					Interesting that they haven't removed the private plate
(21 Nov 2020, 12:20 pm)Michael wrote That's true but isn't the body of the Crusader Citaro's in a shocking state.
(26 Nov 2020, 6:32 pm)Dans_bus_photos wrote Can anyone confirm if 5439 has been repainted into corporate livery? Pretty sure I seen it earlier without 'Sunderland' branding
(28 Nov 2020, 9:52 pm)EL1TE wrote May be the most relevant place to post this..? Something that could be of note is that 6087 is down Bus and Coach World in Blackburn, possibly for a repaint.
Note: Not my photo. Credit to tomstransportsphotos on Flickr.
https://flic.kr/p/2kbsu5f
(28 Nov 2020, 10:12 pm)Michael wrote Might finally be getting its new Livery but also could be going in to Fleet Livery, as the current PVR has dropped by 3 (unless they plan to bring it back to every 12 minutes in the new year).
Sure it was said the new livery would be called
Newcastle & Sunderland CityLink or something.
Edit: must of went down late today, as it was on the 60, it did the 5:30 to Sunderland
(28 Nov 2020, 10:40 pm)Drifter60 wrote Can’t be 6087 on the 60s, low bridge at Dawdon. Ticket machine must be being used in another vehicle for Deptford.Â
Also sunset times would suggest it’s not even possible, by 18:10 it would be dark and the photo is clearly in the light.
 ... what was I thinking?
				(28 Nov 2020, 10:40 pm)Drifter60 wrote Can’t be 6087 on the 60s, low bridge at Dawdon. Ticket machine must be being used in another vehicle for Deptford.ÂThat and the fact 6087 is away to Blackburn
Also sunset times would suggest it’s not even possible, by 18:10 it would be dark and the photo is clearly in the light. Wonder what bus the ticket machine is being used in?
Bus times suggests the ticket machine from 6087 was being regularly used on 56s until Wednesday 11am, so safe to assume 6087 itself was indeed here until then it’s went down Blackburn at some point between Wednesday and Friday.
![[Image: 50671350108_c07ea1ffd5_c.jpg]](https://live.staticflickr.com/65535/50671350108_c07ea1ffd5_c.jpg) Go North East 5383 / NL63 YAJ by kieron mathews, on Flickr
Go North East 5383 / NL63 YAJ by kieron mathews, on Flickr![[Image: 50672097341_24e2e4317b_c.jpg]](https://live.staticflickr.com/65535/50672097341_24e2e4317b_c.jpg) Go North East 8316 / NK10 GOJ by kieron mathews, on Flickr
Go North East 8316 / NK10 GOJ by kieron mathews, on Flickr(03 Dec 2020, 9:34 pm)Malarkey wrote Introducing Quaycity -Â https://www.flickr.com/photos/128497080@...7147824536
(07 Dec 2020, 12:18 pm)ne14ne1 wrote Seems the Angels may be getting a little tidy up, or is it just this one?
https://twitter.com/martijngne/status/13...95200?s=21
				(07 Dec 2020, 12:18 pm)ne14ne1 wrote Seems the Angels may be getting a little tidy up, or is it just this one?Looks like less vinyl on the windows too
(08 Dec 2020, 9:43 am)JP6004 wrote Looks like less vinyl on the windows too
Will the 3 remaining versas have light refurb too? If so, could they possibly go on X66? With 5389 & 5390 as spare for Q3 and X66? This would allow euro 5 streetlites to go to chester to replace a few omnis
(08 Dec 2020, 9:43 am)JP6004 wrote Looks like less vinyl on the windows tooYeah, you can see the outline of the old angel, they've made it smaller and taken it off the windows.
(08 Dec 2020, 10:40 am)Storx wrote Unless plans are changed I believe that some of 6149 - 6161 are planned to go to CLS for the 13/25 which should see off the Omnicities. It was definitely the plan at one point with the other 6 on the 93/94 which appears to already have happened as they've been allocated daily for awhile now.I'd imagine still not enough to withdraw all 8, 11 if you count the temporary allocation of omnis to the 311.
(08 Dec 2020, 11:12 am)JP6004 wrote I'd imagine still not enough to withdraw all 8, 11 if you count the temporary allocation of omnis to the 311.
(08 Dec 2020, 11:38 am)Storx wrote It should be enough like.Depends if the SWB Streetlite are permanent allocation and if the services warrant DD at the moment.
25: B9TL
28/28A: Versa
34: Streetlite (Saltwell)
8/78: Streetlite
71: Solo
21: Streetdeck
X21: B5TL
