Deprecated: preg_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /home/northeas/public_html/inc/functions.php on line 5739
Go North East: Service Suggestions v2 | North East Buses
Service Suggestion:
X1: Reduced to Every 20 minutes Mon to Sat daytimes and hourly evenings and Sundays.
X2: New service with the same frequency as the X1, both will combine to provide the same frequency atm between Hetton and Newcastle. Service X2 will go to Low Moorsley instead of Easington Lane replacing service 35.
X5: Revised to serve Hetton Downs replacing services 35/35A.
35 and 35A: Revised to terminate at Houghton.
10C Newcastle-Metrocentre-Blaydon-Ryton-Crawcrook-Greenside-High Spen-Rowlands Gill-Burnopfield-Tantobie-Tanfield Lea-Stanley
31 Stanley-Burnhope-Langley Park-Cornsay Colliery-Waterhouses-Crook
(10 Jun 2018, 12:44 pm)JM03 wrote 10C Newcastle-Metrocentre-Blaydon-Ryton-Crawcrook-Greenside-High Spen-Rowlands Gill-Burnopfield-Tantobie-Tanfield Lea-Stanley
Nobody would use either, only would exist as a secured service but I can't see the demand for either.
Sent from my SM-G930F using Tapatalk
X8: Consett - Stanley - Beamish Museum - A693 - Chester Le Street - Lambton - Washington - Biddick Woods - Shiney Row - Penshaw - Royal Hospital - Sunderland.
New Express service combined off the 8 and 78. It will run nonstop from Consett to Stanley before heading to Chester via Beamish and A693 missing out Pelton.
The 8 and 78 will be reduced to hourly Mon to Sat daytimes. This service will only run Mon to Sat on a hourly basis.
Between Sunderland and Shiney Row service 78 and X8 will combine to provide a every 30 minute bus service.
Between Sunderland and Washington, Chester, Beamish and Stanley service X8 and 8 will combine to provide a every 30 minute service.
On the subject of the Coast&Country, I have a suggestion for the Sunday 78/78A. It's rather simple (to me anyway!):
Decide which route should serve Consett, instead of having buses run as a 78A there and a 78 back, meaning that in the event that passengers from High Handenhold/Beamish etc do want to go beyond Stanley (whether that be all the way to Consett or not) can't get a direct bus back until the evening when the 78A begins to operate both ways.
(10 Jun 2018, 8:09 pm)S813 FVK wrote On the subject of the Coast&Country, I have a suggestion for the Sunday 78/78A. It's rather simple (to me anyway!):
This doesn't make sense because the route in to sunderland arrives inline with when the opposite one is due out. Only way to fix is add 30 mins in somewhere and therefore another bus.
(12 Jun 2018, 8:09 am)Jamie M wrote This doesn't make sense because the route in to sunderland arrives inline with when the opposite one is due out. Only way to fix is add 30 mins in somewhere and therefore another bus.
It makes perfect sense - it just isn't going to be the most practical thing in the world to do, as nice as it would be.
I was thinking, contrary to my idea in the past of splitting most of the 309/310 workings, could the route through Cobalt on the 309 not be changed slightly? What I'm thinking is that only during the times listed below, the 309 could omit Quicksilver Way and Silverfox Way (the road with the guided bus lane) between the Village Hotel and Cobalt Park Way and instead just call at the stops on The Silverlink North. This would save around 2 mins in each direction with the time either being added to other parts of the route or extra layover time in Blyth.
Times:
- Mon to Fri 0930-1500
- Sat 0900-1700
- Sun 0900-1700
301: Metrocentre - Gateshead - Newcastle - Byker - Wallsend - North Shields - Tynemouth - Whitley Bay - Seaton Sluice - Blyth.
Service 1 withdrawn and replaced by new service 301 to the Coast. Service 301 will operate from Metrocentre to Blyth operating direct to Gateshead then onto Coaster 1 route then extended to Blyth replacing service 309. This service will operate Every 15 minutes between Gateshead and Whitley Bay Monday to Saturday daytimes and a Every 30 minute frequency across the whole route Evening and Sundays.
309/310: Revised to operate every 20 minutes each with a combined frequency on Coast Road of up to Every 10 minutes.
