Go North East Thread Disappeared?
Not sure if its just me but the GNE thread has disappeared and I can't find it by going through previous posts either
RE: Go North East Thread Disappeared?
It's visible to administrators but not members it seems, though settings seem to show it should be available to all.
Let's say that you've all posted too many times on that specific thread, and the forum is throwing a tantrum!
In all seriousness, I'll look into it now - though on the surface, it appears fine! Should I fail to do anything, Liam will be on it. He may not be able to do anything until tomorrow though.
Sorry for any inconvenience caused - we hope to have the issue rectified as soon as possible.
I believe it's fixed.
Thanks for alerting us to the issue. Do post back if you're still having problems with it.
Noticed that the thread is close to 2500 replies. I'd recommend looking at splitting it up, as it'll be causing quite a bit of strain on your database. It's quite common now that communities limit any threads to 1000 replies, at which point they'd lock the thread, and create a 'Part 2', 'Part 3', etc.
(30 May 2013, 9:28 pm)aureolin wrote Noticed that the thread is close to 2500 replies. I'd recommend looking at splitting it up, as it'll be causing quite a bit of strain on your database. It's quite common now that communities limit any threads to 1000 replies, at which point they'd lock the thread, and create a 'Part 2', 'Part 3', etc.
Changes are underway, and are almost at the stage of completion. A little bit more than just "splitting it up".
It's me we're waiting for, which explains everything. :p
