RE: Tyne and Wear Metro
(05 Jun 2025, 9:55 pm)DaveFromUpNorth wrote heworth is needed as a transport hub as oppose to Pelaw imo
it means buses can connect much easier than from pelaw
Nobody is suggesting that Pelaw will become a transport hub. It's just where the junctions are.
Heworth will still remain the nearest transport hub.
Not sure about what this discussion is about . All I ll say is that Metro trains from Sunderland via South Hylton and Washington will leave the Leamside line and enter Pelaw, then en route to Newcastle and beyond. Heworth will remain as a bud interchange.
(05 Jun 2025, 10:14 pm)Economic505 wrote Not sure about what this discussion is about . All I ll say is that Metro trains from Sunderland via South Hylton and Washington will leave the Leamside line and enter Pelaw, then en route to Newcastle and beyond. Heworth will remain as a bud interchange.
This bit, the plan is 3 TPH to Monkseaton and 3 TPH to Heworth in documents that have been released about the line in the past. Lost the document though and after the changes with the NECA sites it's hard to find older stuff now.
Edit: It's this one which is where the study is in: https://www.northeast-ca.gov.uk/download...5nov22.pdf (Page 182)
(05 Jun 2025, 10:20 pm)Storx wrote This bit, the plan is 3 TPH to Monkseaton and 3 TPH to Heworth in documents that have been released about the line in the past. Lost the document though and after the changes with the NECA sites it's hard to find older stuff now.
I think you may be reading it too literally. To me, they're suggesting that one train would start from Monkseaton, run round the loop via Washington, Sunderland and all the way back round on to the Airport. The train starting at the Airport would do the opposite, round the loop via Sunderland, Washington and then on to Monkseaton. It's marked in red because that bit doesn't exist; it presently goes back and forth between South Hylton and the Airport.
Even if you looked at it rationally, it'd make no sense to have a train that has travelled through Washington to terminate at South Hylton, then the trains from Sunderland to also terminate at South Hylton. Why would it be called the Washington Metro Loop in all official papers, if it's not a loop? It'd be a pointless level crossing (which NR hate and try to avoid), if it was never going to be used. You'd just build another platform at the other side of the road.
Plus, if the intention was to terminate everything at South Hylton, they'd use the existing curve alignment and terminate at Penshaw instead. It'd be a huge saving, as they they wouldn't need to build a new curve alignment and a couple of mile of track with no station - it may even become the longest section without a station on the system?
Maybe 2 different line colours to avoid the confusion, but we'll only know closer to completion
So
Yellow- St James to South Shields
Green- Airport to South Hylton
Red- Monkseaton to Airport via Washington (clockwise)
Blue- Airport to Monkseaton via Washington (anti-clockwise)
(06 Jun 2025, 5:13 pm)Adrian wrote I think you may be reading it too literally. To me, they're suggesting that one train would start from Monkseaton, run round the loop via Washington, Sunderland and all the way back round on to the Airport. The train starting at the Airport would do the opposite, round the loop via Sunderland, Washington and then on to Monkseaton. It's marked in red because that bit doesn't exist; it presently goes back and forth between South Hylton and the Airport.
Aye no arguments about South Hylton.
But I personally read it as
3TPH | Airport - Sunderland - Heworth (Terminate)
3TPH | Airport - Sunderland - Heworth - Monkseaton
Why it's like that I don't know but the line from Monkseaton to Heworth on the red line is definitely only 3 TPH (narrow line), well and is says it on the side.
(06 Jun 2025, 5:59 pm)Storx wrote Aye no arguments about South Hylton.
Peaks maybe? That doc will have been written before they temporarily removed them from the timetable, but the ambition is still to bring them back. It needs them, especially on a morning.
(06 Jun 2025, 6:22 pm)Adrian wrote Peaks maybe? That doc will have been written before they temporarily removed them from the timetable, but the ambition is still to bring them back. It needs them, especially on a morning.
God knows to be honest, don't think any of us can really say unless we were part of the study - which I don't think any of us were.
Wonder if they might only have 3 trains running beyond beyond Heworth during the day, with them extended at peaks only giving the full 12 TPH between Monkseaton and Pelaw. Probably more than enough trains having only 3 TPH from Newcastle through the Washington stations during the day really, and would save a few drivers.
