35 pm)Dan wrote Following this update, Scott (tyresmoke) suggested that he wanted to 'clean up' the "Other Operators" section of the forum, too. Scott and I discussed our plans to improve this section this evening, and we'd like to put forward our suggestions to our members to gather opinions. Other than option 4, my preference would be option 2, but I think the 3rd option would also work. The first, imo, would look a bit messy. RE: Little Bits and Bobs: 19/12/14 Update - Dan - 31 Dec 2014 (31 Dec 2014, 7:40 pm)aureolin wrote Other than option 4, my preference would be option 2, but I think the 3rd option would also work. The first, imo, would look a bit messy. My issue with the third option is that things are so unpredictable with independent bus operators... We used to have quite a bit of discussion going on in the Pygall's Coaches thread, but since the withdrawal of the 230 and X27, we've had very little. Similarly, prior to Gateshead Central Taxis gaining a lot of Nexus contracts this year, we did not really discuss their operations at all. If an operator suddenly turns around like both of those operators have done, where do you draw the line to either close the main thread and merge it into 'smaller bus operators' thread or conversely make a new thread completely as the company is rapidly growing? RE: Little Bits and Bobs: 19/12/14 Update - R852 PRG - 31 Dec 2014 Option 2. RE: Little Bits and Bobs: 19/12/14 Update - PH - BQA - 31 Dec 2014 Think option 2 would be the best, option 3 looks like it has the potential to get a bit confusing (it's possible I've completely mis-understood three like )
RE: Little Bits and Bobs: 19/12/14 Update - Jimmi - 31 Dec 2014 Option 2 is my choice. Don't like option 3 at all. RE: Little Bits and Bobs: 19/12/14 Update - Adrian - 31 Dec 2014 (31 Dec 2014, 7:45 pm)Dan wrote My issue with the third option is that things are so unpredictable with independent bus operators... Aye that's true like. Option 2 for me then. RE: Little Bits and Bobs: 19/12/14 Update - tyresmoke - 31 Dec 2014 Thanks guys for your opinions - keep them coming! Helps us to push forward with improving your forum experience! RE: Little Bits and Bobs: 19/12/14 Update - Andreos1 - 31 Dec 2014 Could one or two of the ideas be merged? Stick them into areas as suggested, but set them up in alphabetical order within those sub forums? RE: Little Bits and Bobs: 19/12/14 Update - Dan - 31 Dec 2014 (31 Dec 2014, 8:54 pm)Andreos1 wrote Could one or two of the ideas be merged?Do you mean to create another sub-forum in the alphabetical categories after having put them into county sub-forums, or to just make the threads appear in alphabetical order within the county sub-forum? RE: Little Bits and Bobs: 19/12/14 Update - DanPicken - 01 Jan 2015 Option 2. RE: Little Bits and Bobs: 19/12/14 Update - Dan - 01 Jan 2015 Thanks, all! Will keep this thread open for discussion on options for a few more hours - but it's looking like Option 2 will be the way we go! Whatever we go for, I'll try and get it implemented today (haven't got anything else to do today!) RE: Little Bits and Bobs: 19/12/14 Update - Michael - 01 Jan 2015 Option 2 =) RE: Little Bits and Bobs: 19/12/14 Update - GuyParkRoyal - 01 Jan 2015 My preference is option 1 based on my experince of using that format when viewing fleet lists it is easy to navigate and find what I am looking for. Option 2 looks OK but is not ideal where an operator is based near a county boundary where local knowledge may be required in selecting the correct county. If you go with option 2 can North Yorkshire be included. I don't like the look of option 3. RE: Little Bits and Bobs: 19/12/14 Update - tyresmoke - 01 Jan 2015 (01 Jan 2015, 11:08 am)GuyParkRoyal wrote My preference is option 1 based on my experince of using that format when viewing fleet lists it is easy to navigate and find what I am looking for. Yes I am sure we can provide a forum for North Yorkshire, it would definitely help to provide a room for growth of discussion on the aspects of bus operation in North Yorkshire! RE: Little Bits and Bobs: 19/12/14 Update - Michael - 01 Jan 2015 Although not based on the suggestion of updating the format of the independent operators, i have a suggestion for something else... Can the admins please delete old threads in Off-topic bus chat General off-topic chat Anything below a certain month of the 2014 - delete. (Maybe October, 2014ish)? It's just some haven't had a post in them for a while... and it's pointless having them. RE: Little Bits and Bobs: 19/12/14 Update - Jimmi - 01 Jan 2015 (01 Jan 2015, 12:47 pm)Michael wrote Although not based on the suggestion of updating the format of the independent operators, i have a suggestion for something else... I have just looked through the General Off Topic Chat section and there is a good few threads that could be deleted, some could be merged with a similar thread - for example there is a snooker thread which has seen very little action and could easily be dropped into a sport thread. Some have just been set up to ask a question and then they may get an answer and then there is no point in that thread remaining there. Some small threads with little discussion could be dropped into the Anything and everything thread or deleted. RE: Little Bits and Bobs: 19/12/14 Update - Adrian - 01 Jan 2015 I'd rather we leave the off topic forums exactly as they are, as they're for exactly that. RE: Little Bits and Bobs: 19/12/14 Update - Michael - 01 Jan 2015 (01 Jan 2015, 1:25 pm)aureolin wrote I'd rather we leave the off topic forums exactly as they are, as they're for exactly that. Even if some haven't had posts in them for ages? RE: Little Bits and Bobs: 19/12/14 Update - RM2186 - 01 Jan 2015 OK, have to agree......... option 2 all the way. RE: Little Bits and Bobs: 19/12/14 Update - Tommy1581 - 01 Jan 2015 Option 2 sounds the best. RE: Little Bits and Bobs: 19/12/14 Update - Dan - 01 Jan 2015 We'll try Option 2, then. The "Other Operators" section shouldn't be visible to you guys now until I'm done. If it doesn't work, it's easily sorted back to how it is at present, or to one of the alternative options.
RE: Little Bits and Bobs: 19/12/14 Update - Tommy1581 - 01 Jan 2015 (01 Jan 2015, 2:30 pm)Dan wrote We'll try Option 2, then. I thought that I was being thick or something... RE: Little Bits and Bobs: 19/12/14 Update - Diamond One - 01 Jan 2015 i have an idea although this is a 2nd hand idea i got from a distant past but why not even though this may sound daft create separate forum to separate the top 3 from the independents and i got this idea from a Mr Cooper a few years back under the old NorthEastBus.co.uk it will work RE: Little Bits and Bobs: 19/12/14 Update - Dan - 01 Jan 2015 As discussed, we have updated our "Other Operator" section of the forum. With the primary intention of 'cleaning up' the forum, we have created sub-forums to separate the large number of threads in this section of the forum. The threads are now categorised by counties: Tyne & Wear, County Durham, Northumberland, Teesside, and North Yorkshire. A number of threads did not fit into these categories and as such have been moved. These inlude:
In addition, we have created a new thread in the "Bus Scene - Elsewhere" section of the forum. We have merged together the following threads which were previously found in the "Other Operators" section:
The "Other Operators" section is now available for normal members to see again. |