311: Whitley Bay - North Tyneside Hospital - North Shields - Howdon - Wallsend - Coast Road - Newcastle. This new service will replace service 11 between Whitley Bay and Wallsend, then operate via Coast Road to reach Newcastle instead of via Byker.
*New* 48: This service will replace services 49A, 49C and 64, it will serve the Teams estate and omit Blaydon Bus Station. It will operate up to Every 20 minutes combined with service 49 to provide a bus up to Every 10 minutes. It will also NOT serve Bolam Street Flats.
X66: With the introduction of service 48 and 301 this service will return to a Express service operating up to Every 15 minutes, it will continue to serve Iqea.
*New* M5: Metrocentre - Rowlands Gill - Burnopfield - Stanley.
New Metrocentre Mini service that will combine with the 3 other services to make up 4 buses an hour between Stanley and Metrocentre. This will allow a Every 15 minute service between Stanley and Metrocentre.
95: Wrekenton - Low Fell - Gateshead - Team Valley North - Lobley Hill Gardens - Dunston - Metrocentre.
This service will replace service 1 and 11 on the south side of the Tyne. It will operate 2 journeys an hour, for example at 03 : 23 mins past. Also on Sundays and Evenings the service will serve Springwell Estate replacing service 56.
95A: Kibblesworth - Team Valley Sainsburys - Low Fell - Gateshead - Team Valley North - Lobley Hill (On Sundays service extends to Metrocentre)
New service replacing the current 1A and 95 on a hourly frequency. Service 95 and 95A combined will provide a every 20 minute service between Lobley Hill and Low Fell.
56: No longer serving Springwell Estate.
(15 Jun 2018, 7:24 pm)S830OFT wrote 301: Metrocentre - Gateshead - Newcastle - Byker - Wallsend - North Shields - Tynemouth - Whitley Bay - Seaton Sluice - Blyth.
309/310 at every 20 mins is a plan for disaster
(15 Jun 2018, 10:37 pm)JM03 wrote 309/310 at every 20 mins is a plan for disaster
Not with service 311 along Coast Road aswell, along with service X39 at peak times. There is also service 57 which can take passengers to Newcastle, most passengers tend to get on the first bus that comes on that road.
 Wasnt the 1 originally the 301 along with the 302 which changed into the 1 and 2  in 2007,so why allow it to gain the '30' bit again,also at some point in the past the 301 did serve the metrocentre but was changed, the 49 used to also be the blaydon racers aswell as the 48 never really get why they changed its route number tbh, but it became the 49/A/B/C so if you changed the 49 why dont you have the 49 and 49A do 1 bit and have a 48 and 48A do the other bit you suggested
35: Durham - High Pittington - Low Moorsley - Hetton Le Hole - Hetton Downs - Houghton - Herrington Burn - East Herrington - Silksworth - The Barnes - Royal Hospital - Sunderland Interchange - Fulwell The Grange - Cleadon - Harton Nook - South Shields.
This service is extended from Low Moorsley to Durham, allowing service 265 to serve Rainton. It will no longer operate to Boldon, instead operate to Shields allowing the withdrawal of the 20 services. This service will not run past Low Moorsley for journeys to Durham on Evenings and Sundays.
35A: Durham - Belmont - West Rainton - East Rainton - Hall Lane - Houghton - A690 - East Herrington - The Barnes - Sunderland - Fulwell The Grange - Cleadon - Harton Nook - South Shields.
This is the prime service to Durham, it will operate 7 days a week under a 30 minute frequency. It will pretty much operate directly to the 20 service, apart from serving the Royal Hospital.
X35: Durham - Belmont - Rainton Bridge - Houghton - A690 - East Herrington - The Barnes - Sunderland - Roker - Seaburn - Whitburn - Coastal Route - Gypsys Green and Pier Head - South Shields.
This new express service will not serve Rainton and will operate the same as the current peak X20. However, instead of serving Cleadon and Harton alike services 35/35A it will take the coastal route to Shields operating along the coast.
Service 35/35A/X35 combined will continue the Every 10 minute frequency between Durham and South Shields.
