Stagecoach North East: Latest News & Discussion - February 2015
RE: Stagecoach North East: Latest News & Discussion - February 2015
(10 Feb 2015, 7:19 pm)Dan wrote Volvo Olympians 16833/34/36/39 and the ALX300s with a lettered reg (ie T172MVM opposed to NK54BGU). Stagecoach don't have that many left to go.
Thanks Dan, Smile
(10 Feb 2015, 7:14 pm)bertibassett wrote As far as I know there is no change to the 38. Norton duck pond - ring road - right at the lights then left into weaverham then as normal through the Glebe to Junction road. Hope this helps..
Thanks Ive seen at least 2 in the last few days that have been parked in the layby on The Glebe (the road) not the estate so unless they are doing 2 laps of Ashton Road they must be going up Junction Road
(10 Feb 2015, 9:12 pm)alanf wrote Thanks Ive seen at least 2 in the last few days that have been parked in the layby on The Glebe (the road) not the estate so unless they are doing 2 laps of Ashton Road they must be going up Junction Road
I believe from hearing from friends - they have been advised to go round the estate then go to the layby previously used as the terminus and have their layover there
(10 Feb 2015, 9:29 pm)Kuyoyo wrote I believe from hearing from friends - they have been advised to go round the estate then go to the layby previously used as the terminus and have their layover there
Makes sense I have seen a lot of 38s parked in the stop at Norton Green all switched off It seems to run far to early now at times I think it would make more sense for the 37 to come through the Glebe and get rid of the 38 Maybe run the 37 every 20 minutes That would also free up a bus
(11 Feb 2015, 8:40 am)Cock Robin wrote And the Tridents.
Ah yes, i forgot about the tridents!
Thanks Smile
Moderator
Bit of a silly question - is there any specific reason the 'E' services go E1, E2 and then E6? And no E3, E4 etc?
Just curious. Smile
That's exactly what has been happening Wink Personally i just wait my time out at the duck pond..
(10 Feb 2015, 9:46 pm)alanf wrote Makes sense I have seen a lot of 38s parked in the stop at Norton Green all switched off It seems to run far to early now at times I think it would make more sense for the 37 to come through the Glebe and get rid of the 38 Maybe run the 37 every 20 minutes That would also free up a bus
That wouldn't work. Both the 37 and 38 get the same time to run from the boro, the problem is the 37 goes further hence what would seem a lot of time for the 38. If you run a 37 through the glebe what about junction road? or you would put an extra 10 minutes on the journey if you go down junction road and do a loop around the glebe, then you have a problem of all those lovely pensioners with accute 20/20 vision getting on the bus to the hospital thinking its going to the town only they dont read the destination, they just see the number, some folk just see the bus....doh
(11 Feb 2015, 8:02 pm)MarcTheA4 wrote Bit of a silly question - is there any specific reason the 'E' services go E1, E2 and then E6? And no E3, E4 etc?
Just curious. Smile
It's a long-time survival of competition years ago between Busways and a firm called Catch-a-Bus, who were based at East Boldon. They mainly operated local services in South Shields but also had a route between South Shields and Sunderland, using route number 6. Busways' retaliation was numbered E6 to match the Catch-a-Bus number.
This would be in the 1989-1993 period if I remember correctly. There was also an E3 for a short time. If I can find the details of this route anywhere, I'll post them tomorrow.
Hope this helps,
Chris
Moderator
(11 Feb 2015, 11:00 pm)chrisnorthern wrote It's a long-time survival of competition years ago between Busways and a firm called Catch-a-Bus, who were based at East Boldon. They mainly operated local services in South Shields but also had a route between South Shields and Sunderland, using route number 6. Busways' retaliation was numbered E6 to match the Catch-a-Bus number.
Hope this helps,
Chris
Thanks Chris. Smile It was just one of those things that just sprung into my mind lol.
(11 Feb 2015, 11:01 pm)MarcTheA4 wrote Thanks Chris. Smile It was just one of those things that just sprung into my mind lol.
Some of us older generation do come in handy at times!
You would think by now these services would have been renumbered E1 E2 E3
But then again why E numbers. Economic no longer exists it now all stagecoach in South shields
(11 Feb 2015, 11:30 pm)Acky81 wrote You would think by now these services would have been renumbered  E1 E2 E3
Usual Stagecoach policy - if it ain't broke, don't fix it.
Just think of how many current Stagecoach routes still use the same service numbers as they did 20+ years ago, wherever you think of, Newcastle, South Shields or Sunderland. I don't remember enough about Hartlepool or Teesside to know if the same is true there but I'm sure somebody will put me right!
Chris
Currently on 39727 and the driver is driving like a maniac...
(11 Feb 2015, 8:51 pm)bertibassett wrote That wouldn't work. Both the 37 and 38 get the same time to run from the boro, the problem is the 37 goes further hence what would seem a lot of time for the 38. If you run a 37 through the glebe what about junction road? or you would put an extra 10 minutes on the journey if you go down junction road and do a loop around the glebe, then you have a problem of all those lovely pensioners with accute 20/20 vision getting on the bus to the hospital thinking its going to the town only they dont read the destination, they just see the number, some folk just see the bus....doh
I know what you are saying but it would also give people on the Glebe a bus to the hospital If it ran via the Glebe bothways they would soon realise one is going to the hospital and the other to Middlesbrough As for the ring road its just pointless especially now the 38 appears to do 2 laps of Ashton Road so just go via Junction road both ways as it used to be I realise what you are saying about the extra 10 minutes journey time would a joint 37/38 work on an evening maybe when there is less traffic as i cant see the evening 38s lasting to long They are quite often empty in Norton.
