Helen Bus Blinds
Helen Bus Blinds
RE: Helen Bus Blinds
Manual can be found here:
http://dbiw.net/HanoverDisplays/Helen_v3.0.pdf
▂▃▅▇█▓▒░۩۞۩The Legend ۩۞۩░▒▓█▇▅▃▂
Jamie M
I don't know how long or why this was on my PC, but messed around with it a bit.
(19 May 2016, 11:03 pm)Jamie M wrote I don't know how long or why this was on my PC, but messed around with it a bit.
If you want to get roughly the correct sized destinations - Sign 0 (front) should be either 144x17 or 144x19, 1 (side) is 96x8, 2 (rear) is 32x17.
Non-colour destinations should be "External LED", and front "justification" should be set to right, side destination left.
These are different throughout operators, so I'm open to correction.
Good job Jamie
Jamie M
(20 May 2016, 7:42 am)GX03 SVC wrote If you want to get roughly the correct sized destinations - Sign 0 (front) should be either 144x17 or 144x19, 1 (side) is 96x8, 2 (rear) is 32x17.
Good job Jamie
Thanks! May I ask, is there any list of the possible sizes used within the GNE fleet?
(20 May 2016, 9:25 am)Jamie M wrote Thanks! May I ask, is there any list of the possible sizes used within the GNE fleet?
Front LED - 144x19
Front LED - 144x19 Colour RN
Front LED - 160x19
Front LED - 160x19 Colour RN
Front LED - 160x17
Side LED - 96x8
Side LED - 96x15
Side LED - 128x17
Rear LED - 32x17
Rear LED - 160x24
Rear LED - 128x17
Rear LED - 96x15
Rear LED - 96x17
Front Flipdot - 96x16
Side Flipdot - 84x7
Rear Flipdot - 84x7
Rear Flipdot - 84x14
Rear Flipdot - 20x14
...think I've covered all of them.
(15 Feb 2017, 7:26 pm)Josh wrote Dan I've got a question for you. Is it possible for the led NSAs on to show "bus stopping" when someone presses the bell?
Sent from my iPad using Tapatalk
The software is capable of doing it - but there needs to be an electrical feed from the bells linked into the Next Stop Announcements.
I believe Brighton & Hove do this on their "Coaster" branded double-deck buses. If my memory serves me correctly, they show "Next Stop xxxxx", and when the bell is pressed, it changes to "Bus stopping at xxxxxxxxx".
(15 Feb 2017, 7:42 pm)Josh wrote Isn't that what the bus stopping signs did when b&h had the omnidekkas?
Most likely, As the Omnidekka's still flip to " Bus Stopping " on the NSA's once the bell has been pressed.
My New Flickr https://www.flickr.com/photos/140662069@N02/ - Posts every Weekend at the minimum
Similar, but not quite. I've searched YouTube and can't find a video on the inside of one of the Coaster buses in service.
The displays in the OmniDekkas are linked to a Hanover product but it's a bespoke thing built for Brighton & Hove (and can't be used by Go North East for example).
Helen Bus Blinds
http://www.hanoverdisplays.com/images/ca...bustfl.pdf
This is the display used by gne?
Which is used on the Londons ibus system
(15 Feb 2017, 8:32 pm)Josh wrote http://www.hanoverdisplays.com/images/ca...bustfl.pdf
No, completely different.
That one is more similar to the ones in the OmniDekkas.