Thought i'd provide a list of old units and a list of new units
CLASS 599/994
4001- Stored
4002- Scrapped
4003- Scrapped
4004- Stored
4005- Stored
4006- Active
4007- Scrapped
4008- Active
4009- Active
4010- Scrapped
4011- Active
4012- Stored
4013- Scrapped
4014- Stored
4015- Active
4016- Scrapped
4017- Active
4018- Scrapped
4019- Stored
4020- Active
4021- Scrapped
4022- Scrapped
4023- Active
4024- Active
4025- Scrapped
4026- Active
4027- Active
4028- Active
4029- Active
4030- Active
4031- Scrapped
4032- Active
4033- Scrapped
4034- Active
4035- Active
4036- Scrapped
4037- Scrapped
4038- Active
4039- Active
4040- Scrapped
4041- Stored
4042- Active
4043- Active
4044- Active
4045- Active
4046- Active
4047- Active
4048- Stored
4049- Active
4050- Active
4051- Active
4052- Scrapped
4053- Active
4054- Scrapped
4055- Scrapped
4056- Active
4057- Scrapped
4058- Stored
4059- Active
4060- Active
4061- Active
4062- Scrapped
4063- Stored
4064- Scrapped
4065- Active
4066- Active
4067- Active
4068- Active
4069- Active
4070- Scrapped
4071- Active
4072- Scrapped
4073- Active
4074- Active
4075- Active
4076- Scrapped
4077- Scrapped
4078- Active
4079- Active
4080- Active
4081- Active
4082- Scrapped
4083- Scrapped
4084- Scrapped
4085- Active
4086- Active
4087- Active
4088- Scrapped
4089- Active
4090- Active
Key
Green= Active
Blue= Stored
Red= Scrapped
Peach= Stored and missing parts
CLASS 555's
555001- Delivered (undergoing testing)
555002- In Service
555003- In Service
555004- In Service
555005- In Service
555006- In Service
555007- In Service
555008- In Service
555009- In Service
555010- Delivered
555011- In Service
555012- Delivered (undergoing testing)
555013- Delivered (undergoing testing)
555014- Delivered (undergoing testing)
555015- In Service
555016- Delivered (undergoing testing)
555017- Delivered
555018- Delivered
555019- Delivered
555020- In Service
555021- In Service
555022- Pending
555023- Pending
555024- Pending
555025- Pending
555026- Pending
555027- In Service
555028- In Service
555029- Pending
555030- Pending
555031- Delivered (undergoing testing)
555032- Delivered
555033- Pending
555034- Pending
555035- Delivered (undergoing testing)
555036- Pending
555037- Pending
555038- Delivered
555039- Delivered
555040- Pending
555041- Pending
555042- Pending
555043- Not Built
555044- Not Built
555045- Not Built
555046- Not Built
Key
Purple= In service
Yellow= Delivered (undergoing testing)
Orange= Delivered
Pink= Pending
Teal= Not Built
List Updated: 14/08/2025
If you see any mistakes, or have any updates, please dont hesitate to private message me or quote me directly, and will happily update the list for you
Cheers
(10 Jun 2025, 1:56 pm)V514DFT wrote Thought i'd provide a list of old units and a list of new units
CLASS 599/994
4001- Saved (left for preservation 10/09/2025)
4002- Scrapped
4003- Scrapped
4004- Active
4005- Active
4006- Active
4007- Scrapped
4008- Active
4009- Active
4010- Scrapped
4011- Active
4012- Scrapped
4013- Scrapped
4014- Active
4015- Active
4016- Scrapped
4017- Active
4018- Scrapped
4019- Stored
4020- Active
4021- Scrapped
4022- Scrapped
4023- Active
4024- Active
4025- Scrapped
4026- Active
4027- Active
4028- Active
4029- Active
4030- Active
4031- Scrapped
4032- Active
4033- Scrapped
4034- Scrapped
4035- Active
4036- Scrapped
4037- Scrapped
4038- Active
4039- Active
4040- Scrapped
4041- Active
4042- Active
4043- Active
4044- Active
4045- Stored
4046- Active
4047- Active
4048- Scrapped
4049- Active
4050- Active
4051- Active
4052- Scrapped
4053- Active
4054- Scrapped
4055- Scrapped
4056- Active
4057- Scrapped
4058- Stored
4059- Active
4060- Active
4061- Active
4062- Scrapped
4063- Scrapped
4064- Scrapped
4065- Active
4066- Active
4067- Active
4068- Active
4069- Active
4070- Scrapped
4071- Active
4072- Scrapped
4073- Active
4074- Active
4075- Active
4076- Scrapped
4077- Scrapped
4078- Active
4079- Active
4080- Active
4081- Active
4082- Scrapped
4083- Scrapped
4084- Scrapped
4085- Active
4086- Active
4087- Active
4088- Scrapped
4089- Active
4090- Active
Key
Green= Active
Blue= Stored
Red= Scrapped
Light Blue= Saved
Number Active= 53
Number Scrapped= 33
Number Stored= 3
Number Saved= 2
CLASS 555's
