(21 Feb 2026, 2:27 pm)ReDemPTiion wrote Yes I was spare at the depot today checked that bus over (nothing wrong with it) as a spare bus it went out on the 685 replaced 26276 which was constantly showing engine management light (would have probably broke down) and then 26065 ended up breaking. They need new buses for the 685 the older buses are not good enough.
Yeah I agree. Walkergates would be absolutely fine on there. 26281 has been replaced by 10535 on the 685 another one broken on there
(21 Feb 2026, 5:53 pm)Busesinnewcastle wrote Yeah I agree. Walkergates would be absolutely fine on there. 26281 has been replaced by 10535 on the 685 another one broken on there
So the E200MMCs where fine at Stockton yet within a year of Newcastle having them they have managed to make them knackered.  No doubt now they are knackered Hartlepool will end up with some.
(21 Feb 2026, 8:33 pm)col87 wrote So the E200MMCs where fine at Stockton yet within a year of Newcastle having them they have managed to make them knackered.  No doubt now they are knackered Hartlepool will end up with some.
They were knackered within the first few months of having them. Drivers up here just abuse them
19673 is now at Slatyford
(21 Feb 2026, 8:34 pm)Busesinnewcastle wrote They were knackered within the first few months of having them. Drivers up here just abuse them
And 10639 to walkergate
It's crazy that Slatyford are sending deckers away - E200s and E200MMCs are increasingly being used on the X47/87/88 in their place and they cannot cope with peak loadings.
19385/6/8/9 don't help matters either, doesn't seem that all 4 can ever be on the road at once.
Glad that I don't need to use the X47 to commute anymore, the reliability of the service and the vehicles being used are getting worse by the week.
I don't know but maybe the issue isn't the vehicles but it's actually the engineering. It wouldn't be the only depot in the North East.
It's just been hidden by the fact that the place must have a crazy number of spares, like unless I'm incorrect bar the 6 E200's on the 32/32A the rest of them aren't actually needed there on paper and there's 19 of the things there.
19673 was a loan I drove a driver to Walkergate to pick it up to replace 36469 on the 30/31/36 as that had to go on 32’s to replace 37316.
Not sure why 10639 has gone to Walkergate but 10642 is currently sat at Walkergate broken with no ticket machine on the bus.
(21 Feb 2026, 9:04 pm)Storx wrote I don't know but maybe the issue isn't the vehicles but it's actually the engineering. It wouldn't be the only depot in the North East.
I’m hoping the plan is 6 Yutong E10’s for the 32/32A service which is looking very likely but unsure if it’ll be E10’s or something else. 36468-36477 will hopefully go but 37312-37319 will probably stay in case they need some for the 32’s (low charge on an EV for example)
Then once the remaining E12’s are out for 30/31/36 they can get rid of the horrible 241**’s and 277**’s
(21 Feb 2026, 9:50 pm)BReDemPTiion wrote 19673 was a loan I drove a driver to Walkergate to pick it up to replace 36469 on the 30/31/36 as that had to go on 32’s to replace 37316.
10642 came in to Slatyford last night around 8ish as it was pulled from service. I wish they would bring back the 272s for the 685 and as for the e10s for the 32s when do you find out if it’s going ahead and when do u think we will get them?
(21 Feb 2026, 9:50 pm)ReDemPTiion wrote I’m hoping the plan is 6 Yutong E10’s for the 32/32A service which is looking very likely but unsure if it’ll be E10’s or something else. 36468-36477 will hopefully go but 37312-37319 will probably stay in case they need some for the 32’s (low charge on an EV for example)
Aye wouldn't be a bad move either, hopefully after that they can then look at some deckers and sort out the problems across the region for once and all; the 62/63 on paper is the sort of route which seems like they'd be ideal for really and it's not like it's some little basketcase route. It's arguably due for investment regardless, being 10 year now.
(21 Feb 2026, 10:15 pm)Storx wrote Aye wouldn't be a bad move either, hopefully after that they can then look at some deckers and sort out the problems across the region for once and all; the 62/63 on paper is the sort of route which seems like they'd be ideal for really and it's not like it's some little basketcase route. It's arguably due for investment regardless, being 10 year now.
They need a significant decker order - they send saloons onto far too many routes which they can't handle.
The 22, 37, 38, 62, and 63 should have saloons nowhere near them and yet here we are.
As far as I can see they seem to be fairly good at ensuring the 1, 39, and 40 are constantly decker allocated but the rest is an absolute minefield.
(21 Feb 2026, 10:42 pm)PH - BQA wrote They need a significant decker order - they send saloons onto far too many routes which they can't handle.
Aye agreed, not much Walkergate can do really they've got 16 saloons - arguably for a depot which currently has zero saloon work. They've got to go somewhere.
