RE: Nexus Tenders July 2026
(11 May 2026, 5:37 pm)stagecoachbusdepot wrote Unless I am reading it wrong, when you look at the contract award values compare to the estimated values on the Tender Notice, and indeed the total value (>£4m awarded compared to stated budget of <£3m) I'd say all of the operators appear to have factored in monumental fuel price hikes and then some (or Nexus were wildly inccurate in their estimates across the board, or have made a large error in one or other set of numbers).  From what I can see, the overall cost is >40% higher than the advertised Tender amount.  Which as I say unless I am missing something is pretty dubious process in terms of such a huge variance from the advertised amount; not to mention where have Nexus found the additional >£1m from to fund these inflated awards?
The L&G lot award values in particular are huge compared to the estimated amounts - in some cases almost quadruple.  Though all three lots awarded to L&G are for the exact same amount despite differnt underlying estimates so this may well be an error on Nexus' part.
The three contracts which encompass services 99 and 939 were part of a group bid (for a total of £97k), so Nexus has actually saved >£50k compared to what they currently pay for the same three contracts with Northstar and Go North East - suggests, if anything, that these contracts may have been under-priced (as bus operators work on much smaller margins than that!)
In most cases, other contracts are largely at the same prices as last year (or just a few % higher).
No operator looks to have factored in a price hike for diesel.
(10 May 2026, 11:14 pm)Nerd4321 wrote Wow the July tenders are insane this year
They are as follows (standstill ends 18th May. Contracts signed earlier date by 5th June)
Gateshead Central Taxis, 29/90/92/R3/R4/R5/R6/37/319
L&G Coaches, 99/939
Go North East 51/52PM/67/69
Northstar 9/25/25A/10/11/12/24/26/49/49A/50/51/52AM/96/515/558/568/643
All in standstill which ends 18th May and earliest date which they will be signed is 5th June. Quite a big pick from Northstar and L&G winning stuff as well.
Yeah also Stagecoach won absolutely nothing in the tender
Sorry If I sound stupid. Would rather know than be dumb but for Northstar is that the South Tyneside routes 24/25/26/50 etc? As in the ones Go North East run? I take its a 1 trip sort of thing because thats a lot to take on if its the all day thing.
Again sorry If I sound stupid, never really know what the drill is with the tenders Smile
(11 May 2026, 7:43 pm)X919 WGR wrote Sorry If I sound stupid. Would rather know than be dumb but for Northstar is that the South Tyneside routes 24/25/26/50 etc? As in the ones Go North East run? I take its a 1 trip sort of thing because thats a lot to take on if its the all day thing.
10/11 - Stagecoach South Shields
12/49/49A/51/52/67/69 - GNE Riverside
9/24/25/25A/26 - GNE Deptford
50 - GNE Washington
None of them are the full timetable, but not sure what they are. Assume some might be the full evening / Sunday timetable though.
(11 May 2026, 6:59 pm)Dan wrote The three contracts which encompass services 99 and 939 were part of a group bid (for a total of £97k), so Nexus has actually saved >£50k compared to what they currently pay for the same three contracts with Northstar and Go North East - suggests, if anything, that these contracts may have been under-priced (as bus operators work on much smaller margins than that!)
How are group bids evaluated? Are they stress-tested for affordability?  Assume it's in the tender documents, but they arent on the links posted up the thread.
(11 May 2026, 7:46 pm)Storx wrote 10/11 - Stagecoach South Shields
50 - GNE Washington
No doubt GNE can run those services commercially, all of a sudden.....
Ah thanks that makes sense and is just really shoddy accounting/transparency on find a tender then -
The estimated values for Lots 12, 18 & 19 total £119,084 - https://www.find-tender.service.gov.uk/N...rchResults&p=3
The issue is the award notice wording identifies each lot as a separate contract and gives the total aggregated value against each contract.  Given they already have lot numbers and contract numbers for each service, seems mad they then give them further separate contract numbers and give the full "group bid" value for all three awarded contracts without any indication that they are linked.  Giving "contract value" under each separate contract strongly (wrongly) implies that is the value for that particular contract! https://www.find-tender.service.gov.uk/N...rchResults&p=3
Contract 12
Lots
Lot 12. Contract 1186 (Service 99)
Supplier Contract value
  • £97,530 excluding VAT
  • £117,036 including VAT
Contract 17
Lots
Lot 17. Contract 1192 (Service 939 Contract 1)
Contract 18
Lots
Lot 18. Contract 1193 (Service 939 Contract 2)
Obviously I dont know what they currently pay for these three contracts but can see this comes out at basically the same value as the estimated value £117k inc VAT actual cf. £119k inc. VAT estimate, so minor £2k saving on budgeted amount there.  Presume the same applies to other contracts explaining the discrepancy in totals.
