(25 Aug 2015, 8:31 pm)DanPicken wrote Might just fine Alpha then.
I wrote that Thorntons is a fifteen minute walk from The Elephant, Ashington.........!
(28 Aug 2015, 7:03 pm)Jimmi wrote How do I get to Nightingale Coaches depot from Durham for the open day tomorrow morning. Also where is the depot?
(28 Aug 2015, 7:33 pm)Dan wrote Type in the post code of the address given on the company's fleet list into Traveline Journey Planner.Thanks, was just wanting to make sure that it was the address that is on the fleet list and the one I found elsewhere as when I typed Nightingale Coaches into Google a few different results came up. I'll get the 43 from Durham.
(28 Aug 2015, 7:37 pm)aureolin wrote I'm aiming for the 0905 #43 from Durham to Stanley, so if you can get into Durham before 9, then feel free to tag along?
(28 Aug 2015, 7:39 pm)R852 PRG wrote ...meanwhile, in York; R852 PRG and citaro5284 enjoy a nice Wetherspoons breakfast.
(02 Sep 2015, 1:23 pm)S813 FVK wrote It stops on Birtley Front Street. Just cross the road after getting off for buses to Durham.Cheers mate
(02 Sep 2015, 7:38 pm)DanPicken wrote Thanks what if the hole isn't there also what about the Southbound side?
(02 Sep 2015, 7:43 pm)MurdnunoC wrote https://www.google.co.uk/maps/@54.889603...6656?hl=en
It's permanent.
It's quite a walk to the nearest bus-stop Southbound, the nearest you're gonna get is probably Ayton. Get the X25, then cross the bridge from the Northbound to the Southbound service area.
(02 Sep 2015, 7:47 pm)DanPicken wrote I didn't think it was a wooden fence is noticeable from the X25 may not need to do this yet.
(02 Sep 2015, 7:54 pm)MurdnunoC wrote Well, that latest shot was taken in April 2015 and the last time I used it was probably around November 2002. I think it's unlikely to have been closed-off since April.
There's also another hole you can go through.
https://www.google.co.uk/maps/@54.890510...6656?hl=en
That's the pub and bus-stop to which I referred and, if you pan round towards the row of terraced houses to your right, you'll see another gap you can go through.
(02 Sep 2015, 8:03 pm)MurdnunoC wrote Board Inn.
(02 Sep 2015, 8:08 pm)DanPicken wrote Thanks Adam.
(05 Sep 2015, 2:51 pm)GX03 SVC wrote Caravans? Go straight to the end of the *wide* road, turn left, follow that path, you should pass the Household Waste Recovery Centre on your left, keep following the path, you should pass the village, turn left and stay on the path, you may need to cross the road. Keep on that road until you see a gap on the bush, with buses behind it.Left over an hour ago unfortunately but I'll try and bare that in mind for next time. Managed to find it but was in such a state I had to move on.