555002- In Service
555003- In Service
555004- In Service
555005- In Service
555006- In Service
555007- In Service
555008- In Service
555009- In Service
555010- Delivered
555011- In Service
555012- In Service
555014- In Service
555015- In Service
555016- In Service
555017- Delivered
555018- Delivered
555019- Delivered
555020- In Service
555021- In Service
555022- Pending
555023- Pending
555024- Pending
555025- Pending
555026- Pending
555027- In Service
555028- In Service
555029- Pending
555030- Pending
555032- Delivered
555033- Pending
555034- Pending
555035- In Service
555036- Delivered
555037- Pending
555038- Delivered
555039- Delivered
555040- Delivered
555041- Delivered
555042- Pending
555043- Not Built
555044- Not Built
555045- Not Built
555046- Not Built
Key
Purple= In service
Orange= Delivered
Pink= Pending
Teal= Not Built
Number Operational: 18
Number in Testing: 3
Number to be Delivered: 11
Number to be Built: 4
Number awaiting Testing: 10
List Updated: 10/09/2025
Cheers
(09 Aug 2025, 7:56 pm)Michael wrote Cheers for the update!
Hopefully more units will enter soon, I feel like its taking ages to get them in service.
I’m hoping to get a few more front seat rides on the Classic stock before they’re all gone (and videos made)
(09 Aug 2025, 10:05 pm)NorthEastern wrote I’m hoping to get a few more front seat rides on the Classic stock before they’re all gone (and videos made)
It is likely you will get your wish, the 555s as cheap, and not necessarily cheerful (never was the original fleet when new TBH).
(09 Aug 2025, 11:57 pm)solsburian wrote It is likely you will get your wish, the 555s as cheap, and not necessarily cheerful (never was the original fleet when new TBH).
I’ve posted a few on my Flickr already
(22 Aug 2025, 12:53 pm)NorthEastern wrote So sad to see them getting snipped up
It is especially if you've grew up with them all your life (like me), i've saw them in Yellow/White (with the M at the front ends), Red/Blue/or Green with the triangles on the doors, then the above but with solid Yellow doors, then in the current colours, aswell as the various Advert liveries over the years
(23 Aug 2025, 4:23 pm)V514DFT wrote It is especially if you've grew up with them all your life (like me), i've saw them in Yellow/White (with the M at the front ends), Red/Blue/or Green with the triangles on the doors, then the above but with solid Yellow doors, then in the current colours, aswell as the various Advert liveries over the years
It may be anecdotical but compared to other trains scrapped by the same method, it was quite something to see how easily the bodywork and underframe of 4033 were torn apart with relative ease. It goes to show how lightweight the units are and thankfully never had a collision with a heavier train.
(02 Sep 2025, 6:18 pm)solsburian wrote It may be anecdotical but compared to other trains scrapped by the same method, it was quite something to see how easily the bodywork and underframe of 4033 were torn apart with relative ease. It goes to show how lightweight the units are and thankfully never had a collision with a heavier train.
This is very true, but have to appreciate it was a different when the Metrocars were built, different requirements ect
BIG NEWS!!!
4001 has headed off to preservation today, marking an end to an amazing 50 year career (although retired from the metro network for a length of time) News with a happy outcome
(10 hours ago)DeltaMan wrote I'm not being funny but the Great North Run is the one big day in the year NEXUS has, and the new Trains were not procured to cope with that.
What a joke of an organisation
BBC News - New Metro trains adapted over Great North Run weight fears - BBC News
https://www.bbc.co.uk/news/articles/cvgqe82qd71o
This is reportedly an issue with the 777s also, so not really a Nexus issue is it.
Nexus and Stadler seem to have been pretty proactive here, and evidently this worked as a temporary solution. The fact that they've been used on match days etc. without the plate and without issue suggests that this is only a potential issue in the most extreme of situations.
They're damned if they do and damned if they don't with some folk...