50 - GNE Washington
I think the 50 is just the evening services to/from Chester-le-Street? That's at least what it has been in the past. Like you, I presume some of this, such as the 49/49A/51/52 are the ridiculously early trips on the timetables.
Nexus should really return to marking supported trips in the timetables they produce, as they did in the early 00s.
If Northstar have won the 643 back this year (been awarded subject to standstill period), will they continue to run the X43? Are the X22/X43 permanent services?
Good to see Northstar have won a lot of contracts. Do we know yet if the 10/11 is just evenings and Sundays or daily for the funded part of the route, between Low Simonside and Jarrow?
(13 May 2026, 12:50 pm)OrangeArrow49 wrote If Northstar have won the 643 back this year (been awarded subject to standstill period), will they continue to run the X43? Are the X22/X43 permanent services?
The X22/X43 are commercial - so if they make money and Northstar gave the resource, I don't see any reason why they'd drop them.
(25 May 2026, 11:04 pm)220631612 wrote Only proper surprising ones are NorthStar with the 96 and L&G with the 99 really
Is the 96 the full contract or just evening/Sunday or is it different over Gateshead side
Northstar also look to have gotten the won contracts for the 515, 558. 568 from GCT and the 643 back from Go North East.
(25 May 2026, 11:46 pm)Nerd4321 wrote Is the 96 the full contract or just evening/Sunday or is it different over Gateshead side
Some morning and evening journeys, daily.
Would be funny if City Transport bid for it again, given the recent press.
Wouldn't be the first time an operator has chucked work in due to costs and won it back at a higher rate
(31 May 2026, 5:43 pm)Kimlfixit wrote Would be funny if City Transport bid for it again, given the recent press.
Ive heard rumours of a few different people that City have been banned from bidding on any nexus work
Talk also went around they won the 35 (Newcastle-Red House Farm) contract this year but were stripped due to nexus refuse to allow them the contracts. Also talk went that the contract for the 35 was changed to be stated to allow small buses only. Making me think nexus took one look and thought "he aint getting a bendy round that no sir"
(31 May 2026, 6:23 pm)Nerd4321 wrote Ive heard rumours of a few different people that City have been banned from bidding on any nexus work
Suppose it depends on the reason the connect contract was terminated
Update to the Sunderland Connect tender
The deadline has been pushed back 3 times now
First 8th June then 11th June now 15th June
This rasies a few questions of is nobody bidding for it.
(10 Jun 2026, 1:56 pm)Nerd4321 wrote Update to the Sunderland Connect tender
Rumours were, it was awarded to Northstar, obviously not, I'm sure Dan will let us know.
Not sure I'd fancy bidding on it with all the baggage attached. Interesting to see if a winning bidder would be expected to take on the City drivers. That will have been something all companies would have been looking at
Interesting, surprised at that.
(10 Jun 2026, 5:04 pm)Retro Nero wrote Rumours were, it was awarded to Northstar, obviously not, I'm sure Dan will let us know.
Nexus have been asked a large number of clarification questions by multiple operators, mainly in relation to TUPE, following a letter sent to all operators in the North East by City Transport that they too would get caught up in an Employment Tribunal claim, should they be successful in being awarded the contract from July.
With each clarification question, the deadline has been pushed back slightly.
The award criteria has now changed to better favour quality (guarantees of quick mobilisation) than previous.
The tender submission deadline has not passed yet, so certainly not awarded to Northstar.
(11 Jun 2026, 10:57 pm)Dan wrote Nexus have been asked a large number of clarification questions by multiple operators, mainly in relation to TUPE, following a letter sent to all operators in the North East by City Transport that they too would get caught up in an Employment Tribunal claim, should they be successful in being awarded the contract from July.
Thanks for the clarification Dan, appreciate it
(23 Jun 2026, 7:17 pm)Nerd4321 wrote Nothing yet. Tender deadline ended 15th June
Cheers, hopefully its announced soon.
