Max Brand
Is there any words on the Max brand being took of the buses as seeing currently the only ones Blyth now have max is the X10/X11 from what I've seen. Is this brand staying or being took off
(23 Feb 2021, 7:56 pm)MichealAaron wrote Is there any words on the Max brand being took of the buses as seeing currently the only ones Blyth now have max is the X10/X11 from what I've seen. Is this brand staying or being took off
(25 Feb 2021, 9:52 am)streetdeckfan wrote I don't necessarily think the MAX brand was a bad one, but I do think they ran into the opposite problem that GNE had.
While GNE tried to shoehorn a brand onto every route, Arriva tried to shoehorn every route into one of two brands, Sapphire and MAX, both of which suffered as a result.
(25 Feb 2021, 8:32 am)RMF1254 wrote The B5LH vehicles were given MAX livery before they went to Yorkshire, this one is seen in St Mary’s Place Newcastle on 31-10-2017.
(25 Feb 2021, 10:21 am)mb134 wrote Agreed - I think the 306/308 were prime examples. It almost felt like depots would throw their toys out the pram if they didn't get at least one of each brand.
Realistically, the only MAX routes should have been:
X7/8/9/10/11 at Blyth
X12 at Durham/Stockton
X14/5/8/20 at Ashington
X16 at Jesmond (why this isn't Ashington ran baffles me)
X66/67 at Darlington
X93 at Redcar/Whitby
Sapphire wise, again I don't see why the Jesmond 43/44/45 were converted really. I can't actually remember when the brand went from feeling reasonably premium, with the launch of the 7 and then X21/22, to very diluted as it happened so quickly. 2014-6 Arriva must have found a good deal with a paint supplier.
(25 Feb 2021, 10:56 am)omnicity4659 wrote Yeah, but the 308 has been marketed as Max long after these left. I'm fairly sure the last printed timetables for the route were Max branded, with just a tiny new Arriva logo.Arriva struggle to market some of their services, at Darlington for example the 1/5/5A are pushed as Sapphire due to having the Sapphire Lites branded for said routes but X1 still has MAX marketing as it has 1590-1594 branded for the service yet they interwork with the 1/5/5A so you end up with a mix of Sapphire and MAX spec vehicles across all these services.
(25 Feb 2021, 11:06 am)Jimmi wrote Arriva struggle to market some of their services, at Darlington for example the 1/5/5A are pushed as Sapphire due to having the Sapphire Lites branded for said routes but X1 still has MAX marketing as it has 1590-1594 branded for the service yet they interwork with the 1/5/5A so you end up with a mix of Sapphire and MAX spec vehicles across all these services.
(25 Feb 2021, 11:13 am)streetdeckfan wrote The X1 is listed under both Sapphire and MAX on Arriva's website.
Is there anything different spec wise between the Sapphire and MAX Streetlites? I haven't used them for a while but I remember them being basically the same
(25 Feb 2021, 12:57 pm)Driver9*** wrote Or they could just do what any sensible operator would do, for simplicity have every single vehicle in the fleet painted the same colour with no silly gimmicks or names attached to it. No faffing on having certain buses allocated to certain routes.If 'any sensible operator' would do it, then why are basically none of the main operators doing it?
(25 Feb 2021, 1:44 pm)streetdeckfan wrote If 'any sensible operator' would do it, then why are basically none of the main operators doing it?You tell me? Does it honestly increase passenger numbers by having buses painted in jazzy colours and given silly brand names? 99.9% of punters are not interested in the slightest I'd imagine as long as it turns up on time and is comfortable to sit in.
Sent from my LM-G710 using Tapatalk
(25 Feb 2021, 2:27 pm)Driver9*** wrote You tell me? Does it honestly increase passenger numbers by having buses painted in jazzy colours and given silly brand names? 99.9% of punters are not interested in the slightest I'd imagine as long as it turns up on time and is comfortable to sit in.
(25 Feb 2021, 4:46 pm)omnicity4659 wrote Yes, when done properly, it does. Arriva recorded growth on their Northumbria Sapphire and Max services after every upgrade.If Arriva were willing to put the time & money in, the MAX brand could be as good as GoNE's X-Lines.
Branding raises awareness to the route existing, a physical object driving past someone is one of the best forms of advertising, ultimately keeping you in a job.
(25 Feb 2021, 6:20 pm)L469 YVK wrote If Arriva were willing to put the time & money in, the MAX brand could be as good as GoNE's X-Lines.Same with Sapphire, but Arriva will be Arriva.
(25 Feb 2021, 10:21 am)mb134 wrote Sapphire wise, again I don't see why the Jesmond 43/44/45 were converted really. I can't actually remember when the brand went from feeling reasonably premium, with the launch of the 7 and then X21/22, to very diluted as it happened so quickly. 2014-6 Arriva must have found a good deal with a paint supplier.
(25 Feb 2021, 9:10 pm)IRHardy wrote The only reason that Jesmond's 43/44/45 were converted to become Sapphire routes was that Arriva needed to put the Sapphire ex X21 & X22 E400s (that had been replaced by the new E400MMCs) somewhere.
By making the 43/44/45 Sapphire routes all Arriva needed to do was peel off the X21 & X22 branding and the buses would be ready for use, if the buses needed to de-Sapphiring, that would have taken time and cost money, which Arriva did not think was worth doing.
(25 Feb 2021, 4:46 pm)omnicity4659 wrote Yes, when done properly, it does. Arriva recorded growth on their Northumbria Sapphire and Max services after every upgrade.I keep myself in a job by turning up to work every day, not because the bus is painted a certain colour.
(26 Feb 2021, 7:36 pm)Driver9*** wrote I keep myself in a job by turning up to work every day, not because the bus is painted a certain colour.That's part of it. But the experience onboard is also another part of the equation.
(26 Feb 2021, 9:50 pm)James101 wrote The drivers of the thousands of duties, buses and services that have been permanently withdrawn all turned up for work every day until they were out of a job. Commercial efforts to boost passenger new numbers could save jobs.I've worked for Arriva a long long time and in that time not one driver has ever been made redundant. But if they did offer it because of covid I'd be at the front of the queue to volunteer for it.
(26 Feb 2021, 10:01 pm)Driver9*** wrote I've worked for Arriva a long long time and in that time not one driver has ever been made redundant. But if they did offer it because of covid I'd be at the front of the queue to volunteer for it.