36: Chester Le Street - Great Lumley - Fence Houses - Houghton - Herrington Burn - East Herrington - Silksworth - Tunstall Bank - Esdale Estate - Hollycarside - Leechmere Asda - Ashbrooke - Sunderland - Southwick - Castletown.
This service is revised to operate hourly, it will replace service 38 between Tunstall and Sunderland.
X36: Chester Le Street - Great Lumley - Fence Houses - Rainton Bridge - Houghton - A690 - East Herrington - The Barnes - Sunderland - Enterprise Park - Castletown - Hylton Castle - Town End Farm - Boldon - Heworth.
This new express service will replace the North side section of the current 35 under a hourly frequency.
56B: Sunderland - Southwick - North Hylton Road - Castletown - Hylton Castle - Town End Farm - Downhill - Boldon Cinema - Boldon Asda - Downhill - Red House - Witherwack - Fulwell The Grange - Sunderland.
56C: Opposite direction but will operate clockwise around Boldon, it will serve the Cinema prior to serving Asda.
56B/56C will both operate hourly.
65: Durham - Belmont - West Rainton - East Rainton - Houghton Road - Hetton Le Hole - Murton - Dalton Park - Seaham. Rerouted via Rainton instead of Moorsley.
Frequencys:
35: Mon - Sat (Every 30 minutes) Sun/Evenings* (Hourly)
35A: Mon - Sat (Every 30 minutes) Sun/Evenings (Every 30 minutes)
X35: Mon - Sat (Every 30 minutes) Sun/Evenings (No Service)
36: Mon - Sat (Hourly) Sun/Evenings (Hourly)
X36: Mon - Sat (Hourly) Sun/Evenings (No Service)
56B/C: Mon - Sat (Hourly) Sun/Evenings (Hourly)
65: Mon - Sat (Hourly) Sun/Eve (No Service)
*Journeys to Durham terminate at Low Moorsley, passengers should use service 35A.
Evening and Sunday journeys on 36 group of services:
Service 36/56B/C will operate, however NexusBus 135/136 additionally run.
Services 35A/X35/X36 will operate up the A690, Services 35 and 36 will serve Herrington Burn.
Services 36 and X36 combine to provide a Every 30 minute frequency between Houghton and Chester Le Street.
Low Moorsley will have:
2 buses an hour to Durham. Opposed to the current 1
Rainton will have:
3 buses an hour to Durham opposed to the current 6.
Houghton will have:
6 buses an hour to Durham...
Harton and Cleadon will have:
4 buses an hour to Shields and Sunderland opposed to the current 6.
FrankT1993
(16 Jun 2018, 8:58 am)Michael wrote 64 and 95 to merge, because tbh, they're the most pointless routes Go North East have.
Sorry, I don't agree. For me it's a big difference if I take 64 or 95. I undertand that you don't use those lines on a daily basis, that's why you make this suggestion.
Frank
(18 Jun 2018, 1:01 pm)FrankT1993 wrote Sorry, I don't agree. For me it's a big difference if I take 64 or 95. I undertand that you don't use those lines on a daily basis, that's why you make this suggestion.
Frank
I think this is a problem with a lot of suggestions in these threads. It would make little difference to me if the Gne 59 was scrapped, for example, as I have plenty of other options, including walking to the Arnison centre or centre of Durham, but people in Quarrington Hill would lose their only Sunday service.
X10:
Newcastle - Gateshead - Heworth - Darlton Park - Peterlee - Norton - Stockton - Middlesbrough - (by jetpack) Scarborough
Every 60 minutes mon-sun.
(18 Jun 2018, 5:31 pm)Jamie M wrote X10:
A better option would be to introduce a Coach service.
It would need to go through Lambton thou!  Big Grin
(18 Jun 2018, 5:39 pm)citaro5284 wrote It would need to go through Lambton thou!  Big Grin
That is a very good point, how silly of me to forget!
