RE: Arriva North East: Rare & Odd Workings - April 2017
1509 is on the MAX X75/X76.
(08 Apr 2017, 7:49 am)Stuartphin1639 wrote 4643 on X21Which run is that on? May try and catch that later if it doesn't get taken off.
(08 Apr 2017, 9:03 am)Jimmi wrote Which run is that on? May try and catch that later if it doesn't get taken off.
2811 on 61/62.
Lowlander on 48/X46.
Sent from my F5321 using Tapatalk
(08 Apr 2017, 5:19 pm)Stuartphin1639 wrote That was on 2s this morningIt was also at the depot at about 4 pm before going onto the 13.
(08 Apr 2017, 5:21 pm)ENEB wrote It was also at the depot at about 4 pm before going onto the 13.The 2 must if been to much for it.
Sent from my SM-J320FN using Tapatalk
(08 Apr 2017, 5:27 pm)Kuyoyo wrote 1457 has worked the last Kingsmead 17 replacing a continuallay cutting out 1915
1415 has spent the day on X66/X67, while branded 1405 replaced a Streetlite on 5/5a. 1444 is also on three and out all night replacing 1559.
(08 Apr 2017, 11:14 pm)Multi21 wrote 1915 kept cutting out due to the Cadets weakness... Heat! Brilliant buses in the winter.. April to November they need to be wrapped in cotton wool.LOL so true 1906 at Darlington had the same problem as well. The driver pulled of and it just cut out. It had to be sent back to the depot.
1405 was allocated to the 5/5A from the run out this was due to two Streetlites being VOR
1444 replaced 1559 due to an ABS problem