Always wonder whether the Stockport depot fiasco screwed everything up and half of the buses still stuck in Manchester were meant to come up here. Obviously been years so not really an excuse anymore mind. The 64/65/16 Plate E400MMC's clearly aren't staying as they're not being repainted.
(21 Feb 2026, 10:48 pm)Storx wrote Aye agreed, not much Walkergate can do really they've got 16 saloons - arguably for a depot which currently has zero saloon work. They've got to go somewhere.
Funny you say that as 10485 is at Sunderland in the process of being repainted
(21 Feb 2026, 10:48 pm)Storx wrote Always wonder whether the Stockport depot fiasco screwed everything up and half of the buses still stuck in Manchester were meant to come up here. Obviously been years so not really an excuse anymore mind. The 64/65/16 Plate E400MMC's clearly aren't staying as they're not being repainted.
The 64 plates, bar a small handful, are based at Little Hulton depot for school contracts in the Bolton and Wigan areas - vehicles used exclusively on the school franchises don't have to wear Bee Network livery hence why these haven't been painted. 10429, the example in the Armed Forces Covenant livery, has some sort of special dispensary to keep that livery despite being used on main Bee Network work. As for the rest of the vehicles at Stockport, despite all the older MMCs there still being Stagecoach-owned (except for the 17 and 69 plate examples), they have been modified internally with the TfGM-madated Next Stop Announcement system (from Mobitec - despite the vast majority of the Manchester fleets having standardised on Hanover displays).
(22 Feb 2026, 8:49 am)Dans_bus_photos wrote Funny you say that as 10485 is at Sunderland in the process of being repainted
Wonder if it’ll return to Slatyford, 27727 didn’t and I have no idea why. Plus 10485 been off the road since 27th January sat in the parking shed doing nothing, didn’t even go into engineering. If it doesn’t come to Slatyford after repaint there’s something going on with Slatyford depot.
(22 Feb 2026, 8:54 am)Kuyoyo wrote The 64 plates, bar a small handful, are based at Little Hulton depot for school contracts in the Bolton and Wigan areas - vehicles used exclusively on the school franchises don't have to wear Bee Network livery hence why these haven't been painted. 10429, the example in the Armed Forces Covenant livery, has some sort of special dispensary to keep that livery despite being used on main Bee Network work. As for the rest of the vehicles at Stockport, despite all the older MMCs there still being Stagecoach-owned (except for the 17 and 69 plate examples), they have been modified internally with the TfGM-madated Next Stop Announcement system (from Mobitec - despite the vast majority of the Manchester fleets having standardised on Hanover displays).
I know I'm just using BusTimes so the usual cavaets, but there's 18 of the 64 Plates at Stockport isn't there? No arguments about the school buses though; I know the it's the same reason the E200's haven't been done.
Thanks for confirming, had a feeling they were still Stagecoach owned, wasn't 100% sure. No doubt some of them were meant to be up here I guess but I suppose we'll never find that out. Be interesting to see where they end up in the future though.
(22 Feb 2026, 9:28 am)Storx wrote I know I'm just using BusTimes so the usual cavaets, but there's 18 of the 64 Plates at Stockport isn't there? No arguments about the school buses though; I know the it's the same reason the E200's haven't been done.
A number of Little Hulton-allocated E400MMCs were working 'on-loan' to Stockport in the last week to run additional 192 trips to assist with travel during the Piccadilly Station closure. I believe the only 64 plates normally based at Stockport are 10412/23-9.
(22 Feb 2026, 9:48 am)Kuyoyo wrote A number of Little Hulton-allocated E400MMCs were working 'on-loan' to Stockport in the last week to run additional 192 trips to assist with travel during the Piccadilly Station closure. I believe the only 64 plates normally based at Stockport are 10412/23-9.
That would make sense, considering it was half term. BusTimes seems to back that up since they've got the temp Bee Network sticker branding.
Btw, was talking about the Stockport ones there (10423-30/43-51/10587-99). The North East ones aren't going anywhere, no arguments there.
(21 Feb 2026, 10:00 pm)Busesinnewcastle wrote 10642 came in to Slatyford last night around 8ish as it was pulled from service. I wish they would bring back the 272s for the 685 and as for the e10s for the 32s when do you find out if it’s going ahead and when do u think we will get them?
Apparently just waiting on contract being issued currently in another standstill period until 3rd March so probably anytime after that. It’s not 100% confirmed we’re getting EV’s for the 32’s but a lot of drivers in the depot are mentioning it now so it sounds quite likely.
(22 Feb 2026, 11:06 am)ReDemPTiion wrote Apparently just waiting on contract being issued currently in another standstill period until 3rd March so probably anytime after that. It’s not 100% confirmed we’re getting EV’s for the 32’s but a lot of drivers in the depot are mentioning it now so it sounds quite likely.
why is 10642 awaiting on a contract being singed do you know? Also 10639 is on a walkergate board today on 62/63
To be fair though, Walkergate only have a PVR of three or four on their 62/63 runs and they prioritize deckers for the 60's. It's Slatyford who keeps putting the singles on the 60s
(22 Feb 2026, 12:58 pm)F114TML wrote No, GCT kicked it back.
