(31 Dec 2015, 2:58 pm)Michael wrote I don't think the X1 will be changing at all.
The ques on a morning from the galleries to Newcastle are long, one thing they should do in increase the frequency on that part of the route but don't think they'll do that and just stick with a 10 min frequency through out the full route
Dropping the frequency between Hetton and the galleries to accommodate the increase between the Galleries and Newcastle, won't work either... the full route should stay every 10 minutes.
It isn't just in a morning that the queues at the Galleries are long.
Whilst the runs south from the galleries out of peaks can be quiet, they seem to be intermittent. Haven't worked out why some are busy and others less so.
Trips between Hetton and Houghton in particular, can be very busy. Regardless of time of day.
I wonder if it has anything to do with the X1 being the quickest (regular) service between the two.
With the 35's being reduced from 10, to 20mins, the X1 appears to have picked up a lot of custom between those points.
Ditto short, local runs between Houghton and Herrington Burn - which has the alternative of a longer 35/36 or infrequent 38.
2mins may not be a lot on paper, but to take out a bus from a service that has frequent delays, could mean hanging around a lot longer than the regular 20mins+ waits I have experienced all too often.
Better management of the service between the Galleries and Gateshead in particular, would be my preference.
