Go North East: Latest News & Discussion - July 2015
RE: Go North East: Latest News & Discussion - July 2015
(10 Jul 2015, 9:07 pm)citaro5284 wrote Of course, the tweet could not mean a thing Tongue
It was rather random to say the very least, perhaps we are reading into it too much.
(10 Jul 2015, 9:17 pm)Malarkey wrote Think it would be a good idea not to allocate a Double Decker to the X1A on the 14th/15th July, best give Washington Depot a heads up Wink
http://www.simplygo.com/news/closure-of-...h15th-july
I can't see why not. Basically it's going over Fatfield Bridge (16ft), then joining the Washington Highway at the Fatfield turn off.
Basically this is the route...
Please feel free to visit my Flickr page - https://www.flickr.com/photos/gjm-photogenic/
Who needs heroes anyway? Villians have more fun.
(10 Jul 2015, 9:30 pm)GMitchelhill wrote I can't see why not. Basically it's going over Fatfield Bridge (16ft), then joining the Washington Highway at the Fatfield turn off.
Yeah but Fatfield Bridge has a Weight Restriction, plus what is the Height of a B9TL for example.
Height of most Double Deckers are around 14ft. Think the Geminis are 14ft 3in. It does have a weight restriction of 7.5t but that only applies to HGVs.
Think the highest double deckers I've seen were Alexander RH bodied Leyland Lions which were touching 15ft. Highest deck Go-Ahead Northern had were the highbridge Bristol VRs of which 3401 and 3406 are preserved.
(10 Jul 2015, 8:41 pm)South Tyne Lad wrote That explains why I seen Scania L94 5218 in a convoy with 5162 on the A1 Western Bypass earlier.   That explains 5162...it was moving from Riverside to Deptford though it showed 67 Winlaton on its front Destination Display. will 5218 have come from Deptford with 2 engineers and on arrival at Riverside 1 would switch to 5162 and drive that to Deptford and the other drive 5218 to Deptford?
do not think 5218 will transfer to Deptford due to it being branded for Highwayman services only time it will transfer was if the Highwayman services were changing eg the PVR goes down just by 1 or if new vehicles were on order for Highwayman this vehicle would be going red and further transfer to a different depot
Favourite Company is: Go North East
Favourite Operator in UK is: EYMS
Owner of Bella the Cat
Mood right now: Fustrated and Feel Left Out
(09 Jul 2015, 10:46 pm)GMitchelhill wrote Actually the break down is likely to be as follows.....
Q1 / Q2 has a PVR of 13
Q3 has a PVR of 6.
8310-8315 are likely to be branded for Q3
8317/8318/8328-8338 are likely to be branded for Q1/Q2.
8316 could be the Pride bus. However, 8316 could be branded for either route with either 8310 or 8338 receiving the pride livery.
The 19 yellow Versa will be 8310-8318, 8329-8338.
8310-8315 will be the green ones.
The pride bus is expected to be out of the purple ones.
8328 should become a red spare.
(07 Jul 2015, 12:41 pm)Michael wrote Forgot about the East Durham Solo SR's being due....
I would of liked to see it on the Citaro's more than the Cadets..... would be good to see the 35/35A/36 also gain "Black Cats" brand but on the gold base... would be good to see it on all of the non branded routes in Sunderland, if i'm being honest!
Why should we forget about the East Durham Solo being due?
(10 Jul 2015, 10:44 pm)busmanT wrote Why should we forget about the East Durham Solo being due?
No i did...
(11 Jul 2015, 5:17 am)Michael wrote No i did...
OK you should see them in the next few weeks.
(11 Jul 2015, 8:40 am)busmanT wrote OK you should see them in the next few weeks.
Are they still going to be black and Pink? Tongue
With the Expansion of Tynedale Links routes - New Services 680 and 682 serving the North Tyne Valley from Hexham, I assume this may mean Hexham may need an extra bus or two.
Do they have enough spare buses at Hexham or will the rearrange of a couple of services create enough buses to operate these New services or is it likely that Hexham will get another bus or two.
If they do get another bus or two - do you think it is likely it will be a Transbus MPD/Mini Pointer like some of the other Tynedale Links fleet.
I am pleased GNE have taken on these routes and it would be good to see more coming in the future.
(11 Jul 2015, 11:21 am)thetravelman wrote With the Expansion of Tynedale Links routes - New Services 680 and 682 serving the North Tyne Valley from Hexham, I assume this may mean Hexham may need an extra bus or two.
I would have thought that they may need an extra vehicle somewhere along the line.
(11 Jul 2015, 11:25 am)citaro5284 wrote I would have thought that they may need an extra vehicle somewhere along the line.
Think Dan already mentioned that....
(10 Jul 2015, 10:36 pm)Diamond One wrote do not think 5218 will transfer to Deptford due to it being branded for Highwayman services only time it will transfer was if the Highwayman services were changing eg the PVR goes down just by 1 or if new vehicles were on order for Highwayman this vehicle would be going red and further transfer to a different depot
Corrected I seen 5216 with 5162 on the A1, thanks Bazza for help correcting me.
My New Flickr https://www.flickr.com/photos/140662069@N02/ - Posts every Weekend at the minimum Smile
Does anyone know if you can listen to the drivers and control via a scanner, is there much transmission between them.
If so, does anyone know what frequency to use.
I often use my scanner for listening to aircraft, just wondered if you can do the same with buses.
Cheers
(11 Jul 2015, 11:55 am)thetravelman wrote Does anyone know if you can listen to the drivers and control via a scanner, is there much transmission between them.
Cheers
GNEs system is digital I believe, so I'd be very surprised if they aren't encrypting their traffic.
(11 Jul 2015, 2:29 pm)northern156 wrote 4969 broken down on a 20/20A in Houghton-le-Spring with engine cover up and Fitters Van attending
Maybe its wing mirror is in there.
#burntwingmirrors
#hashtagsonNEB
Against the Anti-Lee Club.
(11 Jul 2015, 2:38 pm)danpick wrote Maybe its wing mirror is in there.
#burntwingmirrors
#hashtagsonNEB
Nah, maybe it over-heated.
(11 Jul 2015, 4:43 pm)S813 FVK wrote 6133 is/was out on the X70/X71s today if anybody is still in Newcastle looking for it. Bit late now like but just in case.
It was involved in an incident earlier today which resulted in the cancellation of the service it was operating (later replaced by another bus) - see this Tweet for confirmation.
(11 Jul 2015, 4:44 pm)Dan wrote It was involved in an incident earlier today which resulted in the cancellation of the service it was operating (later replaced by another bus) - see this Tweet for confirmation.
Hope it was just a passenger being ill rather than a 'crash' incident. Couldn't have happened to a nicer looking bus like.
(11 Jul 2015, 5:44 pm)thetravelman wrote When are the last of the purple "Toon Link" branded Wright Renowns due to be withdrawn?
When the remaining omnicities entre service.
Also, has 4987 transferred to Deptford permanently or just temporally?
(11 Jul 2015, 6:06 pm)Davie wrote When the remaining omnicities entre service.
It's properly transferred, but 4897 is just a float vehicle so can in theory transfer to any location without needing to be replaced as it's just an extra bus in the fleet.
At the moment, it's covering for Deptford's Mercs which are being repainted for services 35/36.
(11 Jul 2015, 6:07 pm)Dan wrote It's properly transferred, but 4897 is just a float vehicle so can in theory transfer to any location without needing to be replaced as it's just an extra bus in the fleet.
ah right, cheers, Dan!
