Cameras | North East Buses
RE: Cameras
(02 Feb 2018, 7:47 pm)EL1TE wrote Anyone got any recommendations for cameras that do really well in low light? Tried some with my B500 tonight but most were just a complete failure.
I have a Nikon D5200 which I think performs quite well in low light.
Jamie M
RE: Cameras
My opinion:
Panasonic G80 with a prime. A few years ago, without a doubt I would be saying the likes of the Nikon D5200 - but the G80 features image stabilization and a tonne of other features that balance out the odds. I found with DSRLS (Nikon and Canon below 1,000£) that I was being forced to use the eye-piece view finder where-as a Panasonic will allow you to use the touchpad display as the view finder. You can see what the shot is going to look like before you even take it. Nikons and Canons at a (lower) consumer level won't have image stabilization, where as the panasonics almost exclusively do. This makes a difference in the freezing winter night on northumberland street.... The Nikon weighs 0.8kg with no technology to counter-act tiny movements you naturally make, the panasonics do.
My advice:
I wouldn't just base your requirements on abstract things like "well in low light". It's far better to find a piece of technology that is practical for you. You can listen to people give you their opinions, but it's about what you feel comfortable with. Pop into jessops and play around with a few. Talk to the people and get an understanding for what you want. Nobody in the world will be able to tell you which is the best camera for your situation, so it's kind of a gamble - but an educated one at that. If you find something you like but don't think you have the money - wait until you do. It's an investment and it's worth taking the time to find something you want and won't get sick off a few days after.
Jamie M
RE: Cameras
Got meself a Nikon D5200, I don't like using it at daytime though, probably ome for night time.. not exactly low profile with a 18-105mm lens on. Partly why I still love my panasonic so much Big Grin
The menu on these nikons aren't very intuitive either, I need more time to adjust like!
Cameras
Still using the Nikon D5100.
This is no doubt not an issue with the camera and more likely a case of me being a complete dummy when it comes to cameras and not knowing settings or anything that work best when photographing in this hobby but... I just can't seem to achieve the quality of photos that I probably should be.
The biggest struggle is when I have to manually select what mode, shutter speeds etc the camera should be in, often the images are not coming out totally clear (usually blurry, not in focus or looking slightly distorted) another issue I always have is the photos either turning out far to bright or dark, recently had to take a photo of a Stagecoach Yorkshire StreetLite in Sheffield and I ended up taking something like 50 shots of the same bus and only managed 4 photos were the lighting was correct and the quality was right.
Anyone know where I am going wrong?
I am maybe looking into possibilities of upgrading but considering how expensive cameras are, I'm unsure if it is worth it, especially if I end up making the same mistakes that I seem to be making currently.
RE: Cameras
So recently I’ve got my hands on a Nikon D3300 and this morning I tested it for a few low light shots.
My two photos of GNE’s 8343 in low light - I’d appreciate any feedback for improving!
Photo 1 - https://www.flickr.com/photos/140920997@...ateposted/
Photo 2 - https://www.flickr.com/photos/140920997@...ateposted/
RE: Cameras
(07 Jun 2018, 7:59 pm)Jimmi wrote Still using the Nikon D5100.
Just seen this, and I think you're right in suggesting that it is you rather than the camera!  Tongue
Difficult to know why it is doing what you're suggesting, without seeing exactly what you're doing; but I remember telling you previously, that when you use the live preview mode (i.e. having the viewfinder open and active when shooting), you'll end up getting shutter lag. Live preview obviously requires the shutter to be open to show you the preview, but because it is, it then has to close, then reset the sensor back to 0, before reopening with your settings for your shot(s). Hence the lag.
Now with the view-finder closed, and if you don't really understand the manual settings, you're best sticking to either sports mode or shutter priority (S) mode. The latter is a semi-automatic mode, so you'll be responsible for setting both the ISO and shutter speed. A good chart for your ISO is below -
On top of this, you'll need to set your shutter speed. This is easy enough to have a play around with, but in perfect conditions, you'll probably get away with using at an absolute maximum for moving buses.
Obviously all this depends on you using the eyelet rather than the view-finder.
(08 Dec 2018, 11:55 am)EL1TE wrote So recently I’ve got my hands on a Nikon D3300 and this morning I tested it for a few low light shots.
Not bad. Was the bus moving or static? If static, you could have probably dropped your shutter speed a bit more and still took the shot handheld, which gives you a bit more light into your shot.
I've never taken any night shots for a while now (I really should start!), but I always found well lit places to work really well. You still got the feeling of the night shot, but the extra light helps.
RE: Cameras
(08 Dec 2018, 12:41 pm)Adrian wrote Just seen this, and I think you're right in suggesting that it is you rather than the camera!  Tongue
Only saw this now, sorry for the late reply! The Streetlite was moving at the time of the photo, yes. I’m still yet to go out and attempt more low light shots, thanks for the tip about getting more light in, I’ll try to when I eventually get round to it!
Cameras
[Image: 60133efe6e22e8d59c41129a6397582b.jpg]
[Image: 0beb007751288c297766197b2b062bfd.jpg]
Got a new lens yesterday for my DSLR, the 75-300mm one, quite impressed with it from my trip to Carlisle today. Made a bit of an error though as forgot to charge it yesterday so couldn’t use it much
Sent from my iPhone XS using Tapatalk
RE: Cameras
(26 Jan 2019, 4:22 pm)TEN 6083 wrote [Image: 60133efe6e22e8d59c41129a6397582b.jpg]
You weren't the only one in Carlisle today, I was their as well and seen Dan in passing.