No P10 Busways movements, and only one to report from Transit:
22206 T206 TND MAN ALX300 Delicenced to Reserve
(12 Feb 2015, 10:22 am)alanf wrote I know what you are saying but it would also give people on the Glebe a bus to the hospital If it ran via the Glebe bothways they would soon realise one is going to the hospital and the other to Middlesbrough As for the ring road its just pointless especially now the 38 appears to do 2 laps of Ashton Road so just go via Junction road both ways as it used to be I realise what you are saying about the extra 10 minutes journey time would a joint 37/38 work on an evening maybe when there is less traffic as i cant see the evening 38s lasting to long They are quite often empty in Norton.
I see what you're saying and to be honest the 38 should never of been moved. As for the double loop, as far as i'm aware not many drivers do it, most drivers I've spoke to tend to use the duck pond, personal preference I pressume.
(11 Feb 2015, 11:35 pm)chrisnorthern wrote Usual Stagecoach policy - if it ain't broke, don't fix it.
Chris
Better than Arriva changing the service numbers every few months!
Hi do you think stagecoach north east will get new Enviro 400 like Manchester ones or other Enviro 400 like Newcastle ones again.
(13 Feb 2015, 5:37 pm)glen1234 wrote Hi do you think stagecoach north east will get new Enviro 400 like Manchester ones or other Enviro 400 like Newcastle ones again.
Hi glen Im not sure if northeast would get any, in any case I believe the E400MMC is now the standard decker. The older style is no longer in production although I couldn't swear by that,
Kind regards
Chris
I don't think we will be getting any second hand buses from any other fleet groups we never do but we might be getting some second hand Enviro 400 from other fleets I think too replace denies trident but not single decker's
does anyone think Stagecoach Gold should be introduced to North East i can name one route that will need it and thats X34 or possible others like 1/10/11/12/39/40
Favourite Company is: Go North East
Favourite Operator in UK is: EYMS
Owner of Bella the Cat
Mood right now: Fustrated and Feel Left Out
Moderator
(14 Feb 2015, 11:10 pm)Racer_Experience wrote does anyone think Stagecoach Gold should be introduced to North East i can name one route that will need it and thats X34 or possible others like 1/10/11/12/39/40
I think it's more of a long-distance service brand, and I'm not sure any of the services Stagecoach operate in the north east are suited to it.
For example, the 300 over in Cumbria is Whitehaven-Maryport or something, and the total journey time from A to B is about 2 hours.
I'm sure I may have asked this question before, and the response I got was - there are no services in the north east that really justify such an investment. I can't imagine Gold hitting the streets of Newcastle, to be honest. And I'm not a Stagecoach expert at all.
A majority of the services in the north east provided by Stagecoach seem to be cross-city, etc, and I'm not really sure the Gold brand is right for any of them.
If Stagecoach introduced a Newcastle-Sunderland service, which would face immediate threat from the Fab56 or Fasts Cats X36 provided by Go North East (and thus be shot down like the OK1 was in competition with Arriva's X1 'The Best One'), I could imagine such a service being a Gold service. But like I say; the chances of that are rather slim.
(14 Feb 2015, 11:17 pm)MarcTheA4 wrote I think it's more of a long-distance service brand, and I'm not sure any of the services Stagecoach operate in the north east are suited to it.
I used to hate Arriva they killed off Go North East OK1 Service
Does anyone know the year which the 22/23/24 started to pass Thornhill school in Sunderland?, was it before the 22/23/24 got merged or was it when it ran as the 22/23/24?
And did they loose a link past Thornhill school, hence why the current 23 goes past?
(14 Feb 2015, 11:20 pm)Racer_Experience wrote I used to hate Arriva they killed off Go North East OK1 Service
Really because of that, that's stupid.
(15 Feb 2015, 5:15 pm)Michael wrote Does anyone know the year which the 22/23/24 started to pass Thornhill school in Sunderland?, was it before the 22/23/24 got merged or was it when it ran as the 22/23/24?
It used to be service 3 which went via Thornhill School, wasn't it? My sister was still in school at the time which is why it rings a bell... She would have left in 2006, so this may act as some guidance...
(15 Feb 2015, 5:23 pm)Dan wrote It used to be service 3 which went via Thornhill School, wasn't it? My sister was still in school at the time which is why it rings a bell... She would have left in 2006, so this may act as some guidance...
Hmm i'm not sure, i can't even remember what year the 22/23/24 or just the 23 started to divert that way.
(15 Feb 2015, 5:27 pm)Michael wrote Hmm i'm not sure, i can't even remember what year the 22/23/24 or just the 23 started to divert that way.
Service 3 stopped serving Thornholme Road in May 2005, coinciding with simplification of the Sunderland network.  This saw the withdrawal of Service 2, with all journeys operating as Service 3 along a new more direct route via New Durham Road, Plains Farm and Atlantis Road - omitting Thornholme Road (replaced by Services 22/23/24) and Gilley Law (replaced by Service 13).