Newcastle - Gatesuhead - Heworth - Darlton Park - Peterlee - Norton - Stockton - Middlesbrough - (by jetpack) Scarborough
Id have it go to Whitby nstead of Scarborough. Deffo be quicker than train and push Arrivas nose out of joint  Tongue
Newcastle - Gateshead - Stockton - Middlesbrough - Whitby
Newcastle - Gateshead - Stockton - Middlesbrough - Whitby - Scarborough
Newcastle - Gateshead - Stockton - Middlesbrough - Whitby - Scarborough - Filey - Bridlington
Newcastle - Gateshead - Stockton - Middlesbrough - Thirsk - York - Market Weighton - Hull
Newcastle - Middlesbrough - Thirsk - Easingwold - York
Newcastle - Middlesbrough - Thirsk - Ripon - Harrogate - Leeds
Newcastle - Middlesbrough - Leeds - Hull
Sunderland - Peterlee - Middlesbrough - Whitby
Sunderland - Peterlee - Middlesbrough - Whitby - Scarborough
Sunderland - Peterlee - Middlesbrough - Whitby - Scarborough - Filey - Bridlington
Sunderland - Peterlee - Middlesbrough - Thirsk - York - Pocklington - Market Weighton - Hull
Sunderland - Middlesbrough - Thirsk - Easingwold - York
Sunderland - Middlesbrough - Thirsk - Ripon - Harrogate - Leeds
Sunderland - Middlesbrough - Leeds - Hull
I haven't came up with a service number series or frequencies for the above suggestion, I do think it would be we wise for Go North East/EYMS to integrate NatEX services and expand them into these routes to make them more viable, alternatively they could adopt a Day Trip style operation again to make services viable.
(18 Jun 2018, 6:56 pm)Malarkey wrote Newcastle - Gateshead - Stockton - Middlesbrough - Whitby
May i suggest something in the 500's
(18 Jun 2018, 9:38 pm)V514DFT wrote May i suggest something in the 500's
Could maybe route the Newcastle routes through Washington Galleries too, just a thought
I don't think there's much point in duplicating corridors which already have plenty of coach services. Between National Express and Megabus, they've got most of these corridors carved up already.
However, I do think a competitive express service with Arriva between Middlesbrough and Scarborough and/or Leeds and Hull would do well, as there'd be traffic at either end (X9/X10 into Middlesbrough, various EYMS services in Scarbs and Hull.
(19 Jun 2018, 2:55 pm)Dan wrote I don't think there's much point in duplicating corridors which already have plenty of coach services. Between National Express and Megabus, they've got most of these corridors carved up already.
Also reduce the line of passengers for X93 as it is extremely busy in the summer.
I think the Whitby/Scarborough - Teesside corridor is pretty much boxed off now the X4 and X93 appear sorted.
Not sure there is enough demand all year round or enough interest to offer any competition.
My initial thoughts on connecting the two operating areas revolved around connecting the X9/10 with the 45 series and EYMS other service around York (is it 18 to McArthur Glen?).
Operated by Pocklington depot, it would be York - Middlesbrough via A59, Knaresbrough, A1/A168, Thirsk, Northallerton and Stokesley - or A19 to A66 (haven't quite decided).
It would call at all local stops to Knaresbrough, then express/non-stop to Thirsk, limited stop beyond there to Middlesbrough calling at key calling points/timing points only.
Through tickets would be available and whilst there may not be massive numbers on a York - Middlesbrough service, through passengers would supplement local travel. Obviously it would also connect the two operating areas.
(19 Jun 2018, 6:33 pm)Andreos1 wrote I think the Whitby/Scarborough - Teesside corridor is pretty much boxed off now the X4 and X93 appear sorted.
Extending the current 128 service might be an option - extending from its current terminus of Helmsley along the A170 Into Thirsk,then either run direct via A19/Via Northallerton or Via Stokesley into Middlesbrough. Run from Scarborough depot with maybe 1 or 2 buses outstationed at Peterlee to allow earlier journeys from Middlesbrough
(19 Jun 2018, 9:46 pm)callum2015 wrote Extending the current 128 service might be an option - extending from its current terminus of Helmsley along the A170 Into Thirsk,then either run direct via A19/Via Northallerton or Via Stokesley into Middlesbrough. Run from Scarborough depot with maybe 1 or 2 buses outstationed at Peterlee to allow earlier journeys from Middlesbrough
Could North East Coach Travel sell their depot as sister company Stephensons ceased trading.
