RE: Go North East: Major Service Changes July 2022
The small section of the X62 thorough Easington Lane is within Tyne & Wear, the rest of the route is within County Durham.
(14 Jul 2022, 9:50 am)Michael wrote Will the 39/39A/39B stay Solo from the day of the changes?, I take it 680 will be repainted to Graphite, if they stick to solo's?And maybe the passengers! I get the official line is that there may not be that much demand for cross city connections.
And I take it, most of Deptford's Citaro's will be withdrawn?
Is that just to confuse the drivers?![]()
(14 Jul 2022, 12:27 pm)F114TML wrote The X62 enters Tyne & Wear for the briefest of moments, I think it's literally 4 stops, before going back into County Durham.
In any case, the X62 seems to have disappeared from GNE's service change list.
(14 Jul 2022, 12:58 pm)Andreos1 wrote And maybe the passengers! I get the official line is that there may not be that much demand for cross city connections.If there's no demand for cross city connections to the point cross city services are being cut, then Stagecoach are screwed.
If there's not, what is being done to encourage it?
If there's not, why continue with having a cross city route?
If there is, I can't see this solution doing much to maintain that demand.
(14 Jul 2022, 12:18 pm)cbma06 wrote 725 and 208 operates solely in County Durham so doesn’t enter Tyne and Wear so won’t be listed on Nexus.
X62 operates in County Durham and Tyne and Wear , so will be on Nexus list
(14 Jul 2022, 1:52 pm)Economic505 wrote SNE’s cross city services have worked for years. Perhaps they have sensible route planners.
(14 Jul 2022, 2:47 pm)F114TML wrote Why?The amount of people who board in Sunderland and aren't sure of the difference between the routes of the 2 & 2A which one goes to Lambton and which one goes to Biddick ,a bit less confusing than just showing via Sunderland which is the place they have boarded the service
(14 Jul 2022, 3:04 pm)Dan wrote Yes, Stanley Travel no longer wish to run the Sunday X15 and JH Coaches no longer wish to run the X62, and Go North East were the next cheapest bidders.
(14 Jul 2022, 3:14 pm)streetdeckfan wrote Do they get penalised for withdrawing after they were awarded the tender?
(14 Jul 2022, 3:14 pm)ASX_Terranova wrote On the services no longer operated by GNE (82/82A, 725, etc...) will those passengers see a huge fare increase?
Also whats happening to the 30 & 31?
(14 Jul 2022, 3:23 pm)OrangeArrow49 wrote I don't think fares will be expensive on the 30/31, 82/82A, 725 etc, but I think fares will increase for passengers connecting with other services for onward travel, for example Weardale 725/GNE 25 for Langley Park to Gateshead/Newcastle...
JH Coaches has the 30/31 if they don't hand back their winning tender like with the X62.
(14 Jul 2022, 3:17 pm)OrangeArrow49 wrote Strange that operators bid and then don't want to run the services when they win!
JH Coaches only have the 30/31 and 82/82A? Be interesting to see what buses they use.
Stanley Travel are not operating any new services?
What scholars buses are Go North East, Arriva, Weardale and JH Coaches operating from September?
(14 Jul 2022, 3:22 pm)gc802002 wrote No , If they return them during the cooling off period there will be no penalty. Although this was a rushed tender process, there will still be a standstill period
I am guessing with the Sunday run, Stanley Travel were maybe hoping to get the 30/31 , Together with existing work might have created the resouce to take on the Sunday work? Perhaps?
JH Maybe taken on too much with the 30/31 and 82/82A and thus didn't want the X62?
All conjecture and i guess we may never know.
I wonder if Arriva/Stagecoach tendered for anything? Or A-Line for that matter.
(08 Jul 2022, 8:23 pm)DeltaMan wrote Could the way NEXUS display the routes at bus stops be causing part of the issue?Your right in Norton and Stockton the 36 37 38 going towards Middlesbrough are all on one timetable together so why nexus won’t do the same is baffling.
Why isn't the 28, 56, 57 shown as a combined timetable along Old Durham Road to Gateshead and Newcastle? Same with the 21 and 25 in Low Fell.
If I see a big wall of numbers for the 21, I ain't going to bother looking at the 25!
I look at other areas where operators have clearly taken time to show combined common section information and wonder why NEXUS can't or won't do that.
Garbage in, garbage out
(14 Jul 2022, 3:52 pm)col87 wrote Your right in Norton and Stockton the 36 37 38 going towards Middlesbrough are all on one timetable together so why nexus won’t do the same is baffling.
(14 Jul 2022, 4:01 pm)OrangeArrow49 wrote Is there a picture of how this layout works?Well with the 36 37 38 it’s exactly the same route between Norton Red Lion and Middlesbrough Bus Station. How the timetable works is it has the main via points with how long it will take to reach it. Then underneath is the boxes with the times the bus is due at that stop so in this combined it would be about every 6 minutes or so during the day and every 15 on evening and Sundays.
Nexus should definitely put everything together which follows the same or similar route for the same destination, irrespective of the operator. Likewise Durham should do the same. However I'm confused how this works for displaying the different via points as some routes may reach the same or similar destination via a slightly or completely different route. Fare information should also be displayed at busy stops to encourage passengers to use better value services for them and perhaps spread passengers more evenly across services. To give an example, the 808 through Fenham could get a share of passengers from the 63 which it follows and could offer better value to passengers in some circumstances.
(14 Jul 2022, 4:31 pm)F114TML wrote Wonder if it's more likely they were bidding to cover all bases and won more services than they can actually run.
(14 Jul 2022, 5:03 pm)OrangeArrow49 wrote Stanley Travel only won the X15. But perhaps they wanted the 30/31 and X15, and don't want the X15 without the 30/31.This is actually good thinking cos presumably they would need to purchase a single decker for this, and it would complment having 2 drivers to cover both service like 4 on, 3 off over a 2 week rota
JH Coaches maybe won more than expected, I hope they run the services well.
Surprised if Arriva didn't go for any Gateshead routes, to compliment the X12.
No idea whether or not A-Line or Phoenix bid for anything but A-Line have got a couple of school contracts.
For the 941, I'm not sure which trip Go North East have won, I thought it was the GCT one but it seems to be the Weardale one and Weardale are doing the GCT one.
(14 Jul 2022, 3:25 pm)ASX_Terranova wrote According to bustimes they only have 3 single deckers in the fleet (1 Streetlite WF & 2 E400's). Unless they want to allocate presidents or trident they may need to invest in newer vehicles.JH also have MX60BXD, a former Peter Hogg Streetlite WF that hasn't entered service yet.
