(15 Oct 2017, 1:39 pm)Ds1197 wrote 5337 and 5338 are a different vehicle then service there spares for which are 5/50
are they not spares for the 4 too though?
(15 Oct 2017, 2:52 pm)Malarkey wrote With regards to depot standardisation I would go with the following.
5304 to 5309 remain at Deptford for the 9
5324/25 - Spares at Washington for the 4/5 & 50
5326 to 5336 - Branded at Washington for the 5 & 50
5337/38 - Spares at Washington for the 4/5 & 50
As a result of the above 5243 to 5247 and 5255 to 5260 would transfer to Deptford for the 35 with the remaining being spares.
(15 Oct 2017, 5:21 pm)Malarkey wrote Another idea from me.
Angel gets 17 Streetdecks.
6056 to 6070 go to Riverside for the 53/54 & 58
As a result of service changes they would merge together into one service numbered 53/54 operating every 7/8 Minutes between Heworth and Gateshead, every 15 minutes on the existing 53/54 route, basically the route would be like this.
Heworth - Leam Lane Estate - Felling Square - Deckham - Gateshead - Newcastle - Bensham Road - Saltwell Park - Coatsworth Road - Gateshead - Deckham - Felling Square - Leam Lane Estate - Heworth
This would then allow the following.
8339 to 8346 transfer to Deptford for the 35
5377 to 5384,5389,5390 transferring to Chester for the single deck boards of 13/14/X25 & services 28/28A.
3961 to 3964 would remain at Chester for the double deck boards of the 13/14/X25.
As for the Citaros I would go with what I said earlier.
5304 to 5309 remain at Deptford for the 61
Black Cats Scania L94's would the be allocated to the 9/38
The Omnicities would then go to Percy Main for the 11/19 with the Scania L94's/Volvo B7RLE's replacing older Scania L94's in the fleet.
(15 Oct 2017, 5:39 pm)S813 FVK wrote Which Versas would end up at Deptford under his plans?
  or start all over again
 (15 Oct 2017, 5:53 pm)cbma06 wrote Forgot that versas end at 38
GNE should put the versas from fleet number series 5000 into the 8000 series of numbers and change the streetlites from the 8000 over to the 5000 series of fleet numbersor start all over again
(15 Oct 2017, 6:25 pm)deanmachine wrote It's because the Saltwell Park Streetlites are shorter than the full size ones, so they've got midibus fleet numbers. I think they're too small for the 35 though, don't see why they'd get rid of Citaros on the 35.
(15 Oct 2017, 8:25 am)Dan wrote 6070 was also allocated to the N21 service last night.
Go North East: 6070 / NK62CZL by Daniel Graham, on Flickr
(15 Oct 2017, 6:41 pm)cbma06 wrote Cheers for the info, I always thought there might of been some kind of merit for service 35 to be extended from low moorsley to high or low pittington, even a circular route in pittington, for potential of passengers wanting to go to houghton, hetton or even Sunderland , seems that GNE doesn't want to dip into the market going into County Durham from this side of Tyne and Wear except the original service which the X5 has claimed, even extending one or 2 journeys on the X1 towards haswell, Wheatley hill and thornley in a circular.
(15 Oct 2017, 10:15 pm)H2bagstew wrote I can’t see them wanting to step on Arriva toes.
				(16 Oct 2017, 1:59 pm)Jamie M wrote My understanding is Stanley will just be a low cost unit with all of the work shifted between riverside and chester. The 6+6a would probably see action from gateshead amongst late 47/45E/45 trips (it closes at 1030pm). The night 15s and 16s would a good way for chester to get a low cost unit of their own established, too - amongst service 40/700s.Don’t believe everything you read Or hear Jamie. Stanley is not becoming a low cost unit and the work is not getting shifted between Chester & riverside. Ground work has already started on the new depot down at hownsgill (opp international cuisine).
Not looking good.
(16 Oct 2017, 2:22 pm)nk55 wrote Don’t believe everything you read Or hear Jamie. Stanley is not becoming a low cost unit and the work is not getting shifted between Chester & riverside. Ground work has already started on the new depot down at hownsgill (opp international cuisine).
(15 Oct 2017, 10:11 am)Dan wrote Probably when 5298 returns, as that's an orange one too.
5229 has now transferred to Chester-le-Street, following repaint.
(15 Oct 2017, 10:25 am)Michael wrote Will that batch be spares at Chester?
![[Image: 37687614746_9f3944e968.jpg]](https://farm5.staticflickr.com/4507/37687614746_9f3944e968.jpg) Go North East: 5229 / NK55OLG by Daniel Graham, on Flickr
				(16 Oct 2017, 2:56 pm)S813 FVK wrote Indeed! Ihad been told that the new depot had been put on hold for now - that obviously is not the case.
(16 Oct 2017, 1:45 pm)Dans_bus_photos wrote Planning permission has been submitted for a new depot in Consett
http://www.consettstanleyadvertiser.co.u...o_Consett/
(16 Oct 2017, 4:26 pm)nk55 wrote Don’t think there’s a month gone by without Jamie mentioning Stanley being operated as a low cost depot. Something to think about Jamie, a lot of Stanley drivers have been there for well over 10 years, so you tell them their wages are being cut by up to £4 per hour. Trust me there’ll be very few buses rolling out of Stanley depot under your plans. Sure Kevin carr and the board would love your plans but none of the driving staff do, rant over.
(16 Oct 2017, 6:37 pm)Michael wrote I did hear a rumour that the allocation would be split between Chester and Riverside with only the Venture and Metro Mini's remaining at the new Consett Depot.... clearly that's now changed because the Depot will allow up to 62 buses..... the Toonlink is the only routes which i could see being split between Consett and Riverside.6,6a,M6,M7,M8 & X31 are supposed to go to riverside all other services will run out of Consett. However some boards on toon links do roll on/off either a 6 or X31. Time will tell.
Stanley currently have 76, so something will move out.
(16 Oct 2017, 6:44 pm)nk55 wrote 6,6a,M6,M7,M8 & X31 are supposed to go to riverside all other services will run out of Consett. However some boards on toon links do roll on/off either a 6 or X31. Time will tell.