It's unbelievable GCT have declined it 2 years in a row. They must have expected to lose a lot of contracts when they bid for it, and have only lost the withdrawn M71, with Stanley Travel giving the X46 back to GCT as well. With a PVR of 6, it was a lot to commit to. But having won it last year, they should have been prepared for it this year.
(22 Feb 2026, 12:48 pm)SN69 ZRC wrote To be fair though, Walkergate only have a PVR of three or four on their 62/63 runs and they prioritize deckers for the 60's. It's Slatyford who keeps putting the singles on the 60s
Agreed that they seem to get their 60s better - but realistically it's more the fault of Stagecoach themselves than depot specific. They've got far too many buses up here which aren't suitable for the work they are used on.
(22 Feb 2026, 2:13 pm)PH - BQA wrote Agreed that they seem to get their 60s better - but realistically it's more the fault of Stagecoach themselves than depot specific. They've got far too many buses up here which aren't suitable for the work they are used on.
100% agree. The amount of singles Walker has. I'll wait for someone to tell me which Walker route warrents a single decker.
Walker only needed the singles for the 317, and the 15 which got withdrawn almost a decade ago.
(22 Feb 2026, 1:14 pm)OrangeArrow49 wrote It's unbelievable GCT have declined it 2 years in a row. They must have expected to lose a lot of contracts when they bid for it, and have only lost the withdrawn M71, with Stanley Travel giving the X46 back to GCT as well. With a PVR of 6, it was a lot to commit to. But having won it last year, they should have been prepared for it this year.
If I were to take a wild guess, when it comes to getting contracts, GCT just click "bid" without even looking and just pray they've got the buses for it
(22 Feb 2026, 3:08 pm)SN69 ZRC wrote 100% agree. The amount of singles Walker has. I'll wait for someone to tell me which Walker route warrents a single decker.
To be fair, perhaps they do! But it's disappointing expecting a GCT service just for it go back to Stagecoach. More importantly, it's not good value for taxpayers with the higher cost of paying Stagecoach to run it compared to GCT.
Especially ridiculous 2 years running.
Strange there was already rumour of  Stagecoach getting EVs for the 32/32A, so it was predicted they would keep it and presumably expected it would be awarded to GCT and given back. At least positive to see GCT have retained the 35 which has largely been operated well this year by GCT.
(20 Feb 2026, 6:14 pm)S830OFT wrote Just wondering if there would be any hope in upgrading the fleet at Hartlepool with the 2018 StreetLites (39101 - 39118) from Stagecoach Yorkshire, if they become available?
Ideally these would allow the complete withdrawal of the 14x 360xx series Enviro 200s, aswell as a few of the tired 61 plates. Also one would assume they would be more suitable for the likes of their Middlesbrough 1 & Durham 59 services over the Enviro 200s currently used.
I'm unsure if they will get E400 19680 back, although from observations the 1s from Middlesbrough do tend to get full, but never seem to leave anybody at Middlesbrough that I've seen. Possibly an every 20 minute frequency to Middlesbrough during peak time may be more suitable, utilising one of the Seaton Carew short runs?
I believe since the fleet has somewhat been sorted out at Hartlepool, their fleet comprises completely of E200s (36081 - 36094, 36461 - 36467, 36965, 36968*, 36969, 36970, 36977 - 36980, 37309, 37310 & 37311).
* - 36968 seems to have been off the road since September...
It seems that Hartlepool are going to be getting more displaced 364XX & 369XX from Slatyford, Shields, and Sunderland to replace the 360XX buses
The 1 is always packed on an evening with college students heading back home, there is a need for more capacity on the 1
I know it's probably not right in some ways but personally wouldn't be surprised if Hartlepool came an outstation of Stockton at some point with a full fleet of electrics.
Would solve out all the issues with the buses not being able to be maintained at Hartlepool.
It's not like they're a million miles away from each other.
Similar discussion with South Shields and Wheatsheaf
It's not really fair that once again Hartlepool gets all the worn out cast-offs. But that's Stagecoach's philosophy, which to an extent I agree, however some newer vehicles would certainly be beneficial for some of the longer routes they operate.
Ideally, the 1 & 59 should have decent vehicles allocated. The 2009/2011 Enviro 200s are pretty expired for longer distance journeys now, even though the 360s now can't be used on the 59 with the 15 year age restriction DCC impose, which will soon affect the 364 series examples later this year.
37309 - 11, aswell as some 369 examples are presumably the most suitable for being used on the 59, hence their frequent use on the route. Although, arguably the 1 should also be getting a thought, especially given how much of a commuter style service it is...
