(24 Sep 2023, 6:17 pm)Storx wrote Bad utilisation of resources that imo.
It would be much better to have it as (all hourly)
19: Ashington to North Shields via Bedlington Station
57: Ashington to Whitley Bay via Choppington
57A: Cramlington to Whitley Bay via Seghill omitting High Pit (run direct from Annitsford).
Means you would have a 30 minutes service from Avenue Head to Cramlington towards Ashington and vice versa since the 19 is already there anyway. Not to mention you'd reopen the Cobalt and North Shields from Bedlington and beyond links. I assume it's now 20/40 towards Ashington under this timetable and give some much needed layover on the 57A with a faster route into Cramlington rather than the 57A and 19 following each other through High Pit like they do currently. Could also potentially renumber one of them so all the numbers are together aswell.
I'm not sure on the timing pattern/layover of the 19 on the southern end, but it seems to be timed as 34 minutes between Cramlington and Ashington so you couldn't do there and back in an hour. The 57A is timed as 26 minutes so is easily achievable within 1 hour, with only 1 extra bus, and with a decent chunk of layover.
