RE: PSV Accessibility Regulations (DDA Regulations) - at a glance
(09 Feb 2016, 5:18 pm)James101 wrote In my opinion, the only people justified to make a complaint to the operator are those genuinely inconvenienced by the PSVAR violation. Other than that its an issue to be left between VOSA/the TC and the operator. Anything else is pointless busy-bodying.
How do you get "make a complaint" from "dropping the operator an email"? If you were an operator running around with faulty equipment, would you not appreciate that someone has pointed it out to you? It may not have been faulty at the time the FUC was carried out, or it may in fact be intermittent. At least if you know about it, you can do something about it, before the authorities see it.
Busy-bodying or not. If you carry out operations in the public domain whilst not law abiding, then you run the risk of being reported for it. Like I say, I'm neutral on the whole issue, but I wouldn't run the risk if it were my business operating outside of the law. The damage to reputation is not worth it, should you be prosecuted.
(09 Feb 2016, 5:18 pm)James101 wrote Further to the point made by Greg in Weardale, if so much responsibility has been placed on operators, local authorities should up their responsibility to make bus stop infrastructure more accessible. I would propose this would to be ensure time information is at every stop, and a universal style to be adopted. I second the point about DCC's timetables being God-awful. Nexus style is much more informative. Raised pavements should be also required; there's many around where I live where a simple flag on a lampost suffices, with a 'both sides' label to indicate buses also pick up passengers on the patch of grass opposite. What is the point on forcing PSVAR buses if the stops are inaccessible?
You may find this to be an interesting read, although it's only guidance and best practice -
https://www.gov.uk/government/publicatio...e-mobility
PSVAR needs to be enforced because as a business, you can't treat someone with disabilities less favourably than someone without. Providing a step entrance bus for example, to someone with mobility issues is doing just that. I find that there is still a big misconception in the industry, that just because someone isn't in a wheelchair, they're more than capable of climbing steps. The same goes about non-physical disabilities.
I do think that our infrastructure does need to be largely improved though, and especially in rural areas. The timetable at stops should be a UK standard, and shouldn't differ from area to area in my opinion.
(09 Feb 2016, 5:18 pm)James101 wrote Andreos1 brings an interesting comparison to DDA building regs. Would a better solution have been for the PSVAR regulation to only apply to vehicles built after a certain date? Based on an average service life of 15 years, most non accessible buses are naturally being withdrawn around now. I fear having the system of having withdrawal dates for non-complying vehicles hits smaller operators even harder as undoubtably PSVAR compliant buses have been for sale at inflated prices in the run up to Jan 2016 as dealers would be aware operators are being forced to purchase. Equally, non PSVAR buses on the way out would have had their value plummet in comparasion to what could have been if they were allowed to be withdrawn at a more natural rate.
This was actually the case. The PSVAR came in on the 31st December
2000. They have had 14-16 years to ensure compliance. There should never need to be a 'run up' with that much notice.
(09 Feb 2016, 5:18 pm)James101 wrote With regards to the process of lawmaking; particularly the research and industry expert aspect. I wonder just how this panel was made up? The cynic in me wonders if this was more weighted towards 'the big 3' operators and bus manufacturers rather than small operators and community groups. I also wonder if the public was asked 'Should all buses be fully accessible'? (a clear yes vote) OR 'Should all buses be even more accessible to these exact standards even at the risk of some bus services having to be withdrawn as a result?'. requires a bit more thought.
It's not a panel. Committees will tend to hear evidence from a wide range of people, such as the groups I've mentioned previously. I've found the following resource that should explain the passage of a Bill a bit better for you, as it's quite a complex process! :
http://www.parliament.uk/about/how/laws/passage-bill/
