RE: Go North East: Upcoming Service Changes v2
					Will the 686 (Hexham to Prudhoe) replace the 687 (Corbridge to Hexham)? - which currently runs off the 686.
(06 Jun 2017, 7:31 pm)Michael wrote Wonder if more solo's will need to repainted............
(06 Jun 2017, 6:30 pm)BusLoverMum wrote Looks like they're splitting up the 82, so it no longer does the whole Heworth - Galleries - Birtley run.
(06 Jun 2017, 10:19 pm)Malarkey wrote And one local resident of this route has just submitted a complaint to them regarding this, zero need to split a service in order to fix an issue with reliability around the Birtley area when in reality the issue will remain regardless of whether it's split or not, reverting back to the clockwise/anti-clockwise loop previously used would fix this issue in my personal opinion.
Also for arguments sake if I was wanting to travel from Lambton to Barmston instead of using 1 bus, with these changes it would take 2 buses and would take longer to complete what is a currently a 15 Minute journey, these changes do nothing but cause an inconvenience to the passengers who use this service.
No doubt Go North East will use this a Marketing Ploy also in order to con those who only pay single fares from point to point into purchasing a Day Ticket to line there pockets with a higher profit margin, despite knowing the local services of Washington are in decline, and have been years.
(07 Jun 2017, 5:29 am)LeeCalder wrote Well said, exactly what I was thinking. The way it is at the moment is as reliable as it has been since the W2 days, when it was spot on! Why change it?
(07 Jun 2017, 7:55 am)Andreos1 wrote I got on a Birtley bound bus at the Galleries recently and it arrived a little late. The SR didn't rush and it had a decent load.
By the time it got to Ayton, we were early.
The bus laid over for a few moments and set off on time again. We got to Birtley early.
It seemed almost as though the timetable wasn't suitable to keep to or maintain the timetable. In the past, the Cadet's struggled to make time up like that.
I alluded to the PVR dropping in my reply to Michael. I wonder if the withdrawal of the MPD's is just a coincidence and has nothing to do with these changes?
(14 Jun 2017, 1:08 pm)Tom wrote More info on the Hexham changes http://www.northumberland.gov.uk/Northum...-06-09.pdf
(15 Jun 2017, 3:04 pm)Michael wrote Finally had a chance to read through the changes, looks like they're set up to replace the MPD's, it looks like a lot of services are merged in to one, which should work well BUT i'm not sure if the changes are positive or not, not from the area.
It looks like:
680 - Hexham - Acomb – Bellingham
683 - Hexham BS-Collingwood Dr-White Cross-RS
684 - Hexham BS-QEHS
686 - Hexham - Corbridge - Ovington – Wylam – Prudhoe
688 - Hexham – Allendale – Allenheads
689 - Hexham-Consett
X84, X85 - Newbrough - Hexham - Newcastle
No idea on frequencies. can't work them out from that PDF.
(15 Jun 2017, 3:26 pm)JP6004 wrote Least its better connections for those in Newbrough and if the rumours about the 6 SIDI mercs are correct about going on to this route; it be hell of an upgrade.
When I lived in Burnopfield a few years back, I thought that merging the X88 & X43 would be good idea and have one express service straight through.........obviously not really feasible now
(15 Jun 2017, 3:34 pm)Michael wrote Ye, it seems they're changing them for better connections, i think the whole area needed a rework.
Not sure on the them getting new buses, they've just got new ones, then again, having the SIDI merc's on the route might workout for the future. The Solo's could replace the remaining MPD's and start to replace the older Solo's but i doubt they'll even get new buses.
				(15 Jun 2017, 3:04 pm)Michael wrote Finally had a chance to read through the changes, looks like they're set up to replace the MPD's, it looks like a lot of services are merged in to one, which should work well BUT i'm not sure if the changes are positive or not, not from the area.This confirms the death of the 687 (Corbridge to Hexham), which originally replaced the Hexham to Horsley(?) (the 684?) which ran from Hexham through Anick (Beaufront) and Corbridge to Newcastle.
It looks like:
(15 Jun 2017, 7:51 pm)LeeCalder wrote No, Hexham have gained the 689 alongside some miscellaneous workings.
(15 Jun 2017, 8:02 pm)G-CPTN wrote The 689 is currently operated by 'Venture' with two 'mature' drivers alternating.
When it arrives in Hexham (weekdays) it runs the 687 to Corbridge and back before returning to Consett.
The two drivers expressed their unwillingness to 'change' (I believe both are beyond retirement age).
I would have thought that a 689 service would need to operate from Consett rather than from Hexham (more people wanting to visit Hexham from Consett than Consett from Hexham).
(15 Jun 2017, 8:06 pm)Michael wrote Wonder if the Versa's from Deptford will move to a depot with Solo's so the Solo's can move to Hexham if the PVR goes up.
So far, 8306 is the only Versa which has been repainted at Deptford, which is now "Go North East".
(15 Jun 2017, 8:37 pm)Tom wrote I think the minibus PVR will be the same - if the 689 transfers over then I would think a Venture would just transfer over.
683/684 seems to be replacing the 682 and the X84 or X85 replacing the 683 to Newbrough so could have a PVR of one instead of the current two so maybe it will go down, and a Tynedale Links Solo or MPD could operate the 689.
(16 Jun 2017, 1:22 pm)nk55 wrote I think the versas will transfer to riverside to replace the remaining B10s and 2 scanias, probably see action on the 67/69. 6 mercs from deptford to Hexham for X84/X85 with the scanias transferring to Chester for the 28/28A, 4956-60 to spare roles or even withdrawn.
(16 Jun 2017, 1:32 pm)cbma06 wrote I would of expected some more versas to Chester for service 28/28A and the rest to Riverside, with citarios from deptford for x84/x85 and those scanias to deptford for service 61 while the black cats scanias from the 39 go onto the 9.
